[Swift-commit] r6799 - trunk/libexec/log-processing
ketan at ci.uchicago.edu
Thu Aug 8 10:24:55 CDT 2013
Author: ketan
Date: 2013-08-08 10:24:54 -0500 (Thu, 08 Aug 2013)
New Revision: 6799
Added:
trunk/libexec/log-processing/plotswiftlogs.ketan
Log:
plotting script version ketan
Added: trunk/libexec/log-processing/plotswiftlogs.ketan
--- trunk/libexec/log-processing/plotswiftlogs.ketan (rev 0)
+++ trunk/libexec/log-processing/plotswiftlogs.ketan 2013-08-08 15:24:54 UTC (rev 6799)
@@ -0,0 +1,67 @@
+#!/bin/bash
+#usage: ./extract4plots <swift.logfile>
+SWIFTLOGFILE=$1
+#TMPDIR=`mktemp -d plotlog.XXX`
+grep -i ProgressTicker $SWIFTLOGFILE > swiftoutfile.out
+SWIFTOUTFILE=swiftoutfile.out
+#extract start time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | head -n 1 | cut -f1-2 -d ' '`
+START_TIME=`date +%s -d "$TMPDATE"`
+#extract end time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | tail -n 1 | cut -f1-2 -d ' '`
+END_TIME=`date +%s -d "$TMPDATE"`
+#duration
+DIFFTIME=$((END_TIME - START_TIME))
+#extract active runs in a file
+(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' >active.txt)
+#extract successful completions in a file
+(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > cumulative.txt)
+#prepare tics
+activelines=`wc -l active.txt | awk '{print $1}'`
+cumulines=`wc -l cumulative.txt | awk '{print $1}'`
+if [ $activelines -ne 0 ]
+then
+ activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
+fi
+seq 0 $activelinespertic $DIFFTIME > activetics.txt
+if [ $cumulines -ne 0 ]
+then
+ cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
+fi
+seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
+#final plot data
+paste activetics.txt active.txt > plot_active.txt
+paste cumultics.txt cumulative.txt > plot_cumulative.txt
+cat << EOF1 > plotit.gp
+set terminal png enhanced
+set output "activeplot.png"
+set nokey
+set xlabel "Time in sec"
+set ylabel "number of active jobs"
+set title "Active jobs"
+plot "plot_active.txt" using 1:2 with line
+set output "cumulativeplot.png"
+set ylabel "number of completed jobs"
+set title "Cumulative jobs"
+plot "plot_cumulative.txt" using 1:2 with lines
+EOF1
+gnuplot plotit.gp 2>/dev/null
Property changes on: trunk/libexec/log-processing/plotswiftlogs.ketan
___________________________________________________________________
Added: svn:executable
More information about the Swift-commit
