[Swift-commit] r5941 - in SwiftApps/CMTS/scaling: . docs docs/images docs/images/icons docs/stylesheets input_files
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu Sep 20 15:16:33 CDT 2012
Author: davidk
Date: 2012-09-20 15:16:33 -0500 (Thu, 20 Sep 2012)
New Revision: 5941
Added:
   SwiftApps/CMTS/scaling/docs/
   SwiftApps/CMTS/scaling/docs/README
   SwiftApps/CMTS/scaling/docs/build_docs.sh
   SwiftApps/CMTS/scaling/docs/images/
   SwiftApps/CMTS/scaling/docs/images/icons/
   SwiftApps/CMTS/scaling/docs/images/icons/caution.png
   SwiftApps/CMTS/scaling/docs/images/icons/example.png
   SwiftApps/CMTS/scaling/docs/images/icons/home.png
   SwiftApps/CMTS/scaling/docs/images/icons/important.png
   SwiftApps/CMTS/scaling/docs/images/icons/next.png
   SwiftApps/CMTS/scaling/docs/images/icons/note.png
   SwiftApps/CMTS/scaling/docs/images/icons/prev.png
   SwiftApps/CMTS/scaling/docs/images/icons/tip.png
   SwiftApps/CMTS/scaling/docs/images/icons/up.png
   SwiftApps/CMTS/scaling/docs/images/icons/warning.png
   SwiftApps/CMTS/scaling/docs/stylesheets/
   SwiftApps/CMTS/scaling/docs/stylesheets/asciidoc.css
Modified:
   SwiftApps/CMTS/scaling/input_files/h0_eq.conf
   SwiftApps/CMTS/scaling/scaling.swift
Log:
Set PMEPencils to 0 to avoid crashes on buggy versions of namd
Doc building scripts
Added: SwiftApps/CMTS/scaling/docs/README
--- SwiftApps/CMTS/scaling/docs/README	                        (rev 0)
+++ SwiftApps/CMTS/scaling/docs/README	2012-09-20 20:16:33 UTC (rev 5941)
@@ -0,0 +1 @@
+link ../README
\ No newline at end of file
Property changes on: SwiftApps/CMTS/scaling/docs/README
___________________________________________________________________
Added: svn:special
Added: SwiftApps/CMTS/scaling/docs/build_docs.sh
--- SwiftApps/CMTS/scaling/docs/build_docs.sh	                        (rev 0)
+++ SwiftApps/CMTS/scaling/docs/build_docs.sh	2012-09-20 20:16:33 UTC (rev 5941)
@@ -0,0 +1,11 @@
+#!/bin/bash
+echo Converting README to HTML
+      asciidoc -a toc -a toclevels=2                            \
+               -a max-width=750px                               \
+               -a textwidth=80                                  \
+               -a stylesheet=$PWD/stylesheets/asciidoc.css	\
+               README
+echo Converting README to PDF
+        a2x --format=pdf --no-xmllint README
Property changes on: SwiftApps/CMTS/scaling/docs/build_docs.sh
Added: svn:executable
Added: SwiftApps/CMTS/scaling/docs/images/icons/caution.png
(Binary files differ)
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/caution.png
Added: svn:mime-type
   + application/octet-stream
Added: SwiftApps/CMTS/scaling/docs/images/icons/example.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/example.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/home.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/home.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/important.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/important.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/next.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/next.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/note.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/note.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/prev.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/prev.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/tip.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/tip.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/up.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/up.png
Added: SwiftApps/CMTS/scaling/docs/images/icons/warning.png
Property changes on: SwiftApps/CMTS/scaling/docs/images/icons/warning.png
Added: SwiftApps/CMTS/scaling/docs/stylesheets/asciidoc.css
--- SwiftApps/CMTS/scaling/docs/stylesheets/asciidoc.css	                        (rev 0)
+++ SwiftApps/CMTS/scaling/docs/stylesheets/asciidoc.css	2012-09-20 20:16:33 UTC (rev 5941)
@@ -0,0 +1,2 @@
+a:link { color:navy; }
+a:visited { color:navy; }
Modified: SwiftApps/CMTS/scaling/input_files/h0_eq.conf
--- SwiftApps/CMTS/scaling/input_files/h0_eq.conf	2012-09-20 20:07:35 UTC (rev 5940)
+++ SwiftApps/CMTS/scaling/input_files/h0_eq.conf	2012-09-20 20:16:33 UTC (rev 5941)
@@ -62,7 +62,7 @@
 stepspercycle       20
 PME                 yes
-PMEPencils          16
+PMEPencils          0
 PMETolerance     1.0e-6
 PMEInterpOrder   4
 PMEGridSpacing   1.0
Modified: SwiftApps/CMTS/scaling/scaling.swift
--- SwiftApps/CMTS/scaling/scaling.swift	2012-09-20 20:07:35 UTC (rev 5940)
+++ SwiftApps/CMTS/scaling/scaling.swift	2012-09-20 20:16:33 UTC (rev 5941)
@@ -17,7 +17,7 @@
 # Range of nodes to test on
 int minNodes=1;
-int maxNodes=4;
+int maxNodes=5;
 int delta=1;
 # Files
