[Swift-commit] r5950 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu
Wed Sep 26 11:57:04 CDT 2012
Author: wozniak
Date: 2012-09-26 11:57:04 -0500 (Wed, 26 Sep 2012)
New Revision: 5950
Modified:
usertools/plotter/src/plotter/Lines.java
Log:
Support line.* property
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java 2012-09-25 20:34:39 UTC (rev 5949)
+++ usertools/plotter/src/plotter/Lines.java 2012-09-26 16:57:04 UTC (rev 5950)
@@ -238,6 +238,8 @@
Series series = collection.getSeries(i);
if (! showShape(series.getDescription()))
renderer.setSeriesShapesVisible(i, false);
+ if (! showLine(series.getDescription()))
+ renderer.setSeriesLinesVisible(i, false);
Plots.setupLegend(chart, properties);
@@ -420,6 +422,18 @@
return true;
+ static boolean showLine(String name)
+ String mode = properties.getProperty("line."+name);
+ // System.out.println(mode);
+ if ("none".equals(mode))
+ return false;
+ mode = properties.getProperty("line.all");
+ return false;
+ return true;
static String toString(double[][] array)
StringBuilder sb = new StringBuilder();
More information about the Swift-commit
