[Swift-commit] r6860 - in SwiftTutorials/CIC_2013-08-09: . OLD
wilde at ci.uchicago.edu
Thu Aug 15 11:16:53 CDT 2013
Author: wilde
Date: 2013-08-15 11:16:52 -0500 (Thu, 15 Aug 2013)
New Revision: 6860
Added:
SwiftTutorials/CIC_2013-08-09/OLD/
SwiftTutorials/CIC_2013-08-09/OLD/addlocal.sh
SwiftTutorials/CIC_2013-08-09/OLD/catsn.swift
SwiftTutorials/CIC_2013-08-09/OLD/setup.bak.sh
Log:
for cic
Added: SwiftTutorials/CIC_2013-08-09/OLD/addlocal.sh
--- SwiftTutorials/CIC_2013-08-09/OLD/addlocal.sh (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/OLD/addlocal.sh 2013-08-15 16:16:52 UTC (rev 6860)
@@ -0,0 +1,9 @@
+#! /bin/sh
+grep -v config sites.xml | (
+ echo "<config>"
+ cat
+ cat local.pool
+ echo "<config/>"
Property changes on: SwiftTutorials/CIC_2013-08-09/OLD/addlocal.sh
___________________________________________________________________
Added: svn:executable
Copied: SwiftTutorials/CIC_2013-08-09/OLD/catsn.swift (from rev 6845, SwiftTutorials/CIC_2013-08-09/cloud/catsn.swift)
--- SwiftTutorials/CIC_2013-08-09/OLD/catsn.swift (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/OLD/catsn.swift 2013-08-15 16:16:52 UTC (rev 6860)
@@ -0,0 +1,26 @@
+type file;
+// app declaration
+app (file o) cat (file i){
+ cat @i stdout=@o;
+// input data
+file data<"data.txt">;
+* output data mapped to files with
+* prefix f and suffix .out in the outdir
+* directory
+file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
+* @arg means n could be specified as commandline argument
+* foreach loop executes 1 to n calls of cat in parallel
+foreach j in [1:@toInt(@arg("n","1"))] {
+ out[j] = cat(data);
Copied: SwiftTutorials/CIC_2013-08-09/OLD/setup.bak.sh (from rev 6845, SwiftTutorials/CIC_2013-08-09/setup.bak.sh)
--- SwiftTutorials/CIC_2013-08-09/OLD/setup.bak.sh (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/OLD/setup.bak.sh 2013-08-15 16:16:52 UTC (rev 6860)
@@ -0,0 +1,51 @@
+export SWIFT_HEAP_MAX=4G
+if which swift >& /dev/null; then
+else
+ echo "Trying to load swift module:"
+ module load swift
+ if which swift >& /dev/null; then
+ Swift loaded from module
+ else
+ echo "Cant find a swift to run"
+ return
+ fi
+fi
+echo -e "\\nUsing swift release from: \\c"
+which swift
+swift -version
+DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+echo Adding $DIR to PATH:
+PATH=$DIR:$PATH
+if [ -e $HOME/.swift ]; then
+ savedotswift=$(mktemp -d $HOME/.swift.save.XXXX)
+ echo Saving $HOME/.swift in $savedotswift
+ mv $HOME/.swift/* $savedotswift
+else
+ mkdir -p $HOME/.swift
+fi
+cat >>$HOME/.swift/swift.properties <<END
+# Properties for Swift Tutorial
+sites.file=sites.xml
+tc.file=apps
+wrapperlog.always.transfer=true
+sitedir.keep=true
+file.gc.enabled=false
+status.mode=provider
+execution.retries=0
+lazy.errors=false
+use.wrapper.staging=false
+use.provider.staging=true
+provider.staging.pin.swiftfiles=true
+END
More information about the Swift-commit
