[Swift-commit] r6853 - SwiftTutorials/CIC_2013-08-09
    wilde at ci.uchicago.edu
    Thu Aug 15 10:59:23 CDT 2013
Author: wilde
Date: 2013-08-15 10:59:22 -0500 (Thu, 15 Aug 2013)
New Revision: 6853
Removed:
   SwiftTutorials/CIC_2013-08-09/README
Log:
for cic
Deleted: SwiftTutorials/CIC_2013-08-09/README
--- SwiftTutorials/CIC_2013-08-09/README	2013-08-15 15:55:03 UTC (rev 6852)
+++ SwiftTutorials/CIC_2013-08-09/README	2013-08-15 15:59:22 UTC (rev 6853)
@@ -1,822 +0,0 @@
-TUTORIAL-NAME 2013 Workflow Tutorial Exercises
-Workflow tutorial setup
-Check out scripts from SVN
-To checkout the most recent TUTORIAL-NAME tutorial scripts from SVN, run the following
-command:
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/TUTORIAL-NAME
-This will create a directory called TUTORIAL-NAME which contains all of the
-scripts mentioned in this document.
-Run setup
-Once the scripts are checked out, run the following commands to perform
-the initial setup.
-$ cd TUTORIAL-NAME       # change to the newly created TUTORIAL-NAME directory
-$ source setup.sh <SITE> # sets swift config files in $HOME/.swift and selects
-                         # a site from the following: ( cloud, uc3, midway )
-$ swift -version         # verify that Swift 0.94 is in your $PATH and functional
-NOTE: If you disconnect from the machine, you will need to re-run source setup.sh.
-Mock "science applications" for the workflow tutorial
-There are two shell scripts included that serve a very simple stand-ins for science application:
-simulation.sh and stats.sh
-simulation.sh
-The simulation.sh script is a simple substitute for a scientific simulation application. It generates and prints a set of one or more random integers in the range 0-29,999 as controlled by its optional arguments, which are:
-.simulation.sh arguments
-[options="header"]
-|Argument number|Description
-|1    |runtime. Set how long simulation.sh should run, in seconds.
-|2    |range. Limit random numbers to the range [0,range-1]
-|3    |biasfile. Adds the integer contained in this file to each random number generated.
-|4    |scale. Multiplies each random number by this integer argument.
-|5    |n. Generate n number of random numbers.
-With no arguments, simulate.sh prints 1 number in the range of 1-100. Otherwise it generates n numbers of the form R * scale + bias.
-$ ./simulate.sh
-96
-stats.sh
-The stats.sh script reads a file containing n numbers and prints the average
-of those numbers to stdout.
-Introductory exercises
-Parts 1-6 (p1.swift - p6.swift) run locally and serve as examples of the Swift language.
-Parts 7-9 (p7.swift - p9.swift) submit jobs to the site specified the setup stage
-p1 - Run an application under Swift
-The first swift script, p1.swift, runs simulate.sh to generate a single random
-number. It writes the number to a file.
-image:p1.png[]
-.p1.swift
-type file;
-app (file o) mysim ()
-  simulate stdout=@filename(o);
-file f = mysim();
-To run this script, run the following command:
-$ cd part01
-$ swift p1.swift
-The simulate application gets translated to simulate.sh within the 'apps' file.
-NOTE: Since the file you created is not named, swift will generate a random
-name for the file in a directory called _concurrent. To view the created
-output, run "cat _concurrent/*"
-To cleanup the directory and remove all outputs, run:
-$ ./clean.sh
-p2 - Mapping (naming) output files
-The second swift script shows an example of naming the file. The output is now
-in a file called sim.out.
-image:p2.png[]
-.p2.swift
-type file;
-file f <"sim.out">;
-f = mysim();
-To run the script:
-$ cd ../part02
-$ swift p2.swift
-p3 - Parallel loops with foreach
-The p3.swift script introduces the foreach loop. This script runs many
-simulations. Output files are named here by Swift and will get created
-in the _concurrent directory.
-image:p3.png[]
-.p3.swift
-type file;
-foreach i in [0:9] {
-  file f = mysim();
-To run:
-$ cd part03
-$ swift p3.swift
-p4 - Mapping arrays to files
-p4.swift gives an example of naming multiple files within a foreach loop.
-image:p4.png[]
-.p4.swift
-type file;
-  file f <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
-  f = mysim();
-To run:
-$ swift p4.swift
-Output files will be named output/sim_N.out.
-p5 - merging/reducing the results of a parallel foreach loop
-p5.swift introduces a postprocessing step. After all the parallel simulations have completed, the files
-created by simulation.sh will be averaged by stats.sh.
-image:p5.png[]
-.p5.swift
-type file;
-app (file o) analyze (file s[])
-  stats @filenames(s) stdout=@filename(o);
-file sims[];
-int nsim = @toInt(@arg("nsim","10"));
-foreach i in [0:nsim-1] {
-  file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
-  simout = mysim();
-  sims[i] = simout;
-file stats<"output/average.out">;
-stats = analyze(sims);
-To run:
-$ swift p5.swift
-p6 - Sending arguments to applications
-p6.swift introduces command line arguments. The script sets a variable called
-"steps" here, which determines the length of time that the simulation.sh
-will run for. It also defines a variable called nsim, which determines the
-number of simulations to run.
-image:p6.png[]
-.p6.swift
-type file;
-app (file o) mysim (int timesteps)
-  simulate timesteps stdout=@filename(o);
-file sims[];
-int steps = @toInt(@arg("steps","1"));
-  simout = mysim(steps);
-  sims[i] = simout;
-Use the command below to specify the time for each simulation.
-$ cd ../part06
-$ swift p6.swift -steps=3  # each simulation takes 3 seconds
-p7 - Running on the remote site nodes
-p7.swift is the first script that will submit jobs to remote site nodes for analysis.
-It is similar to earlier scripts, with a few minor exceptions. To generalize the script
-for other types of remote execution (e.g., when no shared filesystem is available to the compute nodes), the application simulate.sh
-will get transferred to the worker node by Swift, in the same manner as any other input data file.
-image:p7.png[]
-.p7.swift
-type file;
-# Application to be called by this script
-file simulation_script <"simulate.sh">;
-# app() functions for application programs to be called:
-app (file out) simulation (file script, int timesteps, int sim_range)
-  sh @filename(script) timesteps sim_range stdout=@filename(out);
-# Command line params to this script:
-int  nsim  = @toInt(@arg("nsim",  "10"));  # number of simulation programs to run
-int  range = @toInt(@arg("range", "100")); # range of the generated random numbers
-# Main script and data
-int steps=3;
-tracef("\n*** Script parameters: nsim=%i steps=%i range=%i \n\n", nsim, steps, range);
-  simout = simulation(simulation_script, steps, range);
-To run:
-$ cd ../part07
-$ swift p7.swift
-p8 - Running the stats summary step on the remote site
-p8.swift will also stage in and run stats.sh to calculate averages. It adds a
-trace statement so you can see the order in which things execute.
-image:p8.png[]
-.p8.swift
-type file;
-# Applications to be called by this script
-file analysis_script   <"stats.sh">;
-app (file out) simulation (file script, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
-  sh @filename(script) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out);
-app (file out) analyze (file script, file s[])
-  sh @script @filenames(s) stdout=@filename(out);
-int  steps = @toInt(@arg("steps", "1"));   # number of "steps" each simulation (==seconds of runtime)
-int  count = @toInt(@arg("count", "10"));  # number of random numbers generated per simulation
-tracef("\n*** Script parameters: nsim=%i steps=%i range=%i count=%i\n\n", nsim, steps, range, count);
-file sims[];                               # Array of files to hold each simulation output
-file bias<"bias.dat">;                     # Input data file to "bias" the numbers:
-                                           # 1 line: scale offset ( N = n*scale + offset)
-  simout = simulation(simulation_script, steps, range, bias, 100000, count);
-  sims[i] = simout;
-file stats<"output/stats.out">;         # Final output file: average of all "simulations"
-stats = analyze(analysis_script,sims);
-To run:
-$ cd ../part08
-$ swift p8.swift
-p9 - A more complex workflow pattern: multiple parallel pipelines
-p9.swift adds another app function called genrand. Genrand will produce a random
-number that will be used to determine how long each simulation app will run.
-image:p9.png[]
-.p9.swift
-type file;
-app (file out) genrand (file script, int timesteps, int sim_range)
-tracef("\n*** Script parameters: nsim=%i range=%i count=%i\n\n", nsim, range, count);
-file bias<"dynamic_bias.dat">;        # Dynamically generated bias for simulation ensemble
-bias = genrand(simulation_script, 1, 1000);
-  int steps = readData(genrand(simulation_script, 1, 5));
-  tracef("  for simulation[%i] steps=%i\n", i, steps+1);
-  simout = simulation(simulation_script, steps+1, range, bias, 100000, count);
-  sims[i] = simout;
-To run:
-$ cd ../part09
-$ swift p9.swift
-Notes on the Cloud exercises
-The run.catsn shell script contains the full command line to call Swift scripts with configuration files. This script runs swift as follows:
-swift -sites.file sites.xml -tc.file tc -config cf catsn.swift -n=10
-To learn more about the configuration files, see Swift user-guide:
-http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html
-Running Swift/T on Vesta with Python and R integration
-Normally it is difficult to run scripted programs such as Python and
-R on the Blue Gene/Q because of the limited OS environment.  However,
-Swift/T allows you to create a composite application that is linked
-into one Cobalt job at run time.  Thus, you can write a scripted
-program that coordinates calls from Swift to C, C++, Fortran, Python,
-R, or Tcl.  All data movement is handled by the Swift/T runtime over
-MPI, removing the overhead of file access.
-=== p11 - Scripted parallel numerics with Python and R
-As shown on the slides, this example calls the
-http://www.numpy.org[Numpy] numerical libraries via Python as well as
-the http://www.r-project.org[R language] for statistics.  In this
-example, we use Numpy to construct matrices, perform matrix
-arithmetic, and compute determinants.  Since determinant is _O(n^3^)_,
-we compute each determinant in parallel using the Swift +foreach+
-loop.  All result are collected and passed to the R +max()+ function.
-==== Scripts
-This example is designed to run on Vesta.
-To compile and run the script, run:
-.run-dets.sh
-include::part11-swift-py-r/code/run-dets.sh.txt[]
-As a reference, an equivalent plain Python code is provided:
-.dets.py
-include::part11-swift-py-r/code/dets.py[]
-The Swift script is:
-.dets.swift
-include::part11-swift-py-r/code/dets.swift[]
-==== Analysis
-The Turbine run time script creates a +TURBINE_OUTPUT+ directory and
-reports it.  Standard output from the job is in +output.txt+.
-Use +grep dets+ to find the results printed by the Swift script.  You
-will see each determinant as inserted into the Swift array, and the
-maximal result.
-Turbine was launched with +-n 10+; that is, 10 total processes, 8 of
-which are workers, ranks 1-8.  Much of the output is created by rank
-0, the Turbine engine.  (Only one engine is used in this case,
-although Swift/T supports multiple engines for scalability.)  The ADLB
-server runs on rank 9 and produces almost no output.  (Swift/T and
-ADLB support multiple servers.)
-You may +grep+ for +python: expression:+ to see the Python expressions
-evaluated on the workers.  Note the rank numbers.
-For production cases, you may disable logging by setting
-+TURBINE_LOG=0+ in the environment.
-=== More information
-For more information about Swift/T, see:
-* https://sites.google.com/site/exmcomputing/swift-t[Swift/T Overview]
-* http://www.mcs.anl.gov/exm/local/guides/swift.html[Swift/T Guide]
-* http://www.mcs.anl.gov/exm/local/guides/turbine-sites.html[Sites Guide]
-   — notes for running Swift/T on various systems
-Running MPI apps under Swift
-Modis - Satellite image data processing
-In this section we will use swift to process data from a large dataset of
-files that categorize the Earth's surface, derived from the MODIS sensor
-instruments that orbit the Earth on two NASA satellites of the Earth Observing System.
-The dataset we use (for 2002, named +mcd12q1+) consists of 317 "tile" files
-that categorize every 250-meter square of non-ocean surface of the Earth into
-one of 17 "land cover" categories (for example, water, ice, forest, barren, urban).
-Each pixel of these data files has a value of 0 to 16, describing one square
-of the Earth's surface at a specific point in time. Each tile file has
-approximately 5 million 1-byte pixels (5.7 MB), covering 2400x2400 250-meter
-squares, based on a specific map projection.
-image:sinusoidal_v5.gif[]
-modis01 - Process 1 image
-The first modis example defines one app function called getLandUse.
-This app takes a satellite image (data/modis/2002/h00v09.pgm.gz) as
-input. getLandUse creates a text file called landuse/h00v08.landuse.byfreq
-that counts the frequency of each land type defined in the input image.
-.modis01.swift
-type imagefile;
-type landuse;
-app (landuse output) getLandUse (imagefile input)
-  getlanduse @filename(input) stdout=@filename(output);
-imagefile modisImage <"data/global/h00v09.rgb">;
-landuse result <"landuse/h00v09.landuse.byfreq">;
-result = getLandUse(modisImage);
-To run modis01.swift:
-$ cd modis/modis01/
-$ swift modis01.swift
-modis02 - Process multiple images in parallel
-The second modis example expands upon the first example by running getLandUse
-with multiple (317) input files. Ouptut files are stored in the landuse directory.
-In order to map several input files we will use the ext mapper here to specify
-the mapper script, location a suffix to identify matching files.
-TODO: More on mappers
-.modis02.swift
-type imagefile;
-type landuse;
-# Constants and command line arguments
-int nFiles       = @toInt(@arg("nfiles", "1000"));
-string MODISdir  = @arg("modisdir", "data/global");
-# Input Dataset
-imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=n\
-Files>;
-# Compute the land use summary of each MODIS tile
-landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strc\
-at("landuse/\\1.landuse.byfreq")>;
-foreach g,i in geos {
-    land[i] = getLandUse(g);
-To run modis02.swift
-$ cd modis/modis02/
-$ swift modis02.swift
-modis03 - Analyse the processed images
-The third modis example builds on the previous example. It defines a new app function
-called analyzeLandUse. The analyzeLandUse app examines the data generated by getLandUse
-and creates two summary files called topselected.txt and selectedtiles.txt. These
-files contain information about the top 10 urban areas.
-In the previous example, you have noticed that running all 317 input files on
-your laptop, even with 4 tasks a time, is not very efficient.
-TODO : In the next example, instead of running locally, we will use a cluster called midway at the University of Chicago to improve performance.
-.modis03.swift
-type file;
-type imagefile;
-type landuse;
-app (file output, file tilelist) analyzeLandUse (landuse input[], string usetype, int ma\
-xnum)
-  analyzelanduse @output @tilelist usetype maxnum @input;
-int nSelect      = @toInt(@arg("nselect", "10"));
-string landType  = @arg("landtype", "urban");
-# Input Dataset
-Files>;
-# Find the top N tiles (by total area of selected landuse types)
-file topSelected <"topselected.txt">;
-file selectedTiles <"selectedtiles.txt">;
-(topSelected, selectedTiles) = analyzeLandUse(land, landType, nSelect);
-To run modis03.swift
-$ cd modis/modis03/
-$ swift modis03.swift
-modis04 - Mark the top N tiles on a map
-The fourth modis example adds another app called markMap that looks at selectedtiles.txt
-and highlights the selected areas on a map. It will create a new image called
-gridmap.png which marks the top N tiles on a sinusoidal gridded map.
-.modis04.swift
-type file;
-type imagefile;
-type landuse;
-xnum)
-app (imagefile grid) markMap (file tilelist)
-  markmap @tilelist @grid;
-# Input Dataset
-Files>;
-landuse land[]    <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@s\
-trcat("landuse/\\1.landuse.byfreq")>;
-# Mark the top N tiles on a sinusoidal gridded map
-imagefile gridmap <"gridmap.png">;
-gridmap = markMap(topSelected);
-To run modis04.swift
-$ cd modis/modis04/
-$ swift modis04.swift
-modis05 - Create multi-color tile images
-The fifth modis example extends the previous examples by adding the colorModis app
-to create multi-color images for all tiles.
-.modis05.swift
-type file;
-type imagefile;
-type landuse;
-app (file output, file tilelist) analyzeLandUse (landuse input[], string usetype, int maxnum)
-app (imagefile output) colorModis (imagefile input)
-  colormodis @input @output;
-# Input Dataset
-imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=nFiles>;
-landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("landuse/\\1.landuse.byfreq")>;
-# Create multi-color images for all tiles
-imagefile colorImage[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("colorImages/\\1.color.rgb")>;
-foreach g, i in geos {
-  colorImage[i] = colorModis(g);
-To run modis05.swift:
-$ cd modis/modis05/
-$ swift modis05.swift
More information about the Swift-commit
