[Swift-commit] cog r3475
swift at ci.uchicago.edu
Fri Sep 21 02:45:03 CDT 2012
r3475 | hategan | 2012-09-21 02:44:51 -0500 (Fri, 21 Sep 2012) | 1 line
fixed file lock to work with concurrent threads in the same jvm
Index: modules/util/src/org/globus/cog/util/concurrent/FileLock.java
--- modules/util/src/org/globus/cog/util/concurrent/FileLock.java (revision 3474)
+++ modules/util/src/org/globus/cog/util/concurrent/FileLock.java (working copy)
@@ -18,6 +18,8 @@
import java.io.IOException;
import java.security.SecureRandom;
import java.util.Random;
+import java.util.concurrent.locks.Lock;
+import java.util.concurrent.locks.ReentrantLock;
import org.apache.log4j.Logger;
@@ -26,7 +28,7 @@
* It tries to use the PID as thread identifier with fallback to random numbers.
* The Entering and Number arrays are implemented as sparse arrays of
- * files in some directory.
+ * files in some directory. The lock is not re-entrant.
public class FileLock {
public static final Logger logger = Logger.getLogger(FileLock.class);
@@ -36,6 +38,8 @@
private int myId, myN;
private File dir;
+ private Lock jvmLocalLock;
+ private int lockCount;
public FileLock(String dir) {
this(new File(dir));
@@ -45,6 +49,7 @@
this.dir = dir;
dir.mkdirs();
this.myId = getId();
+ jvmLocalLock = new ReentrantLock();
private int getId() {
@@ -65,6 +70,7 @@
public void lock() throws IOException, InterruptedException {
+ jvmLocalLock.lock();
write(ENTERING, myId, 1);
write(NUMBER, myId, myN = 1 + maxNumber());
write(ENTERING, myId, 0);
@@ -185,6 +191,51 @@
public void unlock() throws IOException {
- write("locking.number", myId, 0);
+ try {
+ write("locking.number", myId, 0);
+ finally {
+ jvmLocalLock.unlock();
+ public static void main(String[] args) {
+ String dir = args[0];
+ int delay = Integer.parseInt(args[1]);
+ final FileLock l = new FileLock(dir);
+ try {
+ System.out.println(". " + l.getId());
+ l.lock();
+ System.out.println("+ " + l.getId());
+ try {
+ if (Math.random() < 0.1) {
+ new Thread() {
+ @Override
+ public void run() {
+ try {
+ System.out.println(". " + l.getId() + "x");
+ l.lock();
+ System.out.println("+ " + l.getId() + "x");
+ l.unlock();
+ System.out.println("- " + l.getId() + "x");
+ catch (Exception e) {
+ e.printStackTrace();
+ }.start();
+ Thread.sleep(delay);
+ finally {
+ l.unlock();
+ System.out.println("- " + l.getId());
+ System.exit(1);
More information about the Swift-commit
