[Swift-commit] r6848 - SwiftApps/Swift-MapRed/TurboChirp
yadunandb at ci.uchicago.edu yadunandb at ci.uchicago.edu
Wed Aug 14 15:09:06 CDT 2013
Author: yadunandb
Date: 2013-08-14 15:09:06 -0500 (Wed, 14 Aug 2013)
New Revision: 6848
Added:
   SwiftApps/Swift-MapRed/TurboChirp/jobs_per_site.sh
Modified:
   SwiftApps/Swift-MapRed/TurboChirp/cleanup
   SwiftApps/Swift-MapRed/TurboChirp/combiner.sh
   SwiftApps/Swift-MapRed/TurboChirp/run.sh
   SwiftApps/Swift-MapRed/TurboChirp/teragen.swift
   SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl
   SwiftApps/Swift-MapRed/TurboChirp/teragen_wrap.sh
Log:
Waiting for the correct usage of @location tag
Combiner code tested.
Modified: SwiftApps/Swift-MapRed/TurboChirp/cleanup
--- SwiftApps/Swift-MapRed/TurboChirp/cleanup	2013-08-14 15:42:28 UTC (rev 6847)
+++ SwiftApps/Swift-MapRed/TurboChirp/cleanup	2013-08-14 20:09:06 UTC (rev 6848)
@@ -1,3 +1,2 @@
-rm -rfv *.dat
-rm *{imd2,imd}
-rm err_file final_result
\ No newline at end of file
+rm tgen*{err,out} *{imd2,imd} err_file final_result *~ &> /dev/null
+rm sitecomb*{err,out} &> /dev/null
Modified: SwiftApps/Swift-MapRed/TurboChirp/combiner.sh
--- SwiftApps/Swift-MapRed/TurboChirp/combiner.sh	2013-08-14 15:42:28 UTC (rev 6847)
+++ SwiftApps/Swift-MapRed/TurboChirp/combiner.sh	2013-08-14 20:09:06 UTC (rev 6848)
@@ -1,23 +1,46 @@
 #!/bin/bash
+# The combiner is expecting to receive filenames as args
+# Each file would contains strings in the format HOSTNAME FILEPATH
-FILES=$*
+ARGS=($*)
+PASSED_SITE=${ARGS[0]}
+FILES=(${ARGS[*]:1})
+#CURRENT_HOST=$(hostname -f)
+CURRENT_HOST=$HOSTNAME
+# debug
+#[ "$CURRENT_HOST" == "$PASSED_HOST" ] &&  echo "Local combination";
 SUM=0
 COUNT=0
 fetch_and_process()
     TOKEN=($(cat $1))
-    HOST=${TOKEN[0]}
+    HOST=${TOKEN[0]}
     FILE=${TOKEN[1]}
+    echo "FILE: $FILE on $HOST"
     TARGET=$(basename $FILE)
-    chirp_get $HOST $TARGET $TARGET.imd
-    RES=($(awk '{ sum += $1 } END { print sum,NR }' $TARGET.imd))
+    echo "HOST: $HOST, CURRENT_HOST=$HOSTNAME"
+    if [ "$HOST" != "$CURRENT_HOST" ]
+    then
+        # Fetch if file is remote
+        echo "chirp_get $HOST $TARGET $TARGET.imd"
+        chirp_get $HOST $TARGET /tmp/$TARGET.imd
+        RES=($(awk '{ sum += $1 } END { print sum,NR }' /tmp/$TARGET.imd))
+    else
+        # Process directly if file is local
+        RES=($(awk '{ sum += $1 } END { print sum,NR }' $FILE))
+    fi
     echo "${RES[0]} ${RES[1]}" > "$2.$RANDOM.imd2"
 ID=$RANDOM
-for file_token in $*
+echo "DEBUG: ${FILES[*]}"
+for file_token in ${FILES[*]}
 do
+    echo $file_token
     fetch_and_process $file_token $ID &
 done
 wait
@@ -27,29 +50,6 @@
 echo "SUM  : $SUM"
 echo "COUNT: $COUNT"
-exit 0
-exit 0
-do
-    TOKEN=($(cat $file_token))
-    HOST=${TOKEN[0]}
-    FILE=${TOKEN[1]}
-    TARGET=$(basename $FILE)
-    echo "$TARGET.imd"
-    SUM=$(($SUM+${RES[0]}))
-    COUNT=$(($COUNT+${RES[1]}))
-done
-echo "SUM  : $SUM"
-echo "COUNT: $COUNT"
-exit 0
+#rm *imd2 *imd
+exit 0
Added: SwiftApps/Swift-MapRed/TurboChirp/jobs_per_site.sh
--- SwiftApps/Swift-MapRed/TurboChirp/jobs_per_site.sh	                        (rev 0)
+++ SwiftApps/Swift-MapRed/TurboChirp/jobs_per_site.sh	2013-08-14 20:09:06 UTC (rev 6848)
@@ -0,0 +1,14 @@
+#!/bin/bash
+cat $* > tmp;
+FILES=$*
+SITES=($(awk '{ print $1 }' tmp  | sort -u))
+for SITE in ${SITES[*]}
+do
+#    FILES=$(grep $SITE tmp | awk '{print $2}')
+    FILES=$(grep -l $SITE tgen*out)
+    echo $SITE ${FILES[*]}
+done
+rm tmp;
Property changes on: SwiftApps/Swift-MapRed/TurboChirp/jobs_per_site.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftApps/Swift-MapRed/TurboChirp/run.sh
--- SwiftApps/Swift-MapRed/TurboChirp/run.sh	2013-08-14 15:42:28 UTC (rev 6847)
+++ SwiftApps/Swift-MapRed/TurboChirp/run.sh	2013-08-14 20:09:06 UTC (rev 6848)
@@ -1,5 +1,16 @@
+#!/bin/bash
+if [ "$1" == "" ]
+then
+    PROG=teragen.swift
+else
+    PROG=$1
+fi
+./cleanup
 export TURBINE_LOG=0
-export TURBINE_LAUNCH_OPTS="-f ./hosts.txt"
-stc teragen.swift >teragen.tcl
-turbine -n 8 teragen.tcl
+export TURBINE_LAUNCH_OPTS="-f /homes/yadunand/Swift-MapRed/TurboChirp/hosts.txt"
+stc $PROG > ${PROG%.swift}.tcl
+[ "$?" == "0" ] && echo "Compile done"
+turbine -n 8 ${PROG%.swift}.tcl
+[ "$?" == "0" ] && echo "Execute done"
Modified: SwiftApps/Swift-MapRed/TurboChirp/teragen.swift
--- SwiftApps/Swift-MapRed/TurboChirp/teragen.swift	2013-08-14 15:42:28 UTC (rev 6847)
+++ SwiftApps/Swift-MapRed/TurboChirp/teragen.swift	2013-08-14 20:09:06 UTC (rev 6848)
@@ -3,8 +3,10 @@
 import random;
 import string;
 import sys;
+import location;
+import assert;
-app (file out, file err) gen_data (file run, int recsize){
+app (file out, file err) gen_data  (file run, int recsize){
     "/bin/bash" run recsize @stdout=out @stderr=err
@@ -12,34 +14,55 @@
     "/bin/bash" comb array @stdout=out @stderr=err
-file tgen_out[] <simple_mapper; prefix="tgen", suffix=".out">;
-file tgen_err[] <simple_mapper; prefix="tgen", suffix=".err">;
-string dir = @arg("dir", "./");
-main{
-file wrapper = input_file("teragen_wrap.sh");
-file tgen_out[];
-file tgen_err[];
+app (file out, file err) comb_data_local (file comb, string array){
+    "/bin/bash" comb array @stdout=out @stderr=err
-int loop = 7;
-int fsize = 10;
+app (file out) get_uniq_sites (file sites, file array[]){
+    "/bin/bash" sites array @stdout=out
-foreach item,i in [0:loop-1] {
+main
+    file wrapper = input_file("teragen_wrap.sh");
+	file tgen_out[];
+    int loop = 10;
+    int fsize = 1;
+    foreach item,i in [0:loop-1] {
+        file out <sprintf("tgen_%i.out", i)>;
+        file err <sprintf("tgen_%i.err", i)>;
+    	(out, err) = gen_data(wrapper, fsize);
+        tgen_out[i]=out;
+    file jobs_per_site = input_file("jobs_per_site.sh");
+    file combiner_list <"uniq_sites">;
+    combiner_list = get_uniq_sites(jobs_per_site, tgen_out);
-    file out <sprintf("tgenout-%i.dat", i)>;
-    file err <sprintf("tgenerr-%i.dat", i)>;
+    string sites[] = split(readFile(combiner_list), "\n");
-	(out, err) = gen_data(wrapper, fsize);
-    tgen_out[i]=out;
-    tgen_err[i]=err;
+    file combine = input_file("combiner.sh");
+    //Here we are forcing jobs to sites to run local combiners
+    file comb_out[];
+    foreach site,i in sites {
+        file out1 <sprintf("sitecomb_%i.out", i)>;
+        file err1 <sprintf("sitecomb_%i.err", i)>;
+        string site_info[] = split(site, " ");
+        printf("Site: %s String: %s\n", site_info[0], site);
+        location rank = hostmap_one(site_info[0]);
+        printf("Site: %s Rank: %i", site_info[0], rank);
+        //(out1, err1) = comb_data_local(combine, site);
+        // Todo : Find @location usage
+        (out1, err1) = @location=rank comb_data_local(combine, site);
+        comb_out[i] = out1;
-file combine =input_file("combiner.sh");
-file final <"final_result">;
-file errs <"err_file">;
+    // Here's where we do a K_way reduce of the comb_out array
-(final, errs) = comb_data(combine, tgen_out);
Modified: SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl
--- SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl	2013-08-14 15:42:28 UTC (rev 6847)
+++ SwiftApps/Swift-MapRed/TurboChirp/teragen.tcl	2013-08-14 20:09:06 UTC (rev 6848)
@@ -1,353 +0,0 @@
-# Generated by stc version 0.2.0
-# date                    : 2013/08/13 16:55:59
-# Turbine version         : 0.3.0
-# Input filename          : /nfs2/yadunand/Swift-MapRed/TurboChirp/teragen.swift
-# Output filename         : /nfs2/yadunand/Swift-MapRed/TurboChirp
-# STC home                : /nfs2/yadunand/bin/exm/stc
-# Turbine home            : /homes/yadunand/bin/exm/turbine
-# Compiler settings:
-# stc.auto-declare              : true
-# stc.c_preprocess              : true
-# stc.codegen.no-stack          : true
-# stc.codegen.no-stack-vars     : true
-# stc.compiler-debug            : true
-# stc.debugging                 : COMMENTS
-# stc.exp.refcounting           : false
-# stc.ic.output-file            :
-# stc.input_filename            : teragen.swift
-# stc.log.file                  :
-# stc.log.trace                 : false
-# stc.opt.algebra               : false
-# stc.opt.cancel-refcounts      : true
-# stc.opt.constant-fold         : true
-# stc.opt.controlflow-fusion    : true
-# stc.opt.dead-code-elim        : true
-# stc.opt.disable-asserts       : false
-# stc.opt.expand-dataflow-ops   : true
-# stc.opt.expand-loop-threshold-insts: 256
-# stc.opt.expand-loop-threshold-iters: 16
-# stc.opt.expand-loops          : true
-# stc.opt.flatten-nested        : true
-# stc.opt.forward-dataflow      : true
-# stc.opt.full-unroll           : false
-# stc.opt.function-inline       : false
-# stc.opt.function-inline-threshold: 500
-# stc.opt.function-signature    : true
-# stc.opt.hoist                 : true
-# stc.opt.max-iterations        : 10
-# stc.opt.piggyback-refcounts   : true
-# stc.opt.pipeline              : false
-# stc.opt.reorder-insts         : false
-# stc.opt.shared-constants      : true
-# stc.opt.unroll-loop-threshold-insts: 192
-# stc.opt.unroll-loop-threshold-iters: 8
-# stc.opt.unroll-loops          : true
-# stc.opt.wait-coalesce         : true
-# stc.output_filename           :
-# stc.preproc.force-cpp         : false
-# stc.preproc.force-gcc         : false
-# stc.preprocess_only           : false
-# stc.profile                   : false
-# stc.rpath                     :
-# stc.stc_home                  : /nfs2/yadunand/bin/exm/stc
-# stc.turbine.version           : 0.3.0
-# stc.turbine_home              : /homes/yadunand/bin/exm/turbine
-# stc.version                   : 0.2.0
-# Metadata:
-package require turbine 0.3.0
-namespace import turbine::*
-proc swift:constants {  } {
-    turbine::c::log "function:swift:constants"
-    global c:i_10
-    turbine::allocate_custom c:i_10 integer 1 1 1
-    turbine::store_integer ${c:i_10} 10
-    global c:s_combiner_s
-    turbine::allocate_custom c:s_combiner_s string 1 1 1
-    turbine::store_string ${c:s_combiner_s} "combiner.sh"
-    global c:s_teragen_wr
-    turbine::allocate_custom c:s_teragen_wr string 1 1 1
-    turbine::store_string ${c:s_teragen_wr} "teragen_wrap.sh"
-proc f:ternary { stack u:o u:b u:i1 u:i2 } {
-    turbine::c::log "enter function: ternary"
-    turbine::rule [ list ${u:b} ${u:i1} ${u:i2} ] "ternary-argwait ${stack} ${u:b} ${u:o} ${u:i2} ${u:i1}"
-proc ternary-argwait { stack u:b u:o u:i2 u:i1 } {
-    # Value __v_b with type $boolean was defined
-    # Value __v_i1 with type $int was defined
-    # Value __v_i2 with type $int was defined
-    # Value __v_o with type $int was defined
-    set v:b [ turbine::retrieve_integer ${u:b} CACHED 1 ]
-    set v:i1 [ turbine::retrieve_integer ${u:i1} CACHED 1 ]
-    set v:i2 [ turbine::retrieve_integer ${u:i2} CACHED 1 ]
-    if { ${v:b} } { set v:o ${v:i1} } else { set v:o ${v:i2} }
-    turbine::store_integer ${u:o} ${v:o}
-proc f:file_type { stack u:t u:f } {
-    turbine::c::log "enter function: file_type"
-    turbine::rule [ list [ turbine::get_file_status ${u:f} ] ] "file_type-argwait ${stack} {${u:f}} ${u:t}"
-proc file_type-argwait { stack u:f u:t } {
-    # Value __v_f with type $file was defined
-    # Value __v_t with type $string was defined
-    set v:f [ turbine::get_file ${u:f} 1 ]
-    set v:t [ file type [ lindex ${v:f} 0 ] ]
-    turbine::store_string ${u:t} ${v:t}
-proc f:file_exists { stack u:o u:f } {
-    turbine::c::log "enter function: file_exists"
-    turbine::rule [ list ${u:f} ] "file_exists-argwait ${stack} ${u:f} ${u:o}"
-proc file_exists-argwait { stack u:f u:o } {
-    # Value __v_f with type $string was defined
-    # Value __v_o with type $boolean was defined
-    set v:f [ turbine::retrieve_string ${u:f} CACHED 1 ]
-    set v:o [ file exists ${v:f} ]
-proc f:file_mtime { stack u:o u:f } {
-    turbine::c::log "enter function: file_mtime"
-    turbine::rule [ list ${u:f} ] "file_mtime-argwait ${stack} ${u:f} ${u:o}"
-proc file_mtime-argwait { stack u:f u:o } {
-    set v:o [ file mtime ${v:f} ]
-proc f:strlen { stack u:n u:s } {
-    turbine::c::log "enter function: strlen"
-    turbine::rule [ list ${u:s} ] "strlen-argwait ${stack} ${u:s} ${u:n}"
-proc strlen-argwait { stack u:s u:n } {
-    # Value __v_s with type $string was defined
-    # Value __v_n with type $int was defined
-    set v:s [ turbine::retrieve_string ${u:s} CACHED 1 ]
-    set v:n [ string length ${v:s} ]
-    turbine::store_integer ${u:n} ${v:n}
-proc f:trim { stack u:o u:s } {
-    turbine::c::log "enter function: trim"
-    turbine::rule [ list ${u:s} ] "trim-argwait ${stack} ${u:s} ${u:o}"
-proc trim-argwait { stack u:s u:o } {
-    # Value __v_o with type $string was defined
-    set v:o [ string trim ${v:s} ]
-    turbine::store_string ${u:o} ${v:o}
-proc f:hash { stack u:h u:s } {
-    turbine::c::log "enter function: hash"
-    turbine::rule [ list ${u:s} ] "hash-argwait ${stack} ${u:s} ${u:h}"
-proc hash-argwait { stack u:s u:h } {
-    # Value __v_h with type $int was defined
-    set v:h [ c_utils::hash ${v:s} ]
-    turbine::store_integer ${u:h} ${v:h}
-proc f:clock_seconds { stack u:t } {
-    turbine::c::log "enter function: clock_seconds"
-    # Value __v_t with type $int was defined
-    set v:t [ clock seconds ]
-    turbine::store_integer ${u:t} ${v:t}
-proc f:clock { stack u:t } {
-    turbine::c::log "enter function: clock"
-    # Value __v_t with type $float was defined
-    set v:t [ expr {[ clock clicks -milliseconds ] / 1000.0 } ]
-    turbine::store_float ${u:t} ${v:t}
-proc f:gen_data { stack u:out u:err u:run u:recsize dr:location } {
-    turbine::c::log "enter function: gen_data"
-    # Alias __filename_run with type string was defined
-    # Alias __filename_out with type string was defined
-    # Alias __filename_err with type string was defined
-    set filename:run [ turbine::get_file_path ${u:run} ]
-    set filename:out [ turbine::get_output_file_path ${u:out} ]
-    set filename:err [ turbine::get_output_file_path ${u:err} ]
-    turbine::rule [ list ${filename:err} ${filename:out} ${filename:run} ${u:recsize} [ turbine::get_file_status ${u:run} ] ] "gen_data-app-leaf0 ${stack} {${u:err}} ${filename:run} ${filename:out} ${filename:err} {${u:run}} ${u:recsize} {${u:out}}" target ${dr:location} type ${::turbine::WORK}
-proc gen_data-app-leaf0 { stack u:err filename:run filename:out filename:err u:run u:recsize u:out } {
-    # Value __v___filename_run with type $string was defined
-    # Value __v_recsize with type $int was defined
-    # Value __v___filename_out with type $string was defined
-    # Value __v___filename_err with type $string was defined
-    # Value __v_run with type $file was defined
-    # Value __v_out with type $file was defined
-    # Value __v_err with type $file was defined
-    set v:__filename_run [ turbine::retrieve_string ${filename:run} CACHED 1 ]
-    set v:recsize [ turbine::retrieve_integer ${u:recsize} CACHED 1 ]
-    set v:__filename_out [ turbine::retrieve_string ${filename:out} CACHED 1 ]
-    set v:__filename_err [ turbine::retrieve_string ${filename:err} CACHED 1 ]
-    set v:run [ turbine::get_file ${u:run} 1 ]
-    turbine::c::log [ list exec: /bin/bash ${v:__filename_run} ${v:recsize} [ dict create "stdout" ${v:__filename_out} "stderr" ${v:__filename_err} ] ]
-    turbine::exec_external "/bin/bash" [ dict create "stdout" ${v:__filename_out} "stderr" ${v:__filename_err} ] ${v:__filename_run} ${v:recsize}
-    set v:out [ turbine::create_local_file_ref ${v:__filename_out} ]
-    set v:err [ turbine::create_local_file_ref ${v:__filename_err} ]
-    turbine::set_file ${u:out} v:out
-    turbine::set_file ${u:err} v:err
-    turbine::decr_local_file_refcount v:out
-    turbine::decr_local_file_refcount v:err
-proc f:comb_data { stack u:out u:err u:comb u:array dr:location } {
-    turbine::c::log "enter function: comb_data"
-    # Alias __filename_comb with type string was defined
-    set filename:comb [ turbine::get_file_path ${u:comb} ]
-    turbine::deeprule [ list ${filename:comb} ${filename:err} ${filename:out} ${u:array} [ turbine::get_file_status ${u:comb} ] ] [ list 0 0 0 1 0 ] [ list 0 0 0 1 1 ] "comb_data-app-leaf0 ${stack} {${u:err}} ${filename:out} ${filename:err} {${u:comb}} ${filename:comb} {${u:out}} ${u:array}" target ${dr:location} type ${::turbine::WORK}
-proc comb_data-app-leaf0 { stack u:err filename:out filename:err u:comb filename:comb u:out u:array } {
-    # Value __v___filename_comb with type $string was defined
-    # Value __v_comb with type $file was defined
-    set v:__filename_comb [ turbine::retrieve_string ${filename:comb} CACHED 1 ]
-    set v:comb [ turbine::get_file ${u:comb} 1 ]
-    turbine::c::log [ list exec: /bin/bash ${v:__filename_comb} {*}[ turbine::unpack_args ${u:array} 1 1 ] [ dict create "stdout" ${v:__filename_out} "stderr" ${v:__filename_err} ] ]
-    turbine::exec_external "/bin/bash" [ dict create "stdout" ${v:__filename_out} "stderr" ${v:__filename_err} ] ${v:__filename_comb} {*}[ turbine::unpack_args ${u:array} 1 1 ]
-proc swift:main {  } {
-    turbine::c::log "enter function: main"
-    set stack 0
-    lassign [ adlb::multicreate [ list ${::adlb::CONTAINER} ${::adlb::INTEGER} 1 1 ] [ list ${::adlb::CONTAINER} ${::adlb::INTEGER} 1 1 ] [ list ${::adlb::STRING} 1 ] [ list ${::adlb::STRING} 1 ] ] u:tgen_out t:1 t:10 t:11
-    turbine::c::log "allocated u:tgen_out=<${u:tgen_out}> t:1=<${t:1}> t:10=<${t:10}> t:11=<${t:11}>"
-    turbine::allocate_file2 u:wrapper "" 1
-    turbine::allocate_file2 u:combine "" 1
-    turbine::allocate_file2 u:final ${t:10} 1
-    turbine::allocate_file2 u:errs ${t:11} 1
-    # Swift l.21: assigning expression to wrapper
-    turbine::input_file [ list ${u:wrapper} ] [ list ${c:s_teragen_wr} ]
-    # Swift l.25: assigning expression to loop
-    # Swift l.26: assigning expression to fsize
-    turbine::range_work ${t:1} 0 6 1
-    # Swift l.38: assigning expression to combine
-    turbine::input_file [ list ${u:combine} ] [ list ${c:s_combiner_s} ]
-    turbine::store_string ${t:10} "final_result"
-    turbine::store_string ${t:11} "err_file"
-    # Swift l.42: assigning expression to final
-    # Swift l.42: assigning expression to errs
-    f:comb_data ${stack} ${u:final} ${u:errs} ${u:combine} ${u:tgen_out} -100
-    # Swift l.33: assigning expression to out
-    # Swift l.33: assigning expression to err
-    # Swift l.34: assigning expression to tgen_out[_]
-    # Swift l.35: assigning expression to tgen_err[_]
-    set tcltmp:container_sz [ adlb::enumerate ${t:1} count all 0 ]
-    set tcltmp:iters ${tcltmp:container_sz}
-    adlb::slot_create ${u:tgen_out} [ expr { ${tcltmp:iters} - 1 } ]
-    main-foreach0:outer ${stack} ${u:wrapper} ${u:tgen_out} ${t:1} 0 [ expr { ${tcltmp:container_sz} - 1 } ] 1
-proc main-foreach0:outer { stack u:wrapper u:tgen_out t:1 tcltmp:lo tcltmp:hi tcltmp:inc } {
-    set tcltmp:itersleft [ expr { max(0,(${tcltmp:hi} - ${tcltmp:lo}) / ${tcltmp:inc} + 1) } ]
-    if { [ expr { ${tcltmp:itersleft} <= 0 } ] } {
-        return
-    if { [ expr { ${tcltmp:itersleft} <= 64 } ] } {
-        main-foreach0:inner ${stack} ${u:wrapper} ${u:tgen_out} ${t:1} ${tcltmp:lo} ${tcltmp:hi} ${tcltmp:inc}
-    } else {
-        set tcltmp:skip [ expr { ${tcltmp:inc} * max(64,((${tcltmp:itersleft} - 1) / 16) + 1) } ]
-        for { set tcltmp:splitstart ${tcltmp:lo} } { ${tcltmp:splitstart} <= ${tcltmp:hi} } { incr tcltmp:splitstart ${tcltmp:skip} } {
-            set tcltmp:splitend [ expr { min(${tcltmp:hi},${tcltmp:splitstart} + ${tcltmp:skip} - 1) } ]
-            set tcltmp:prio [ turbine::get_priority ]
-            turbine::set_priority ${tcltmp:prio}
-            adlb::spawn 1 "command main-foreach0:outer ${stack} {${u:wrapper}} ${u:tgen_out} ${t:1} ${tcltmp:splitstart} ${tcltmp:splitend} ${tcltmp:inc}"
-            turbine::reset_priority
-proc main-foreach0:inner { stack u:wrapper u:tgen_out t:1 tcltmp:lo tcltmp:hi tcltmp:inc } {
-    set tcltmp:splitlen [ expr { ${tcltmp:hi} - ${tcltmp:lo} + 1 } ]
-    set tcltmp:contents [ adlb::enumerate ${t:1} dict ${tcltmp:splitlen} ${tcltmp:lo} ]
-    dict for {v:i u:item} ${tcltmp:contents} {
-        global c:i_10
-        # Value __ov___t5 with type $string was defined
-        # Value __ov___t7 with type $string was defined
-        lassign [ adlb::multicreate [ list ${::adlb::STRING} 1 ] [ list ${::adlb::STRING} 1 ] ] t:5 t:7
-        turbine::c::log "allocated t:5=<${t:5}> t:7=<${t:7}>"
-        turbine::allocate_file2 u:out ${t:5} 1
-        turbine::allocate_file2 u:err ${t:7} 1
-        set optv:__t5 [ eval format [ list "tgenout-%i.dat" ${v:i} ] ]
-        turbine::store_string ${t:5} ${optv:__t5}
-        set optv:__t7 [ eval format [ list "tgenerr-%i.dat" ${v:i} ] ]
-        turbine::store_string ${t:7} ${optv:__t7}
-        f:gen_data ${stack} ${u:out} ${u:err} ${u:wrapper} ${c:i_10} -100
-        turbine::container_insert ${u:tgen_out} ${v:i} ${u:out} 1
-    set tcltmp:iters [ expr { max(0,(${tcltmp:hi} - ${tcltmp:lo}) / ${tcltmp:inc} + 1) } ]
-turbine::defaults
-turbine::init $engines $servers
-turbine::check_constants "WORKER" ${turbine::WORK_TASK} 0 "CONTROL" ${turbine::CONTROL_TASK} 1 "ADLB_RANK_ANY" ${adlb::RANK_ANY} -100
-turbine::start swift:main swift:constants
-turbine::finalize
Modified: SwiftApps/Swift-MapRed/TurboChirp/teragen_wrap.sh
--- SwiftApps/Swift-MapRed/TurboChirp/teragen_wrap.sh	2013-08-14 15:42:28 UTC (rev 6847)
+++ SwiftApps/Swift-MapRed/TurboChirp/teragen_wrap.sh	2013-08-14 20:09:06 UTC (rev 6848)
@@ -34,6 +34,7 @@
 FILE=$FOLDER/$FILE;
 shuf -i $LOWERLIMIT-$UPPERLIMIT -n $(($SLICESIZE*$ARG1)) | awk '{printf "%-99s\n", $0}' > $FILE
 sleep 5;
-HOST=$(hostname -f)
-echo "$HOST $FILE"
+#HOST=$(hostname -f)
+#echo "$HOST $FILE"
+echo "$HOSTNAME $FILE"
 exit 0
