[Swift-commit] r6736 - in SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r: . code
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Sun Aug 4 10:04:10 CDT 2013
Author: wozniak
Date: 2013-08-04 10:04:10 -0500 (Sun, 04 Aug 2013)
New Revision: 6736
Added:
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.py
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.swift
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/numpy.swift
Removed:
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.py
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift
Log:
Move code to code/
Copied: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.py (from rev 6734, SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.py)
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.py	                        (rev 0)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.py	2013-08-04 15:04:10 UTC (rev 6736)
@@ -0,0 +1,24 @@
+from numpy import *
+N = 3
+U = 7
+s = repr(eye(3))
+print(eval(s)*2)
+dets = zeros(U-1)
+for i in range(1,U):
+    A = ones(N)
+    A = A + i*eye(N)
+    A[2,0] = (U-i+1)**3
+    print(A)
+    d = linalg.det(A)
+    print(d)
+    dets[i-1] = abs(d)
+    print
+print(dets)
+print(max(dets))
Copied: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.swift (from rev 6734, SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift)
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/dets.swift	2013-08-04 15:04:10 UTC (rev 6736)
@@ -0,0 +1,32 @@
+import io;
+import math;
+import python;
+import string;
+import R;
+import numpy;
+global const int N = 3;
+global const int U = 7;
+main
+  // Define our collection of determinants:
+  float dets[];
+  foreach i in [1:U-1]
+    // For U, i, construct a matrix via Numpy:
+    A = matrix_add(matrix_scale(eye(N), itof(i)), ones(N));
+    B = matrix_set(A, 2, 0, (U-i+1)**3);
+    // Obtain its determinant via Numpy:
+    v = determinant(B);
+    // Store the determinant in a Swift array:
+    dets[i] = abs_float(v);
+  // Build a fragment of R code with the dets:
+  code = sprintf("max(%s)", string_from_floats(dets));
+  r = R(code);
+  printf("max: %f", r);
Copied: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/numpy.swift (from rev 6734, SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift)
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/numpy.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/code/numpy.swift	2013-08-04 15:04:10 UTC (rev 6736)
@@ -0,0 +1,58 @@
+global const string numpy = "from numpy import *\n\n";
+typedef matrix string;
+(matrix A) eye(int n)
+  string command = sprintf("repr(eye(%i))", n);
+  string code = numpy+command;
+  matrix t = python(code);
+  A = replace_all(t, "\n", "", 0);
+(matrix A) ones(int n)
+  string command = sprintf("repr(ones(%i))", n);
+(matrix M) matrix_scale(matrix A, float s)
+  string command = sprintf("repr(%s*%s)", A, s);
+  M = replace_all(t, "\n", "", 0);
+(matrix M) matrix_set(matrix A, int row, int column, float s)
+  string fragment =
+A = %s
+A[%i,%i] = %f
+repr(A)
+  string command = sprintf(fragment, A, row, column, s);
+(matrix M) matrix_add(matrix A1, matrix A2)
+  string command = sprintf("repr(%s+%s)", A1, A2);
+(float d) determinant(matrix A)
+  string command = sprintf("repr(linalg.det(%s))", A);
+  string t = python(code);
+  d = tofloat(t);
Deleted: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.py
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.py	2013-08-04 15:02:08 UTC (rev 6735)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.py	2013-08-04 15:04:10 UTC (rev 6736)
@@ -1,24 +0,0 @@
-from numpy import *
-N = 3
-U = 7
-s = repr(eye(3))
-print(eval(s)*2)
-dets = zeros(U-1)
-for i in range(1,U):
-    A = ones(N)
-    A = A + i*eye(N)
-    A[2,0] = (U-i+1)**3
-    print(A)
-    d = linalg.det(A)
-    print(d)
-    dets[i-1] = abs(d)
-    print
-print(dets)
-print(max(dets))
Deleted: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift	2013-08-04 15:02:08 UTC (rev 6735)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift	2013-08-04 15:04:10 UTC (rev 6736)
@@ -1,32 +0,0 @@
-import io;
-import math;
-import python;
-import string;
-import R;
-import numpy;
-global const int N = 3;
-global const int U = 7;
-main
-  // Define our collection of determinants:
-  float dets[];
-  foreach i in [1:U-1]
-    // For U, i, construct a matrix via Numpy:
-    A = matrix_add(matrix_scale(eye(N), itof(i)), ones(N));
-    B = matrix_set(A, 2, 0, (U-i+1)**3);
-    // Obtain its determinant via Numpy:
-    v = determinant(B);
-    // Store the determinant in a Swift array:
-    dets[i] = abs_float(v);
-  // Build a fragment of R code with the dets:
-  code = sprintf("max(%s)", string_from_floats(dets));
-  r = R(code);
-  printf("max: %f", r);
Deleted: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift	2013-08-04 15:02:08 UTC (rev 6735)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift	2013-08-04 15:04:10 UTC (rev 6736)
@@ -1,58 +0,0 @@
-global const string numpy = "from numpy import *\n\n";
-typedef matrix string;
-(matrix A) eye(int n)
-  string command = sprintf("repr(eye(%i))", n);
-  string code = numpy+command;
-  matrix t = python(code);
-  A = replace_all(t, "\n", "", 0);
-(matrix A) ones(int n)
-  string command = sprintf("repr(ones(%i))", n);
-(matrix M) matrix_scale(matrix A, float s)
-  string command = sprintf("repr(%s*%s)", A, s);
-  M = replace_all(t, "\n", "", 0);
-(matrix M) matrix_set(matrix A, int row, int column, float s)
-  string fragment =
-A = %s
-A[%i,%i] = %f
-repr(A)
-  string command = sprintf(fragment, A, row, column, s);
-(matrix M) matrix_add(matrix A1, matrix A2)
-  string command = sprintf("repr(%s+%s)", A1, A2);
-(float d) determinant(matrix A)
-  string command = sprintf("repr(linalg.det(%s))", A);
-  string t = python(code);
-  d = tofloat(t);
