[Swift-commit] cog r3460
swift at ci.uchicago.edu swift at ci.uchicago.edu
Sat Sep 8 20:40:18 CDT 2012
r3460 | hategan | 2012-09-08 20:38:12 -0500 (Sat, 08 Sep 2012) | 1 line
non-working, initial version of coaster c client
Index: modules/provider-coaster-c-client/.project
--- modules/provider-coaster-c-client/.project	(revision 0)
+++ modules/provider-coaster-c-client/.project	(revision 3460)
@@ -0,0 +1,72 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<projectDescription>
+	<name>provider-coaster-c-client</name>
+	<comment></comment>
+	<projects>
+	</projects>
+	<buildSpec>
+		<buildCommand>
+			<name>org.eclipse.linuxtools.cdt.autotools.core.genmakebuilderV2</name>
+			<arguments>
+			</arguments>
+		</buildCommand>
+		<buildCommand>
+			<name>org.eclipse.cdt.managedbuilder.core.genmakebuilder</name>
+			<triggers>clean,full,incremental,</triggers>
+			<arguments>
+				<dictionary>
+					<key>?name?</key>
+					<value></value>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.append_environment</key>
+					<value>true</value>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.buildArguments</key>
+					<value></value>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.buildCommand</key>
+					<value>make</value>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.contents</key>
+					<value>org.eclipse.cdt.make.core.activeConfigSettings</value>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.enableAutoBuild</key>
+					<value>false</value>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.enableCleanBuild</key>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.enableFullBuild</key>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.stopOnError</key>
+				</dictionary>
+				<dictionary>
+					<key>org.eclipse.cdt.make.core.useDefaultBuildCmd</key>
+				</dictionary>
+			</arguments>
+		</buildCommand>
+		<buildCommand>
+			<name>org.eclipse.cdt.managedbuilder.core.ScannerConfigBuilder</name>
+			<triggers>full,incremental,</triggers>
+			<arguments>
+			</arguments>
+		</buildCommand>
+	</buildSpec>
+	<natures>
+		<nature>org.eclipse.cdt.core.cnature</nature>
+		<nature>org.eclipse.cdt.managedbuilder.core.managedBuildNature</nature>
+		<nature>org.eclipse.cdt.managedbuilder.core.ScannerConfigNature</nature>
+		<nature>org.eclipse.linuxtools.cdt.autotools.core.autotoolsNatureV2</nature>
+	</natures>
+</projectDescription>
Index: modules/provider-coaster-c-client/AUTHORS
--- modules/provider-coaster-c-client/AUTHORS	(revision 0)
+++ modules/provider-coaster-c-client/AUTHORS	(revision 3460)
@@ -0,0 +1 @@
+Mihael Hategan
Index: modules/provider-coaster-c-client/src/CoasterChannel.h
--- modules/provider-coaster-c-client/src/CoasterChannel.h	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterChannel.h	(revision 3460)
@@ -0,0 +1,115 @@
+ * coaster-channel.h
+ *  Created on: Jun 9, 2012
+ *      Author: mike
+#ifndef COASTER_CHANNEL_H_
+#define COASTER_CHANNEL_H_
+#define HEADER_LENGTH 20
+#define READ_STATE_IDLE 0
+#define READ_STATE_HDR 1
+#define READ_STATE_DATA 2
+#include <map>
+#include <list>
+#include <string>
+#include "CommandCallback.h"
+#include "Handler.h"
+#include "Command.h"
+#include "HandlerFactory.h"
+#include "ChannelCallback.h"
+#include "Flags.h"
+#include "CoasterLoop.h"
+#include "CoasterClient.h"
+#include "Lock.h"
+#include "Buffer.h"
+#include "Logger.h"
+using namespace std;
+class Command;
+class Handler;
+class CoasterLoop;
+class CoasterClient;
+class HandlerFactory;
+class DataChunk {
+	public:
+		Buffer* buf;
+		int bufpos;
+		ChannelCallback* cb;
+		DataChunk();
+		DataChunk(Buffer* buf, ChannelCallback* pcb);
+		void reset();
+class CoasterChannel: public CommandCallback {
+	private:
+		list<DataChunk*> sendQueue;
+		DataChunk readChunk;
+		HandlerFactory* handlerFactory;
+		map<int, Handler*> handlers;
+		map<int, Command*> commands;
+		int sockFD;
+		bool connected;
+		DataChunk whdr, rhdr, msg;
+		int rtag, rflags, rlen;
+		int tagSeq;
+		int readState;
+		CoasterLoop* loop;
+		CoasterClient* client;
+		Lock writeLock;
+		void makeHeader(int tag, Buffer* buf, int flags);
+		void decodeHeader(int* tag, int* flags, int* len);
+		void dispatchData();
+		void dispatchRequest();
+		void dispatchReply();
+		bool read(DataChunk* dc);
+	public:
+		CoasterChannel(CoasterClient* client, CoasterLoop* pLoop, HandlerFactory* pHandlerFactory);
+		virtual ~CoasterChannel();
+		int getSockFD();
+		void setSockFD(int psockFD);
+		list<DataChunk*> getSendQueue();
+		void shutdown();
+		void start();
+		void read();
+		bool write();
+		void registerCommand(Command* cmd);
+		void unregisterCommand(Command* cmd);
+		void registerHandler(int tag, Handler* h);
+		void unregisterHandler(Handler* h);
+		void send(int tag, Buffer* buf, int flags, ChannelCallback* cb);
+		CoasterClient* getClient();
+		void checkHeartbeat();
+		friend ostream& operator<< (ostream& os, CoasterChannel* channel);
+		void errorReceived(Command* cmd, string* message, string* details);
+		void replyReceived(Command* cmd);
+#endif /* COASTER_CHANNEL_H_ */
Index: modules/provider-coaster-c-client/src/CoasterClient.cpp
--- modules/provider-coaster-c-client/src/CoasterClient.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterClient.cpp	(revision 3460)
@@ -0,0 +1,227 @@
+ * coaster-client.c
+ *      Author: mike
+#include "JobSubmitCommand.h"
+#include <stdlib.h>
+#include <string.h>
+#include <errno.h>
+#include <sys/socket.h>
+#include <sys/types.h>
+#include <netinet/in.h>
+#include <arpa/inet.h>
+ConnectionError::ConnectionError(string msg) {
+	message = msg.c_str();
+const char* ConnectionError::what() const throw() {
+	return message;
+CoasterClient::CoasterClient(string URLp, CoasterLoop& ploop) {
+	URL = URLp;
+	sockFD = 0;
+	loop = &ploop;
+	started = false;
+void CoasterClient::start() {
+	if (started) {
+		return;
+	struct addrinfo* addrInfo;
+	struct addrinfo* it;
+	char* error = NULL;
+	addrInfo = resolve(getHostName().c_str(), getPort());
+	for (it = addrInfo; it != NULL; it = it->ai_next) {
+		sockFD = socket(it->ai_family, it->ai_socktype, it->ai_protocol);
+		if (sockFD == -1) {
+			continue;
+		if (connect(sockFD, it->ai_addr, it->ai_addrlen) == 0) {
+			break;
+		error = strerror(errno);
+		close(sockFD);
+		sockFD = -1;
+	freeaddrinfo(addrInfo);
+		// none succeeded
+		if (error != NULL) {
+			throw ConnectionError("Failed to connect to " + URL + ": " + error);
+		else {
+			throw ConnectionError("Failed to connect to " + URL);
+	channel = new CoasterChannel(this, loop, handlerFactory);
+	channel->setSockFD(sockFD);
+	channel->start();
+	loop->addChannel(channel);
+	started = true;
+void CoasterClient::stop() {
+	if (!started) {
+		return;
+	channel->shutdown();
+	loop->removeChannel(channel);
+	close(sockFD);
+	delete channel;
+	started = false;
+void CoasterClient::submit(Job& job) {
+	{ Lock::Scoped l(lock);
+		jobs[&job.getIdentity()] = &job;
+	JobSubmitCommand* sjc = new JobSubmitCommand(&job);
+	sjc->send(channel, this);
+void CoasterClient::errorReceived(Command* cmd, string* message, string* details) {
+	if (*(cmd->getName()) == JobSubmitCommand::NAME) {
+		JobSubmitCommand* jsc = static_cast<JobSubmitCommand*>(cmd);
+		updateJobStatus(jsc->getJob()->getIdentity(), new JobStatus(FAILED, message, details));
+	else {
+		LogWarn << "Error received for command " << cmd;
+		if (message != NULL) {
+			LogWarn << ": " << message;
+		if (details != NULL) {
+			LogWarn << "\n" << message;
+		LogWarn << endl;
+	delete cmd;
+void CoasterClient::replyReceived(Command* cmd) {
+		updateJobStatus(jsc->getJob()->getIdentity(), new JobStatus(SUBMITTED));
+	delete cmd;
+void CoasterClient::updateJobStatus(string& jobId, JobStatus* status) { Lock::Scoped l(lock);
+	if (jobs.count(&jobId) == 0) {
+		LogWarn << "Received job status notification for unknown job (" << jobId << "): " << status << endl;
+	else {
+		Job* job = jobs[&jobId];
+		job->setStatus(status);
+		if (status->isTerminal()) {
+			jobs.erase(&jobId);
+			doneJobs.push_back(job);
+			cv.broadcast();
+int CoasterClient::getPort() {
+	size_t index;
+	index = URL.find(':');
+	if (index == string::npos) {
+		// default port
+		return 1984;
+	else {
+		return atoi(URL.substr(index).c_str());
+string CoasterClient::getHostName() {
+	size_t index;
+		return URL;
+	else {
+		return URL.substr(0, index);
+struct addrinfo* CoasterClient::resolve(const char* hostName, int port) {
+	struct addrinfo hints;
+	struct addrinfo* info;
+	memset(&hints, 0, sizeof(struct addrinfo));
+	hints.ai_family = AF_INET;
+	hints.ai_socktype = SOCK_STREAM;
+	hints.ai_flags = 0;
+	hints.ai_protocol = 0;
+	char* sPort = (char *) malloc(sizeof(int) * 8 + 1);
+	sprintf(sPort, "%d", port);
+	int result = getaddrinfo(hostName, sPort, &hints, &info);
+	if (result != 0) {
+		throw ConnectionError(string("Host name lookup failure: ") + gai_strerror(result));
+	free(sPort);
+	return info;
+ * Retrieve the list of completed/failed/canceled jobs. If no more jobs
+ * finish after this call, a subsequent call to this method will return
+ * NULL. It's the caller's responsibility to delete the returned list.
+list<Job*>* CoasterClient::getAndPurgeDoneJobs() { Lock::Scoped l(lock);
+	if (doneJobs.size() == 0) {
+		return NULL;
+	else {
+		list<Job*>* l = new list<Job*>(doneJobs);
+		doneJobs.clear();
+		return l;
+void CoasterClient::waitForJobs() { Lock::Scoped l(lock);
+	while (jobs.size() != 0) {
+		cv.wait(lock);
+void CoasterClient::waitForJob(Job& job) { Lock::Scoped l(lock);
+	while (jobs.count(&(job.getIdentity())) != 0) {
+		cv.wait(lock);
+string& CoasterClient::getURL() {
+	return URL;
Index: modules/provider-coaster-c-client/src/CoasterClientTest.cpp
--- modules/provider-coaster-c-client/src/CoasterClientTest.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterClientTest.cpp	(revision 3460)
@@ -0,0 +1,43 @@
+#include <stdio.h>
+#include <list>
+#include "Job.h"
+int main(void) {
+	try {
+		CoasterLoop loop = CoasterLoop();
+		loop.start();
+		CoasterClient client("localhost:1984", loop);
+		client.start();
+		Job j1("/bin/date");
+		Job j2("/bin/echo");
+		j2.addArgument("testing");
+		j2.addArgument("1, 2, 3");
+		client.submit(j1);
+		client.submit(j2);
+		client.waitForJob(j1);
+		client.waitForJob(j2);
+		list<Job*>* doneJobs = client.getAndPurgeDoneJobs();
+		printf("All done\n");
+		client.stop();
+		loop.stop();
+		return EXIT_SUCCESS;
+	catch (exception& e) {
+		cerr << "Exception caught: " << e.what() << endl;
+		return EXIT_FAILURE;
Index: modules/provider-coaster-c-client/src/CoasterLoop.h
--- modules/provider-coaster-c-client/src/CoasterLoop.h	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterLoop.h	(revision 3460)
@@ -0,0 +1,70 @@
+ * coaster-loop.h
+ *      Author: mike
+#ifndef COASTER_LOOP_H_
+#define COASTER_LOOP_H_
+#include "CoasterChannel.h"
+#include "Lock.h"
+#include <map>
+#include <list>
+#include <pthread.h>
+#include <sys/select.h>
+#include <ctime>
+#include <stdio.h>
+// 1 minute
+#define HEARTBEAT_CHECK_INTERVAL 60
+class CoasterLoop {
+	private:
+		pthread_t thread;
+		map<int, CoasterChannel*> channelMap;
+		list<CoasterChannel*> addList;
+		list<CoasterChannel*> removeList;
+		int wakePipe[2];
+		fd_set rfds, wfds;
+		int socketCount;
+		int maxFD;
+		void updateMaxFD();
+		void acknowledgeWake();
+		time_t lastHeartbeatCheck;
+	public:
+		bool started;
+		bool done;
+		Lock lock;
+		CoasterLoop();
+		void start();
+		void stop();
+		void addChannel(CoasterChannel* channel);
+		void removeChannel(CoasterChannel* channel);
+		void addSockets();
+		void removeSockets();
+		void awake();
+		fd_set* getReadFDs();
+		fd_set* getWriteFDs();
+		int getMaxFD();
+		bool readSockets(fd_set* fds);
+		void writeSockets(fd_set* fds);
+		int getWakePipeReadFD();
+		void requestWrite(CoasterChannel* channel);
+		void checkHeartbeats();
+#endif /* COASTER_LOOP_H_ */
Index: modules/provider-coaster-c-client/src/ConditionVariable.h
--- modules/provider-coaster-c-client/src/ConditionVariable.h	(revision 0)
+++ modules/provider-coaster-c-client/src/ConditionVariable.h	(revision 3460)
@@ -0,0 +1,25 @@
+ * ConditionVariable.h
+ *  Created on: Sep 7, 2012
+ *      Author: mike
+#ifndef CONDITIONVARIABLE_H_
+#define CONDITIONVARIABLE_H_
+#include "Lock.h"
+class ConditionVariable {
+	private:
+		pthread_cond_t cv;
+	public:
+		ConditionVariable();
+		virtual ~ConditionVariable();
+		void wait(Lock& lock);
+		void signal();
+		void broadcast();
+#endif /* CONDITIONVARIABLE_H_ */
Index: modules/provider-coaster-c-client/src/HeartBeatCommand.h
--- modules/provider-coaster-c-client/src/HeartBeatCommand.h	(revision 0)
+++ modules/provider-coaster-c-client/src/HeartBeatCommand.h	(revision 3460)
@@ -0,0 +1,29 @@
+ * HeartBeatCommand.h
+ *  Created on: Sep 5, 2012
+ *      Author: mike
+#ifndef HEARTBEATCOMMAND_H_
+#define HEARTBEATCOMMAND_H_
+#include <sys/time.h>
+#include <string>
+class HeartBeatCommand: public Command {
+	private:
+		long sendtime;
+	public:
+		static string NAME;
+		HeartBeatCommand();
+		virtual ~HeartBeatCommand();
+		void send(CoasterChannel* channel, CommandCallback* cb);
+		virtual void dataSent(Buffer* buf);
+		virtual void replyReceived();
+#endif /* HEARTBEATCOMMAND_H_ */
Index: modules/provider-coaster-c-client/src/ClientHandlerFactory.cpp
--- modules/provider-coaster-c-client/src/ClientHandlerFactory.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/ClientHandlerFactory.cpp	(revision 3460)
@@ -0,0 +1,17 @@
+ * ClientHandlerFactory.cpp
+ *  Created on: Aug 31, 2012
+ *      Author: mike
+#include "ClientHandlerFactory.h"
+#include "JobStatusHandler.h"
+ClientHandlerFactory::ClientHandlerFactory() {
+	addHandler<JobStatusHandler>("JOBSTATUS");
+ClientHandlerFactory::~ClientHandlerFactory() {
+	// TODO Auto-generated destructor stub
Index: modules/provider-coaster-c-client/src/RequestReply.cpp
--- modules/provider-coaster-c-client/src/RequestReply.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/RequestReply.cpp	(revision 3460)
@@ -0,0 +1,116 @@
+ * RequestReply.cpp
+ *  Created on: Aug 30, 2012
+ *      Author: mike
+#include "RequestReply.h"
+#include "CoasterError.h"
+#include <sstream>
+RequestReply::RequestReply() {
+	channel = NULL;
+RequestReply::~RequestReply() {
+	clearBufferVector(inData);
+	clearBufferVector(outData);
+	clearBufferVector(*errorData);
+	delete errorData;
+void RequestReply::clearBufferVector(vector<Buffer*>& v) {
+	vector<Buffer*>::iterator i;
+	for (i = v.begin(); i != v.end(); i++) {
+		delete *i;
+void RequestReply::setChannel(CoasterChannel* pchannel) {
+	channel = pchannel;
+CoasterChannel* RequestReply::getChannel() {
+	return channel;
+void RequestReply::setTag(int ptag) {
+	tag = ptag;
+int RequestReply::getTag() {
+	return tag;
+void RequestReply::addOutData(Buffer* buf) {
+	outData.push_back(buf);
+void RequestReply::addInData(Buffer* buf) {
+	inData.push_back(buf);
+void RequestReply::getInDataAsString(int index, string& dest) {
+	Buffer* buf = getInData()->at(index);
+	dest.assign(buf->getData(), buf->getLen());
+int RequestReply::getInDataAsInt(int index) {
+	return getInData()->at(index)->getInt(0);
+long RequestReply::getInDataAsLong(int index) {
+	return getInData()->at(index)->getLong(0);
+void RequestReply::addErrorData(Buffer* buf) {
+	if (errorData == NULL) {
+		errorData = new vector<Buffer*>;
+	errorData->push_back(buf);
+vector<Buffer*>* RequestReply::getOutData() {
+	return &outData;
+vector<Buffer*>* RequestReply::getInData() {
+	return &inData;
+vector<Buffer*>* RequestReply::getErrorData() {
+	return errorData;
+void RequestReply::dataReceived(Buffer* buf, int flags) {
+	if (flags & FLAG_ERROR != 0) {
+		addErrorData(buf);
+	else {
+		addInData(buf);
+void RequestReply::signalReceived(Buffer* buf) {
+	throw CoasterError("Unhandled signal: " + string(buf->getData(), buf->getLen()));
+string RequestReply::getErrorString() {
+		return "";
+	else {
+		stringstream ss;
+		vector<Buffer*>::iterator it;
+		for (it = errorData->begin(); it != errorData->end(); it++) {
+			ss << (*it) << '\n';
+		return ss.str();
Index: modules/provider-coaster-c-client/src/HandlerFactory.h
--- modules/provider-coaster-c-client/src/HandlerFactory.h	(revision 0)
+++ modules/provider-coaster-c-client/src/HandlerFactory.h	(revision 3460)
@@ -0,0 +1,30 @@
+ * HandlerFactory.h
+ *  Created on: Aug 28, 2012
+ *      Author: mike
+#ifndef HANDLERFACTORY_H_
+#define HANDLERFACTORY_H_
+#include <map>
+#include <string>
+class Handler;
+class HandlerFactory {
+	private:
+		map<string, Handler*(*)()> creators;
+	public:
+		HandlerFactory();
+		virtual ~HandlerFactory();
+		template<typename T> void addHandler(string name);
+		Handler* newInstance(string& name);
+		Handler* newInstance(const string* name);
+#endif /* HANDLERFACTORY_H_ */
Index: modules/provider-coaster-c-client/src/JobStatus.cpp
--- modules/provider-coaster-c-client/src/JobStatus.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/JobStatus.cpp	(revision 3460)
@@ -0,0 +1,105 @@
+ * job-status.c
+ *      Author: mike
+#include <time.h>
+#include "JobStatus.h"
+JobStatus::JobStatus(JobStatusCode pstatusCode, time_t ptime, const string* pmessage, const string* pexception) {
+	statusCode = pstatusCode;
+	stime = ptime;
+	// always copy strings because the job status' lifetime is weird
+	if (pmessage != NULL) {
+		message = new string(*pmessage);
+	else {
+		message = NULL;
+	if (pexception != NULL) {
+		exception = new string(*pexception);
+	else {
+		exception = NULL;
+JobStatus::JobStatus(JobStatusCode pstatusCode, const string* pmessage, const string* pexception) {
+	JobStatus(pstatusCode, time(NULL), pmessage, pexception);
+JobStatus::JobStatus(JobStatusCode pstatusCode) {
+	JobStatus(pstatusCode, NULL, NULL);
+JobStatus::JobStatus() {
+	JobStatus(UNSUBMITTED);
+JobStatusCode JobStatus::getStatusCode() {
+	return statusCode;
+time_t JobStatus::getTime() {
+	return stime;
+string* JobStatus::getMessage() {
+	return message;
+string* JobStatus::getException() {
+	return exception;
+void JobStatus::setPreviousStatus(JobStatus* pprev) {
+	prev = pprev;
+const JobStatus* JobStatus::getPreviousStatus() {
+	return prev;
+bool JobStatus::isTerminal() {
+	return statusCode == COMPLETED || statusCode == CANCELED || statusCode == FAILED;
+JobStatus::~JobStatus() {
+	if (prev != NULL) {
+		delete prev;
+static const char* statusCodeToStr(JobStatusCode code) {
+	switch (code) {
+		case UNSUBMITTED: return "UNSUBMITTED";
+		case SUBMITTING: return "SUBMITTING";
+		case SUBMITTED: return "SUBMITTED";
+		case ACTIVE: return "ACTIVE";
+		case SUSPENDED: return "SUSPENDED";
+		case RESUMED: return "RESUMED";
+		case FAILED: return "FAILED";
+		case CANCELED: return "CANCELED";
+		case COMPLETED: return "COMPLETED";
+		case STAGE_IN: return "STAGE_IN";
+		case STAGE_OUT: return "STAGE_OUT";
+		default: return "UNKNWON";
+ostream& operator<< (ostream& os, JobStatus& s) {
+	return os << &s;
+ostream& operator<< (ostream& os, JobStatus* s) {
+	os << "Status(" << statusCodeToStr(s->getStatusCode());
+	if (s->getMessage()->length() != 0) {
+		os << ", msg: " << s->getMessage();
+	os << ")";
+	return os;
Index: modules/provider-coaster-c-client/src/Buffer.h
--- modules/provider-coaster-c-client/src/Buffer.h	(revision 0)
+++ modules/provider-coaster-c-client/src/Buffer.h	(revision 3460)
@@ -0,0 +1,67 @@
+ * Buffer.h
+ *      Author: mike
+#ifndef BUFFER_H_
+#define BUFFER_H_
+#include <string>
+#include <ostream>
+#include <stdexcept>
+class Buffer {
+	protected:
+		int len;
+	public:
+		Buffer(int plen);
+		int getLen() const;
+		virtual const char* getData();
+		virtual char* getModifiableData();
+		virtual void setData(const char* data);
+		virtual ~Buffer();
+		virtual string* str();
+		int getInt(int index);
+		long getLong(int index);
+		void putInt(int index, int value);
+		void putLong(int index, long value);
+		static Buffer* wrap(int i);
+		static Buffer* wrap(long l);
+		static Buffer* wrap(const char* buf, int len);
+		static Buffer* wrap(string s);
+		static Buffer* wrap(const string* s);
+class StaticBuffer: public Buffer {
+	private:
+		const char* data;
+	public:
+		StaticBuffer(int plen);
+		virtual ~StaticBuffer();
+class DynamicBuffer: public Buffer {
+	private:
+		char* data;
+	public:
+		DynamicBuffer(int plen);
+		virtual ~DynamicBuffer();
+		friend ostream& operator<< (ostream& os, Buffer& buf);
+#endif /* BUFFER_H_ */
Index: modules/provider-coaster-c-client/src/Job.h
--- modules/provider-coaster-c-client/src/Job.h	(revision 0)
+++ modules/provider-coaster-c-client/src/Job.h	(revision 3460)
@@ -0,0 +1,90 @@
+ * job-description.h
+ *      Author: mike
+#ifndef JOB_H_
+#define JOB_H_
+#include "StagingSetEntry.h"
+#include <string>
+#include <vector>
+#include <map>
+class Job {
+	private:
+		string identity;
+		string executable;
+		vector<string*>* arguments;
+		string* directory;
+		string* stdinLocation;
+		string* stdoutLocation;
+		string* stderrLocation;
+		string* jobManager;
+		map<string, string>* env;
+		map<string, string>* attributes;
+		vector<StagingSetEntry>* stageIns;
+		vector<StagingSetEntry>* stageOuts;
+		vector<string>* cleanups;
+		string* stdout;
+		string* stderr;
+		JobStatus* status;
+	public:
+		Job(string executable);
+		virtual ~Job();
+		string& getExecutable();
+		string& getIdentity();
+		vector<string*>* getArguments();
+		void addArgument(string& arg);
+		void addArgument(const char* arg);
+		string* getDirectory();
+		void setDirectory(string& directory);
+		string* getStdinLocation();
+		void setStdinLocation(string& loc);
+		string* getStdoutLocation();
+		void setStdoutLocation(string& loc);
+		string* getStderrLocation();
+		void setStderrLocation(string& loc);
+		string* getJobManager();
+		void setJobManager(string& jm);
+		map<string, string>* getEnv();
+		string* getEnv(string name);
+		void setEnv(string name, string value);
+		map<string, string>* getAttributes();
+		string* getAttribute(string name);
+		void setAttribute(string name, string value);
+		vector<StagingSetEntry>* getStageIns();
+		void addStageIn(string src, string dest, StagingMode mode);
+		vector<StagingSetEntry>* getStageOuts();
+		void addStageOut(string src, string dest, StagingMode mode);
+		vector<string>* getCleanups();
+		void addCleanup(string cleanup);
+		string* getStderr();
+		string* getStdout();
+		JobStatus* getStatus();
+		void setStatus(JobStatus* status);
+#endif /* JOB_DESCRIPTION_H_ */
Index: modules/provider-coaster-c-client/src/CoasterError.h
--- modules/provider-coaster-c-client/src/CoasterError.h	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterError.h	(revision 3460)
@@ -0,0 +1,30 @@
+ * CoasterError.h
+ *  Created on: Aug 26, 2012
+ *      Author: mike
+#ifndef COASTERERROR_H_
+#define COASTERERROR_H_
+#include <string>
+#include <stdarg.h>
+#include <stdio.h>
+#include <sstream>
+#define MAX_MSG_LEN 256
+class CoasterError: public exception {
+	private:
+		const char* message;
+	public:
+		CoasterError(string msg);
+		CoasterError(const char* format, ...);
+		CoasterError(const stringstream* ss);
+		virtual const char* what() const throw();
+#endif /* COASTERERROR_H_ */
Index: modules/provider-coaster-c-client/src/Logger.cpp
--- modules/provider-coaster-c-client/src/Logger.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/Logger.cpp	(revision 3460)
@@ -0,0 +1,131 @@
+ * Logger.cpp
+ *  Created on: Aug 13, 2012
+ *      Author: mike
+#include <time.h>
+Logger::Logger(ostream& pout) {
+	out = &pout;
+	level = NONE;
+	setFile("<unknown>");
+	flushed = true;
+Logger::~Logger() {
+Logger& Logger::operator<< (Level plevel) {
+	setLevel(plevel);
+	return *this;
+void Logger::setLevel(Level plevel) {
+	level = plevel;
+	strLevel = levelToStr(level);
+const char* Logger::levelToStr(Level level) {
+	switch (level) {
+		case NONE:
+			return "NONE ";
+		case ERROR:
+			return "ERROR";
+		case WARN:
+			return "WARN ";
+		case INFO:
+			return "INFO ";
+		case DEBUG:
+			return "DEBUG";
+		default:
+			return "?????";
+Logger& Logger::operator<< (string str) {
+	header();
+	*out << str << '\n';
+	return *this;
+Logger& Logger::operator<< (const string* str) {
+	header();
+	*out << *str << '\n';
+	return *this;
+Logger& Logger::operator<< (const char* str) {
+	header();
+	return *this;
+Logger& Logger::operator<< (ostream& ( *pf )(ostream&)) {
+	(*pf)(*this);
+	return *this;
+Logger& Logger::setFile(const char* pfile) {
+	 file = strrchr(pfile, '/');
+	 if (file == NULL) {
+		 file = pfile;
+	 return *this;
+Logger& Logger::flush() {
+	ostream::flush();
+	flushed = true;
+	return *this;
+void Logger::log(Level level, const char* fileName, const char* msg) {
+	setLevel(level);
+	setFile(fileName);
+	header();
+	*out << msg << endl;
+void Logger::log(Level level, const char* fileName, string msg) {
+	setLevel(level);
+	header();
+char* Logger::timeStamp() {
+	timeval tv;
+	tm *tm;
+	char fmt[TS_LEN + 10];
+	gettimeofday(&tv, NULL);
+	if((tm = localtime(&tv.tv_sec)) != NULL) {
+		strftime(fmt, sizeof(fmt), "%Y-%m-%d %H:%M:%S.%%03u%z", tm);
+	    snprintf(ts, sizeof(ts), fmt, tv.tv_usec / 1000);
+	return ts;
+void Logger::header() {
+	if (flushed) {
+		*out << timeStamp() << " " << strLevel << " " << file << " ";
+		flushed = false;
+StdoutLogger::StdoutLogger(): Logger(cout) {
+StdoutLogger::~StdoutLogger() {
+Logger& Logger::singleton() {
+	return *Logger::instance;
+Logger* Logger::instance = new StdoutLogger();
Index: modules/provider-coaster-c-client/src/JobStatusHandler.h
--- modules/provider-coaster-c-client/src/JobStatusHandler.h	(revision 0)
+++ modules/provider-coaster-c-client/src/JobStatusHandler.h	(revision 3460)
@@ -0,0 +1,21 @@
+ * JobStatusHandler.h
+ *      Author: mike
+#ifndef JOBSTATUSHANDLER_H_
+#define JOBSTATUSHANDLER_H_
+class JobStatusHandler: public Handler {
+	public:
+		JobStatusHandler();
+		virtual ~JobStatusHandler();
+		virtual void requestReceived();
+#endif /* JOBSTATUSHANDLER_H_ */
Index: modules/provider-coaster-c-client/src/Handler.h
--- modules/provider-coaster-c-client/src/Handler.h	(revision 0)
+++ modules/provider-coaster-c-client/src/Handler.h	(revision 3460)
@@ -0,0 +1,32 @@
+ * handler.h
+ *      Author: mike
+#ifndef HANDLER_H_
+#define HANDLER_H_
+class CoasterChannel;
+class Handler: public RequestReply {
+	protected:
+		virtual void sendReply(string& reply);
+		virtual void sendReply(const char* reply);
+	public:
+		virtual void receiveCompleted(int flags);
+		virtual void errorReceived();
+		virtual void send(CoasterChannel* channel);
+#endif /* HANDLER_H_ */
Index: modules/provider-coaster-c-client/src/Command.h
--- modules/provider-coaster-c-client/src/Command.h	(revision 0)
+++ modules/provider-coaster-c-client/src/Command.h	(revision 3460)
@@ -0,0 +1,46 @@
+ * command.h
+ *      Author: mike
+#ifndef COMMAND_H_
+#define COMMAND_H_
+#include <list>
+#include <string>
+#include "Flags.h"
+class CommandCallback;
+class Command: public RequestReply {
+	private:
+		const string* name;
+		CommandCallback* cb;
+	public:
+		Command(const string* pname);
+		const string* getName();
+		virtual void send(CoasterChannel* channel, CommandCallback* cb);
+		friend ostream& operator<< (ostream& os, Command* cmd);
+#endif /* COMMAND_H_ */
Index: modules/provider-coaster-c-client/src/ChannelCallback.cpp
--- modules/provider-coaster-c-client/src/ChannelCallback.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/ChannelCallback.cpp	(revision 3460)
@@ -0,0 +1,14 @@
+ * ChannelCallback.cpp
+ *      Author: mike
+ChannelCallback::ChannelCallback() {
+ChannelCallback::~ChannelCallback() {
Index: modules/provider-coaster-c-client/src/Lock.cpp
--- modules/provider-coaster-c-client/src/Lock.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/Lock.cpp	(revision 3460)
@@ -0,0 +1,36 @@
+ * Lock.cpp
+ *      Author: mike
+#include "Lock.h"
+Lock::Lock() {
+	pthread_mutex_init(&l, NULL);
+Lock::~Lock() {
+void Lock::lock() {
+	pthread_mutex_lock(&l);
+void Lock::unlock() {
+	pthread_mutex_unlock(&l);
+pthread_mutex_t* Lock::getMutex() {
+	return &l;
+Lock::Scoped::Scoped(Lock& plock) {
+	myLock = &plock;
+	myLock->lock();
+Lock::Scoped::~Scoped() {
+	myLock->unlock();
Index: modules/provider-coaster-c-client/src/CoasterChannel.cpp
--- modules/provider-coaster-c-client/src/CoasterChannel.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterChannel.cpp	(revision 3460)
@@ -0,0 +1,320 @@
+ * coaster-channel.cpp
+ *      Author: mike
+#include "HeartBeatCommand.h"
+#include <errno.h>
+#include <sstream>
+int socksend(int fd, const char* buf, int len, int flags);
+class HeartBeatCommand;
+DataChunk::DataChunk() {
+	buf = NULL;
+	cb = NULL;
+	bufpos = 0;
+DataChunk::DataChunk(Buffer* pbuf, ChannelCallback* pcb) {
+	buf = pbuf;
+	cb = pcb;
+	bufpos = 0;
+void DataChunk::reset() {
+	bufpos = 0;
+CoasterChannel::CoasterChannel(CoasterClient* pClient, CoasterLoop* pLoop, HandlerFactory* pHandlerFactory) {
+	sockFD = 0;
+	handlerFactory = pHandlerFactory;
+	tagSeq = rand() % 65536;
+	loop = pLoop;
+	client = pClient;
+	readState = READ_STATE_IDLE;
+	whdr.buf = new DynamicBuffer(HEADER_LENGTH);
+	rhdr.buf = new DynamicBuffer(HEADER_LENGTH);
+CoasterChannel::~CoasterChannel() {
+	delete whdr.buf;
+	delete rhdr.buf;
+ostream& operator<< (ostream& os, CoasterChannel* channel) {
+	os << "Channel[" << channel->getClient()->getURL() << "]";
+	return os;
+void CoasterChannel::start() {
+	if (sockFD == 0) {
+		throw CoasterError("channel start() called but no socket set");
+void CoasterChannel::shutdown() {
+int CoasterChannel::getSockFD() {
+	return sockFD;
+void CoasterChannel::setSockFD(int psockFD) {
+	sockFD = psockFD;
+void CoasterChannel::read() {
+	switch(readState) {
+		case READ_STATE_IDLE:
+			break;
+		case READ_STATE_HDR:
+			if (read(&rhdr)) {
+				// full header read
+				msg.reset();
+				decodeHeader(&rtag, &rflags, &rlen);
+				msg.buf = new DynamicBuffer(rlen);
+				readState = READ_STATE_DATA;
+			else {
+				break;
+		case READ_STATE_DATA:
+			if (read(&msg)) {
+				// full message read
+				dispatchData();
+				rhdr.reset();
+				readState = READ_STATE_HDR;
+			break;
+bool CoasterChannel::read(DataChunk* dc) {
+	int ret = recv(sockFD, dc->buf->getModifiableData(), (dc->buf->getLen() - dc->bufpos), MSG_DONTWAIT);
+	if (ret == -1) {
+		if (errno == EAGAIN || errno == EWOULDBLOCK) {
+			return false;
+		else {
+			throw CoasterError("Socket read error: %s", strerror(errno));
+	else {
+		dc->bufpos += ret;
+		if (dc->bufpos == dc->buf->getLen()) {
+			return true;
+void CoasterChannel::dispatchData() {
+	if (rflags & FLAG_REPLY != 0) {
+		dispatchReply();
+	else {
+		dispatchRequest();
+void CoasterChannel::dispatchReply() {
+	if (commands.count(rtag) == 0) {
+		throw new CoasterError("Received reply to unknown command (tag: %d)", rtag);
+	Command* cmd = commands[rtag];
+	if (rflags & FLAG_SIGNAL != 0) {
+		try {
+			cmd->signalReceived(msg.buf);
+		catch (exception &e) {
+			Logger::singleton() << endl;
+			LogWarn << endl;
+			LogWarn << "Command::signalReceived() threw exception: " << e.what() << endl;
+		catch (...) {
+			LogWarn << "Command::signalReceived() threw unknown exception" << endl;
+	else {
+		cmd->dataReceived(msg.buf, rflags);
+		if (rflags & FLAG_FINAL) {
+			unregisterCommand(cmd);
+			try {
+				cmd->receiveCompleted(rflags);
+				LogWarn << "Command::receiveCompleted() threw exception: " << e.what() << endl;
+			catch (...) {
+				LogWarn << "Command::receiveCompleted() threw unknown exception" << endl;
+void CoasterChannel::dispatchRequest() {
+	if (handlers.count(rtag) == 0) {
+		// initial request
+		string* name = msg.buf->str();
+		Handler* h = handlerFactory->newInstance(name);
+		if (h == NULL) {
+			LogWarn << "Unknown handler: " << name << endl;
+		else {
+			registerHandler(rtag, h);
+		delete name;
+	else {
+		Handler* h = handlers[rtag];
+			try {
+				h->signalReceived(msg.buf);
+				LogWarn << "Handler::signalReceived() threw exception: " << e.what() << endl;
+			catch (...) {
+				LogWarn << "Handler::signalReceived() threw unknown exception" << endl;
+		else {
+			h->dataReceived(msg.buf, rflags);
+				try{
+					h->receiveCompleted(rflags);
+					LogWarn << "Handler::receiveCompleted() threw exception: " << e.what() << endl;
+				catch (...) {
+					LogWarn << "Handler::receiveCompleted() threw unknown exception" << endl;
+bool CoasterChannel::write() { Lock::Scoped l(writeLock);
+	DataChunk* dc = sendQueue.front();
+	Buffer* buf = dc->buf;
+	int ret = socksend(sockFD, buf->getData(), (buf->getLen() - dc->bufpos), MSG_DONTWAIT);
+	if (ret == -1) {
+			return false;
+		else {
+			throw CoasterError("Socket write error: %s", strerror(errno));
+	else {
+		if (dc->bufpos == buf->getLen()) {
+			sendQueue.pop_front();
+			if (dc->cb != NULL) {
+				try {
+					dc->cb->dataSent(buf);
+					LogWarn << "Callback threw exception: " << e.what() << endl;
+				catch (...) {
+					LogWarn << "Callback threw unknown exception" << endl;
+		return true;
+void CoasterChannel::makeHeader(int tag, Buffer* buf, int flags) {
+	whdr.reset();
+	Buffer* hdr = whdr.buf;
+	hdr->putInt(0, tag);
+	hdr->putInt(4, flags);
+	hdr->putInt(8, buf->getLen());
+	hdr->putInt(12, tag ^ flags ^ buf->getLen());
+	hdr->putInt(16, 0);
+void CoasterChannel::decodeHeader(int* tag, int* flags, int* len) {
+	Buffer* buf = rhdr.buf;
+	*tag = buf->getInt(0);
+	*flags = buf->getInt(4);
+	*len = buf->getInt(8);
+	int hcsum = buf->getInt(12);
+	int ccsum = *tag ^ *flags ^ *len;
+	if (hcsum != ccsum) {
+		throw CoasterError("Header checksum failed. Received checksum: %d, computed checksum: %d", hcsum, ccsum);
+void CoasterChannel::registerCommand(Command* cmd) {
+	int tag = tagSeq++;
+	cmd->setTag(tag);
+	commands[tag] = cmd;
+void CoasterChannel::unregisterCommand(Command* cmd) {
+	commands.erase(cmd->getTag());
+void CoasterChannel::registerHandler(int tag, Handler* h) {
+	h->setTag(tag);
+	handlers[tag] = h;
+void CoasterChannel::unregisterHandler(Handler* h) {
+	handlers.erase(h->getTag());
+void CoasterChannel::send(int tag, Buffer* buf, int flags, ChannelCallback* cb) { Lock::Scoped l(writeLock);
+	makeHeader(tag, buf, flags);
+	sendQueue.push_back(&whdr);
+	sendQueue.push_back(new DataChunk(buf, cb));
+	loop->requestWrite(this);
+CoasterClient* CoasterChannel::getClient() {
+	return client;
+void CoasterChannel::checkHeartbeat() {
+	Command* cmd = new HeartBeatCommand();
+	cmd->send(this);
+void CoasterChannel::errorReceived(Command* cmd, string* message, string* details) {
+	delete cmd;
+	LogWarn << "Heartbeat failed: " << message << endl;
+void CoasterChannel::replyReceived(Command* cmd) {
+	delete cmd;
+ * Without this, GCC gets confused by CoasterChannel::send.
+int socksend(int fd, const char* buf, int len, int flags) {
+	return send(fd, buf, len, flags);
Index: modules/provider-coaster-c-client/src/CoasterLoop.cpp
--- modules/provider-coaster-c-client/src/CoasterLoop.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterLoop.cpp	(revision 3460)
@@ -0,0 +1,239 @@
+ * coaster-loop.cpp
+ *      Author: mike
+#include <unistd.h>
+#include <fcntl.h>
+#include <errno.h>
+void* run(void* ptr);
+void checkSelectError(int ret);
+CoasterLoop::CoasterLoop() {
+	started = false;
+	done = false;
+	socketCount = 0;
+	FD_ZERO(&rfds);
+	FD_ZERO(&wfds);
+void CoasterLoop::start() { Lock::Scoped l(lock);
+	if (started) {
+		return;
+	time(&lastHeartbeatCheck);
+	if (pipe2(wakePipe, O_NONBLOCK) != 0) {
+			throw CoasterError(string("Could not create pipe: ") + strerror(errno));
+	FD_SET(wakePipe[0], &rfds);
+	thread = pthread_create(&thread, NULL, run, this);
+	started = 1;
+void CoasterLoop::stop() { Lock::Scoped l(lock);
+	if (!started) {
+		return;
+	done = 1;
+void* run(void* ptr) {
+	struct timeval timeout;
+	CoasterLoop* loop = (CoasterLoop*) ptr;
+	fd_set myrfds, mywfds;
+	fd_set* rfds = loop->getReadFDs();
+	fd_set* wfds = loop->getWriteFDs();
+	while(1) {
+		{ Lock::Scoped l(loop->lock);
+			if (loop->done) {
+				loop->started = false;
+				break;
+			loop->addSockets();
+			loop->removeSockets();
+		timeout.tv_sec = 0.1;
+		timeout.tv_usec = 0;
+		// fd sets are updated by select, so make new ones every time
+		memcpy(&myrfds, rfds, sizeof(myrfds));
+		int ret = select(loop->getMaxFD() + 1, &myrfds, NULL, NULL, &timeout);
+		checkSelectError(ret);
+		// can read or has data to write
+		// try to read from each socket
+		if (!loop->readSockets(&myrfds)) {
+			// no channel sockets had anything to read, so there is data to write
+				// synchronize when copying wfds since they are concurrently updated
+				// based on whether a channel has stuff to write or not
+				memcpy(&mywfds, wfds, sizeof(mywfds));
+			timeout.tv_sec = 0;
+			// don't wait; just see if any sockets that need to be written to
+			// can be written to
+			int ret = select(loop->getMaxFD() + 1, NULL, &mywfds, NULL, &timeout);
+			loop->writeSockets(&mywfds);
+		loop->checkHeartbeats();
+	return NULL;
+bool CoasterLoop::readSockets(fd_set* fds) {
+	map<int, CoasterChannel*>::iterator it;
+	bool writePending = false;
+	for (it = channelMap.begin(); it != channelMap.end(); ++it) {
+		if (FD_ISSET(it->first, fds)) {
+			if (it->first == getWakePipeReadFD()) {
+				writePending = true;
+			else {
+				it->second->read();
+	return writePending;
+void CoasterLoop::writeSockets(fd_set* fds) {
+			if (it->second->write()) {
+				acknowledgeWake();
+void checkSelectError(int ret) {
+	if (ret < 0) {
+		if (errno == EBADF) {
+			// at least one fd is invalid/has an error
+		else {
+			throw CoasterError(string("Error in select: ") + strerror(errno));
+void CoasterLoop::addSockets() {
+	// must be called with lock held
+	list<CoasterChannel*>::iterator i;
+	for (i = addList.begin(); i != addList.end(); ++i) {
+		int sockFD = (*i)->getSockFD();
+		FD_SET(sockFD, &rfds);
+		channelMap[sockFD] = *i;
+		socketCount++;
+	updateMaxFD();
+	addList.clear();
+void CoasterLoop::removeSockets() {
+	for (i = removeList.begin(); i != removeList.end(); ++i) {
+		FD_CLR(sockFD, &rfds);
+		channelMap.erase(sockFD);
+		socketCount--;
+	updateMaxFD();
+	removeList.clear();
+void CoasterLoop::addChannel(CoasterChannel* channel) { Lock::Scoped l(lock);
+	addList.push_back(channel);
+void CoasterLoop::removeChannel(CoasterChannel* channel) { Lock::Scoped l(lock);
+	removeList.push_back(channel);
+void CoasterLoop::awake() {
+	int result = write(wakePipe[1], "0", 1);
+void CoasterLoop::acknowledgeWake() {
+	char buf[1];
+	int result = read(wakePipe[0], buf, 1);
+fd_set* CoasterLoop::getReadFDs() {
+	return &rfds;
+fd_set* CoasterLoop::getWriteFDs() {
+	return &wfds;
+int CoasterLoop::getMaxFD() {
+	return maxFD;
+void CoasterLoop::updateMaxFD() {
+	maxFD = getWakePipeReadFD();
+		if (maxFD < it->first) {
+			maxFD = it->first;
+int CoasterLoop::getWakePipeReadFD() {
+	return wakePipe[0];
+void CoasterLoop::requestWrite(CoasterChannel* channel) { Lock::Scoped l(lock);
+	FD_SET(channel->getSockFD(), &wfds);
+	updateMaxFD();
+	awake();
+void CoasterLoop::checkHeartbeats() {
+	time_t now;
+	time(&now);
+	if (now - lastHeartbeatCheck > HEARTBEAT_CHECK_INTERVAL) {
+		lastHeartbeatCheck = now;
+				it->second->checkHeartbeat();
Index: modules/provider-coaster-c-client/src/ConditionVariable.cpp
--- modules/provider-coaster-c-client/src/ConditionVariable.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/ConditionVariable.cpp	(revision 3460)
@@ -0,0 +1,28 @@
+ * ConditionVariable.cpp
+ *      Author: mike
+#include "ConditionVariable.h"
+ConditionVariable::ConditionVariable() {
+	pthread_cond_init(&cv, NULL);
+ConditionVariable::~ConditionVariable() {
+	pthread_cond_destroy(&cv);
+void ConditionVariable::wait(Lock& lock) {
+	pthread_cond_wait(&cv, lock.getMutex());
+void ConditionVariable::signal() {
+	pthread_cond_signal(&cv);
+void ConditionVariable::broadcast() {
+	pthread_cond_broadcast(&cv);
Index: modules/provider-coaster-c-client/src/HeartBeatCommand.cpp
--- modules/provider-coaster-c-client/src/HeartBeatCommand.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/HeartBeatCommand.cpp	(revision 3460)
@@ -0,0 +1,38 @@
+ * HeartBeatCommand.cpp
+ *      Author: mike
+#include <sstream>
+string HeartBeatCommand::NAME("HEARTBEAT");
+HeartBeatCommand::HeartBeatCommand(): Command(&NAME) {
+HeartBeatCommand::~HeartBeatCommand() {
+void HeartBeatCommand::send(CoasterChannel* channel, CommandCallback* cb) {
+	timeval now;
+	gettimeofday(&now, NULL);
+	sendtime = now.tv_sec * 1000 + now.tv_usec / 1000;
+	addOutData(new StaticBuffer(sendtime));
+	Command::send(channel, cb);
+void HeartBeatCommand::dataSent(Buffer* buf) {
+	delete buf;
+void HeartBeatCommand::replyReceived() {
+	long rectime = getInData()->at(0)->getLong(0);
+	LogInfo << "Latency for " << getChannel() << ": " << (rectime - sendtime) << endl;
Index: modules/provider-coaster-c-client/src/StagingSetEntry.h
--- modules/provider-coaster-c-client/src/StagingSetEntry.h	(revision 0)
+++ modules/provider-coaster-c-client/src/StagingSetEntry.h	(revision 3460)
@@ -0,0 +1,30 @@
+ * StagingSetEntry.h
+ *  Created on: Aug 11, 2012
+ *      Author: mike
+#ifndef STAGINGSETENTRY_H_
+#define STAGINGSETENTRY_H_
+#include <string>
+enum StagingMode { ALWAYS = 1, IF_PRESENT = 2, ON_ERROR = 4, ON_SUCCESS = 8 };
+class StagingSetEntry {
+	private:
+		string source;
+		string destination;
+		StagingMode mode;
+	public:
+		StagingSetEntry(string source, string destination, StagingMode mode);
+		string getSource();
+		string getDestination();
+		StagingMode getMode();
+		virtual ~StagingSetEntry();
+#endif /* STAGINGSETENTRY_H_ */
Index: modules/provider-coaster-c-client/src/CommandCallback.h
--- modules/provider-coaster-c-client/src/CommandCallback.h	(revision 0)
+++ modules/provider-coaster-c-client/src/CommandCallback.h	(revision 3460)
@@ -0,0 +1,25 @@
+ * CommandCallback.h
+ *      Author: mike
+#ifndef COMMANDCALLBACK_H_
+#define COMMANDCALLBACK_H_
+#include <string>
+class Command;
+class CommandCallback {
+	public:
+		virtual void errorReceived(Command* cmd, string* message, string* details) = 0;
+		virtual void replyReceived(Command* cmd) = 0;
+#endif /* COMMANDCALLBACK_H_ */
Index: modules/provider-coaster-c-client/src/Flags.h
--- modules/provider-coaster-c-client/src/Flags.h	(revision 0)
+++ modules/provider-coaster-c-client/src/Flags.h	(revision 3460)
@@ -0,0 +1,16 @@
+ * Constants.h
+ *      Author: mike
+#ifndef CONSTANTS_H_
+#define CONSTANTS_H_
+#define FLAG_ERROR 0x04
+#define FLAG_REPLY 0x01
+#define FLAG_SIGNAL 0x10
+#define FLAG_FINAL 0x02
+#endif /* CONSTANTS_H_ */
Index: modules/provider-coaster-c-client/src/JobSubmitCommand.h
--- modules/provider-coaster-c-client/src/JobSubmitCommand.h	(revision 0)
+++ modules/provider-coaster-c-client/src/JobSubmitCommand.h	(revision 3460)
@@ -0,0 +1,26 @@
+#ifndef JOB_SUBMIT_COMMAND_H_
+#define JOB_SUBMIT_COMMAND_H_
+#include "Job.h"
+#include <vector>
+#include <string>
+class JobSubmitCommand: public Command {
+	private:
+		Job* job;
+	public:
+		JobSubmitCommand(Job* job);
+		Job* getJob();
+	private:
+		void serialize();
+#endif
Index: modules/provider-coaster-c-client/src/CoasterClient.h
--- modules/provider-coaster-c-client/src/CoasterClient.h	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterClient.h	(revision 3460)
@@ -0,0 +1,77 @@
+ * coaster-client.h
+ *      Author: mike
+#ifndef COASTER_CLIENT_H_
+#define COASTER_CLIENT_H_
+#include <string>
+#include "Lock.h"
+#include "Job.h"
+#include <list>
+#include <map>
+#include <netdb.h>
+class CoasterLoop;
+class ConnectionError: public exception {
+	private:
+	public:
+		ConnectionError(string msg);
+class CoasterClient: public CommandCallback {
+	private:
+		Lock lock;
+		ConditionVariable cv;
+		string URL;
+		CoasterChannel* channel;
+		bool started;
+		int sockFD;
+		int getPort();
+		string getHostName();
+		struct addrinfo* resolve(const char* hostName, int port);
+		map<const string*, Job*> jobs;
+		list<Job*> doneJobs;
+	public:
+		CoasterClient(string URL, CoasterLoop& loop);
+		void start();
+		void stop();
+		void submit(Job& job);
+		void waitForJob(Job& job);
+		list<Job*>* getAndPurgeDoneJobs();
+		void waitForJobs();
+		void updateJobStatus(string& jobId, JobStatus* status);
+		string& getURL();
+#endif /* COASTER_CLIENT_H_ */
Index: modules/provider-coaster-c-client/src/HandlerFactory.cpp
--- modules/provider-coaster-c-client/src/HandlerFactory.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/HandlerFactory.cpp	(revision 3460)
@@ -0,0 +1,38 @@
+ * HandlerFactory.cpp
+ *      Author: mike
+HandlerFactory::HandlerFactory() {
+HandlerFactory::~HandlerFactory() {
+template<typename T> Handler * newHandler() { return new T; }
+template<typename T> void HandlerFactory::addHandler(string name) {
+	creators[name] = &newHandler<T>;
+Handler* HandlerFactory::newInstance(string& name) {
+	if (creators.count(name) == 0) {
+		return NULL;
+	else {
+		return creators[name]();
+Handler* HandlerFactory::newInstance(const string* name) {
+	if (creators.count(*name) == 0) {
+		return NULL;
+	else {
+		return creators[*name]();
Index: modules/provider-coaster-c-client/src/RequestReply.h
--- modules/provider-coaster-c-client/src/RequestReply.h	(revision 0)
+++ modules/provider-coaster-c-client/src/RequestReply.h	(revision 3460)
@@ -0,0 +1,60 @@
+ * RequestReply.h
+ *      Author: mike
+#ifndef REQUESTREPLY_H_
+#define REQUESTREPLY_H_
+#include "Flags.h"
+#include <vector>
+class RequestReply: public ChannelCallback {
+	private:
+		vector<Buffer*> outData;
+		vector<Buffer*> inData;
+		vector<Buffer*>* errorData;
+		void clearBufferVector(vector<Buffer*>& v);
+	protected:
+		virtual void addOutData(Buffer*);
+		virtual void addInData(Buffer*);
+		virtual void addErrorData(Buffer*);
+		virtual vector<Buffer*>* getOutData();
+		virtual vector<Buffer*>* getErrorData();
+		virtual vector<Buffer*>* getInData();
+		int getInDataAsInt(int index);
+		long getInDataAsLong(int index);
+		void getInDataAsString(int index, string& dest);
+		string getErrorString();
+		int tag;
+	public:
+		RequestReply();
+		virtual ~RequestReply();
+		void setChannel(CoasterChannel* pchannel);
+		CoasterChannel* getChannel();
+		void setTag(int ptag);
+		int getTag();
+		virtual void dataReceived(Buffer*, int flags);
+		virtual void signalReceived(Buffer*);
+		virtual void receiveCompleted(int flags) = 0;
+#endif /* REQUESTREPLY_H_ */
Index: modules/provider-coaster-c-client/src/ClientHandlerFactory.h
--- modules/provider-coaster-c-client/src/ClientHandlerFactory.h	(revision 0)
+++ modules/provider-coaster-c-client/src/ClientHandlerFactory.h	(revision 3460)
@@ -0,0 +1,19 @@
+ * ClientHandlerFactory.h
+ *      Author: mike
+#ifndef CLIENTHANDLERFACTORY_H_
+#define CLIENTHANDLERFACTORY_H_
+class ClientHandlerFactory: public HandlerFactory {
+	public:
+		ClientHandlerFactory();
+		virtual ~ClientHandlerFactory();
+#endif /* CLIENTHANDLERFACTORY_H_ */
Index: modules/provider-coaster-c-client/src/Buffer.cpp
--- modules/provider-coaster-c-client/src/Buffer.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/Buffer.cpp	(revision 3460)
@@ -0,0 +1,161 @@
+ * Buffer.cpp
+ *      Author: mike
+Buffer::Buffer(int plen) {
+	len = plen;
+int Buffer::getLen() const {
+	return len;
+const char* Buffer::getData() {
+	return NULL;
+char* Buffer::getModifiableData() {
+	throw logic_error("putInt called on static buffer");
+void Buffer::setData(const char* pdata) {
+	throw logic_error("illegal operation: Buffer::setData()");
+Buffer::~Buffer() {
+string* Buffer::str() {
+	return new string(getData(), getLen());
+int Buffer::getInt(int index) {
+	if (index + 4 > getLen()) {
+		throw out_of_range("getInt index out of range");
+	const char* buf = getData();
+	int value = 0;
+	index += 3;
+	for (int i = 0; i < 4; i++) {
+		value <<= 8;
+		value = value + (0x000000ff & buf[index--]);
+	return value;
+long Buffer::getLong(int index) {
+	if (index + 8 > getLen()) {
+		throw out_of_range("getLong index out of range");
+	long value = 0;
+	index += 7;
+	for (int i = 0; i < 8; i++) {
+		value <<= 8;
+		value = value + (0x00000000000000ffL & buf[index--]);
+	return value;
+void Buffer::putInt(int index, int value) {
+		throw out_of_range("putInt index out of range");
+	char* buf = getModifiableData();
+		buf[index++] = value & 0x000000ff;
+		value >>= 8;
+void Buffer::putLong(int index, long value) {
+		throw out_of_range("putLong index out of range");
+		buf[index++] = value & 0x00000000000000ffL;
+		value >>= 8;
+Buffer* Buffer::wrap(int i) {
+	DynamicBuffer* b = new DynamicBuffer(4);
+	b->putInt(0, i);
+	return b;
+Buffer* Buffer::wrap(long l) {
+	DynamicBuffer* b = new DynamicBuffer(8);
+	b->putLong(0, l);
+	return b;
+Buffer* Buffer::wrap(const char* data, int len) {
+	StaticBuffer* b = new StaticBuffer(len);
+	b->setData(data);
+	return b;
+Buffer* Buffer::wrap(string s) {
+	StaticBuffer* b = new StaticBuffer(s.length());
+	b->setData(s.data());
+	return b;
+Buffer* Buffer::wrap(const string* s) {
+	StaticBuffer* b = new StaticBuffer(s->length());
+	b->setData(s->data());
+	return b;
+ostream& operator<< (ostream& os, Buffer& buf) {
+	const char* data = buf.getData();
+	int len = buf.getLen();
+	for (int i = 0; i < len; i++) {
+		os.put(data[i]);
+	return os;
+StaticBuffer::StaticBuffer(int plen): Buffer(plen) {
+const char* StaticBuffer::getData() {
+	return data;
+void StaticBuffer::setData(const char* pdata) {
+	data = pdata;
+StaticBuffer::~StaticBuffer() {
+DynamicBuffer::DynamicBuffer(int plen): Buffer(plen) {
+	data = (char *) malloc(len);
+const char* DynamicBuffer::getData() {
+	return data;
+char* DynamicBuffer::getModifiableData() {
+	return data;
+DynamicBuffer::~DynamicBuffer() {
+	free(data);
Index: modules/provider-coaster-c-client/src/Job.cpp
--- modules/provider-coaster-c-client/src/Job.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/Job.cpp	(revision 3460)
@@ -0,0 +1,211 @@
+#include "Job.h"
+#include <sstream>
+static int seq = 0;
+Job::Job(string pexecutable) {
+	executable = pexecutable;
+	stringstream ss;
+	ss << "job-";
+	ss << seq++;
+	identity = ss.str();
+	arguments = NULL;
+	directory = NULL;
+	stdinLocation = NULL;
+	stdoutLocation = NULL;
+	stderrLocation = NULL;
+	jobManager = NULL;
+	env = NULL;
+	attributes = NULL;
+	stageIns = NULL;
+	stageOuts = NULL;
+	cleanups = NULL;
+	stdout = NULL;
+	stderr = NULL;
+	status = NULL;
+string& Job::getIdentity() {
+	return identity;
+vector<string*>* Job::getArguments() {
+	return arguments;
+void Job::addArgument(string& arg) {
+	if (arguments == NULL) {
+		arguments = new vector<string*>;
+	arguments->push_back(new string(arg));
+string& Job::getExecutable() {
+	return executable;
+void Job::addArgument(const char* arg) {
+	addArgument(*(new string(arg)));
+string* Job::getDirectory() {
+	return directory;
+void Job::setDirectory(string& pdirectory) {
+	directory = &pdirectory;
+string* Job::getStdinLocation() {
+	return stdinLocation;
+void Job::setStdinLocation(string& loc) {
+	stdinLocation = &loc;
+string* Job::getStdoutLocation() {
+	return stdoutLocation;
+void Job::setStdoutLocation(string& loc) {
+	stdoutLocation = &loc;
+string* Job::getStderrLocation() {
+	return stderrLocation;
+void Job::setStderrLocation(string& loc) {
+	stderrLocation = &loc;
+string* Job::getJobManager() {
+	return jobManager;
+void Job::setJobManager(string& jm) {
+	jobManager = &jm;
+map<string, string>* Job::getEnv() {
+	return env;
+string* Job::getEnv(string name) {
+	if (env == NULL) {
+		return NULL;
+	else {
+		map<string, string>::iterator it;
+		it = env->find(name);
+		if (it == env->end()) {
+			return NULL;
+		else {
+			return &(it->second);
+void Job::setEnv(string name, string value) {
+		env = new map<string, string>;
+	env->insert(pair<string, string>(name, value));
+map<string, string>* Job::getAttributes() {
+	return attributes;
+string* Job::getAttribute(string name) {
+	if (attributes == NULL) {
+		return NULL;
+	else {
+		it = attributes->find(name);
+		if (it == attributes->end()) {
+			return NULL;
+		else {
+void Job::setAttribute(string name, string value) {
+		attributes = new map<string, string>;
+	attributes->insert(pair<string, string>(name, value));
+vector<StagingSetEntry>* Job::getStageIns() {
+	return stageIns;
+void Job::addStageIn(string src, string dest, StagingMode mode) {
+	if (stageIns == NULL) {
+		stageIns = new vector<StagingSetEntry>;
+	stageIns->push_back(StagingSetEntry(src, dest, mode));
+vector<StagingSetEntry>* Job::getStageOuts() {
+	return stageOuts;
+void Job::addStageOut(string src, string dest, StagingMode mode) {
+	if (stageOuts == NULL) {
+		stageOuts = new vector<StagingSetEntry>;
+	stageOuts->push_back(StagingSetEntry(src, dest, mode));
+vector<string>* Job::getCleanups() {
+	return cleanups;
+void Job::addCleanup(string cleanup) {
+	if (cleanups == NULL) {
+		cleanups = new vector<string>;
+	cleanups->push_back(cleanup);
+string* Job::getStderr() {
+	return stderr;
+string* Job::getStdout() {
+	return stdout;
+JobStatus* Job::getStatus() {
+	return status;
+void Job::setStatus(JobStatus* newStatus) {
+	newStatus->setPreviousStatus(status);
+	status = newStatus;
+Job::~Job() {
+	if (status != NULL) {
+		delete status;
+	if (arguments != NULL) {
+		for (int i = 0; i < arguments->size(); i++) {
+			delete arguments->at(i);
+		delete arguments;
Index: modules/provider-coaster-c-client/src/CoasterError.cpp
--- modules/provider-coaster-c-client/src/CoasterError.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/CoasterError.cpp	(revision 3460)
@@ -0,0 +1,31 @@
+ * CoasterError.cpp
+ *      Author: mike
+CoasterError::CoasterError(string msg) {
+CoasterError::CoasterError(const char* format, ...) {
+	va_list args;
+	char* buf = (char *) malloc(MAX_MSG_LEN + 1);
+	va_start(args, format);
+	vsnprintf(buf, MAX_MSG_LEN, format, args);
+	va_end(args);
+	message = buf;
+CoasterError::CoasterError(const stringstream* ss) {
+	message = ss->str().c_str();
+const char* CoasterError::what() const throw() {
+	return message;
Index: modules/provider-coaster-c-client/src/JobStatusHandler.cpp
--- modules/provider-coaster-c-client/src/JobStatusHandler.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/JobStatusHandler.cpp	(revision 3460)
@@ -0,0 +1,33 @@
+ * JobStatusHandler.cpp
+ *      Author: mike
+#include <sstream>
+JobStatusHandler::JobStatusHandler() {
+JobStatusHandler::~JobStatusHandler() {
+void JobStatusHandler::requestReceived() {
+	string jobId, msg;
+	getInDataAsString(0, jobId);
+	JobStatusCode statusCode = (JobStatusCode) getInDataAsInt(1);
+	int exitCode = getInDataAsInt(2);
+	getInDataAsString(3, msg);
+	long timestamp = getInDataAsLong(4);
+	if (statusCode == FAILED && msg.length() == 0) {
+		stringstream ss;
+		ss << "Job failed with an exit code of " << exitCode;
+		msg.assign(ss.str());
+	JobStatus* s = new JobStatus(statusCode, timestamp, &msg, NULL);
+	getChannel()->getClient()->updateJobStatus(jobId, s);
Index: modules/provider-coaster-c-client/src/Handler.cpp
--- modules/provider-coaster-c-client/src/Handler.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/Handler.cpp	(revision 3460)
@@ -0,0 +1,60 @@
+void Handler::receiveCompleted(int flags) {
+		errorReceived();
+	else {
+		requestReceived();
+void Handler::errorReceived() {
+	vector<Buffer*>* errorData = getErrorData();
+		LogWarn << "Unspecified error receiving request." << endl;
+	else if (errorData->size() == 1) {
+		string* msg = errorData->at(0)->str();
+		LogWarn << "Error receiving request: " << msg << endl;
+		delete msg;
+	else {
+		string* detail = errorData->at(1)->str();
+		LogWarn << "Error receiving request: " << msg << "\n" << detail << endl;
+		delete msg;
+		delete detail;
+void Handler::requestReceived() {
+	sendReply("OK");
+void Handler::sendReply(string& msg) {
+	addOutData(Buffer::wrap(msg));
+	send(getChannel());
+void Handler::sendReply(const char* msg) {
+void Handler::send(CoasterChannel* channel) {
+	vector<Buffer*>* od = getOutData();
+	for (i = od->begin(); i != od->end(); i++) {
+		channel->send(tag, *i, FLAG_REPLY + (i == --od->end() ? FLAG_FINAL : 0), this);
+	channel->unregisterHandler(this);
+void Handler::dataSent(Buffer* buf) {
+	delete buf;
Index: modules/provider-coaster-c-client/src/Command.cpp
--- modules/provider-coaster-c-client/src/Command.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/Command.cpp	(revision 3460)
@@ -0,0 +1,76 @@
+Command::Command(const string* pname) {
+	name = pname;
+const string* Command::getName() {
+	return name;
+void Command::send(CoasterChannel* channel) {
+	send(channel, NULL);
+ostream& operator<< (ostream& os, Command* cmd) {
+	os << "Command[" << cmd->getName() << ", tag: " << cmd->getTag() << "]";
+	return os;
+void Command::send(CoasterChannel* channel, CommandCallback* pcb) {
+	cb = pcb;
+	channel->registerCommand(this);
+	channel->send(tag, Buffer::wrap(name), od->empty() ? FLAG_FINAL : 0, this);
+		channel->send(tag, *i, i == --od->end() ? FLAG_FINAL : 0, this);
+void Command::receiveCompleted(int flags) {
+		errorReceived();
+	else {
+		replyReceived();
+void Command::errorReceived() {
+	if (cb != NULL) {
+			cb->errorReceived(this, NULL, NULL);
+			cb->errorReceived(this, msg, NULL);
+			delete msg;
+		else {
+			cb->errorReceived(this, msg, detail);
+			delete msg;
+			delete detail;
+void Command::replyReceived() {
+	if (cb != NULL) {
+		cb->replyReceived(this);
+void Command::dataSent(Buffer* buf) {
+	delete buf;
Index: modules/provider-coaster-c-client/src/JobStatus.h
--- modules/provider-coaster-c-client/src/JobStatus.h	(revision 0)
+++ modules/provider-coaster-c-client/src/JobStatus.h	(revision 3460)
@@ -0,0 +1,59 @@
+ * job-status.h
+ *      Author: mike
+#ifndef JOB_STATUS_H_
+#define JOB_STATUS_H_
+#include <time.h>
+#include <string>
+#include <iostream>
+enum JobStatusCode {
+	UNSUBMITTED = 0,
+	SUBMITTING = 8,
+	SUBMITTED = 1,
+	ACTIVE = 2,
+	SUSPENDED = 3,
+	RESUMED = 4,
+	FAILED = 5,
+	CANCELED = 6,
+	COMPLETED = 7,
+	STAGE_IN = 16,
+	STAGE_OUT = 17,
+	UNKNOWN = 9999
+class JobStatus {
+	JobStatusCode statusCode;
+	time_t stime;
+	string* message;
+	string* exception;
+	JobStatus* prev;
+	public:
+		JobStatus(JobStatusCode statusCode, time_t time, const string* message, const string* exception);
+		JobStatus(JobStatusCode statusCode, const string* message, const string* exception);
+		JobStatus(JobStatusCode statusCode);
+		JobStatus();
+		virtual ~JobStatus();
+		JobStatusCode getStatusCode();
+		time_t getTime();
+		string* getMessage();
+		string* getException();
+		const JobStatus* getPreviousStatus();
+		void setPreviousStatus(JobStatus* prev);
+		static const char* statusCodeToStr(JobStatusCode code);
+		bool isTerminal();
+		friend ostream& operator<< (ostream& os, JobStatus& s);
+		friend ostream& operator<< (ostream& os, JobStatus* s);
+#endif /* JOB_STATUS_H_ */
Index: modules/provider-coaster-c-client/src/Logger.h
--- modules/provider-coaster-c-client/src/Logger.h	(revision 0)
+++ modules/provider-coaster-c-client/src/Logger.h	(revision 3460)
@@ -0,0 +1,65 @@
+ * Logger.h
+ *      Author: mike
+#ifndef LOGGER_H_
+#define LOGGER_H_
+#define TS_LEN 28
+#include <fstream>
+#include <string>
+class Logger: public ostream {
+	public:
+		enum Level { NONE = -1, DEBUG = 0, INFO = 1, WARN = 2, ERROR = 3, FATAL = 4 };
+		static Logger* instance;
+	private:
+		ostream* out;
+		Level level;
+		const char* file;
+		const char* strLevel;
+		char ts[TS_LEN + 1];
+		bool flushed;
+	protected:
+		Logger(ostream& out);
+		void setLevel(Level level);
+		const char* levelToStr(Level level);
+		void header();
+		char* timeStamp();
+	public:
+		virtual ~Logger();
+		Logger& operator<< (Level level);
+		Logger& operator<< (string str);
+		Logger& operator<< (const string* str);
+		Logger& operator<< (const char* str);
+		Logger& operator<< (int i);
+		Logger& operator<< (long l);
+		Logger& operator<< (ostream& ( *pf )(ostream&));
+		Logger& setFile(const char* file);
+		Logger& flush();
+		void log(Level level, const char* fileName, const char* msg);
+		void log(Level level, const char* fileName, string msg);
+		static Logger& singleton();
+class StdoutLogger: public Logger {
+	public:
+		StdoutLogger();
+		virtual ~StdoutLogger();
+#define LogError Logger::singleton().setFile(__FILE__) << Logger::ERROR
+#define LogWarn Logger::singleton().setFile(__FILE__) << Logger::WARN
+#define LogInfo Logger::singleton().setFile(__FILE__) << Logger::INFO
+#define LogDebug Logger::singleton().setFile(__FILE__) << Logger::DEBUG
+#endif /* LOGGER_H_ */
Index: modules/provider-coaster-c-client/src/Makefile.am
--- modules/provider-coaster-c-client/src/Makefile.am	(revision 0)
+++ modules/provider-coaster-c-client/src/Makefile.am	(revision 3460)
@@ -0,0 +1,28 @@
+bin_PROGRAMS = CoasterClientTest
+CoasterClientTest_SOURCES = CoasterClientTest.cpp
+CoasterClientTest_LDADD = libcoasterclient.la
+lib_LTLIBRARIES = libcoasterclient.la
+libcoasterclient_la_SOURCES = Lock.h Lock.cpp \
+	ConditionVariable.h ConditionVariable.cpp \
+	CommandCallback.h \
+	Buffer.h Buffer.cpp \
+	SerUtil.h \
+	Logger.h Logger.cpp \
+	HandlerFactory.h HandlerFactory.cpp \
+	ChannelCallback.h ChannelCallback.cpp \
+	CoasterCannel.h CoasterChannel.cpp \
+	CoasterClient.h CoasterClient.cpp \
+	CoasterLoop.h CoasterLoop.cpp \
+	RequestReply.h RequestReply.cpp \
+	Command.h Command.cpp \
+	Handler.h Handler.cpp \
+	JobStatus.h JobStatus.cpp \
+	Job.h Job.cpp \
+	JobSubmitCommand.h JobSubmitCommand.cpp \
+	StagingSetEntry.h StagingSetEntry.cpp \
+	CoasterError.h CoasterError.cpp \
+	JobStatusHandler.h JobStatusHandler.cpp \
+	HeartBeatCommand.h HeartBeatCommand.cpp
Index: modules/provider-coaster-c-client/src/ChannelCallback.h
--- modules/provider-coaster-c-client/src/ChannelCallback.h	(revision 0)
+++ modules/provider-coaster-c-client/src/ChannelCallback.h	(revision 3460)
@@ -0,0 +1,20 @@
+ * ChannelCallback.h
+ *      Author: mike
+#ifndef CHANNELCALLBACK_H_
+#define CHANNELCALLBACK_H_
+class ChannelCallback {
+	public:
+		ChannelCallback();
+		virtual ~ChannelCallback();
+		virtual void dataSent(Buffer* buf) = 0;
+#endif /* CHANNELCALLBACK_H_ */
Index: modules/provider-coaster-c-client/src/StagingSetEntry.cpp
--- modules/provider-coaster-c-client/src/StagingSetEntry.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/StagingSetEntry.cpp	(revision 3460)
@@ -0,0 +1,29 @@
+ * StagingSetEntry.cpp
+ *      Author: mike
+StagingSetEntry::StagingSetEntry(string psource, string pdestination, StagingMode pmode) {
+	source = psource;
+	destination = pdestination;
+	mode = pmode;
+string StagingSetEntry::getSource() {
+	return source;
+string StagingSetEntry::getDestination() {
+	return destination;
+StagingMode StagingSetEntry::getMode() {
+	return mode;
+StagingSetEntry::~StagingSetEntry() {
Index: modules/provider-coaster-c-client/src/JobSubmitCommand.cpp
--- modules/provider-coaster-c-client/src/JobSubmitCommand.cpp	(revision 0)
+++ modules/provider-coaster-c-client/src/JobSubmitCommand.cpp	(revision 3460)
@@ -0,0 +1,106 @@
+#include <cstring>
+#include <sstream>
+char* copyStr(const char* str);
+void add(stringstream& ss, const char* key, string* value);
+void add(stringstream& ss, const char* key, string value);
+void add(stringstream& ss, const char* key, const char* value);
+string JobSubmitCommand::NAME("SUBMITJOB");
+JobSubmitCommand::JobSubmitCommand(Job* pjob): Command(&NAME) {
+	job = pjob;
+void JobSubmitCommand::send(CoasterChannel* channel, CommandCallback* cb) {
+	serialize();
+Job* JobSubmitCommand::getJob() {
+	return job;
+void JobSubmitCommand::serialize() {
+	addOutData(Buffer::wrap(getName()));
+	stringstream ss;
+	add(ss, "identity", job->getIdentity());
+	add(ss, "executable", job->getExecutable());
+	add(ss, "directory", job->getDirectory());
+	add(ss, "stdin", job->getStdinLocation());
+	add(ss, "stdout", job->getStdoutLocation());
+	add(ss, "stderr", job->getStderrLocation());
+	vector<string*>* arguments = job->getArguments();
+		for (vector<string*>::iterator i = arguments->begin(); i != arguments->end(); ++i) {
+			add(ss, "arg", *i);
+	map<string, string>* env = job->getEnv();
+	if (env != NULL) {
+		for (map<string, string>::iterator i = env->begin(); i != env->end(); ++i) {
+			stringstream tmp;
+			tmp << i->first;
+			tmp << "=";
+			tmp << i->second;
+			add(ss, "env", tmp.str().c_str());
+	map<string, string>* attributes = job->getAttributes();
+	if (attributes != NULL) {
+		for (map<string, string>::iterator i = attributes->begin(); i != attributes->end(); ++i) {
+			stringstream tmp;
+			tmp << i->first;
+			tmp << "=";
+			tmp << i->second;
+			add(ss, "attr", tmp.str().c_str());
+	if (job->getJobManager() == NULL) {
+		add(ss, "jm", "fork");
+	else {
+		add(ss, "jm", job->getJobManager());
+	addOutData(Buffer::wrap(ss.str()));
+void add(stringstream& ss, const char* key, string* value) {
+	if (value != NULL) {
+		add(ss, key, value->c_str());
+void add(stringstream& ss, const char* key, string value) {
+	add(ss, key, value.c_str());
+void add(stringstream& ss, const char* key, const char* value) {
+		ss << key << "=";
+		while (*value) {
+			char c = *value;
+			switch (c) {
+				case '\n':
+					c = 'n';
+				case '\\':
+					ss << '\\';
+				default:
+					ss << c;
+			value++;
Index: modules/provider-coaster-c-client/src/Lock.h
--- modules/provider-coaster-c-client/src/Lock.h	(revision 0)
+++ modules/provider-coaster-c-client/src/Lock.h	(revision 3460)
@@ -0,0 +1,34 @@
+ * Lock.h
+ *      Author: mike
+#ifndef LOCK_H_
+#define LOCK_H_
+class Lock {
+	private:
+		pthread_mutex_t l;
+	public:
+		Lock();
+		virtual ~Lock();
+		void lock();
+		void unlock();
+		pthread_mutex_t* getMutex();
+		class Scoped {
+			private:
+				Lock* myLock;
+			public:
+				Scoped(Lock& plock);
+				virtual ~Scoped();
+#endif /* LOCK_H_ */
Index: modules/provider-coaster-c-client/.cproject
--- modules/provider-coaster-c-client/.cproject	(revision 0)
+++ modules/provider-coaster-c-client/.cproject	(revision 3460)
@@ -0,0 +1,688 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<?fileVersion 4.0.0?>
+<cproject storage_type_id="org.eclipse.cdt.core.XmlProjectDescriptionStorage">
+	<storageModule moduleId="org.eclipse.cdt.core.settings">
+		<cconfiguration id="org.eclipse.linuxtools.cdt.autotools.core.configuration.build.1741424405">
+			<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="org.eclipse.linuxtools.cdt.autotools.core.configuration.build.1741424405" moduleId="org.eclipse.cdt.core.settings" name="Build (GNU)">
+				<externalSettings/>
+				<extensions>
+					<extension id="org.eclipse.cdt.core.ELF" point="org.eclipse.cdt.core.BinaryParser"/>
+					<extension id="org.eclipse.cdt.core.GNU_ELF" point="org.eclipse.cdt.core.BinaryParser"/>
+					<extension id="org.eclipse.cdt.core.MakeErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
+					<extension id="org.eclipse.cdt.core.GCCErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
+					<extension id="org.eclipse.cdt.core.GASErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
+					<extension id="org.eclipse.cdt.core.GLDErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
+				</extensions>
+			</storageModule>
+			<storageModule moduleId="scannerConfiguration">
+				<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId=""/>
+				<profile id="org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile">
+					<buildOutputProvider>
+						<openAction enabled="true" filePath=""/>
+						<parser enabled="true"/>
+					</buildOutputProvider>
+					<scannerInfoProvider id="specsFile">
+						<runAction arguments="-E -P -v -dD ${plugin_state_location}/${specs_file}" command="gcc" useDefault="true"/>
+					</scannerInfoProvider>
+				</profile>
+				<profile id="org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile">
+					<scannerInfoProvider id="makefileGenerator">
+						<runAction arguments="-E -P -v -dD" command="" useDefault="true"/>
+				</profile>
+				<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile">
+				</profile>
+				<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP">
+						<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.cpp" command="g++" useDefault="true"/>
+				</profile>
+				<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC">
+						<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.c" command="gcc" useDefault="true"/>
+				</profile>
+				<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile">
+						<runAction arguments="-c 'gcc -E -P -v -dD "${plugin_state_location}/${specs_file}"'" command="sh" useDefault="true"/>
+				</profile>
+				<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP">
+						<runAction arguments="-c 'g++ -E -P -v -dD "${plugin_state_location}/specs.cpp"'" command="sh" useDefault="true"/>
+				</profile>
+				<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC">
+						<runAction arguments="-c 'gcc -E -P -v -dD "${plugin_state_location}/specs.c"'" command="sh" useDefault="true"/>
+				</profile>
+				<profile id="org.eclipse.ptp.rdt.core.RemoteGCCStandardMakePerProjectProfile">
+						<runAction arguments="-E -P -v -dD ${specs_file_path}" command="gcc" useDefault="true"/>
+				</profile>
+				<scannerConfigBuildInfo instanceId="cdt.managedbuild.config.gnu.so.debug.2120212018;cdt.managedbuild.config.gnu.so.debug.2120212018.;cdt.managedbuild.tool.gnu.c.compiler.so.debug.705570784;cdt.managedbuild.tool.gnu.c.compiler.input.83140249">
+					<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC"/>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+				</scannerConfigBuildInfo>
+				<scannerConfigBuildInfo instanceId="cdt.managedbuild.config.gnu.so.release.900885378;cdt.managedbuild.config.gnu.so.release.900885378.;cdt.managedbuild.tool.gnu.c.compiler.so.release.897273566;cdt.managedbuild.tool.gnu.c.compiler.input.1489389094">
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+					</profile>
+			</storageModule>
+			<storageModule moduleId="cdtBuildSystem" version="4.0.0">
+				<configuration artifactName="${ProjName}" buildArtefactType="org.eclipse.linuxtools.cdt.autotools.core.buildArtefactType.autotools" buildProperties="org.eclipse.cdt.build.core.buildArtefactType=org.eclipse.linuxtools.cdt.autotools.core.buildArtefactType.autotools" cleanCommand="rm -rf" description="" errorParsers="org.eclipse.cdt.core.MakeErrorParser;org.eclipse.cdt.core.GCCErrorParser;org.eclipse.cdt.core.GLDErrorParser;org.eclipse.cdt.core.GASErrorParser" id="org.eclipse.linuxtools.cdt.autotools.core.configuration.build.1741424405" name="Build (GNU)" parent="org.eclipse.linuxtools.cdt.autotools.core.configuration.build">
+					<folderInfo id="org.eclipse.linuxtools.cdt.autotools.core.configuration.build.1741424405." name="/" resourcePath="">
+						<toolChain id="org.eclipse.linuxtools.cdt.autotools.core.toolChain.1284732845" name="GNU Autotools Toolchain" superClass="org.eclipse.linuxtools.cdt.autotools.core.toolChain">
+							<targetPlatform id="org.eclipse.linuxtools.cdt.autotools.core.toolchain.targetPlatform.1492195252" isAbstract="false" name="GNU Autotools Target Platform" superClass="org.eclipse.linuxtools.cdt.autotools.core.toolchain.targetPlatform"/>
+							<builder id="org.eclipse.linuxtools.cdt.autotools.core.toolchain.builder.293319211" keepEnvironmentInBuildfile="false" managedBuildOn="true" superClass="org.eclipse.linuxtools.cdt.autotools.core.toolchain.builder"/>
+							<tool id="org.eclipse.linuxtools.cdt.autotools.core.gnu.toolchain.tool.configure.382117173" name="configure" superClass="org.eclipse.linuxtools.cdt.autotools.core.gnu.toolchain.tool.configure">
+								<option id="org.eclipse.linuxtools.cdt.autotools.core.option.configure.name.1625301134" superClass="org.eclipse.linuxtools.cdt.autotools.core.option.configure.name" value="org.eclipse.linuxtools.cdt.autotools.core.configuration.build.1741424405" valueType="string"/>
+							</tool>
+							<tool id="org.eclipse.linuxtools.cdt.autotools.core.toolchain.tool.autogen.1994545804" name="autogen.sh" superClass="org.eclipse.linuxtools.cdt.autotools.core.toolchain.tool.autogen"/>
+							<tool id="org.eclipse.linuxtools.cdt.autotools.core.toolchain.tool.gcc.1622970238" name="GCC C Compiler" superClass="org.eclipse.linuxtools.cdt.autotools.core.toolchain.tool.gcc">
+								<inputType id="cdt.managedbuild.tool.gnu.c.compiler.input.774141483" superClass="cdt.managedbuild.tool.gnu.c.compiler.input"/>
+							</tool>
+							<tool id="org.eclipse.linuxtools.cdt.autotools.core.toolchain.tool.gpp.950725862" name="GCC C++ Compiler" superClass="org.eclipse.linuxtools.cdt.autotools.core.toolchain.tool.gpp"/>
+						</toolChain>
+					</folderInfo>
+					<sourceEntries>
+						<entry flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name="src"/>
+					</sourceEntries>
+				</configuration>
+			</storageModule>
+			<storageModule moduleId="org.eclipse.cdt.core.externalSettings"/>
+			<storageModule moduleId="org.eclipse.cdt.make.core.buildtargets">
+				<buildTargets>
+					<target name="all" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildCommand>make</buildCommand>
+						<buildArguments/>
+						<buildTarget>all</buildTarget>
+						<stopOnError>true</stopOnError>
+						<useDefaultCommand>true</useDefaultCommand>
+						<runAllBuilders>false</runAllBuilders>
+					</target>
+					<target name="am--refresh" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>am--refresh</buildTarget>
+					</target>
+					<target name="check" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>check</buildTarget>
+					</target>
+					<target name="clean" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>clean</buildTarget>
+					</target>
+					<target name="ctags" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>ctags</buildTarget>
+					</target>
+					<target name="ctags-recursive" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>ctags-recursive</buildTarget>
+					</target>
+					<target name="dist" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist</buildTarget>
+					</target>
+					<target name="dist-all" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-all</buildTarget>
+					</target>
+					<target name="dist-bzip2" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-bzip2</buildTarget>
+					</target>
+					<target name="dist-gzip" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-gzip</buildTarget>
+					</target>
+					<target name="dist-lzip" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-lzip</buildTarget>
+					</target>
+					<target name="dist-lzma" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-lzma</buildTarget>
+					</target>
+					<target name="dist-shar" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-shar</buildTarget>
+					</target>
+					<target name="dist-tarZ" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-tarZ</buildTarget>
+					</target>
+					<target name="dist-xz" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-xz</buildTarget>
+					</target>
+					<target name="dist-zip" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dist-zip</buildTarget>
+					</target>
+					<target name="distcheck" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>distcheck</buildTarget>
+					</target>
+					<target name="distclean" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>distclean</buildTarget>
+					</target>
+					<target name="distclean-tags" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>distclean-tags</buildTarget>
+					</target>
+					<target name="distcleancheck" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>distcleancheck</buildTarget>
+					</target>
+					<target name="distdir" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>distdir</buildTarget>
+					</target>
+					<target name="distuninstallcheck" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>distuninstallcheck</buildTarget>
+					</target>
+					<target name="dvi" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>dvi</buildTarget>
+					</target>
+					<target name="html" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>html</buildTarget>
+					</target>
+					<target name="info" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>info</buildTarget>
+					</target>
+					<target name="install" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install</buildTarget>
+					</target>
+					<target name="install-data" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-data</buildTarget>
+					</target>
+					<target name="install-dvi" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-dvi</buildTarget>
+					</target>
+					<target name="install-exec" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-exec</buildTarget>
+					</target>
+					<target name="install-html" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-html</buildTarget>
+					</target>
+					<target name="install-info" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-info</buildTarget>
+					</target>
+					<target name="install-man" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-man</buildTarget>
+					</target>
+					<target name="install-pdf" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-pdf</buildTarget>
+					</target>
+					<target name="install-ps" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-ps</buildTarget>
+					</target>
+					<target name="install-strip" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>install-strip</buildTarget>
+					</target>
+					<target name="installcheck" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>installcheck</buildTarget>
+					</target>
+					<target name="installdirs" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>installdirs</buildTarget>
+					</target>
+					<target name="maintainer-clean" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>maintainer-clean</buildTarget>
+					</target>
+					<target name="Makefile" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>Makefile</buildTarget>
+					</target>
+					<target name="mostlyclean" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>mostlyclean</buildTarget>
+					</target>
+					<target name="pdf" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>pdf</buildTarget>
+					</target>
+					<target name="ps" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>ps</buildTarget>
+					</target>
+					<target name="tags" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>tags</buildTarget>
+					</target>
+					<target name="tags-recursive" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>tags-recursive</buildTarget>
+					</target>
+					<target name="uninstall" path="" targetID="org.eclipse.cdt.build.MakeTargetBuilder">
+						<buildArguments/>
+						<buildTarget>uninstall</buildTarget>
+					</target>
+				</buildTargets>
+			</storageModule>
+		</cconfiguration>
+	</storageModule>
+		<project id="provider-coaster-c-client.org.eclipse.linuxtools.cdt.autotools.core.projectType.1749205663" name="GNU Autotools" projectType="org.eclipse.linuxtools.cdt.autotools.core.projectType"/>
+	</storageModule>
+</cproject>
Index: modules/provider-coaster-c-client/ChangeLog
Index: modules/provider-coaster-c-client/README
--- modules/provider-coaster-c-client/README	(revision 0)
+++ modules/provider-coaster-c-client/README	(revision 3460)
@@ -0,0 +1 @@
+It only compiles, so don't assume that it works!
\ No newline at end of file
Index: modules/provider-coaster-c-client/configure.ac
--- modules/provider-coaster-c-client/configure.ac	(revision 0)
+++ modules/provider-coaster-c-client/configure.ac	(revision 3460)
@@ -0,0 +1,39 @@
+AC_PREREQ([2.68])
+AC_INIT(coaster-c-client, 1.0)
+AC_CONFIG_AUX_DIR(config)
+AC_CONFIG_SRCDIR(src/CoasterClient.cpp)
+#AC_CONFIG_HEADERS([config.h])
+AC_CONFIG_MACRO_DIR([m4])
+AM_INIT_AUTOMAKE
+LT_INIT
+AC_LIBTOOL_CXX
+# Checks for programs.
+AC_PROG_CXX
+AC_PROG_AWK
+AC_PROG_CC
+AC_PROG_CPP
+AC_PROG_INSTALL
+AC_PROG_LN_S
+AC_PROG_MAKE_SET
+AC_PROG_RANLIB
+# Checks for header files.
+AC_CHECK_HEADERS([arpa/inet.h fcntl.h netdb.h netinet/in.h stdlib.h string.h sys/socket.h sys/time.h unistd.h])
+# Libs
+AC_CHECK_LIB(pthread, pthread_create)
+# Checks for typedefs, structures, and compiler characteristics.
+AC_HEADER_STDBOOL
+AC_TYPE_SIZE_T
+# Checks for library functions.
+AC_FUNC_MALLOC
+AC_CHECK_FUNCS([gettimeofday memset select socket strerror strrchr])
+AC_OUTPUT(Makefile src/Makefile)
Index: modules/provider-coaster-c-client/INSTALL
--- modules/provider-coaster-c-client/INSTALL	(revision 0)
+++ modules/provider-coaster-c-client/INSTALL	(revision 3460)
@@ -0,0 +1,370 @@
+Installation Instructions
+Copyright (C) 1994-1996, 1999-2002, 2004-2011 Free Software Foundation,
+Inc.
+   Copying and distribution of this file, with or without modification,
+are permitted in any medium without royalty provided the copyright
+notice and this notice are preserved.  This file is offered as-is,
+without warranty of any kind.
+Basic Installation
+   Briefly, the shell commands `./configure; make; make install' should
+configure, build, and install this package.  The following
+more-detailed instructions are generic; see the `README' file for
+instructions specific to this package.  Some packages provide this
+`INSTALL' file but do not implement all of the features documented
+below.  The lack of an optional feature in a given package is not
+necessarily a bug.  More recommendations for GNU packages can be found
+in *note Makefile Conventions: (standards)Makefile Conventions.
+   The `configure' shell script attempts to guess correct values for
+various system-dependent variables used during compilation.  It uses
+those values to create a `Makefile' in each directory of the package.
+It may also create one or more `.h' files containing system-dependent
+definitions.  Finally, it creates a shell script `config.status' that
+you can run in the future to recreate the current configuration, and a
+file `config.log' containing compiler output (useful mainly for
+debugging `configure').
+   It can also use an optional file (typically called `config.cache'
+and enabled with `--cache-file=config.cache' or simply `-C') that saves
+the results of its tests to speed up reconfiguring.  Caching is
+disabled by default to prevent problems with accidental use of stale
+cache files.
+   If you need to do unusual things to compile the package, please try
+to figure out how `configure' could check whether to do them, and mail
+diffs or instructions to the address given in the `README' so they can
+be considered for the next release.  If you are using the cache, and at
+some point `config.cache' contains results you don't want to keep, you
+may remove or edit it.
+   The file `configure.ac' (or `configure.in') is used to create
+`configure' by a program called `autoconf'.  You need `configure.ac' if
+you want to change it or regenerate `configure' using a newer version
+of `autoconf'.
+   The simplest way to compile this package is:
+  1. `cd' to the directory containing the package's source code and type
+     `./configure' to configure the package for your system.
+     Running `configure' might take a while.  While running, it prints
+     some messages telling which features it is checking for.
+  2. Type `make' to compile the package.
+  3. Optionally, type `make check' to run any self-tests that come with
+     the package, generally using the just-built uninstalled binaries.
+  4. Type `make install' to install the programs and any data files and
+     documentation.  When installing into a prefix owned by root, it is
+     recommended that the package be configured and built as a regular
+     user, and only the `make install' phase executed with root
+     privileges.
+  5. Optionally, type `make installcheck' to repeat any self-tests, but
+     this time using the binaries in their final installed location.
+     This target does not install anything.  Running this target as a
+     regular user, particularly if the prior `make install' required
+     root privileges, verifies that the installation completed
+     correctly.
+  6. You can remove the program binaries and object files from the
+     source code directory by typing `make clean'.  To also remove the
+     files that `configure' created (so you can compile the package for
+     a different kind of computer), type `make distclean'.  There is
+     also a `make maintainer-clean' target, but that is intended mainly
+     for the package's developers.  If you use it, you may have to get
+     all sorts of other programs in order to regenerate files that came
+     with the distribution.
+  7. Often, you can also type `make uninstall' to remove the installed
+     files again.  In practice, not all packages have tested that
+     uninstallation works correctly, even though it is required by the
+     GNU Coding Standards.
+  8. Some packages, particularly those that use Automake, provide `make
+     distcheck', which can by used by developers to test that all other
+     targets like `make install' and `make uninstall' work correctly.
+     This target is generally not run by end users.
+Compilers and Options
+   Some systems require unusual options for compilation or linking that
+the `configure' script does not know about.  Run `./configure --help'
+for details on some of the pertinent environment variables.
+   You can give `configure' initial values for configuration parameters
+by setting variables in the command line or in the environment.  Here
+is an example:
+     ./configure CC=c99 CFLAGS=-g LIBS=-lposix
+   *Note Defining Variables::, for more details.
+Compiling For Multiple Architectures
+   You can compile the package for more than one kind of computer at the
+same time, by placing the object files for each architecture in their
+own directory.  To do this, you can use GNU `make'.  `cd' to the
+directory where you want the object files and executables to go and run
+the `configure' script.  `configure' automatically checks for the
+source code in the directory that `configure' is in and in `..'.  This
+is known as a "VPATH" build.
+   With a non-GNU `make', it is safer to compile the package for one
+architecture at a time in the source code directory.  After you have
+installed the package for one architecture, use `make distclean' before
+reconfiguring for another architecture.
+   On MacOS X 10.5 and later systems, you can create libraries and
+executables that work on multiple system types--known as "fat" or
+"universal" binaries--by specifying multiple `-arch' options to the
+compiler but only a single `-arch' option to the preprocessor.  Like
+this:
+     ./configure CC="gcc -arch i386 -arch x86_64 -arch ppc -arch ppc64" \
+                 CXX="g++ -arch i386 -arch x86_64 -arch ppc -arch ppc64" \
+                 CPP="gcc -E" CXXCPP="g++ -E"
+   This is not guaranteed to produce working output in all cases, you
+may have to build one architecture at a time and combine the results
+using the `lipo' tool if you have problems.
+Installation Names
+   By default, `make install' installs the package's commands under
+`/usr/local/bin', include files under `/usr/local/include', etc.  You
+can specify an installation prefix other than `/usr/local' by giving
+`configure' the option `--prefix=PREFIX', where PREFIX must be an
+absolute file name.
+   You can specify separate installation prefixes for
+architecture-specific files and architecture-independent files.  If you
+pass the option `--exec-prefix=PREFIX' to `configure', the package uses
+PREFIX as the prefix for installing programs and libraries.
+Documentation and other data files still use the regular prefix.
+   In addition, if you use an unusual directory layout you can give
+options like `--bindir=DIR' to specify different values for particular
+kinds of files.  Run `configure --help' for a list of the directories
+you can set and what kinds of files go in them.  In general, the
+default for these options is expressed in terms of `${prefix}', so that
+specifying just `--prefix' will affect all of the other directory
+specifications that were not explicitly provided.
+   The most portable way to affect installation locations is to pass the
+correct locations to `configure'; however, many packages provide one or
+both of the following shortcuts of passing variable assignments to the
+`make install' command line to change installation locations without
+having to reconfigure or recompile.
+   The first method involves providing an override variable for each
+affected directory.  For example, `make install
+prefix=/alternate/directory' will choose an alternate location for all
+directory configuration variables that were expressed in terms of
+`${prefix}'.  Any directories that were specified during `configure',
+but not in terms of `${prefix}', must each be overridden at install
+time for the entire installation to be relocated.  The approach of
+makefile variable overrides for each directory variable is required by
+the GNU Coding Standards, and ideally causes no recompilation.
+However, some platforms have known limitations with the semantics of
+shared libraries that end up requiring recompilation when using this
+method, particularly noticeable in packages that use GNU Libtool.
+   The second method involves providing the `DESTDIR' variable.  For
+example, `make install DESTDIR=/alternate/directory' will prepend
+`/alternate/directory' before all installation names.  The approach of
+`DESTDIR' overrides is not required by the GNU Coding Standards, and
+does not work on platforms that have drive letters.  On the other hand,
+it does better at avoiding recompilation issues, and works well even
+when some directory options were not specified in terms of `${prefix}'
+at `configure' time.
+Optional Features
+   If the package supports it, you can cause programs to be installed
+with an extra prefix or suffix on their names by giving `configure' the
+option `--program-prefix=PREFIX' or `--program-suffix=SUFFIX'.
+   Some packages pay attention to `--enable-FEATURE' options to
+`configure', where FEATURE indicates an optional part of the package.
+They may also pay attention to `--with-PACKAGE' options, where PACKAGE
+is something like `gnu-as' or `x' (for the X Window System).  The
+`README' should mention any `--enable-' and `--with-' options that the
+package recognizes.
+   For packages that use the X Window System, `configure' can usually
+find the X include and library files automatically, but if it doesn't,
+you can use the `configure' options `--x-includes=DIR' and
+`--x-libraries=DIR' to specify their locations.
+   Some packages offer the ability to configure how verbose the
+execution of `make' will be.  For these packages, running `./configure
+--enable-silent-rules' sets the default to minimal output, which can be
+overridden with `make V=1'; while running `./configure
+--disable-silent-rules' sets the default to verbose, which can be
+overridden with `make V=0'.
+Particular systems
+   On HP-UX, the default C compiler is not ANSI C compatible.  If GNU
+CC is not installed, it is recommended to use the following options in
+order to use an ANSI C compiler:
+     ./configure CC="cc -Ae -D_XOPEN_SOURCE=500"
+and if that doesn't work, install pre-built binaries of GCC for HP-UX.
+   HP-UX `make' updates targets which have the same time stamps as
+their prerequisites, which makes it generally unusable when shipped
+generated files such as `configure' are involved.  Use GNU `make'
+instead.
+   On OSF/1 a.k.a. Tru64, some versions of the default C compiler cannot
+parse its `<wchar.h>' header file.  The option `-nodtk' can be used as
+a workaround.  If GNU CC is not installed, it is therefore recommended
+to try
+     ./configure CC="cc"
+and if that doesn't work, try
+     ./configure CC="cc -nodtk"
+   On Solaris, don't put `/usr/ucb' early in your `PATH'.  This
+directory contains several dysfunctional programs; working variants of
+these programs are available in `/usr/bin'.  So, if you need `/usr/ucb'
+in your `PATH', put it _after_ `/usr/bin'.
+   On Haiku, software installed for all users goes in `/boot/common',
+not `/usr/local'.  It is recommended to use the following options:
+     ./configure --prefix=/boot/common
+Specifying the System Type
+   There may be some features `configure' cannot figure out
+automatically, but needs to determine by the type of machine the package
+will run on.  Usually, assuming the package is built to be run on the
+_same_ architectures, `configure' can figure that out, but if it prints
+a message saying it cannot guess the machine type, give it the
+`--build=TYPE' option.  TYPE can either be a short name for the system
+type, such as `sun4', or a canonical name which has the form:
+     CPU-COMPANY-SYSTEM
+where SYSTEM can have one of these forms:
+     OS
+     KERNEL-OS
+   See the file `config.sub' for the possible values of each field.  If
+`config.sub' isn't included in this package, then this package doesn't
+need to know the machine type.
+   If you are _building_ compiler tools for cross-compiling, you should
+use the option `--target=TYPE' to select the type of system they will
+produce code for.
+   If you want to _use_ a cross compiler, that generates code for a
+platform different from the build platform, you should specify the
+"host" platform (i.e., that on which the generated programs will
+eventually be run) with `--host=TYPE'.
+Sharing Defaults
+   If you want to set default values for `configure' scripts to share,
+you can create a site shell script called `config.site' that gives
+default values for variables like `CC', `cache_file', and `prefix'.
+`configure' looks for `PREFIX/share/config.site' if it exists, then
+`PREFIX/etc/config.site' if it exists.  Or, you can set the
+`CONFIG_SITE' environment variable to the location of the site script.
+A warning: not all `configure' scripts look for a site script.
+Defining Variables
+   Variables not defined in a site shell script can be set in the
+environment passed to `configure'.  However, some packages may run
+configure again during the build, and the customized values of these
+variables may be lost.  In order to avoid this problem, you should set
+them in the `configure' command line, using `VAR=value'.  For example:
+     ./configure CC=/usr/local2/bin/gcc
+causes the specified `gcc' to be used as the C compiler (unless it is
+overridden in the site shell script).
+Unfortunately, this technique does not work for `CONFIG_SHELL' due to
+an Autoconf bug.  Until the bug is fixed you can use this workaround:
+     CONFIG_SHELL=/bin/bash /bin/bash ./configure CONFIG_SHELL=/bin/bash
+`configure' Invocation
+   `configure' recognizes the following options to control how it
+operates.
+`--help'
+`-h'
+     Print a summary of all of the options to `configure', and exit.
+`--help=short'
+`--help=recursive'
+     Print a summary of the options unique to this package's
+     `configure', and exit.  The `short' variant lists options used
+     only in the top level, while the `recursive' variant lists options
+     also present in any nested packages.
+`--version'
+`-V'
+     Print the version of Autoconf used to generate the `configure'
+     script, and exit.
+`--cache-file=FILE'
+     Enable the cache: use and save the results of the tests in FILE,
+     traditionally `config.cache'.  FILE defaults to `/dev/null' to
+     disable caching.
+`--config-cache'
+`-C'
+     Alias for `--cache-file=config.cache'.
+`--quiet'
+`--silent'
+`-q'
+     Do not print messages saying which checks are being made.  To
+     suppress all normal output, redirect it to `/dev/null' (any error
+     messages will still be shown).
+`--srcdir=DIR'
+     Look for the package's source code in directory DIR.  Usually
+     `configure' can determine that directory automatically.
+`--prefix=DIR'
+     Use DIR as the installation prefix.  *note Installation Names::
+     for more details, including other options available for fine-tuning
+     the installation locations.
+`--no-create'
+`-n'
+     Run the configure checks, but stop before creating any output
+     files.
+`configure' also accepts some other, not widely useful, options.  Run
+`configure --help' for more details.
Index: modules/provider-coaster-c-client/.autotools
--- modules/provider-coaster-c-client/.autotools	(revision 0)
+++ modules/provider-coaster-c-client/.autotools	(revision 3460)
@@ -0,0 +1,37 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<configurations>
+<configuration id="org.eclipse.linuxtools.cdt.autotools.core.configuration.build.1741424405">
+<option id="configure" value="configure"/>
+<option id="configdir" value=""/>
+<option id="cache-file" value=""/>
+<option id="help" value="false"/>
+<option id="no-create" value="false"/>
+<option id="quiet" value="false"/>
+<option id="version" value="false"/>
+<option id="host" value=""/>
+<option id="build" value=""/>
+<option id="target" value=""/>
+<option id="prefix" value=""/>
+<option id="exec-prefix" value=""/>
+<option id="libdir" value=""/>
+<option id="bindir" value=""/>
+<option id="sbindir" value=""/>
+<option id="includedir" value=""/>
+<option id="datadir" value=""/>
+<option id="sysconfdir" value=""/>
+<option id="infodir" value=""/>
+<option id="mandir" value=""/>
+<option id="srcdir" value=""/>
+<option id="localstatedir" value=""/>
+<option id="sharedstatedir" value=""/>
+<option id="libexecdir" value=""/>
+<option id="oldincludedir" value=""/>
+<option id="program-prefix" value=""/>
+<option id="program-suffix" value=""/>
+<option id="program-transform-name" value=""/>
+<option id="enable-maintainer-mode" value="false"/>
+<option id="user" value=""/>
+<option id="autogen" value="autogen.sh"/>
+<option id="autogenOpts" value=""/>
+</configuration>
+</configurations>
Index: modules/provider-coaster-c-client/COPYING
--- modules/provider-coaster-c-client/COPYING	(revision 0)
+++ modules/provider-coaster-c-client/COPYING	(revision 3460)
@@ -0,0 +1 @@
+<Place your desired license here.>
Index: modules/provider-coaster-c-client/Makefile.am
--- modules/provider-coaster-c-client/Makefile.am	(revision 0)
+++ modules/provider-coaster-c-client/Makefile.am	(revision 3460)
@@ -0,0 +1,6 @@
+ACLOCAL_AMFLAGS = -I m4
+SUBDIRS = src
+EXTRA_DIST = autogen.sh
+LIBS="-pthread $LIBS"
+CXXFLAGS="$CFLAGS -pthread"
Index: modules/provider-coaster-c-client/autogen.sh
--- modules/provider-coaster-c-client/autogen.sh	(revision 0)
+++ modules/provider-coaster-c-client/autogen.sh	(revision 3460)
@@ -0,0 +1,23 @@
+#!/bin/sh
+run() {
+	checkerror
+	LAST="$@"
+	echo "$@"
+checkerror() {
+	if [ "$?" != "0" ]; then
+		echo "$LAST failed"
+		exit q
+	fi
+#autoreconf --force --install -I config -I . -I m4
+run libtoolize -i -f -c -q
+run aclocal
+run automake --gnu --add-missing
+run autoconf
+checkerror
+echo "Done"
Property changes on: modules/provider-coaster-c-client/autogen.sh
___________________________________________________________________
Added: svn:executable
Index: modules/provider-coaster-c-client/NEWS
