[Swift-commit] r6856 - SwiftApps/Swift-MapRed/TurboChirp
    ketan at ci.uchicago.edu
    Thu Aug 15 11:13:49 CDT 2013
Author: ketan
Date: 2013-08-15 11:13:49 -0500 (Thu, 15 Aug 2013)
New Revision: 6856
Removed:
   SwiftApps/Swift-MapRed/TurboChirp/teragen.out
Modified:
   SwiftApps/Swift-MapRed/TurboChirp/hosts.txt
   SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl
Log:
removed teragen.out, updated hosts list
Modified: SwiftApps/Swift-MapRed/TurboChirp/hosts.txt
--- SwiftApps/Swift-MapRed/TurboChirp/hosts.txt	2013-08-15 16:09:39 UTC (rev 6855)
+++ SwiftApps/Swift-MapRed/TurboChirp/hosts.txt	2013-08-15 16:13:49 UTC (rev 6856)
@@ -1,7 +1,10 @@
-thwomp
-stomp
-crush
-crank
-steamroller
-thrash
+crush
+thwomp
+stomp
+crank
+steamroller
+grind
+churn
+trounce
+thrash
 vanquish
Deleted: SwiftApps/Swift-MapRed/TurboChirp/teragen.out
--- SwiftApps/Swift-MapRed/TurboChirp/teragen.out	2013-08-15 16:09:39 UTC (rev 6855)
+++ SwiftApps/Swift-MapRed/TurboChirp/teragen.out	2013-08-15 16:13:49 UTC (rev 6856)
@@ -1,205 +0,0 @@
-++ dirname /homes/wozniak/Public/turbine/bin/turbine
-+ TURBINE_BIN=/homes/wozniak/Public/turbine/bin
-+ [[ -z '' ]]
-++ cd /homes/wozniak/Public/turbine/bin/..
-++ /bin/pwd
-+ TURBINE_HOME=/nfs2/wozniak/Public/turbine
-+ source /nfs2/wozniak/Public/turbine/scripts/turbine-config.sh
-++ TURBINE_HOME=/homes/wozniak/Public/turbine
-++ TURBINE_VERSION=0.5.0
-++ export C_UTILS=/nfs2/wozniak/Public/c-utils
-++ C_UTILS=/nfs2/wozniak/Public/c-utils
-++ export TCL=/homes/wozniak/Public/tcl-8.5.11-x86_64
-++ TCL=/homes/wozniak/Public/tcl-8.5.11-x86_64
-++ export TCLSH=/homes/wozniak/Public/tcl-8.5.11-x86_64/bin/tclsh8.5
-++ TCLSH=/homes/wozniak/Public/tcl-8.5.11-x86_64/bin/tclsh8.5
-++ export ADLB=/nfs2/wozniak/Public/lb
-++ ADLB=/nfs2/wozniak/Public/lb
-++ export MPI_IMPL=MPICH2
-++ MPI_IMPL=MPICH2
-++ export MPI=@USE_MPI@
-++ MPI=@USE_MPI@
-++ export MPI_LIB=/nfs2/wozniak/Public/mpich-master-x86_64/lib
-++ MPI_LIB=/nfs2/wozniak/Public/mpich-master-x86_64/lib
-++ export TURBINE_LAUNCHER=mpiexec
-++ TURBINE_LAUNCHER=mpiexec
-++ TCLLIBPATH=
-++ [[ -n '' ]]
-++ TCLLIBPATH+=/homes/wozniak/Public/turbine/lib
-++ export TCLLIBPATH
-++ [[ /homes/wozniak/Public/tcl-8.5.11-x86_64/bin/tclsh8.5 == '' ]]
-++ export TURBINE_MACHINE=normal
-++ TURBINE_MACHINE=normal
-++ [[ normal == \s\i\c\o\r\t\e\x ]]
-++ return 0
-+ [[ 0 != 0 ]]
-+ ((  REPORT_VERSION  ))
-+ ((  PRINT_HELP  ))
-+ [[ hosts.txt != 0 ]]
-+ TURBINE_LAUNCH_OPTIONS+=' -f hosts.txt'
-+ shift 6
-+ PROGRAM=teragen.tcl
-+ shift
-+ ARGS=
-+ [[ teragen.tcl == '' ]]
-+ [[ ! -f teragen.tcl ]]
-+ ((  1  ))
-+ [[ MPICH2 == \M\P\I\C\H\2 ]]
-+ LINE_PREFIX=-l
-+ OPTIONS=
-+ OPTIONS+='-l '
-+ OPTIONS+='-n 10 '
-+ OPTIONS+=' -f hosts.txt'
-+ ((  VERBOSE  ))
-+ which mpiexec
-/usr/bin/mpiexec
-+ mpiexec -l -n 10 -f hosts.txt /homes/wozniak/Public/tcl-8.5.11-x86_64/bin/tclsh8.5 teragen.tcl
-[9] DEBUG_ADLB: ADLB SERVER...
-[0] DEBUG_ADLB: adlb::insert <8>["0"]=<19>
-[0] DEBUG_ADLB: adlb::insert <8>["1"]=<20>
-[0] DEBUG_ADLB: adlb::insert <8>["2"]=<21>
-[0] DEBUG_ADLB: adlb::insert <8>["3"]=<22>
-[0] DEBUG_ADLB: adlb::insert <8>["4"]=<23>
-[0] DEBUG_ADLB: adlb::insert <8>["5"]=<24>
-[0] DEBUG_ADLB: adlb::insert <8>["6"]=<25>
-[0] DEBUG_ADLB: adlb::insert <8>["7"]=<26>
-[0] DEBUG_ADLB: adlb::insert <8>["8"]=<27>
-[0] DEBUG_ADLB: adlb::insert <8>["9"]=<28>
-[0] DEBUG_ADLB: adlb::insert <7>["7"]=<32 30 1>
-[0] DEBUG_ADLB: adlb::insert <7>["0"]=<36 34 1>
-[0] DEBUG_ADLB: adlb::insert <7>["9"]=<40 38 1>
-[0] DEBUG_ADLB: adlb::insert <7>["3"]=<44 42 1>
-[0] DEBUG_ADLB: adlb::insert <7>["2"]=<48 46 1>
-[0] DEBUG_ADLB: adlb::insert <7>["1"]=<52 50 1>
-[0] DEBUG_ADLB: adlb::insert <7>["5"]=<56 54 1>
-[0] DEBUG_ADLB: adlb::insert <7>["6"]=<60 58 1>
-[0] DEBUG_ADLB: adlb::insert <7>["8"]=<64 62 1>
-[0] DEBUG_ADLB: adlb::insert <7>["4"]=<68 66 1>
-[0] DEBUG_ADLB: adlb::get: type=1
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "140 gen_data-app-leaf0 0 {33 31 1} 13 30 31 {12 13 0} 1 {32 30 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "170 gen_data-app-leaf0 0 {37 35 1} 13 34 35 {12 13 0} 1 {36 34 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "200 gen_data-app-leaf0 0 {41 39 1} 13 38 39 {12 13 0} 1 {40 38 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "230 gen_data-app-leaf0 0 {45 43 1} 13 42 43 {12 13 0} 1 {44 42 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "260 gen_data-app-leaf0 0 {49 47 1} 13 46 47 {12 13 0} 1 {48 46 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "290 gen_data-app-leaf0 0 {53 51 1} 13 50 51 {12 13 0} 1 {52 50 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "320 gen_data-app-leaf0 0 {57 55 1} 13 54 55 {12 13 0} 1 {56 54 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "350 gen_data-app-leaf0 0 {61 59 1} 13 58 59 {12 13 0} 1 {60 58 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "380 gen_data-app-leaf0 0 {65 63 1} 13 62 63 {12 13 0} 1 {64 62 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "410 gen_data-app-leaf0 0 {69 67 1} 13 66 67 {12 13 0} 1 {68 66 1}" 0
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "80 deeprule_action "29" "get_uniq_sites-app-leaf0 0 {14 15 0} 9 {16 9 1} 15 7"" 0
-[2] grep: tgen*out[2] : No such file or directory
-[0] DEBUG_ADLB: adlb::put: target_rank: -100 type: 0 "420 main-call_builtin-read 0 11 {16 9 1}" 0
-[0] DEBUG_ADLB: adlb::insert <10>["0"]=<70>
-[0] DEBUG_ADLB: adlb::insert <10>["1"]=<71>
-[0] DEBUG_ADLB: adlb::insert <10>["2"]=<72>
-[0] DEBUG_ADLB: adlb::insert <10>["3"]=<73>
-[0] DEBUG_ADLB: adlb::insert <10>["4"]=<74>
-[0] DEBUG_ADLB: adlb::insert <10>["5"]=<75>
-[0] DEBUG_ADLB: adlb::insert <10>["6"]=<76>
-[0] DEBUG_ADLB: adlb::insert <10>["7"]=<77>
-[0] DEBUG_ADLB: adlb::insert <87>["0"]=<134>
-[0] DEBUG_ADLB: adlb::insert <94>["0"]=<135>
-[0] DEBUG_ADLB: adlb::insert <101>["0"]=<136>
-[0] DEBUG_ADLB: adlb::insert <108>["0"]=<137>
-[0] DEBUG_ADLB: adlb::insert <115>["0"]=<138>
-[0] DEBUG_ADLB: adlb::insert <122>["0"]=<139>
-[0] DEBUG_ADLB: adlb::insert <129>["0"]=<140>
-[0] Site: crank Rank: 3
-[0] DEBUG_ADLB: adlb::put: target_rank: 3 type: 0 "870 comb_data_local-app-leaf0 0 {91 86 1} 85 86 {17 18 0} 18 {90 85 1} 70" 0
-[0] Site: crank String: crank
-[0]
-[0] Site: thrash Rank: 5
-[0] DEBUG_ADLB: adlb::put: target_rank: 5 type: 0 "890 comb_data_local-app-leaf0 0 {133 128 1} 127 128 {17 18 0} 18 {132 127 1} 74" 0
-[0] Site: thrash String: thrash
-[0]
-[0] Site: vanquish Rank: 6
-[0] DEBUG_ADLB: adlb::put: target_rank: 6 type: 0 "930 comb_data_local-app-leaf0 0 {126 121 1} 120 121 {17 18 0} 18 {125 120 1} 76" 0
-[0] Site: vanquish String: vanquish
-[0]
-[0] Site: thwomp Rank: 0
-[0] DEBUG_ADLB: adlb::put: target_rank: 0 type: 0 "950 comb_data_local-app-leaf0 0 {119 114 1} 113 114 {17 18 0} 18 {118 113 1} 75" 0
-[0] Site: thwomp String: thwomp
-[0]
-[0] Site: crush Rank: 9
-[0] DEBUG_ADLB: adlb::put: target_rank: 9 type: 0 "990 comb_data_local-app-leaf0 0 {112 107 1} 106 107 {17 18 0} 18 {111 106 1} 71" 0
-[0] Site: crush String: crush
-[0]
-[0] Site: steamroller Rank: 4
-[0] DEBUG_ADLB: adlb::put: target_rank: 4 type: 0 "1010 comb_data_local-app-leaf0 0 {105 100 1} 99 100 {17 18 0} 18 {104 99 1} 72" 0
-[0] Site: steamroller String: steamroller
-[0]
-[0] Site: stomp Rank: 8
-[0] DEBUG_ADLB: adlb::put: target_rank: 8 type: 0 "1040 comb_data_local-app-leaf0 0 {98 93 1} 92 93 {17 18 0} 18 {97 92 1} 73" 0
-[0] Site: stomp String: stomp
-[0]
-[9] WARNING: server contains targeted work![0] WAITING TRANSFORMS: 8
-[0] TRANSFORM:      {450} decr-filename-[ 83 78 ] LOCAL (/83/)
-[0] TRANSFORM:      {460} decr-filename-[ 84 79 ] LOCAL (/84/)
-[0] TRANSFORM:      {480} DRS-81-82 LOCAL (/82/)
-[0] TRANSFORM:      {490} main-optmerged  LOCAL (/81/)
-[0] TRANSFORM:      {650} decr-filename-[ 111 106 ] LOCAL (/111/)
-[0] TRANSFORM:      {660} decr-filename-[ 112 107 ] LOCAL (/112/)
-[0] TRANSFORM:      {700} decr-filename-[ 118 113 ] LOCAL (/118/)
-[0] TRANSFORM:      {710} decr-filename-[ 119 114 ] LOCAL (/119/)
-[9]
-[9] WARNING: server contains targeted work![9]
Modified: SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl
--- SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl	2013-08-15 16:09:39 UTC (rev 6855)
+++ SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl	2013-08-15 16:13:49 UTC (rev 6856)
@@ -1,11 +1,11 @@
 # Generated by stc version 0.2.0
-# date                    : 2013/08/15 10:49:08
+# date                    : 2013/08/15 11:04:50
 # Turbine version         : 0.3.0
-# Input filename          : /nfs2/yadunand/Swift-MapRed/TurboChirp/teragen.swift
-# Output filename         : /nfs2/yadunand/Swift-MapRed/TurboChirp
+# Input filename          : /nfs2/ketan/Swift-MapRed/TurboChirp/teragen.swift
+# Output filename         : /nfs2/ketan/Swift-MapRed/TurboChirp
 # STC home                : /nfs2/wozniak/Public/stc
-# Turbine home            : /homes/wozniak/Public/turbine
+# Turbine home            : /home/wozniak/Public/turbine
 # Compiler settings:
 # stc.auto-declare              : true
 # stc.c_preprocess              : true
@@ -53,7 +53,7 @@
 # stc.rpath                     :
 # stc.stc_home                  : /nfs2/wozniak/Public/stc
 # stc.turbine.version           : 0.3.0
-# stc.turbine_home              : /homes/wozniak/Public/turbine
+# stc.turbine_home              : /home/wozniak/Public/turbine
 # stc.version                   : 0.2.0
 # Metadata:
More information about the Swift-commit
