[Swift-commit] r6804 - SwiftApps/Scattering/paintgrid/docs
    davidk at ci.uchicago.edu
    Thu Aug  8 13:18:20 CDT 2013
Author: davidk
Date: 2013-08-08 13:18:19 -0500 (Thu, 08 Aug 2013)
New Revision: 6804
Added:
   SwiftApps/Scattering/paintgrid/docs/tutorial.html
Modified:
   SwiftApps/Scattering/paintgrid/docs/README
   SwiftApps/Scattering/paintgrid/docs/build_docs.sh
Log:
x bit for build_docs.sh
Adding html output
Intro setup material for readme
Modified: SwiftApps/Scattering/paintgrid/docs/README
--- SwiftApps/Scattering/paintgrid/docs/README	2013-08-08 18:08:53 UTC (rev 6803)
+++ SwiftApps/Scattering/paintgrid/docs/README	2013-08-08 18:18:19 UTC (rev 6804)
@@ -1,15 +1,31 @@
-Demo / tutorial application to mimic the needs of the PaintGrid application
+Demo / tutorial PaintGrid application
-Setup:
+PaintGrid tutorial setup
-  $ PATH=/clhome/WILDE/swift/rev/swift-0.94.1/bin:$PATH
+Check out scripts from SVN
+To checkout the most recent PaintGrid tutorial scripts from SVN, run the following command:
-Create a test data file:
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/Scattering/paintgrid
+This will create a directory called paintgrid which contains all of the scripts mentioned in this document.
-  $ dd bs=8M  count=1 if=/dev/zero of=data.0001.tif
-  $ dd bs=800 count=1 if=/dev/zero of=data.0001.tiny
+Run setup
+Once the scripts are checked out, run the following commands to perform
+the initial setup.
+$ cd paintgrid          # change to the newly created paintgrid directory
+$ source setup.sh       # Updates PATH and creates a configuration file in $HOME/.swift
+NOTE: If you disconnect from the machine, you will need to re-run source setup.sh.
 Run the Swift script:
   $ mkdir ~/swift
Property changes on: SwiftApps/Scattering/paintgrid/docs/build_docs.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/Scattering/paintgrid/docs/tutorial.html
--- SwiftApps/Scattering/paintgrid/docs/tutorial.html	                        (rev 0)
+++ SwiftApps/Scattering/paintgrid/docs/tutorial.html	2013-08-08 18:18:19 UTC (rev 6804)
@@ -0,0 +1,683 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"
+    "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
+<head>
+<meta http-equiv="Content-Type" content="application/xhtml+xml; charset=UTF-8" />
+<meta name="generator" content="AsciiDoc 8.6.4" />
+<title>Demo / tutorial PaintGrid application</title>
+<style type="text/css">
+/* Sans-serif font. */
+h1, h2, h3, h4, h5, h6,
+div.title, caption.title,
+thead, p.table.header,
+div#toctitle,
+span#author, span#revnumber, span#revdate, span#revremark,
+div#footer {
+  font-family: Arial,Helvetica,sans-serif;
+/* Serif font. */
+div.sectionbody {
+  font-family: Georgia,"Times New Roman",Times,serif;
+/* Monospace font. */
+tt {
+  font-size: inherit;
+body {
+  margin: 1em 5% 1em 5%;
+a {
+  color: blue;
+  text-decoration: underline;
+a:visited {
+  color: fuchsia;
+em {
+  font-style: italic;
+  color: navy;
+strong {
+  font-weight: bold;
+  color: #083194;
+tt {
+  color: navy;
+h1, h2, h3, h4, h5, h6 {
+  color: #527bbd;
+  margin-top: 1.2em;
+  margin-bottom: 0.5em;
+  line-height: 1.3;
+h1, h2, h3 {
+  border-bottom: 2px solid silver;
+h2 {
+  padding-top: 0.5em;
+h3 {
+  float: left;
+h3 + * {
+  clear: left;
+div.sectionbody {
+  margin-left: 0;
+hr {
+  border: 1px solid silver;
+p {
+  margin-top: 0.5em;
+ul, ol, li > p {
+  margin-top: 0;
+ul > li     { color: #aaa; }
+ul > li > * { color: black; }
+pre {
+  padding: 0;
+  margin: 0;
+span#author {
+  color: #527bbd;
+  font-size: 1.1em;
+span#email {
+span#revnumber, span#revdate, span#revremark {
+div#footer {
+  font-size: small;
+  border-top: 2px solid silver;
+  margin-top: 4.0em;
+div#footer-text {
+  float: left;
+  padding-bottom: 0.5em;
+div#footer-badges {
+  float: right;
+div#preamble {
+  margin-top: 1.5em;
+  margin-bottom: 1.5em;
+div.tableblock, div.imageblock, div.exampleblock, div.verseblock,
+div.quoteblock, div.literalblock, div.listingblock, div.sidebarblock,
+div.admonitionblock {
+  margin-top: 1.0em;
+  margin-top: 2.0em;
+  margin-bottom: 2.0em;
+  margin-right: 10%;
+  color: #606060;
+div.content { /* Block element content. */
+  padding: 0;
+/* Block element titles. */
+div.title, caption.title {
+  color: #527bbd;
+  text-align: left;
+div.title + * {
+  margin-top: 0;
+td div.title:first-child {
+  margin-top: 0.0em;
+div.content div.title:first-child {
+div.content + div.title {
+div.sidebarblock > div.content {
+  background: #ffffee;
+  border: 1px solid #dddddd;
+  border-left: 4px solid #f0f0f0;
+  padding: 0.5em;
+div.listingblock > div.content {
+  border-left: 5px solid #f0f0f0;
+  background: #f8f8f8;
+  padding: 0.5em;
+div.quoteblock, div.verseblock {
+  padding-left: 1.0em;
+  margin-left: 1.0em;
+  color: #777777;
+div.quoteblock > div.attribution {
+  text-align: right;
+div.verseblock > pre.content {
+  font-family: inherit;
+div.verseblock > div.attribution {
+  padding-top: 0.75em;
+  text-align: left;
+/* DEPRECATED: Pre version 8.2.7 verse style literal block. */
+div.verseblock + div.attribution {
+  text-align: left;
+div.admonitionblock .icon {
+  vertical-align: top;
+  font-size: 1.1em;
+  color: #527bbd;
+  padding-right: 0.5em;
+div.admonitionblock td.content {
+  padding-left: 0.5em;
+  border-left: 3px solid #dddddd;
+div.exampleblock > div.content {
+div.imageblock div.content { padding-left: 0; }
+span.image img { border-style: none; }
+a.image:visited { color: white; }
+dl {
+  margin-top: 0.8em;
+  margin-bottom: 0.8em;
+dt {
+  margin-bottom: 0;
+  font-style: normal;
+  color: navy;
+dd > *:first-child {
+  margin-top: 0.1em;
+ul, ol {
+    list-style-position: outside;
+ol.arabic {
+  list-style-type: decimal;
+ol.loweralpha {
+  list-style-type: lower-alpha;
+ol.upperalpha {
+  list-style-type: upper-alpha;
+ol.lowerroman {
+  list-style-type: lower-roman;
+ol.upperroman {
+  list-style-type: upper-roman;
+div.compact ul, div.compact ol,
+div.compact p, div.compact p,
+div.compact div, div.compact div {
+  margin-bottom: 0.1em;
+div.tableblock > table {
+  border: 3px solid #527bbd;
+thead, p.table.header {
+  color: #527bbd;
+tfoot {
+td > div.verse {
+  white-space: pre;
+p.table {
+  margin-top: 0;
+/* Because the table frame attribute is overriden by CSS in most browsers. */
+div.tableblock > table[frame="void"] {
+  border-style: none;
+div.tableblock > table[frame="hsides"] {
+  border-left-style: none;
+  border-right-style: none;
+div.tableblock > table[frame="vsides"] {
+  border-top-style: none;
+  border-bottom-style: none;
+div.hdlist {
+div.hdlist tr {
+  padding-bottom: 15px;
+dt.hdlist1.strong, td.hdlist1.strong {
+td.hdlist1 {
+  padding-right: 0.8em;
+  color: navy;
+td.hdlist2 {
+div.hdlist.compact tr {
+  margin: 0;
+  padding-bottom: 0;
+.comment {
+  background: yellow;
+.footnote, .footnoteref {
+  font-size: 0.8em;
+span.footnote, span.footnoteref {
+  vertical-align: super;
+#footnotes {
+  margin: 20px 0 20px 0;
+  padding: 7px 0 0 0;
+#footnotes div.footnote {
+  margin: 0 0 5px 0;
+#footnotes hr {
+  border: none;
+  border-top: 1px solid silver;
+  height: 1px;
+  text-align: left;
+  margin-left: 0;
+  width: 20%;
+  min-width: 100px;
+div.colist td {
+  padding-bottom: 0.3em;
+div.colist td img {
+  margin-top: 0.3em;
+ at media print {
+  div#footer-badges { display: none; }
+div#toc {
+  margin-bottom: 2.5em;
+div#toctitle {
+  color: #527bbd;
+  font-size: 1.1em;
+div.toclevel1, div.toclevel2, div.toclevel3, div.toclevel4 {
+  margin-top: 0;
+  margin-bottom: 0;
+div.toclevel2 {
+  margin-left: 2em;
+  font-size: 0.9em;
+div.toclevel3 {
+  margin-left: 4em;
+  font-size: 0.9em;
+div.toclevel4 {
+  margin-left: 6em;
+  font-size: 0.9em;
+span.aqua { color: aqua; }
+span.black { color: black; }
+span.blue { color: blue; }
+span.fuchsia { color: fuchsia; }
+span.gray { color: gray; }
+span.green { color: green; }
+span.lime { color: lime; }
+span.maroon { color: maroon; }
+span.navy { color: navy; }
+span.olive { color: olive; }
+span.purple { color: purple; }
+span.red { color: red; }
+span.silver { color: silver; }
+span.teal { color: teal; }
+span.white { color: white; }
+span.yellow { color: yellow; }
+span.aqua-background { background: aqua; }
+span.black-background { background: black; }
+span.blue-background { background: blue; }
+span.fuchsia-background { background: fuchsia; }
+span.gray-background { background: gray; }
+span.green-background { background: green; }
+span.lime-background { background: lime; }
+span.maroon-background { background: maroon; }
+span.navy-background { background: navy; }
+span.olive-background { background: olive; }
+span.purple-background { background: purple; }
+span.red-background { background: red; }
+span.silver-background { background: silver; }
+span.teal-background { background: teal; }
+span.white-background { background: white; }
+span.yellow-background { background: yellow; }
+span.big { font-size: 2em; }
+span.small { font-size: 0.6em; }
+a:link { color:navy; }
+a:visited { color:navy; }
+</style>
+<script type="text/javascript">
+    // Function that scans the DOM tree for header elements (the DOM2
+    // nodeIterator API would be a better technique but not supported by all
+    // browsers).
+    var iterate = function (el) {
+      for (var i = el.firstChild; i != null; i = i.nextSibling) {
+        if (i.nodeType == 1 /* Node.ELEMENT_NODE */) {
+          var mo = re.exec(i.tagName);
+          if (mo && (i.getAttribute("class") || i.getAttribute("className")) != "float") {
+            result[result.length] = new TocEntry(i, getText(i), mo[1]-1);
+          iterate(i);
+    iterate(el);
+    return result;
+  var toc = document.getElementById("toc");
+  var entries = tocEntries(document.getElementById("content"), toclevels);
+  for (var i = 0; i < entries.length; ++i) {
+    var entry = entries[i];
+    if (entry.element.id == "")
+      entry.element.id = "_toc_" + i;
+    var a = document.createElement("a");
+    a.href = "#" + entry.element.id;
+    a.appendChild(document.createTextNode(entry.text));
+    var div = document.createElement("div");
+    div.appendChild(a);
+    div.className = "toclevel" + entry.toclevel;
+    toc.appendChild(div);
+  if (entries.length == 0)
+    toc.parentNode.removeChild(toc);
+// Footnotes generator
+/* Based on footnote generation code from:
+ * http://www.brandspankingnew.net/archive/2005/07/format_footnote.html
+footnotes: function () {
+  var cont = document.getElementById("content");
+  var noteholder = document.getElementById("footnotes");
+  var spans = cont.getElementsByTagName("span");
+  var refs = {};
+  var n = 0;
+  for (i=0; i<spans.length; i++) {
+    if (spans[i].className == "footnote") {
+      n++;
+      // Use [\s\S] in place of . so multi-line matches work.
+      // Because JavaScript has no s (dotall) regex flag.
+      note = spans[i].innerHTML.match(/\s*\[([\s\S]*)]\s*/)[1];
+      noteholder.innerHTML +=
+        "<div class='footnote' id='_footnote_" + n + "'>" +
+        "<a href='#_footnoteref_" + n + "' title='Return to text'>" +
+        n + "</a>. " + note + "</div>";
+      spans[i].innerHTML =
+        "[<a id='_footnoteref_" + n + "' href='#_footnote_" + n +
+        "' title='View footnote' class='footnote'>" + n + "</a>]";
+      var id =spans[i].getAttribute("id");
+      if (id != null) refs["#"+id] = n;
+  if (n == 0)
+    noteholder.parentNode.removeChild(noteholder);
+  else {
+    // Process footnoterefs.
+      if (spans[i].className == "footnoteref") {
+        var href = spans[i].getElementsByTagName("a")[0].getAttribute("href");
+        href = href.match(/#.*/)[0];  // Because IE return full URL.
+        n = refs[href];
+          "[<a href='#_footnote_" + n +
+</script>
+</head>
+<body class="article" style="max-width:800px">
+<div id="header">
+<h1>Demo / tutorial PaintGrid application</h1>
+<div id="toc">
+  <div id="toctitle">Table of Contents</div>
+  <noscript><p><b>JavaScript must be enabled in your browser to display the table of contents.</b></p></noscript>
+</div>
+</div>
+<div id="content">
+<div class="sect1">
+<h2 id="_paintgrid_tutorial_setup">PaintGrid tutorial setup</h2>
+<div class="sectionbody">
+<div class="sect2">
+<h3 id="_check_out_scripts_from_svn">Check out scripts from SVN</h3>
+<div class="paragraph"><p>To checkout the most recent PaintGrid tutorial scripts from SVN, run the following command:</p></div>
+<div class="listingblock">
+<div class="content">
+<pre><tt>$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/Scattering/paintgrid</tt></pre>
+</div></div>
+<div class="paragraph"><p>This will create a directory called paintgrid which contains all of the scripts mentioned in this document.</p></div>
+</div>
+<h3 id="_run_setup">Run setup</h3>
+<div class="paragraph"><p>Once the scripts are checked out, run the following commands to perform
+the initial setup.</p></div>
+<pre><tt>$ cd paintgrid          # change to the newly created paintgrid directory
+$ source setup.sh       # Updates PATH and creates a configuration file in $HOME/.swift</tt></pre>
+</div></div>
+<div class="admonitionblock">
+<table><tr>
+<td class="icon">
+<div class="title">Note</div>
+</td>
+<td class="content">If you disconnect from the machine, you will need to re-run source setup.sh.</td>
+</tr></table>
+</div>
+<div class="paragraph"><p>Run the Swift script:</p></div>
+<div class="literalblock">
+<pre><tt>$ mkdir ~/swift
+$ cp swift.properties ~/.swift</tt></pre>
+</div></div>
+<pre><tt>$ swift -tc.file apps -sites.file amd.xml paintgrid.swift -runDir=$PWD -params=genpoints.params -image=data.0001.tiny</tt></pre>
+</div></div>
+<div class="paragraph"><p>TODO:</p></div>
+<div class="paragraph"><p>Execution scenarios:</p></div>
+<pre><tt>run.local.sh</tt></pre>
+</div></div>
+<pre><tt>run.beagle.sh</tt></pre>
+</div></div>
+<pre><tt>run.midway.sh</tt></pre>
+</div></div>
+<pre><tt>run.midway+beagle.sh</tt></pre>
+</div></div>
+<pre><tt>run.blues.sh</tt></pre>
+</div></div>
+<pre><tt>run.orthros.sh</tt></pre>
+</div></div>
+<div class="paragraph"><p>Data transfer models:</p></div>
+<div class="ulist"><ul>
+<li>
+<p>
+provider staging without caching
+</p>
+</li>
+<li>
+<p>
+provider staging with ad-hoc caching of big common files
+</p>
+</li>
+<li>
+<p>
+gridftp staging
+</p>
+</li>
+<li>
+<p>
+ssh (scp) staging
+</p>
+</li>
+<li>
+<p>
+wrapper staging with scp and caching
+</p>
+</li>
+</ul></div>
+</div>
+</div>
+</div>
+</div>
+<div id="footnotes"><hr /></div>
+<div id="footer">
+<div id="footer-text">
+Last updated 2013-08-08 13:12:10 CDT
+</div>
+</div>
+</body>
+</html>
More information about the Swift-commit
