[Swift-commit] r6812 - SwiftApps/Scattering/paintgrid
davidk at ci.uchicago.edu
Thu Aug 8 17:02:57 CDT 2013
Author: davidk
Date: 2013-08-08 17:02:57 -0500 (Thu, 08 Aug 2013)
New Revision: 6812
Modified:
SwiftApps/Scattering/paintgrid/apps
SwiftApps/Scattering/paintgrid/beagle.xml
SwiftApps/Scattering/paintgrid/orthros.xml
SwiftApps/Scattering/paintgrid/paintgrid.swift
SwiftApps/Scattering/paintgrid/sites.xml
Log:
Use tiny image by default
Add more comments in sites file
Modified: SwiftApps/Scattering/paintgrid/apps
--- SwiftApps/Scattering/paintgrid/apps 2013-08-08 21:43:00 UTC (rev 6811)
+++ SwiftApps/Scattering/paintgrid/apps 2013-08-08 22:02:57 UTC (rev 6812)
@@ -1,3 +1,4 @@
localhost local_python python
+local python python
orthros python python
beagle python python
Modified: SwiftApps/Scattering/paintgrid/beagle.xml
--- SwiftApps/Scattering/paintgrid/beagle.xml 2013-08-08 21:43:00 UTC (rev 6811)
+++ SwiftApps/Scattering/paintgrid/beagle.xml 2013-08-08 22:02:57 UTC (rev 6812)
@@ -15,12 +15,14 @@
<profile namespace="globus" key="lowOverAllocation">100</profile>
<profile namespace="globus" key="highOverAllocation">100</profile>
<profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
- <profile namespace="globus" key="maxtime">3600</profile>
- <profile namespace="globus" key="maxWalltime">00:05:00</profile>
- <profile namespace="globus" key="slots">5</profile>
+ <!-- Set estimated app time (maxwalltime) and requested job time (maxtime) here: -->
+ <profile namespace="globus" key="maxtime">3600</profile> <!-- seconds -->
+ <profile namespace="globus" key="maxWalltime">00:05:00</profile> <!-- hh:mm:ss -->
+ <profile namespace="globus" key="slots">5</profile> <!-- Maximum number of pbs jobs -->
<profile namespace="globus" key="maxnodes">1</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
- <profile namespace="karajan" key="jobThrottle">4.80</profile>
+ <profile namespace="karajan" key="jobThrottle">4.80</profile> <!-- 480 active tasks -->
<profile namespace="karajan" key="initialScore">10000</profile>
<workdirectory>/lustre/beagle/{env.USER}/swiftwork</workdirectory>
</pool>
Modified: SwiftApps/Scattering/paintgrid/orthros.xml
--- SwiftApps/Scattering/paintgrid/orthros.xml 2013-08-08 21:43:00 UTC (rev 6811)
+++ SwiftApps/Scattering/paintgrid/orthros.xml 2013-08-08 22:02:57 UTC (rev 6812)
@@ -1,17 +1,32 @@
<config>
+ <pool handle="localhost">
+ <execution provider="coaster" jobmanager="local:local"/>
+ <profile namespace="karajan" key="jobThrottle">0</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local"/>
+ <workdirectory>{env.HOME}/swiftwork</workdirectory>
+ </pool>
<pool handle="orthros">
<execution provider="coaster" jobmanager="local:sge"/>
- <profile namespace="globus" key="jobsPerNode">1</profile>
- <profile namespace="globus" key="maxWalltime">00:15:00</profile>
+ <profile namespace="globus" key="jobsPerNode">1</profile> <!-- apps per node. On orthros, a node=1 cpu -->
+ <profile namespace="globus" key="maxWalltime">00:15:00</profile> <!-- hh:mm:ss -->
+ <profile namespace="globus" key="maxtime">1200</profile> <!-- seconds -->
+ <profile namespace="globus" key="slots">10</profile> <!-- maximum number of SGE jobs -->
- <profile namespace="globus" key="slots">10</profile>
+ <!-- Define queue and parallel environment -->
<profile namespace="globus" key="queue">sec1all.q</profile>
<profile namespace="globus" key="pe">sec1_all</profile>
- <profile namespace="globus" key="maxtime">1200</profile>
<profile namespace="globus" key="jobThrottle">10.00</profile>
+ <!-- Set data staging model and work dir here: -->
- <workdirectory>{env.HOME}/swiftwork</workdirectory>
+ <workdirectory>{env.HOME}/swiftwork</workdirectory> <!-- Use env variable HOME to set default work directory -->
</pool>
</config>
Modified: SwiftApps/Scattering/paintgrid/paintgrid.swift
--- SwiftApps/Scattering/paintgrid/paintgrid.swift 2013-08-08 21:43:00 UTC (rev 6811)
+++ SwiftApps/Scattering/paintgrid/paintgrid.swift 2013-08-08 22:02:57 UTC (rev 6812)
@@ -22,7 +22,7 @@
# Command line args to this script
file params <single_file_mapper;file=@arg("params", "genpoints.params")>;
-file image <single_file_mapper;file=@arg("image", "UNSPECIFIED.tif")>;
+file image <single_file_mapper;file=@arg("image", "data.0001.tiny")>;
global string runTime = @arg("runTime","0.0");
global string runDir = @java("java.lang.System","getProperty","user.dir");
Modified: SwiftApps/Scattering/paintgrid/sites.xml
--- SwiftApps/Scattering/paintgrid/sites.xml 2013-08-08 21:43:00 UTC (rev 6811)
+++ SwiftApps/Scattering/paintgrid/sites.xml 2013-08-08 22:02:57 UTC (rev 6812)
@@ -1,9 +1,19 @@
<config>
- <profile namespace="karajan" key="jobThrottle">0</profile>
+ <profile namespace="karajan" key="jobThrottle">0</profile> <!-- Since running locally, set a maximum of 1 active job -->
</pool>
+ <pool handle="local">
+ </pool>
</config>
More information about the Swift-commit
