[Swift-commit] r6732 - in branches/release-0.94/tests/stress/IO:	beagle multiple uc3
    yadunandb at ci.uchicago.edu
    Sat Aug  3 17:59:23 CDT 2013
Author: yadunandb
Date: 2013-08-03 17:59:23 -0500 (Sat, 03 Aug 2013)
New Revision: 6732
Added:
   branches/release-0.94/tests/stress/IO/beagle/z_stats.clean.sh
   branches/release-0.94/tests/stress/IO/beagle/z_stats.swift
   branches/release-0.94/tests/stress/IO/multiple/z_stats.clean.sh
   branches/release-0.94/tests/stress/IO/multiple/z_stats.swift
   branches/release-0.94/tests/stress/IO/uc3/z_stats.clean.sh
   branches/release-0.94/tests/stress/IO/uc3/z_stats.swift
Removed:
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.setup.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.source.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.swift
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.timeout
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.setup.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.source.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.swift
   branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.timeout
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.setup.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.source.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.swift
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.timeout
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.setup.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.source.sh
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.swift
   branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.timeout
Log:
Committing updates for tests
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.setup.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.setup.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.setup.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,40 +0,0 @@
-#!/bin/bash
-ARGS_FILE=${0%.setup.sh}.args
-BEAGLE_USERNAME=$BEAGLE_USERNAME
-case $STRESS in
-    "S1")
-        SIZE=300
-        LOOPS=0
-    "S2")
-        SIZE=500
-        LOOPS=0
-        SIZE=300
-        LOOPS=0
-esac
-echo "-loops=$LOOPS -size=$SIZE " > $ARGS_FILE
-cat <<'EOF' > filemaker.sh
-#!/bin/bash
-echo "From filemaker.sh $1 $2 on Host:$HOSTNAME"
-MAXSIZE=$1
-OUT=$2
-dd if=/dev/zero of=$OUT bs=1024 count=0 seek=$((1024*MAXSIZE))
-EOF
-if [[ -z $BEAGLE_USERNAME ]]
-then
-    echo "Remote username not provided. Skipping sites configs"
-else
-    ls *xml
-    cat sites.xml  | sed "s/{env.USER}/$BEAGLE_USERNAME/" > tmp && mv tmp sites.xml
-fi
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.source.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.source.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.source.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,8 +0,0 @@
-#!/bin/bash
-if [ "midway001" == "midway001" ]
-then
-   export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
-   export GLOBUS_TCP_PORT_RANGE=50000,51000
-fi;
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.swift
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.swift	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.swift	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,17 +0,0 @@
-type file;
-file script  <"filemaker.sh">;
-app (file out, file log) remote_driver (file run, int size)
-    bash @run size @out stdout=@filename(log);
-file driver_out[] <simple_mapper; prefix="driver", suffix=".out">;
-file driver_log[] <simple_mapper; prefix="driver", suffix=".log">;
-int filesize = @toInt(@arg("size","10"));
-int loop = @toInt(@arg("loops","0"));
-foreach item,i in [0:loop] {
-        (driver_out[i], driver_log[i]) = remote_driver(script, filesize);
\ No newline at end of file
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.timeout
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.timeout	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remote1x3.timeout	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1 +0,0 @@
-600
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.setup.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.setup.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.setup.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,39 +0,0 @@
-#!/bin/bash
-case $STRESS in
-    "S1")
-        SIZE=10
-        LOOPS=100
-    "S2")
-        SIZE=15
-        LOOPS=100
-        SIZE=10
-        LOOPS=100
-esac
-#!/bin/bash
-MAXSIZE=$1
-OUT=$2
-EOF
-then
-else
-    ls *xml
-fi
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.source.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.source.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.source.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,8 +0,0 @@
-#!/bin/bash
-then
-fi;
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.swift
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.swift	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.swift	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,17 +0,0 @@
-type file;
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.timeout
--- branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.timeout	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_from_remoteNx3.timeout	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1 +0,0 @@
-600
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.setup.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.setup.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.setup.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,47 +0,0 @@
-#!/bin/bash
-case $STRESS in
-        FILES=500
-        LOOPS=0
-esac
-dd if=/dev/zero of=dummy bs=1024 count=0 seek=$((1024*FILES))
-echo "-loops=$LOOPS" > $ARGS_FILE
-cat <<'EOF' > wrapper.sh
-#!/bin/bash
-ARG1=$1
-ls | grep "$1" &> /dev/null
-if [ $? == 0 ]
-then
-    echo "Hey this is wrapper and the $1 exists as a file";
-    ls -lah;
-else
-    echo "Doinks! the file we need isn't here";
-    ls -lah
-fi
-cat $ARG1 > $ARG1.test
-if [ $? == 0 ]
-then
-    echo "The cat worked! ";
-else
-    echo "The cat failed ";
-fi
-rm $ARG1 $ARG1.test
-echo "Residual files cleaned up"
-EOF
-then
-else
-    ls *xml
-fi
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.source.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.source.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.source.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,8 +0,0 @@
-#!/bin/bash
-then
-fi;
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.swift
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.swift	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.swift	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,17 +0,0 @@
-type file;
-file package <"dummy">;
-file script  <"wrapper.sh">;
-app (file out, file err) remote_driver (file run, file tar)
-    bash @run @filename(tar) stdout=@filename(out) stderr=@filename(err);
-file driver_err[] <simple_mapper; prefix="driver", suffix=".err">;
-        (driver_out[i], driver_err[i]) = remote_driver(script, package);
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.timeout
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.timeout	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remote1x3.timeout	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1 +0,0 @@
-600
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.setup.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.setup.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.setup.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,55 +0,0 @@
-#!/bin/bash
-case $STRESS in
-    "S1")
-        FILES=100
-        LOOPS=50
-    "S2")
-        FILES=100
-        LOOPS=100
-        FILES=100
-        LOOPS=50
-esac
-#!/bin/bash
-ARG1=$1
-if [ $? == 0 ]
-then
-    ls -lah;
-else
-    ls -lah
-fi
-if [ $? == 0 ]
-then
-else
-fi
-EOF
-then
-else
-    ls *xml
-fi
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.source.sh
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.source.sh	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.source.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,8 +0,0 @@
-#!/bin/bash
-then
-fi;
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.swift
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.swift	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.swift	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1,17 +0,0 @@
-type file;
-    bash @run @tar stdout=@out stderr=@err;
Deleted: branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.timeout
--- branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.timeout	2013-08-03 22:56:46 UTC (rev 6731)
+++ branches/release-0.94/tests/stress/IO/beagle/stage_to_remoteNx3.timeout	2013-08-03 22:59:23 UTC (rev 6732)
@@ -1 +0,0 @@
-1200
Added: branches/release-0.94/tests/stress/IO/beagle/z_stats.clean.sh
--- branches/release-0.94/tests/stress/IO/beagle/z_stats.clean.sh	                        (rev 0)
+++ branches/release-0.94/tests/stress/IO/beagle/z_stats.clean.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -0,0 +1,24 @@
+#!/bin/bash
+HOME=$PWD
+echo "Current test : $HOME"
+TESTS_HOME=$(dirname $HOME)
+echo "Tests home : $TESTS_HOME"
+ps -u $USER
+echo "Clearing all java instances"
+ps -u $USER | grep java
+if [ "$?" == "0" ]
+then
+    killall -u $USER java -9
+fi
+echo "Collecting stats"
+for test_case in `ls $TESTS_HOME | grep stage`
+do
+    echo "$test_case"
+    cat $TESTS_HOME/$test_case/*check.stdout
+    echo
+done
Property changes on: branches/release-0.94/tests/stress/IO/beagle/z_stats.clean.sh
___________________________________________________________________
Added: svn:executable
Added: branches/release-0.94/tests/stress/IO/beagle/z_stats.swift
--- branches/release-0.94/tests/stress/IO/beagle/z_stats.swift	                        (rev 0)
+++ branches/release-0.94/tests/stress/IO/beagle/z_stats.swift	2013-08-03 22:59:23 UTC (rev 6732)
@@ -0,0 +1 @@
+type file;
Added: branches/release-0.94/tests/stress/IO/multiple/z_stats.clean.sh
--- branches/release-0.94/tests/stress/IO/multiple/z_stats.clean.sh	                        (rev 0)
+++ branches/release-0.94/tests/stress/IO/multiple/z_stats.clean.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -0,0 +1,24 @@
+#!/bin/bash
+HOME=$PWD
+ps -u $USER
+if [ "$?" == "0" ]
+then
+fi
+do
+    echo "$test_case"
+    echo
+done
Property changes on: branches/release-0.94/tests/stress/IO/multiple/z_stats.clean.sh
Added: branches/release-0.94/tests/stress/IO/multiple/z_stats.swift
--- branches/release-0.94/tests/stress/IO/multiple/z_stats.swift	                        (rev 0)
+++ branches/release-0.94/tests/stress/IO/multiple/z_stats.swift	2013-08-03 22:59:23 UTC (rev 6732)
@@ -0,0 +1 @@
+type file;
Added: branches/release-0.94/tests/stress/IO/uc3/z_stats.clean.sh
--- branches/release-0.94/tests/stress/IO/uc3/z_stats.clean.sh	                        (rev 0)
+++ branches/release-0.94/tests/stress/IO/uc3/z_stats.clean.sh	2013-08-03 22:59:23 UTC (rev 6732)
@@ -0,0 +1,24 @@
+#!/bin/bash
+HOME=$PWD
+ps -u $USER
+if [ "$?" == "0" ]
+then
+fi
+do
+    echo "$test_case"
+    echo
+done
Property changes on: branches/release-0.94/tests/stress/IO/uc3/z_stats.clean.sh
Added: branches/release-0.94/tests/stress/IO/uc3/z_stats.swift
--- branches/release-0.94/tests/stress/IO/uc3/z_stats.swift	                        (rev 0)
+++ branches/release-0.94/tests/stress/IO/uc3/z_stats.swift	2013-08-03 22:59:23 UTC (rev 6732)
@@ -0,0 +1 @@
+type file;
More information about the Swift-commit
