[Swift-commit] r6816 - SwiftApps/Scattering/paintgrid/docs
    davidk at ci.uchicago.edu
    Fri Aug  9 08:07:11 CDT 2013
Author: davidk
Date: 2013-08-09 08:07:10 -0500 (Fri, 09 Aug 2013)
New Revision: 6816
Modified:
   SwiftApps/Scattering/paintgrid/docs/README
   SwiftApps/Scattering/paintgrid/docs/tutorial.html
Log:
Exaple of how to plot from a lot file
Modified: SwiftApps/Scattering/paintgrid/docs/README
--- SwiftApps/Scattering/paintgrid/docs/README	2013-08-09 01:20:22 UTC (rev 6815)
+++ SwiftApps/Scattering/paintgrid/docs/README	2013-08-09 13:07:10 UTC (rev 6816)
@@ -223,6 +223,14 @@
 the number of active jobs over time. When the worker agents are trasnferring
 data to and from nodes, this time does not get marked as active.
+After each swift run, a log file will be created called
+paintgrid-<YYYYmmdd>-<hhmm>-<random>.log. Once you have identified the log
+file, run the following command to generate the plots:
+$ ./plot.sh <logfile>
 Below is an example of two images created during a run to Beagle.
 image:cumulativeplot.png[]
Modified: SwiftApps/Scattering/paintgrid/docs/tutorial.html
--- SwiftApps/Scattering/paintgrid/docs/tutorial.html	2013-08-09 01:20:22 UTC (rev 6815)
+++ SwiftApps/Scattering/paintgrid/docs/tutorial.html	2013-08-09 13:07:10 UTC (rev 6816)
@@ -917,6 +917,13 @@
 cumulativeplot.png shows overall progress over time, while activeplot.png shows
 data to and from nodes, this time does not get marked as active.</p></div>
+<div class="paragraph"><p>After each swift run, a log file will be created called
+file, run the following command to generate the plots:</p></div>
+<div class="listingblock">
+<div class="content">
+<pre><tt>$ ./plot.sh <logfile></tt></pre>
+</div></div>
 <div class="paragraph"><p>Below is an example of two images created during a run to Beagle.</p></div>
 <div class="paragraph"><p><span class="image">
 <img src="cumulativeplot.png" alt="cumulativeplot.png" />
@@ -939,7 +946,7 @@
 <div id="footnotes"><hr /></div>
 <div id="footer">
 <div id="footer-text">
-Last updated 2013-08-08 16:31:38 CDT
+Last updated 2013-08-08 23:13:52 CDT
 </div>
 </div>
 </body>
More information about the Swift-commit
