[Swift-commit] r6000 - branches/release-0.94/tests
davidk at ci.uchicago.edu
Mon Oct 29 14:25:43 CDT 2012
Author: davidk
Date: 2012-10-29 14:25:43 -0500 (Mon, 29 Oct 2012)
New Revision: 6000
Modified:
branches/release-0.94/tests/suite.sh
Log:
Fix suite.sh to display the correct swift script name in standard output
Modified: branches/release-0.94/tests/suite.sh
--- branches/release-0.94/tests/suite.sh 2012-10-29 19:25:10 UTC (rev 5999)
+++ branches/release-0.94/tests/suite.sh 2012-10-29 19:25:43 UTC (rev 6000)
@@ -1079,15 +1079,6 @@
(( SKIP_COUNTER++ < SKIP_TESTS )) && continue
- echo
- echo
- echo "/--------------------------------------------------------------"
- echo -e "| Test case: $LGREEN$TESTNAME$GRAY"
- echo "\--------------------------------------------------------------"
- echo
- TESTLINK=$TESTNAME
# Use repeat.txt to determine number of test iterations
SCRIPT_BASENAME=`basename $TESTNAME .swift`
TESTLINK="$TESTNAMEDIR/$TESTNAME"
@@ -1102,9 +1093,16 @@
TESTNAME=$( basename $TEST )
TESTNAMEDIR=`basename $TESTNAME .swift`-$HOURMINSEC
+ echo
+ echo
+ echo "+--------------------------------------------------------------"
+ echo -e "| Test case: $LGREEN$TESTNAME$GRAY"
+ echo
mkdir -p $TESTNAMEDIR
pushd $TESTNAMEDIR > /dev/null 2>&1
cp $TEST .
group_swift_properties
group_sites_xml
More information about the Swift-commit
