[Swift-commit] cog r3488
swift at ci.uchicago.edu
Sat Oct 20 13:05:04 CDT 2012
r3488 | hategan | 2012-10-20 13:00:46 -0500 (Sat, 20 Oct 2012) | 1 line
sync when instantiating pullthread; more careful syncing on pull
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Cpu.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Cpu.java (revision 3487)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Cpu.java (working copy)
@@ -123,9 +123,11 @@
static PullThread getPullThread(Block block) {
- if (pullThread == null) {
- pullThread = new PullThread(block.getAllocationProcessor());
- pullThread.start();
+ synchronized(Cpu.class) {
+ if (pullThread == null) {
+ pullThread = new PullThread(block.getAllocationProcessor());
+ pullThread.start();
return pullThread;
@@ -139,6 +141,7 @@
getPullThread(block).enqueue(cpu);
private synchronized void sleep(Cpu cpu) {
getPullThread(cpu.node.getBlock()).sleep(cpu);
@@ -151,7 +154,7 @@
The Cpu requests work from the BlockQueueProcessor
The Cpu is awake when calling this (not in PullThread.sleeping)
- public synchronized void pull() {
+ public void pull() {
boolean success = true;
try {
if (checkSuspended(block)) {
@@ -160,34 +163,36 @@
if (logger.isTraceEnabled()) {
logger.trace(block.getId() + ":" + getId() + " pull");
- if (shutdown) {
- return;
- if (!started()) {
- sleep();
- else if (running == null) {
- lastseq = bqp.getQueueSeq();
- TimeInterval time = endtime.subtract(Time.now());
- int cpus = pullThread.sleepers() + 1;
- if (logger.isDebugEnabled())
- logger.debug("requesting work: " +
- "block=" + block.getId() +
- " id=" + getId() +
- " Cpus sleeping: " + cpus);
- running = bqp.request(time, cpus);
- if (running != null) {
- block.jobPulled();
- success = launch(running);
+ synchronized (this) {
+ if (shutdown) {
+ return;
- else {
+ if (!started()) {
sleep();
+ else if (running == null) {
+ lastseq = bqp.getQueueSeq();
+ TimeInterval time = endtime.subtract(Time.now());
+ int cpus = pullThread.sleepers() + 1;
+ if (logger.isDebugEnabled())
+ logger.debug("requesting work: " +
+ "block=" + block.getId() +
+ " id=" + getId() +
+ " Cpus sleeping: " + cpus);
+ running = bqp.request(time, cpus);
+ if (running != null) {
+ block.jobPulled();
+ success = launch(running);
+ else {
+ sleep();
+ else {
+ CoasterService.error(40, "pull called while another job was running",
+ new Throwable());
- else {
- CoasterService.error(40, "pull called while another job was running",
- new Throwable());
catch (Exception e) {
taskFailed("Failed pull", e);
More information about the Swift-commit
