[Swift-commit] r5971 - SwiftApps/ParVis/HiRAMTools
wilde at ci.uchicago.edu
Tue Oct 16 09:58:44 CDT 2012
Author: wilde
Date: 2012-10-16 09:58:43 -0500 (Tue, 16 Oct 2012)
New Revision: 5971
Added:
SwiftApps/ParVis/HiRAMTools/makeyearly.sh
Removed:
SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh
Modified:
SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh
Log:
Rename makeyearly-cdo.sh back to makeyearly.sh
Deleted: SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh
--- SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh 2012-10-16 14:55:15 UTC (rev 5970)
+++ SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh 2012-10-16 14:58:43 UTC (rev 5971)
@@ -1,83 +0,0 @@
-#! /bin/bash
-# Create a fast (local-filesystem) working dir
-if mkdir -p /scratch/wilde; then
- scratch=/scratch/wilde
-elif mkdir -p $HOME/scratch; then
- scratch=$HOME/scratch
-else
- echo $0: cant create scratch dir
- exit 11
-fi
-tmp=$(mktemp -d $scratch/makeyearly_XXXXXX)
-startdir=$PWD
-cd $tmp
-echo running in $PWD
-qtrdec1=$1 # 1st quarter-decade dir
-qtrdec2=$2 # 2nd quarter-decade dir
-destbase=$3 # base dir for output years
-echo destbase=$destbase qtrdec1=$1 qtrdec2=$2
-# Add cdo and nco tools to PATH and Intel compiler v11 libs to LD_LIBRARY_PATH
-#export PATH=/soft/apps/cdo-1.4.7/bin:/soft/apps/nco-4.0.9/bin:$PATH
-export PATH=/soft/apps/nco-4.0.9/bin:$PATH
-export LD_LIBRARY_PATH=/soft/apps/intel-fc-11.0.074/lib/intel64:/soft/apps/intel-cc-11.0.074/lib/intel64:/soft/apps/netcdf-3.6.3/lib:/usr/lib:/usr/X11R6/lib:/usr/local/lib
-fname=$(basename $qtrdec1 .nc)
-firstyear=$(basename $(dirname $qtrdec1) | sed -e 's/....$//')
-# process only the time-based files
-if echo $fname | egrep -v 'grid_spec|scalar'; then
- # Merge 2 quarter-decade files into one half-decade file
- ncrcat $qtrdec1 $qtrdec2 5years.nc
- # Extract each year from the half-decade file
- for (( y=$firstyear; y<$firstyear+5; y++ )); do
- ncks -d time,"${y}-01-01 00:00:00","${y}-12-31 23:59:59" 5years.nc $y.nc
- done
-fi
-# Copy the years from temporary to permanent filesystem
-for (( y=$firstyear; y<$firstyear+5; y++ ))
-do
- destdir=$destbase/${y}0101
- mkdir -p $destdir
- if echo $fname | egrep -v 'grid_spec|scalar'; then
- dd if=$y.nc of=$destdir/$fname.nc bs=8M
- else
- dd if=$qtrdec1 of=$destdir/$fname.nc bs=8M
- fi
-done
-rm -rf $tmp
-# Delete when this works:
- # Old method:
- # cdo mergetime $qtrdec1 $qtrdec2 ${fname}.nc
- # cdo splityear ${fname}.nc ${fname}.
- # Yields, eg, from atmos_month.tile1:
- # atmos_month.tile1.1950.nc
- # atmos_month.tile1.1951.nc
- # atmos_month.tile1.1952.nc
- # atmos_month.tile1.1953.nc
- # atmos_month.tile1.1954.nc
- # New method:
- # ncrcat input1.nc input2.nc 5years.nc
- # ncks -d time,"$yyyy-01-01 00:00:00","$yyyy-12-31 23:59:59" 5years.nc year1.nc
Copied: SwiftApps/ParVis/HiRAMTools/makeyearly.sh (from rev 5969, SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh)
--- SwiftApps/ParVis/HiRAMTools/makeyearly.sh (rev 0)
+++ SwiftApps/ParVis/HiRAMTools/makeyearly.sh 2012-10-16 14:58:43 UTC (rev 5971)
@@ -0,0 +1,83 @@
+#! /bin/bash
+# Create a fast (local-filesystem) working dir
+if mkdir -p /scratch/wilde; then
+ scratch=/scratch/wilde
+elif mkdir -p $HOME/scratch; then
+ scratch=$HOME/scratch
+else
+ echo $0: cant create scratch dir
+ exit 11
+fi
+tmp=$(mktemp -d $scratch/makeyearly_XXXXXX)
+startdir=$PWD
+cd $tmp
+echo running in $PWD
+qtrdec1=$1 # 1st quarter-decade dir
+qtrdec2=$2 # 2nd quarter-decade dir
+destbase=$3 # base dir for output years
+echo destbase=$destbase qtrdec1=$1 qtrdec2=$2
+# Add cdo and nco tools to PATH and Intel compiler v11 libs to LD_LIBRARY_PATH
+#export PATH=/soft/apps/cdo-1.4.7/bin:/soft/apps/nco-4.0.9/bin:$PATH
+export PATH=/soft/apps/nco-4.0.9/bin:$PATH
+export LD_LIBRARY_PATH=/soft/apps/intel-fc-11.0.074/lib/intel64:/soft/apps/intel-cc-11.0.074/lib/intel64:/soft/apps/netcdf-3.6.3/lib:/usr/lib:/usr/X11R6/lib:/usr/local/lib
+fname=$(basename $qtrdec1 .nc)
+firstyear=$(basename $(dirname $qtrdec1) | sed -e 's/....$//')
+# process only the time-based files
+if echo $fname | egrep -v 'grid_spec|scalar'; then
+ # Merge 2 quarter-decade files into one half-decade file
+ ncrcat $qtrdec1 $qtrdec2 5years.nc
+ # Extract each year from the half-decade file
+ for (( y=$firstyear; y<$firstyear+5; y++ )); do
+ ncks -d time,"${y}-01-01 00:00:00","${y}-12-31 23:59:59" 5years.nc $y.nc
+ done
+fi
+# Copy the years from temporary to permanent filesystem
+for (( y=$firstyear; y<$firstyear+5; y++ ))
+do
+ destdir=$destbase/${y}0101
+ mkdir -p $destdir
+ if echo $fname | egrep -v 'grid_spec|scalar'; then
+ dd if=$y.nc of=$destdir/$fname.nc bs=8M
+ else
+ dd if=$qtrdec1 of=$destdir/$fname.nc bs=8M
+ fi
+done
+rm -rf $tmp
+# Delete when this works:
+ # Old method:
+ # cdo mergetime $qtrdec1 $qtrdec2 ${fname}.nc
+ # cdo splityear ${fname}.nc ${fname}.
+ # Yields, eg, from atmos_month.tile1:
+ # atmos_month.tile1.1950.nc
+ # atmos_month.tile1.1951.nc
+ # atmos_month.tile1.1952.nc
+ # atmos_month.tile1.1953.nc
+ # atmos_month.tile1.1954.nc
+ # New method:
+ # ncrcat input1.nc input2.nc 5years.nc
+ # ncks -d time,"$yyyy-01-01 00:00:00","$yyyy-12-31 23:59:59" 5years.nc year1.nc
Modified: SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh
--- SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh 2012-10-16 14:55:15 UTC (rev 5970)
+++ SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh 2012-10-16 14:58:43 UTC (rev 5971)
@@ -82,7 +82,7 @@
cat >$rundir/tc <<END
-cobalt makeyearly $bindir/makeyearly-cdo.sh
+cobalt makeyearly $bindir/makeyearly.sh
END
More information about the Swift-commit
