[Swift-commit] r6726 - SwiftTutorials/ATPESC_2013-08-06/cloud
ketan at ci.uchicago.edu
Fri Aug 2 21:06:17 CDT 2013
Author: ketan
Date: 2013-08-02 21:06:17 -0500 (Fri, 02 Aug 2013)
New Revision: 6726
Modified:
SwiftTutorials/ATPESC_2013-08-06/cloud/coaster-service.conf
SwiftTutorials/ATPESC_2013-08-06/cloud/setup
SwiftTutorials/ATPESC_2013-08-06/cloud/sites.xml
SwiftTutorials/ATPESC_2013-08-06/cloud/tc.data
Log:
test with strict key host checking and removed fixed ports from coaster conf
Modified: SwiftTutorials/ATPESC_2013-08-06/cloud/coaster-service.conf
--- SwiftTutorials/ATPESC_2013-08-06/cloud/coaster-service.conf 2013-08-02 22:59:58 UTC (rev 6725)
+++ SwiftTutorials/ATPESC_2013-08-06/cloud/coaster-service.conf 2013-08-03 02:06:17 UTC (rev 6726)
@@ -24,8 +24,8 @@
export WORKER_LOG_DIR=/root
# Manually define ports. If not specified, ports will be automatically generated
- export LOCAL_PORT=50100
- export SERVICE_PORT=50200
+ #export LOCAL_PORT=50100
+ #export SERVICE_PORT=50200
# Set shared filesystem to no since work will be done in local /sandbox directory
export SHARED_FILESYSTEM=no
Modified: SwiftTutorials/ATPESC_2013-08-06/cloud/setup
--- SwiftTutorials/ATPESC_2013-08-06/cloud/setup 2013-08-02 22:59:58 UTC (rev 6725)
+++ SwiftTutorials/ATPESC_2013-08-06/cloud/setup 2013-08-03 02:06:17 UTC (rev 6726)
@@ -1,22 +1,22 @@
#!/bin/bash
-count=$(cat ~/.ssh/config | grep 54.212.50.12 | wc -l)
+while read line
+do
+ count=$(cat ~/.ssh/config | grep $line | wc -l)
-if [ $count -eq 0 ]
-then
- echo -ne 'Host 54.212.50.12 \n IdentityFile ~/.ssh/tutorial.pem \n User root \n' >> ~/.ssh/config
-fi
+ if [ $count -eq 0 ]
+ then
+ echo -ne "Host $line \n IdentityFile ~/.ssh/tutorial.pem \n User root \n" >> ~/.ssh/config
+ fi
+done < hosts.txt
+count=$(cat ~/.ssh/config | grep StrictHostKeyChecking | wc -l)
-count=$(cat ~/.ssh/config | grep 54.212.89.44 | wc -l)
+if [ $count -eq 0 ]
then
- echo -ne 'Host 54.212.89.44 \n IdentityFile ~/.ssh/tutorial.pem \n User root \n' >> ~/.ssh/config
+ echo -ne "Host * \n StrictHostKeyChecking=no" >> ~/.ssh/config
fi
-echo 'StrictHostKeyChecking=no' >> ~/.ssh/config
export WORKER_HOSTS=`cat hosts.txt`
chmod 0600 ~/.ssh/tutorial.pem
eval $(ssh-agent)
Modified: SwiftTutorials/ATPESC_2013-08-06/cloud/sites.xml
--- SwiftTutorials/ATPESC_2013-08-06/cloud/sites.xml 2013-08-02 22:59:58 UTC (rev 6725)
+++ SwiftTutorials/ATPESC_2013-08-06/cloud/sites.xml 2013-08-03 02:06:17 UTC (rev 6726)
@@ -1,7 +1,7 @@
<config>
<pool handle="persistent-coasters">
<execution provider="coaster-persistent"
- url="http://localhost:50200"
+ url="http://localhost:35249"
jobmanager="local:local"/>
<profile namespace="globus" key="workerManager">passive</profile>
<profile namespace="globus" key="jobsPerNode">4</profile>
Modified: SwiftTutorials/ATPESC_2013-08-06/cloud/tc.data
--- SwiftTutorials/ATPESC_2013-08-06/cloud/tc.data 2013-08-02 22:59:58 UTC (rev 6725)
+++ SwiftTutorials/ATPESC_2013-08-06/cloud/tc.data 2013-08-03 02:06:17 UTC (rev 6726)
@@ -37,3 +37,18 @@
persistent-coasters cat /bin/cat null null null
persistent-coasters bash /bin/bash null null null
persistent-coasters echo /bin/echo null null null
+persistent-coasters cat /bin/cat null null null
+persistent-coasters bash /bin/bash null null null
+persistent-coasters echo /bin/echo null null null
More information about the Swift-commit
