[Swift-commit] r6708 - in SwiftApps/modis: . src
    wozniak at ci.uchicago.edu
    Fri Aug  2 09:44:41 CDT 2013
Author: wozniak
Date: 2013-08-02 09:44:41 -0500 (Fri, 02 Aug 2013)
New Revision: 6708
Added:
   SwiftApps/modis/src/rgb_adjust_color-main.c
   SwiftApps/modis/src/rgb_adjust_color.h
Modified:
   SwiftApps/modis/Makefile
   SwiftApps/modis/src/rgb_adjust_color.c
Log:
Apparently working version
Modified: SwiftApps/modis/Makefile
--- SwiftApps/modis/Makefile	2013-08-02 14:43:41 UTC (rev 6707)
+++ SwiftApps/modis/Makefile	2013-08-02 14:44:41 UTC (rev 6708)
@@ -1,24 +1,33 @@
 MODIS = lib/libmodis.so
-BINS = bin/rgb_histogram
+BINS = bin/rgb_histogram bin/rgb_adjust_color
 all: $(MODIS) $(BINS)
-CFLAGS = -std=gnu99 -I . -fPIC
+CFLAGS = -g -std=gnu99 -fPIC -Wall -I .
 # Include library objects that are not a main program file
 SRCS = $(shell ls src/*.c | grep -v -- -main )
 OBJS = $(patsubst %.c,%.o,$(SRCS))
+map = $(foreach a,$(2),$(call $(1),$(a)))
+get_main = src/$(patsubst bin/%,%,$(1))-main.c
+MAINS = $(call map,get_main,$(BINS))
+LIBS   = -L lib -lmodis
+RPATHS = -Wl,-rpath -Wl,$(PWD)/lib
+LDFLAGS = $(LIBS) $(RPATHS)
 lib:
 	mkdir lib
 bin/rgb_histogram: src/rgb_histogram-main.o $(MODIS)
-	gcc -o $(@) $(<) $(OBJS) \
-		-L lib -lmodis \
-		-Wl,-rpath -Wl,$(PWD)/lib
+	gcc -o $(@) $(<) $(OBJS) $(LDFLAGS)
+bin/rgb_adjust_color: src/rgb_adjust_color-main.o $(MODIS)
 $(MODIS): lib $(OBJS)
 	gcc -shared -o $(@) $(OBJS)
@@ -29,5 +38,6 @@
 debug_build:
 	@echo "BINS:      $(BINS)"
 	@echo "BIN_NAMES: $(BIN_NAMES)"
+	@echo "MAINS:     $(MAINS)"
 	@echo "OBJS:      $(OBJS)"
 	@echo "SRCS:      $(SRCS)"
Added: SwiftApps/modis/src/rgb_adjust_color-main.c
--- SwiftApps/modis/src/rgb_adjust_color-main.c	                        (rev 0)
+++ SwiftApps/modis/src/rgb_adjust_color-main.c	2013-08-02 14:44:41 UTC (rev 6708)
@@ -0,0 +1,98 @@
+ * rgb_adjust_color-main.c
+ *  Created on: Aug 1, 2013
+ *      Author: wozniak
+#include <stdbool.h>
+#include <stdio.h>
+#include <string.h>
+#include "src/rgb_adjust_color.h"
+static void usage(void)
+  printf("usage: rbg_adjust_color input.rgb table.txt output.rgb\n");
+static bool scan_translation(const char* translation_filename,
+                             int* translation);
+   Usage: rgb_adjust_color input.rgb table.txt output.rgb
+int
+main(int argc, char* argv[])
+  if (argc != 4)
+    usage();
+    return 1;
+  int translation[17];
+  bool result = scan_translation(argv[2], translation);
+  if (!result) return 1;
+  FILE* input_file = fopen(argv[1], "r");
+  if (input_file == NULL)
+    printf("could not open input file: %s\n", argv[1]);
+    return false;
+  FILE* output_file = fopen(argv[3], "w");
+  if (output_file == NULL)
+    printf("could not open output file: %s\n", argv[3]);
+    return false;
+  translate(input_file, translation, output_file);
+  return 0;
+ * @param translation OUT The translation table
+static bool
+scan_translation(const char* translation_filename, int* translation)
+  FILE* translation_file = fopen(translation_filename, "r");
+  if (translation_file == NULL)
+    printf("could not open translation table: %s\n",
+           translation_filename);
+    return false;
+  char buffer[64];
+  int key;
+  int value;
+  while (true)
+    char* result = fgets(buffer, 64, translation_file);
+    if (!result) break;
+    int n = sscanf(buffer, "#%x #%x", &key, &value);
+    if (n != 2)
+      printf("bad line in translation table: %s\n", buffer);
+      return false;
+    // printf("%x __ %x\n", key, value);
+    int k = key % 17;
+    // printf("k: %i\n", k);
+    unsigned char* p = (unsigned char*) &value;
+    unsigned char t = p[0];
+    // printf("p: %x %x %x %x\n", p[0], p[1], p[2], p[3]);
+    memcpy(&p[0], &p[2], sizeof(char));
+    memcpy(&p[2], &t, sizeof(char));
+    translation[k] = value;
+  printf("scan done\n");
+  return true;
Modified: SwiftApps/modis/src/rgb_adjust_color.c
--- SwiftApps/modis/src/rgb_adjust_color.c	2013-08-02 14:43:41 UTC (rev 6707)
+++ SwiftApps/modis/src/rgb_adjust_color.c	2013-08-02 14:44:41 UTC (rev 6708)
@@ -1,35 +1,40 @@
-#!/usr/bin/perl
-# Usage: rgb_adjust_color.pl input.rgb table.txt output.rgb
+ * rgb_adjust_color.c
+ *      Author: wozniak
-my ($input_filename, $translation_table, $output_filename) = @ARGV;
-open(FILE_INPUT, "$input_filename") || die "Unable to open $input_filename!";
-open(FILE_OUTPUT, ">$output_filename") || die "Unable to create $output_filename";
-# Read translation table into a hash
-my %tr_table = ();
-open(TRANSLATION_TABLE, "$translation_table") || die "Unable to open $translation_table";
-while(<TRANSLATION_TABLE>) {
-   my ($from, $to) = split;
-   $tr_table{$from} = $to;
-# Read data
-$/ = \3;
-while(<FILE_INPUT>) {
-   my $hex = sprintf ("#%2.2X%2.2X%2.2X", unpack('C3', $_));
+bool
+translate(FILE* file, int* translation, FILE* output)
+  unsigned char b[3];
-   if(defined($tr_table{$hex})) {
-      my $new_value = $tr_table{$hex};
-      print FILE_OUTPUT pack('C3',
-                             hex(substr($new_value,1,2)),
-                             hex(substr($new_value,3,2)),
-                             hex(substr($new_value,5,2))
+  while (true)
+    int rc = fread(b, sizeof(b), 1, file);
+    if (rc == 0) break;
+    int k = 0;
+    char* t = (char*) &k;
+    memcpy(&t[0], &b[0], sizeof(char)*3);
+    int v;
+    if (k == 0xffffff)
+      v = 0xffffff;
+    else
+      v = translation[k%17];
+    char* p = (char*) &v;
+    // printf("%u %u %u\n", b[0], b[1], b[2]);
+    // printf("%x -> %x\n", k, v);
+    fwrite(&p[0], sizeof(char), 3, output);
-   else { print FILE_OUTPUT $_; }
+  if (!feof(file))
+    return false;
+  return true;
-close(FILE_INPUT);
-close(FILE_OUTPUT);
Added: SwiftApps/modis/src/rgb_adjust_color.h
--- SwiftApps/modis/src/rgb_adjust_color.h	                        (rev 0)
+++ SwiftApps/modis/src/rgb_adjust_color.h	2013-08-02 14:44:41 UTC (rev 6708)
@@ -0,0 +1,17 @@
+ * rgb_adjust_color.h
+ *      Author: wozniak
+#ifndef RGB_ADJUST_COLOR_H_
+#define RGB_ADJUST_COLOR_H_
+#include <stdio.h>
+bool
+translate(FILE* file, int* translation, FILE* output);
+#endif
More information about the Swift-commit
