[Swift-commit] r5932 - SwiftApps/CMTS/scaling/input_files
davidk at ci.uchicago.edu
Tue Sep 18 14:33:39 CDT 2012
Author: davidk
Date: 2012-09-18 14:33:39 -0500 (Tue, 18 Sep 2012)
New Revision: 5932
Added:
SwiftApps/CMTS/scaling/input_files/h0_eq.conf
Log:
namd config file
Added: SwiftApps/CMTS/scaling/input_files/h0_eq.conf
--- SwiftApps/CMTS/scaling/input_files/h0_eq.conf (rev 0)
+++ SwiftApps/CMTS/scaling/input_files/h0_eq.conf 2012-09-18 19:33:39 UTC (rev 5932)
@@ -0,0 +1,109 @@
+## JOB DESCRIPTION ##
+# Minimization and equilibration of waters with
+# protein held fixed to reduce artifacts
+set WORK _WORK_
+## ADJUSTABLE PARAMETERS ##
+structure $WORK/h0_solvion.psf
+coordinates $WORK/h0_solvion.pdb
+# Output Names ##
+set basename h0_eq.JOB
+outputName $WORK/OUT/$basename
+DCDfile $WORK/OUT/$basename.dcd
+restartname $WORK/RESTART/$basename.restart
+# Initial temperature
+set temperature 310
+# Continuing a job from the restart files
+if {1} {
+set inputname h0_eq.0
+binCoordinates $WORK/RESTART/$inputname.restart.coor
+binVelocities $WORK/RESTART/$inputname.restart.vel
+extendedSystem $WORK/RESTART/$inputname.restart.xsc
+firsttimestep 0
+## SIMULATION PARAMETERS ##
+# Input
+paraTypeCharmm on
+parameters $WORK/par_all22_prot.inp
+# Periodic Boundary Conditions from extended system cell (.xsc)
+wrapWater on
+wrapAll on
+# Force-Field Parameters
+exclude scaled1-4
+1-4scaling 1.0
+cutoff 12.0
+switching on
+switchdist 10.0
+pairlistdist 13.5
+# Integrator Parameters
+timestep 2.0 ;# 2fs/step
+rigidBonds all ;# needed for 2fs steps
+nonbondedFreq 2
+fullElectFrequency 2
+stepspercycle 20
+PME yes
+PMEPencils 16
+PMETolerance 1.0e-6
+PMEInterpOrder 4
+PMEGridSpacing 1.0
+# Constant Temperature Control
+langevin on ;# do langevin dynamics
+langevinDamping .5 ;# damping coefficient (gamma) of 5/ps
+langevinTemp $temperature
+langevinHydrogen off
+# Constant Pressure Control (variable volume)
+if {0} {
+useGroupPressure yes ;# needed for 2fs steps
+useFlexibleCell no ;# no for water box, yes for membrane
+useConstantArea no ;# no for water box, yes for membrane
+langevinPiston on
+langevinPistonTarget 1.01325 ;# in bar -> 1 atm
+langevinPistonPeriod 2000.0
+langevinPistonDecay 2000.0
+langevinPistonTemp $temperature
+restartfreq 20 ;# 1000steps = every 2ps
+dcdfreq 20
+xstFreq 20
+outputEnergies 20
+outputPressure 20
+## EXTRA PARAMETERS ##
+# Put here any custom parameters that are specific to
+# this job (e.g., SMD, TclForces, etc...)
+## EXECUTION SCRIPT ##
+run 5000
More information about the Swift-commit
