[Swift-commit] r6777 - in SwiftTutorials/ATPESC_2013-08-06/modis:	bin modis01 modis02 modis03 modis04 modis05 modis06
    davidk at ci.uchicago.edu
    Mon Aug  5 17:47:27 CDT 2013
Author: davidk
Date: 2013-08-05 17:47:27 -0500 (Mon, 05 Aug 2013)
New Revision: 6777
Modified:
   SwiftTutorials/ATPESC_2013-08-06/modis/bin/assemble.sh
   SwiftTutorials/ATPESC_2013-08-06/modis/bin/colormodis.sh
   SwiftTutorials/ATPESC_2013-08-06/modis/modis01/modis01.swift
   SwiftTutorials/ATPESC_2013-08-06/modis/modis02/modis02.swift
   SwiftTutorials/ATPESC_2013-08-06/modis/modis03/modis03.swift
   SwiftTutorials/ATPESC_2013-08-06/modis/modis04/modis04.swift
   SwiftTutorials/ATPESC_2013-08-06/modis/modis05/modis05.swift
   SwiftTutorials/ATPESC_2013-08-06/modis/modis06/modis06.swift
Log:
Use a subset of data rather than all global data
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/bin/assemble.sh
--- SwiftTutorials/ATPESC_2013-08-06/modis/bin/assemble.sh	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/bin/assemble.sh	2013-08-05 22:47:27 UTC (rev 6777)
@@ -1,48 +1,25 @@
-#!/bin/bash
+#!/bin/bash -x
-output=$(cd $(dirname $1); echo $PWD/$(basename $1))     # Full pathname of output file
-selected=$(cd $(dirname $2); echo $PWD/$(basename $2))   # Full pathname of input text file "selected"
-indir=$(cd $(dirname $3); echo $PWD/$(basename $3))      # Full pathname of image input dir
-echo output=$output
-echo selected=$selected
-echo indir=$indir
+output=shift
+output=$(cd $(dirname $output); echo $PWD/$(basename $output))     # Full pathname of output file
 tmpdir=$( eval mktemp -d $PWD/modis.assemble.XXXX )
 bindir=$(cd $(dirname $0); pwd)
-graytile=$bindir/gray.rgb
 # input files are expected to start with hNNvNN.
 # we reverse this to form the final image
-cd $indir
-for h in {0..35}; do
-   h=$( printf %02d $h );
-   for v in {0..17}; do
-      v=$( printf %02d $v );
-      hv=h${h}v${v}
-      vh=v${v}h${h}
-      # Use graytile if the expected section is not found
-      if [ ! -f $indir/$hv.color.rgb ]; then
-         echo $indir/$hv.color.rgb does not exist
-         cp $graytile $tmpdir
-         mv $tmpdir/gray.rgb $tmpdir/$vh.rgb
-      # Otherwise, downscale input images
-      #elif grep $hv $selected >&/dev/null; then
-      #   convert $hv.png -resize 290x290 $tmpdir/t.png
-      #   convert $tmp/t.png -bordercolor red -border 5x5 $tmpdir/$vh.png
-      else
-         # $bindir/rgb_downscale.pl $indir/$hv.color.rgb 2400 2400 8 $tmpdir/$vh.rgb
-         cp $indir/$hv.color.rgb $tmpdir/$vh.rgb
-      fi
-  done
+while [ $# -gt 0 ]
+do
+   file=$1
+   shift
+   h=$( basename $file | cut -c2-3 )
+   v=$( basename $file | cut -c5-6 )
+   vh=v"$v"h"$h"
+   cp $file $tmpdir/$vh.rgb
 done
-$bindir/montage.pl 36 18 100 100 $tmpdir/v*
-$bindir/rgb_to_png.py map.rgb 3600 1800 ../map.png
+cd $tmpdir
+$bindir/montage.pl 5 5 200 200 v*
+$bindir/rgb_to_png.py map.rgb 1000 1000 ../map.png
 exit 0
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/bin/colormodis.sh
--- SwiftTutorials/ATPESC_2013-08-06/modis/bin/colormodis.sh	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/bin/colormodis.sh	2013-08-05 22:47:27 UTC (rev 6777)
@@ -7,7 +7,7 @@
 infile=$1
 outfile=$2
-scale=${3-24}
+scale=${3-12}
 xres=${4-2400}
 yres=${5-2400}
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/modis01/modis01.swift
--- SwiftTutorials/ATPESC_2013-08-06/modis/modis01/modis01.swift	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/modis01/modis01.swift	2013-08-05 22:47:27 UTC (rev 6777)
@@ -6,6 +6,6 @@
   getlanduse @filename(input) stdout=@filename(output);
-imagefile modisImage <"data/global/h00v09.rgb">;
-landuse result <"landuse/h00v09.landuse.byfreq">;
+imagefile modisImage <"data/europe/h18v05.rgb">;
+landuse result <"landuse/h18v05.landuse.byfreq">;
 result = getLandUse(modisImage);
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/modis02/modis02.swift
--- SwiftTutorials/ATPESC_2013-08-06/modis/modis02/modis02.swift	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/modis02/modis02.swift	2013-08-05 22:47:27 UTC (rev 6777)
@@ -8,7 +8,7 @@
 # Constants and command line arguments
 int nFiles       = @toInt(@arg("nfiles", "1000"));
-string MODISdir  = @arg("modisdir", "data/global");
+string MODISdir  = @arg("modisdir", "data/europe");
 # Input Dataset
 imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=nFiles>;
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/modis03/modis03.swift
--- SwiftTutorials/ATPESC_2013-08-06/modis/modis03/modis03.swift	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/modis03/modis03.swift	2013-08-05 22:47:27 UTC (rev 6777)
@@ -16,7 +16,7 @@
 int nSelect      = @toInt(@arg("nselect", "10"));
 string landType  = @arg("landtype", "urban");
 # Input Dataset
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/modis04/modis04.swift
--- SwiftTutorials/ATPESC_2013-08-06/modis/modis04/modis04.swift	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/modis04/modis04.swift	2013-08-05 22:47:27 UTC (rev 6777)
@@ -21,7 +21,7 @@
 # Input Dataset
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/modis05/modis05.swift
--- SwiftTutorials/ATPESC_2013-08-06/modis/modis05/modis05.swift	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/modis05/modis05.swift	2013-08-05 22:47:27 UTC (rev 6777)
@@ -26,7 +26,7 @@
 # Input Dataset
Modified: SwiftTutorials/ATPESC_2013-08-06/modis/modis06/modis06.swift
--- SwiftTutorials/ATPESC_2013-08-06/modis/modis06/modis06.swift	2013-08-05 22:26:00 UTC (rev 6776)
+++ SwiftTutorials/ATPESC_2013-08-06/modis/modis06/modis06.swift	2013-08-05 22:47:27 UTC (rev 6777)
@@ -22,16 +22,16 @@
   colormodis @input @output;
-app (imagefile mon, file o, file e) assemble (file tiles, imagefile images[], string data_dir)
+app (imagefile mon) assemble (imagefile images[])
-   assemble @filename(o) @filename(tiles) data_dir stdout=@filename(o) stderr=@filename(e);
+   assemble @filename(mon) @filenames(images);
 # Input Dataset
@@ -61,7 +61,5 @@
 # Assemble a montage of the top selected areas
 imagefile montage<"map.png">; # @arg
-file assemble_olog <"logs/assemble.o.log">;
-file assemble_elog <"logs/assemble.e.log">;
-(montage, assemble_olog, assemble_elog) = assemble(selectedTiles, colorImage, "colorImages");
+montage = assemble(colorImage);
More information about the Swift-commit
