[Swift-commit] r6721 - SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Fri Aug 2 16:52:56 CDT 2013
Author: wozniak
Date: 2013-08-02 16:52:56 -0500 (Fri, 02 Aug 2013)
New Revision: 6721
Added:
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift
   SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift
Log:
Swift example
Added: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/dets.swift	2013-08-02 21:52:56 UTC (rev 6721)
@@ -0,0 +1,32 @@
+import io;
+import math;
+import python;
+import string;
+import R;
+import numpy;
+global const int N = 3;
+global const int U = 7;
+main
+  // Define our collection of determinants:
+  float dets[];
+  foreach i in [1:U-1]
+    // For U, i, construct a matrix via Numpy:
+    A = matrix_add(matrix_scale(eye(N), itof(i)), ones(N));
+    B = matrix_set(A, 2, 0, (U-i+1)**3);
+    // Obtain its determinant via Numpy:
+    v = determinant(B);
+    // Store the determinant in a Swift array:
+    dets[i] = abs_float(v);
+  // Build a fragment of R code with the dets:
+  code = sprintf("max(%s)", string_from_floats(dets));
+  r = R(code);
+  printf("max: %f", r);
Added: SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift
--- SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2013-08-06/part11-swift-py-r/numpy.swift	2013-08-02 21:52:56 UTC (rev 6721)
@@ -0,0 +1,58 @@
+global const string numpy = "from numpy import *\n\n";
+typedef matrix string;
+(matrix A) eye(int n)
+  string command = sprintf("repr(eye(%i))", n);
+  string code = numpy+command;
+  matrix t = python(code);
+  A = replace_all(t, "\n", "", 0);
+(matrix A) ones(int n)
+  string command = sprintf("repr(ones(%i))", n);
+(matrix M) matrix_scale(matrix A, float s)
+  string command = sprintf("repr(%s*%s)", A, s);
+  M = replace_all(t, "\n", "", 0);
+(matrix M) matrix_set(matrix A, int row, int column, float s)
+  string fragment =
+A = %s
+A[%i,%i] = %f
+repr(A)
+  string command = sprintf(fragment, A, row, column, s);
+(matrix M) matrix_add(matrix A1, matrix A2)
+  string command = sprintf("repr(%s+%s)", A1, A2);
+(float d) determinant(matrix A)
+  string command = sprintf("repr(linalg.det(%s))", A);
+  string t = python(code);
+  d = tofloat(t);
