[Swift-commit] r5927 - in trunk/src/org/griphyn/vdl: karajan karajan/lib mapping mapping/file
hategan at ci.uchicago.edu
Sat Sep 15 03:59:46 CDT 2012
Author: hategan
Date: 2012-09-15 03:59:46 -0500 (Sat, 15 Sep 2012)
New Revision: 5927
Added:
trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java
Modified:
trunk/src/org/griphyn/vdl/karajan/Monitor.java
trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java
trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
trunk/src/org/griphyn/vdl/karajan/lib/New.java
trunk/src/org/griphyn/vdl/karajan/lib/NiceName.java
trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java
trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java
trunk/src/org/griphyn/vdl/mapping/DSHandle.java
trunk/src/org/griphyn/vdl/mapping/DataNode.java
trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java
trunk/src/org/griphyn/vdl/mapping/Mapper.java
trunk/src/org/griphyn/vdl/mapping/MapperFactory.java
trunk/src/org/griphyn/vdl/mapping/MappingParam.java
trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
trunk/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java
trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
Log:
typesafe (or namesafe?) class for mapper parameters; all swift internal parameters are prefixed with "swift#"
Modified: trunk/src/org/griphyn/vdl/karajan/Monitor.java
--- trunk/src/org/griphyn/vdl/karajan/Monitor.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/Monitor.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -37,13 +37,9 @@
import java.net.ServerSocket;
import java.net.Socket;
import java.util.ArrayList;
-import java.util.HashMap;
-import java.util.HashSet;
import java.util.Iterator;
-import java.util.LinkedList;
import java.util.List;
import java.util.Map;
-import java.util.Set;
import javax.swing.BorderFactory;
import javax.swing.JButton;
@@ -67,6 +63,7 @@
import org.griphyn.vdl.mapping.ArrayDataNode;
import org.griphyn.vdl.mapping.DSHandle;
import org.griphyn.vdl.mapping.DependentException;
+import org.griphyn.vdl.mapping.MappingParam;
import org.griphyn.vdl.mapping.Path;
public class Monitor implements ActionListener, MouseListener {
@@ -228,6 +225,9 @@
for (Map.Entry<DSHandle, Future> en : copy.entrySet()) {
Future f = en.getValue();
AbstractDataNode handle = (AbstractDataNode) en.getKey();
+ if (handle.isClosed()) {
+ continue;
String value = "-";
try {
if (handle.getValue() != null) {
@@ -244,8 +244,10 @@
ps.println(handle.getType() + " " + handle.getDisplayableName() + " " + value + " " + f);
catch (Exception e) {
- ps.println(handle.getDisplayableName() + " - error");
- e.printStackTrace(ps);
+ if (!handle.isClosed()) {
+ ps.println(handle.getDisplayableName() + " - error");
+ e.printStackTrace(ps);
ps.println("----");
@@ -280,9 +282,9 @@
public static String varWithLine(DSHandle value) {
- String line = value.getRoot().getParam("line");
+ String line = value.getRoot().getParam(MappingParam.SWIFT_LINE);
Path path = value.getPathFromRoot();
- return value.getRoot().getParam("dbgname") +
+ return value.getRoot().getParam(MappingParam.SWIFT_DBGNAME) +
(value == value.getRoot() ? "" : (path.isArrayIndex(0) ? path : "." + path)) +
(line == null ? "" : " (declared on line " + line + ")");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -17,7 +17,6 @@
package org.griphyn.vdl.karajan.lib;
-import java.util.Collections;
@@ -28,6 +27,8 @@
import org.globus.cog.karajan.workflow.ExecutionException;
import org.globus.cog.karajan.workflow.futures.FutureFault;
+import org.griphyn.vdl.mapping.MappingParamSet;
import org.griphyn.vdl.mapping.RootArrayDataNode;
import org.griphyn.vdl.type.Field;
@@ -102,9 +103,9 @@
private void setMapper(DSHandle handle) {
// slap a concurrent mapper on this
- Map<String, Object> params = new HashMap<String, Object>();
- params.put("descriptor", "concurrent_mapper");
- params.put("dbgname", "arrayexpr");
+ MappingParamSet params = new MappingParamSet();
+ params.set(MappingParam.SWIFT_DESCRIPTOR, "concurrent_mapper");
+ params.set(MappingParam.SWIFT_DBGNAME, "arrayexpr");
handle.init(params);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -29,6 +29,7 @@
import org.globus.cog.karajan.workflow.nodes.restartLog.LogEntry;
public class IsLogged extends VDLFunction {
@@ -51,7 +52,7 @@
public static boolean isLogged(VariableStack stack, DSHandle var, Path path) throws ExecutionException {
path = var.getPathFromRoot().append(path);
- LogEntry entry = LogEntry.build(var.getRoot().getParam("swift#restartid") + "." + path.stringForm());
+ LogEntry entry = LogEntry.build(var.getRoot().getParam(MappingParam.SWIFT_RESTARTID) + "." + path.stringForm());
Map map = getLogData(stack);
boolean found = false;
synchronized (map) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
--- trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -27,6 +27,7 @@
import org.globus.cog.karajan.workflow.nodes.restartLog.RestartLog;
public class LogVar extends VDLFunction {
@@ -57,7 +58,7 @@
} else {
annotation = "unmapped";
- RestartLog.LOG_CHANNEL.ret(stack, var.getRoot().getParam("swift#restartid")
+ RestartLog.LOG_CHANNEL.ret(stack, var.getRoot().getParam(MappingParam.SWIFT_RESTARTID)
+ "." + path.stringForm() + "!" + annotation);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -20,22 +20,22 @@
import org.apache.log4j.Logger;
import org.globus.cog.karajan.arguments.Arg;
import org.globus.cog.karajan.stack.VariableStack;
import org.globus.cog.karajan.util.TypeUtil;
+import org.griphyn.vdl.mapping.ExternalDataNode;
import org.griphyn.vdl.mapping.RootDataNode;
-import org.griphyn.vdl.mapping.ExternalDataNode;
import org.griphyn.vdl.mapping.file.ConcurrentMapper;
import org.griphyn.vdl.type.Type;
import org.griphyn.vdl.type.Types;
@@ -64,35 +64,34 @@
String dbgname = TypeUtil.toString(OA_DBGNAME.getValue(stack));
String waitfor = (String) OA_WAITFOR.getValue(stack);
String line = (String) getProperty("_defline");
+ MappingParamSet mps = new MappingParamSet();
+ mps.setAll(mapping);
- if (mapping == null) {
- mapping = new HashMap<String, Object>();
if (dbgname != null) {
- mapping.put("dbgname", dbgname);
+ mps.set(MappingParam.SWIFT_DBGNAME, dbgname);
if (line != null) {
- mapping.put("line", line);
+ mps.set(MappingParam.SWIFT_LINE, line);
- mapping.put("swift#restartid", getThreadPrefix(stack) + ":" + dbgname);
+ mps.set(MappingParam.SWIFT_RESTARTID, getThreadPrefix(stack) + ":" + dbgname);
if (waitfor != null) {
- mapping.put("waitfor", waitfor);
+ mps.set(MappingParam.SWIFT_WAITFOR, waitfor);
if (typename == null && value == null) {
throw new ExecutionException("You must specify either a type or a value");
- String mapper = (String) mapping.get("descriptor");
+ String mapper = (String) mps.get(MappingParam.SWIFT_DESCRIPTOR);
if ("concurrent_mapper".equals(mapper)) {
String threadPrefix = getThreadPrefix(stack);
- ConcurrentMapper.PARAM_THREAD_PREFIX.setValue(mapping, threadPrefix);
+ mps.set(ConcurrentMapper.PARAM_THREAD_PREFIX, threadPrefix);
- mapping.put("#basedir", stack.getExecutionContext().getBasedir());
+ mps.set(MappingParam.SWIFT_BASEDIR, stack.getExecutionContext().getBasedir());
try {
Type type;
@@ -139,14 +138,14 @@
handle.closeShallow();
- handle.init(mapping);
+ handle.init(mps);
else if (value instanceof DSHandle) {
handle = (DSHandle) value;
else {
handle = new RootDataNode(type);
+ handle.init(mps);
if (value != null) {
handle.setValue(internalValue(type, value));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/NiceName.java
--- trunk/src/org/griphyn/vdl/karajan/lib/NiceName.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/lib/NiceName.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -25,6 +25,7 @@
import org.griphyn.vdl.mapping.InvalidPathException;
public class NiceName extends VDLFunction {
@@ -39,7 +40,7 @@
DSHandle field = var.getField(path);
Path p = field.getPathFromRoot();
if (p.equals(Path.EMPTY_PATH)) {
- Object dbgname = field.getRoot().getParam("dbgname");
+ Object dbgname = field.getRoot().getParam(MappingParam.SWIFT_DBGNAME);
if (dbgname == null) {
return "tmp"+field.getRoot().hashCode();
@@ -48,7 +49,7 @@
else {
- return field.getRoot().getParam("dbgname") + "." + p;
+ return field.getRoot().getParam(MappingParam.SWIFT_DBGNAME) + "." + p;
catch (InvalidPathException e) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java
--- trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -22,6 +22,7 @@
import java.util.StringTokenizer;
@@ -73,7 +74,7 @@
logger.debug("Adding token "+closeID+" with hash "+closeID.hashCode());
- String needToWaitFor = var.getParam("waitfor");
+ String needToWaitFor = var.getParam(MappingParam.SWIFT_WAITFOR);
logger.debug("need to wait for " + needToWaitFor);
StringTokenizer stok = new StringTokenizer(needToWaitFor, " ");
while(stok.hasMoreTokens()) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -37,6 +37,7 @@
import org.griphyn.vdl.mapping.Mapper;
@@ -84,7 +85,7 @@
private String getVarName(DSHandle var) {
- String name = var.getRoot().getParam("dbgname");
+ String name = var.getRoot().getParam(MappingParam.SWIFT_DBGNAME);
if (var == var.getRoot()) {
return name;
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -87,9 +87,13 @@
- public void init(Map<String, Object> params) {
+ public void init(MappingParamSet params) {
throw new UnsupportedOperationException();
+ public final void init(Map<String, Object> params) {
+ throw new UnsupportedOperationException();
public Type getType() {
return field.getType();
@@ -193,9 +197,9 @@
public String getDisplayableName() {
- String prefix = getRoot().getParam("dbgname");
+ String prefix = getRoot().getParam(MappingParam.SWIFT_DBGNAME);
if (prefix == null) {
- prefix = getRoot().getParam("prefix");
+ prefix = getRoot().getParam(PARAM_PREFIX);
prefix = "?";
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -17,9 +17,6 @@
package org.griphyn.vdl.mapping;
-import java.util.Map;
import org.griphyn.vdl.mapping.file.FileGarbageCollector;
@@ -33,25 +30,25 @@
public static final Logger logger = Logger.getLogger(AbstractMapper.class);
public static final MappingParam PARAM_INPUT = new MappingParam("input", Boolean.FALSE);
- protected Map<String, Object> params;
+ protected MappingParamSet params;
- public synchronized void setParam(String name, Object value) {
+ public synchronized void setParam(MappingParam param, Object value) {
if (params == null) {
- params = new HashMap<String, Object>();
+ params = new MappingParamSet();
- params.put(name, value);
+ params.set(param, value);
- public synchronized Object getParam(String name) {
+ public synchronized Object getParam(MappingParam param) {
if (params != null) {
- return params.get(name);
+ return params.get(param);
else {
return null;
- public void setParams(Map<String, Object> params) {
+ public void setParams(MappingParamSet params) {
this.params = params;
Modified: trunk/src/org/griphyn/vdl/mapping/DSHandle.java
--- trunk/src/org/griphyn/vdl/mapping/DSHandle.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/DSHandle.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -47,7 +47,7 @@
public Type getType();
- public void init(Map<String, Object> params);
+ public void init(MappingParamSet params);
public DSHandle getRoot();
@@ -90,7 +90,7 @@
public void set(DSHandle svar);
- public String getParam(String name);
+ public String getParam(MappingParam name);
public boolean isClosed();
Modified: trunk/src/org/griphyn/vdl/mapping/DataNode.java
--- trunk/src/org/griphyn/vdl/mapping/DataNode.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/DataNode.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -48,7 +48,7 @@
this.parent = parent;
- public String getParam(String name) {
+ public String getParam(MappingParam p) {
return null;
Modified: trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -39,14 +39,14 @@
private static final String datasetIDPartialID = Loader.getUUID();
- private Map<String, Object> params;
+ private MappingParamSet params;
public ExternalDataNode() {
super(new FieldImpl("", Types.EXTERNAL));
@Override
@@ -113,10 +113,10 @@
return null;
return null;
- return (String) params.get(name);
+ return (String) params.get(p);
Modified: trunk/src/org/griphyn/vdl/mapping/Mapper.java
--- trunk/src/org/griphyn/vdl/mapping/Mapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/Mapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -18,7 +18,6 @@
import java.util.Collection;
/** This interface must be implemented by a Java class that represents
a Swift mapper between SwiftScript variables and external data
@@ -55,11 +54,11 @@
boolean isStatic();
- void setParams(Map<String, Object> params);
+ void setParams(MappingParamSet params);
- void setParam(String name, Object value);
+ void setParam(MappingParam p, Object value);
- Object getParam(String name);
+ Object getParam(MappingParam name);
* Specifies whether paths mapped by this mapper can be re-mapped
Modified: trunk/src/org/griphyn/vdl/mapping/MapperFactory.java
--- trunk/src/org/griphyn/vdl/mapping/MapperFactory.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/MapperFactory.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -62,8 +62,7 @@
registerMapper("test_mapper", TestMapper.class);
- public synchronized static Mapper getMapper(String type,
- Map<String,Object> params)
+ public synchronized static Mapper getMapper(String type, MappingParamSet params)
throws InvalidMapperException {
Class<Mapper> cls = mappers.get(type);
if (cls == null) {
Modified: trunk/src/org/griphyn/vdl/mapping/MappingParam.java
--- trunk/src/org/griphyn/vdl/mapping/MappingParam.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/MappingParam.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -17,8 +17,6 @@
/** The MappingParam class provides helper methods to deal with
@@ -28,6 +26,16 @@
* retrieve parameters in the mapper code.
public class MappingParam {
+ public static final MappingParam SWIFT_LINE = new MappingParam("swift#line");
+ public static final MappingParam SWIFT_DBGNAME = new MappingParam("swift#dbgname");
+ public static final MappingParam SWIFT_RESTARTID = new MappingParam("swift#restartid");
+ public static final MappingParam SWIFT_WAITFOR = new MappingParam("swift#waitfor");
+ public static final MappingParam SWIFT_BASEDIR = new MappingParam("swift#basedir");
+ public static final MappingParam SWIFT_DESCRIPTOR = new MappingParam("swift#descriptor");
+ public static final MappingParam SWIFT_INPUT = new MappingParam("swift#input");
+ public static final MappingParam SWIFT_HANDLE = new MappingParam("swift#handle");
private final String name;
private Object defValue;
private boolean defSet;
@@ -57,7 +65,7 @@
* will be returned.
public Object getValue(Mapper mapper) {
- Object value = mapper.getParam(name);
+ Object value = mapper.getParam(this);
if (value instanceof AbstractDataNode) {
AbstractDataNode handle = (AbstractDataNode) value;
handle.waitFor();
@@ -82,8 +90,8 @@
- public Object getValue(Map<String, Object> params) {
- Object value = params.get(name);
+ public Object getValue(MappingParamSet params) {
+ Object value = params.get(this);
handle.waitFor();
@@ -108,7 +116,7 @@
/** return the raw value of this parameter. Defaulting and type
* conversion will not occur. */
public Object getRawValue(Mapper mapper) {
- return mapper.getParam(name);
+ return mapper.getParam(this);
/** Returns the mapper parameter as a String. Other data types will be
@@ -121,7 +129,7 @@
return String.valueOf(value);
- public String getStringValue(Map params) {
+ public String getStringValue(MappingParamSet params) {
Object value = getValue(params);
if (value == null) {
return null;
@@ -130,15 +138,15 @@
public void setValue(Mapper mapper, Object value) {
- mapper.setParam(name, value);
+ mapper.setParam(this, value);
public boolean isPresent(Mapper mapper) {
- return mapper.getParam(name) != null;
+ return mapper.getParam(this) != null;
- public boolean isPresent(Map map) {
- return map.containsKey(name);
+ public boolean isPresent(MappingParamSet map) {
+ return map.isPresent(this);
@@ -178,8 +186,8 @@
- public void setValue(Map map, Object value) {
- map.put(name, value);
+ public void setValue(MappingParamSet map, Object value) {
+ map.set(this, value);
public String toString() {
Added: trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java
--- trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -0,0 +1,50 @@
+ * Created on Sep 14, 2012
+package org.griphyn.vdl.mapping;
+import java.util.Collection;
+import java.util.HashMap;
+import java.util.Map;
+public class MappingParamSet {
+ private Map<String, Object> params;
+ public MappingParamSet() {
+ params = new HashMap<String, Object>();
+ public void set(MappingParam p, Object value) {
+ params.put(p.getName(), value);
+ public void setAll(Map<String, Object> m) {
+ if (m != null) {
+ for (Map.Entry<String, Object> e : m.entrySet()) {
+ params.put(e.getKey(), e.getValue());
+ public Object get(MappingParam p) {
+ return params.get(p.getName());
+ public boolean isPresent(MappingParam p) {
+ return params.containsKey(p.getName());
+ public AbstractDataNode getFirstOpenParamValue() {
+ for (Map.Entry<String, Object> entry : params.entrySet()) {
+ Object v = entry.getValue();
+ if (v instanceof AbstractDataNode && !((AbstractDataNode) v).isClosed()) {
+ return (AbstractDataNode) v;
+ return null;
+ public Collection<String> names() {
+ return params.keySet();
Modified: trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -33,7 +33,7 @@
private boolean initialized = false;
private Mapper mapper;
private AbstractDataNode waitingMapperParam;
@@ -43,7 +43,7 @@
super(Field.Factory.createField(null, type), null, null);
if (this.params == null) {
initialized();
@@ -57,16 +57,14 @@
if (logger.isDebugEnabled()) {
logger.debug("innerInit: " + this);
+ waitingMapperParam = params.getFirstOpenParamValue();
+ if (waitingMapperParam != null) {
+ waitingMapperParam.getFutureWrapper().addModificationAction(this, null);
+ return;
- for (Map.Entry<String, Object> entry : params.entrySet()) {
- Object v = entry.getValue();
- if (v instanceof AbstractDataNode && !((AbstractDataNode) v).isClosed()) {
- waitingMapperParam = (AbstractDataNode) v;
- waitingMapperParam.getFutureWrapper().addModificationAction(this, null);
- return;
- String desc = (String) params.get("descriptor");
+ String desc = (String) params.get(MappingParam.SWIFT_DESCRIPTOR);
if (desc == null) {
initialized();
return;
@@ -99,11 +97,11 @@
innerInit();
return null;
public DSHandle getRoot() {
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -32,11 +32,11 @@
public class RootDataNode extends AbstractDataNode implements FutureListener {
- static Logger logger = Logger.getLogger(RootDataNode.class);
+ static Logger logger = Logger.getLogger(RootDataNode.class);
private boolean initialized=false;
public RootDataNode(Type type) {
@@ -49,7 +49,7 @@
setValue(value);
- public void init(Map<String,Object> params) {
if(this.params == null) {
initialized();
@@ -61,17 +61,13 @@
/** must have this.params set to the appropriate parameters before
being called. */
private synchronized void innerInit() {
- for (Object v : params.values()) {
- if(v instanceof AbstractDataNode && !((AbstractDataNode) v).isClosed()) {
- if (logger.isDebugEnabled()) {
- logger.debug("addListener: " + this + " " + v);
- return;
+ return;
if (desc == null) {
initialized();
return;
@@ -111,23 +107,10 @@
- static protected void checkInputs(Map<String, Object> params, Mapper mapper, AbstractDataNode root) {
- String input = (String) params.get("input");
+ static protected void checkInputs(MappingParamSet params, Mapper mapper, AbstractDataNode root) {
+ String input = (String) params.get(MappingParam.SWIFT_INPUT);
if (input != null && Boolean.valueOf(input.trim()).booleanValue()) {
- for (Path p : mapper.existing()) {
- try {
- DSHandle field = root.getField(p);
- field.closeShallow();
- if (logger.isInfoEnabled()) {
- logger.info("Found data " + root + "." + p);
- catch (InvalidPathException e) {
- throw new IllegalStateException("Structure of mapped data is " +
- "incompatible with the mapped variable type: " + e.getMessage());
- root.closeDeep();
+ addExisting(mapper, root);
checkConsistency(root);
else if (mapper.isStatic()) {
@@ -164,7 +147,24 @@
- public static void checkConsistency(DSHandle handle) {
+ private static void addExisting(Mapper mapper, AbstractDataNode root) {
+ for (Path p : mapper.existing()) {
+ try {
+ DSHandle field = root.getField(p);
+ field.closeShallow();
+ if (logger.isInfoEnabled()) {
+ logger.info("Found data " + root + "." + p);
+ catch (InvalidPathException e) {
+ throw new IllegalStateException("Structure of mapped data is " +
+ "incompatible with the mapped variable type: " + e.getMessage());
+ root.closeDeep();
+ public static void checkConsistency(DSHandle handle) {
if (handle.getType().isArray()) {
// any number of indices is ok
try {
@@ -197,11 +197,11 @@
return null;
Modified: trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -25,7 +25,6 @@
import org.globus.cog.util.Base64;
@@ -34,6 +33,7 @@
import org.griphyn.vdl.mapping.AbstractMapper;
import org.griphyn.vdl.mapping.InvalidMappingParameterException;
import org.griphyn.vdl.mapping.PhysicalFormat;
@@ -99,7 +99,7 @@
this.elementMapper = elementMapper;
- public void setParams(Map<String,Object> params) {
super.setParams(params);
if (PARAM_SUFFIX.isPresent(this)) {
String suffix = PARAM_SUFFIX.getStringValue(this);
@@ -136,7 +136,7 @@
Iterator<Path.Entry> pi = path.iterator();
int level = 0, tokenCount = path.size();
while (pi.hasNext()) {
- Path.Entry nextPathElement = (Path.Entry) pi.next();
+ Path.Entry nextPathElement = pi.next();
if (nextPathElement.isIndex()) {
Comparable<?> key = nextPathElement.getKey();
String f, token;
@@ -262,7 +262,7 @@
private String getVarName() {
- AbstractDataNode var = (AbstractDataNode) getParam("handle");
+ AbstractDataNode var = (AbstractDataNode) getParam(MappingParam.SWIFT_HANDLE);
return var == null ? "" : var.getDisplayableName();
Modified: trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -17,29 +17,30 @@
package org.griphyn.vdl.mapping.file;
-import java.io.BufferedReader;
-import java.io.FileNotFoundException;
-import java.io.FileReader;
-import java.io.IOException;
-import java.util.ArrayList;
-import java.util.Collection;
-import java.util.Iterator;
-import java.util.List;
-import java.util.StringTokenizer;
+import java.io.BufferedReader;
+import java.io.FileNotFoundException;
+import java.io.FileReader;
+import java.io.IOException;
+import java.util.ArrayList;
+import java.util.Iterator;
+import java.util.List;
+import java.util.StringTokenizer;
+import org.griphyn.vdl.mapping.AbsFile;
+import org.griphyn.vdl.mapping.AbstractMapper;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.GeneralizedFileFormat;
+import org.griphyn.vdl.mapping.InvalidMappingParameterException;
+import org.griphyn.vdl.mapping.Mapper;
+import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.mapping.PhysicalFormat;
+import org.griphyn.vdl.type.Types;
-import org.griphyn.vdl.mapping.AbsFile;
-import org.griphyn.vdl.mapping.AbstractMapper;
-import org.griphyn.vdl.mapping.DSHandle;
-import org.griphyn.vdl.mapping.GeneralizedFileFormat;
-import org.griphyn.vdl.mapping.InvalidMappingParameterException;
-import org.griphyn.vdl.mapping.Mapper;
-import org.griphyn.vdl.mapping.MappingParam;
-import org.griphyn.vdl.mapping.Path;
-import org.griphyn.vdl.mapping.PhysicalFormat;
-import org.griphyn.vdl.type.Types;
public class CSVMapper extends AbstractMapper {
public static final MappingParam PARAM_FILE = new MappingParam("file");
@@ -68,7 +69,7 @@
/** whether the CSV file has been read already. */
private boolean read = false;
- public void setParams(Map params) {
if (!PARAM_FILE.isPresent(this)) {
throw new InvalidMappingParameterException("CSV mapper must have a file parameter.");
Modified: trunk/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -41,7 +41,7 @@
super(new ConcurrentElementMapper());
String prefix = PARAM_PREFIX.getStringValue(params);
prefix = "_concurrent/" + (prefix == null ? "" : prefix + "-") +
PARAM_THREAD_PREFIX.getValue(params);
Modified: trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -17,26 +17,27 @@
-import java.io.File;
-import java.io.InputStream;
-import java.io.InputStreamReader;
+import java.io.File;
+import java.io.InputStream;
+import java.io.InputStreamReader;
+import java.util.HashSet;
+import java.util.Set;
+import org.apache.log4j.Logger;
-import org.apache.log4j.Logger;
public class ExternalMapper extends AbstractMapper {
public static final Logger logger = Logger.getLogger(ExternalMapper.class);
@@ -44,36 +45,22 @@
private Map<String, Path> rmap;
public static final MappingParam PARAM_EXEC = new MappingParam("exec");
- public static final MappingParam PARAM_BASEDIR = new MappingParam("#basedir", null);
- private static Set<String> ignored;
- static {
- ignored = new HashSet<String>();
- ignored.add("exec");
- ignored.add("input");
- ignored.add("dbgname");
- ignored.add("descriptor");
- ignored.add("#basedir");
- ignored.add("waitfor");
- ignored.add("swift#restartid");
private static final String[] STRING_ARRAY = new String[0];
map = new HashMap<Path, AbsFile>();
rmap = new HashMap<String, Path>();
String exec = PARAM_EXEC.getStringValue(this);
- String bdir = PARAM_BASEDIR.getStringValue(this);
+ String bdir = MappingParam.SWIFT_BASEDIR.getStringValue(this);
if (bdir != null && !exec.startsWith("/")) {
exec = bdir + File.separator + exec;
List<String> cmd = new ArrayList<String>();
cmd.add(exec);
- for (String name : params.keySet()) {
- if (!ignored.contains(name)) {
+ for (String name : params.names()) {
+ if (!name.contains("#") && !name.equals("exec")) {
MappingParam tp = new MappingParam(name);
cmd.add('-' + name);
cmd.add(tp.getStringValue(this));
@@ -81,12 +68,12 @@
try {
- logger.debug("invoking external mapper for " + getParam("dbgname") + ": " + cmd);
+ logger.debug("invoking external mapper for " + getParam(MappingParam.SWIFT_DBGNAME) + ": " + cmd);
Process p = Runtime.getRuntime().exec(cmd.toArray(STRING_ARRAY));
List<String> lines = fetchOutput(p.getInputStream());
- logger.debug("external mapper for " + getParam("dbgname") + " output: " + lines);
+ logger.debug("external mapper for " + getParam(MappingParam.SWIFT_DBGNAME) + " output: " + lines);
int ec = p.waitFor();
if (ec != 0) {
Modified: trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -20,13 +20,13 @@
@@ -40,7 +40,7 @@
super();
String cfiles = PARAM_FILES.getStringValue(this);
if (cfiles == null) {
Modified: trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -17,21 +17,22 @@
-import java.util.Arrays;
-import java.util.regex.Matcher;
-import java.util.regex.Pattern;
+import java.util.Arrays;
+import java.util.Collections;
+import java.util.regex.Matcher;
+import java.util.regex.Pattern;
public class RegularExpressionMapper extends AbstractMapper {
public static final MappingParam PARAM_SOURCE = new MappingParam("source");
public static final MappingParam PARAM_MATCH = new MappingParam("match");
@@ -40,18 +41,18 @@
public RegularExpressionMapper() {
if (!PARAM_MATCH.isPresent(this)) {
throw new RuntimeException("Missing parameter match!");
- public Collection existing() {
+ public Collection<Path> existing() {
if (exists(Path.EMPTY_PATH))
return Arrays.asList(new Path[] { Path.EMPTY_PATH });
else {
- return Collections.EMPTY_LIST;
+ return Collections.emptyList();
@@ -97,11 +98,13 @@
public static void main(String[] args) {
RegularExpressionMapper reMapper = new RegularExpressionMapper();
- Map params = new HashMap();
+ Map<String, Object> params = new HashMap<String, Object>();
params.put("source", "2mass-j1223.fits");
params.put("match", "(.*)\\.(.*)");
- params.put("transform", "\\1_area.\\2");
- reMapper.setParams(params);
+ params.put("transform", "\\1_area.\\2");
+ mps.setAll(params);
+ reMapper.setParams(mps);
System.out.println(reMapper.map(Path.EMPTY_PATH));
Modified: trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -20,9 +20,8 @@
public class SimpleFileMapper extends AbstractFileMapper {
public static final MappingParam PARAM_PADDING = new MappingParam("padding", new Integer(4));
@@ -31,7 +30,7 @@
super();
int precision = PARAM_PADDING.getIntValue(this);
setElementMapper(new DefaultFileNameElementMapper(precision));
Modified: trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java 2012-09-15 08:49:25 UTC (rev 5926)
+++ trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java 2012-09-15 08:59:46 UTC (rev 5927)
@@ -17,24 +17,23 @@
+import org.griphyn.vdl.mapping.HandleOpenException;
+import org.griphyn.vdl.mapping.InvalidPathException;
-import org.griphyn.vdl.mapping.HandleOpenException;
-import org.griphyn.vdl.mapping.InvalidPathException;
public class StructuredRegularExpressionMapper extends AbstractFileMapper {
@@ -47,32 +46,32 @@
public StructuredRegularExpressionMapper() {
DSHandle sourceHandle = (DSHandle) PARAM_SOURCE.getRawValue(this);
- Collection output = new ArrayList();
- Collection sourceFields;
+ Collection<Path> output = new ArrayList<Path>();
+ Collection<DSHandle> sourceFields;
try {
sourceFields = sourceHandle.getFields(Path.CHILDREN);
catch (InvalidPathException ipe) {
catch (HandleOpenException hoe) {
"Handle open. Throwing this exception may not be the right thing to do. TODO");
- Iterator i = sourceFields.iterator();
+ Iterator<DSHandle> i = sourceFields.iterator();
while (i.hasNext()) {
- DSHandle f = (DSHandle) i.next();
+ DSHandle f = i.next();
output.add(f.getPathFromRoot());
More information about the Swift-commit
