[Swift-commit] r6835 - trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui
hategan at ci.uchicago.edu
Mon Aug 12 19:29:53 CDT 2013
Author: hategan
Date: 2013-08-12 19:29:53 -0500 (Mon, 12 Aug 2013)
New Revision: 6835
Modified:
trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java
Log:
display exceptions caught in the TUI loop in a nice dialog and log them
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java 2013-08-13 00:29:21 UTC (rev 6834)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java 2013-08-13 00:29:53 UTC (rev 6835)
@@ -49,6 +49,8 @@
private Terminal terminal;
private boolean redraw;
private UnicodeDrawingScheme uds;
+ private Dialog errorDialog;
+ private TextArea errorTA;
public ANSIContext(OutputStream os, InputStream is) {
unicode = "true".equals(System.getProperty("tui.use.unicode"));
@@ -410,17 +412,12 @@
if (key != null) {
if (screen != null) {
- try {
- if (doubleBuffered) {
- // buf.invalidate();
- screen.keyboardEvent(key);
- if (screen != null) {
- screen.redraw();
+ if (doubleBuffered) {
+ // buf.invalidate();
- catch (Exception e) {
- e.printStackTrace();
+ screen.keyboardEvent(key);
+ if (screen != null) {
+ screen.redraw();
//screen.status(key.toString());
@@ -428,20 +425,60 @@
if (!done) {
- logger.warn("Rendering exception", e);
- moveTo(1, 1);
- bgColor(ANSI.RED);
- fgColor(ANSI.WHITE);
- CharArrayWriter cr = new CharArrayWriter();
- PrintWriter wr = new PrintWriter(cr);
- e.printStackTrace(wr);
- text(cr.toString());
- sync();
+ logger.info("Rendering exception", e);
+ displayErrorDialog(e);
+ private void displayErrorDialog(Exception e) {
+ CharArrayWriter cr = new CharArrayWriter();
+ PrintWriter wr = new PrintWriter(cr);
+ e.printStackTrace(wr);
+ synchronized(this) {
+ if (errorDialog == null) {
+ createErrorDialog();
+ if (errorTA.getText() == null) {
+ errorTA.setText(cr.toString());
+ else {
+ errorTA.setText(errorTA.getText() + "\n" + cr.toString());
+ private void createErrorDialog() {
+ Dialog d = new Dialog();
+ d.setFgColor(ANSI.RED);
+ errorDialog = d;
+ d.setTitle("Error");
+ d.setSize(getScreen().getWidth() * 3 / 4, getScreen().getHeight() * 3 / 4);
+ errorTA = new TextArea();
+ d.add(errorTA);
+ errorTA.setFgColor(ANSI.RED);
+ errorTA.setLocation(1, 1);
+ errorTA.setSize(d.getWidth() - 2, d.getHeight() - 3);
+ errorTA.setScrollBarVisible(true);
+ Button close = new Button("Close");
+ d.add(close);
+ close.setLocation((d.getWidth() - close.getWidth()) / 2, d.getHeight() - 1);
+ close.addActionListener(new ActionListener() {
+ @Override
+ public void actionPerformed(Component source) {
+ synchronized(ANSIContext.this) {
+ errorDialog.close();
+ errorDialog = null;
+ d.center(getScreen());
+ d.display(getScreen());
private int read() throws IOException {
while (is.available() == 0) {
if (redraw) {
More information about the Swift-commit
