[Swift-commit] cog r3491
swift at ci.uchicago.edu swift at ci.uchicago.edu
Sun Oct 28 21:05:16 CDT 2012
r3491 | hategan | 2012-10-28 21:01:32 -0500 (Sun, 28 Oct 2012) | 1 line
create file appender if one does not exist instead of failing
Index: modules/util/src/org/globus/cog/util/Misc.java
--- modules/util/src/org/globus/cog/util/Misc.java	(revision 3490)
+++ modules/util/src/org/globus/cog/util/Misc.java	(working copy)
@@ -12,13 +12,17 @@
 import org.apache.log4j.Appender;
 import org.apache.log4j.FileAppender;
+import org.apache.log4j.Layout;
+import org.apache.log4j.Level;
 import org.apache.log4j.Logger;
+import org.apache.log4j.PatternLayout;
 public class Misc
-	   Set the FileAppender output from the given Logger
-	   to the given file name
+	 * Set the FileAppender output from the given Logger
+	 * to the given file name. If no file appender exists, one
+	 * is created.
 	public static void setFileAppenderOutput(Logger logger,
 	                                         String filename) {
@@ -26,8 +30,11 @@
 		FileAppender fa =
 			(FileAppender) Misc.getAppender(FileAppender.class);
 		if (fa == null) {
-			logger.fatal("Failed to configure log file name");
-			System.exit(2);
+		    fa = new FileAppender();
+		    Layout l = new PatternLayout("%d{yyyy-MM-dd HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n");
+		    fa.setLayout(l);
+		    fa.setThreshold(Level.DEBUG);
+		    Logger.getRootLogger().addAppender(fa);
 		fa.setFile(file.getAbsolutePath());
 		fa.activateOptions();
