[Swift-commit] r6077 - in trunk/src/org/griphyn/vdl: engine karajan	karajan/lib mapping
    hategan at ci.uchicago.edu
    Fri Nov 23 02:56:37 CST 2012
Author: hategan
Date: 2012-11-23 02:56:28 -0600 (Fri, 23 Nov 2012)
New Revision: 6077
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/SetWaitCount.java
Modified:
   trunk/src/org/griphyn/vdl/engine/CompilerUtils.java
   trunk/src/org/griphyn/vdl/engine/Karajan.java
   trunk/src/org/griphyn/vdl/engine/VariableScope.java
   trunk/src/org/griphyn/vdl/karajan/Loader.java
   trunk/src/org/griphyn/vdl/karajan/lib/New.java
   trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java
   trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/mapping/DSHandle.java
   trunk/src/org/griphyn/vdl/mapping/MappingParam.java
   trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
revamped variable closing stuff using reference counting and improved static analysis
Modified: trunk/src/org/griphyn/vdl/engine/CompilerUtils.java
--- trunk/src/org/griphyn/vdl/engine/CompilerUtils.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/engine/CompilerUtils.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -14,8 +14,8 @@
 public class CompilerUtils {
     public static String getLine(Node n) {
-        if (n == null) {
-            return "line unknown";
+        if (n == null || n.getAttributes() == null) {
+            return "unknown";
         Node src = n.getAttributes().getNamedItem("src");
         if (src == null) {
@@ -38,4 +38,8 @@
         return getLine(src.getDomNode());
+    public static String info(XmlObject src) {
+        return src.getDomNode().getLocalName() + ", line " + getLine(src);
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -17,6 +17,8 @@
 package org.griphyn.vdl.engine;
+import static org.griphyn.vdl.engine.CompilerUtils.getLine;
 import java.io.File;
 import java.io.FileInputStream;
 import java.io.FileOutputStream;
@@ -58,14 +60,15 @@
 import org.globus.swift.language.TypesDocument.Types.Type;
 import org.globus.swift.language.Variable.Mapping;
 import org.globus.swift.language.Variable.Mapping.Param;
+import org.griphyn.vdl.engine.VariableScope.EnclosureType;
+import org.griphyn.vdl.engine.VariableScope.WriteType;
 import org.griphyn.vdl.karajan.CompilationException;
 import org.griphyn.vdl.karajan.Loader;
 import org.griphyn.vdl.toolkit.VDLt2VDLx;
+import org.griphyn.vdl.type.NoSuchTypeException;
 import org.safehaus.uuid.UUIDGenerator;
 import org.w3c.dom.Node;
-import static org.griphyn.vdl.engine.CompilerUtils.*;
 public class Karajan {
 	public static final Logger logger = Logger.getLogger(Karajan.class);
@@ -79,7 +82,6 @@
 	Map<String,Type> typesMap = new HashMap<String,Type>();
 	List<StringTemplate> variables = new ArrayList<StringTemplate>();
-	Set<String> usedVariables = new HashSet<String>();
 	public static final String TEMPLATE_FILE_NAME = "Karajan.stg";
 	public static final String TEMPLATE_FILE_NAME_NO_PROVENANCE = "Karajan-no-provenance.stg";
@@ -92,7 +94,6 @@
 	/** an arbitrary statement identifier. Start at some high number to
 	    aid visual distinction in logs, but the actual value doesn't
 		matter. */
-	int callID = 88000;
 	StringTemplateGroup m_templates;
@@ -126,8 +127,9 @@
 		ProgramDocument programDoc;
 		try {
 			programDoc = parseProgramXML(in);
-		} catch(Exception e) {
-			throw new CompilationException("Unable to parse intermediate XML",e);
+		catch(Exception e) {
+			throw new CompilationException("Unable to parse intermediate XML", e);
 		Program prog = programDoc.getProgram();
@@ -293,7 +295,7 @@
 	public StringTemplate program(Program prog) throws CompilationException {
-		VariableScope scope = new VariableScope(this, null);
+		VariableScope scope = new VariableScope(this, null, prog);
 		scope.bodyTemplate = template("program");
 		scope.bodyTemplate.setAttribute("buildversion",Loader.buildVersion);
@@ -310,37 +312,17 @@
         for (Program program : importList)
             statements(program, scope);
-        checkUninitializedVariables();
 		generateInternedConstants(scope.bodyTemplate);
+		scope.analyzeWriters();
 		scope.bodyTemplate.setAttribute("cleanups", scope.getCleanups());
 		return scope.bodyTemplate;
-	private void checkUninitializedVariables() throws CompilationException {
-	    for (StringTemplate var : variables) {
-	        String name = (String) var.getAttribute("name");
-	        if (var.getAttribute("waitfor") == null) {
-	            if (usedVariables.contains(name)) {
-    	            if (org.griphyn.vdl.type.Types.isPrimitive((String) var.getAttribute("type"))) {
-    	                throw new CompilationException("Uninitalized variable: " + name);
-	            else {
-	                logger.info("Unused variable " + name);
-	private void setVariableUsed(String s) {
-	    usedVariables.add(s);
     public void procedure(Procedure proc, VariableScope containingScope) throws CompilationException {
-		VariableScope outerScope = new VariableScope(this, containingScope, VariableScope.ENCLOSURE_PROCEDURE);
-		VariableScope innerScope = new VariableScope(this, outerScope, VariableScope.ENCLOSURE_NONE);
+		VariableScope outerScope = new VariableScope(this, containingScope, EnclosureType.PROCEDURE, proc);
+		VariableScope innerScope = new VariableScope(this, outerScope, EnclosureType.NONE, proc);
 		StringTemplate procST = template("procedure");
 		containingScope.bodyTemplate.setAttribute("procedures", procST);
 		procST.setAttribute("line", getLine(proc));
@@ -349,25 +331,14 @@
 			FormalParameter param = proc.getOutputArray(i);
 			StringTemplate paramST = parameter(param, innerScope);
 			procST.setAttribute("outputs", paramST);
-			if (!param.isNil())
-				procST.setAttribute("optargs", paramST);
-			else
-				procST.setAttribute("arguments", paramST);
-			String type = normalize(param.getType().getLocalPart());
-            checkIsTypeDefined(type);
-            innerScope.addVariable(param.getName(), type, "Return parameter", param);
+			addArg(procST, param, paramST, true, innerScope);
 		for (int i = 0; i < proc.sizeOfInputArray(); i++) {
 			FormalParameter param = proc.getInputArray(i);
 			StringTemplate paramST = parameter(param, outerScope);
 			procST.setAttribute("inputs", paramST);
-			else
-			outerScope.addVariable(param.getName(), type, "Parameter", param);
+			addArg(procST, param, paramST, false, outerScope);
+			outerScope.addWriter(param.getName(), WriteType.FULL, proc, procST);
 		Binding bind;
@@ -375,7 +346,7 @@
 			binding(bind, procST, innerScope);
 		else {
-			VariableScope compoundScope = new VariableScope(this, innerScope);
+			VariableScope compoundScope = new VariableScope(this, innerScope, proc);
 			compoundScope.bodyTemplate = procST;
 			statementsForSymbols(proc, compoundScope);
 			statements(proc, compoundScope);
@@ -383,6 +354,26 @@
+    private void addArg(StringTemplate procST, FormalParameter param,
+            StringTemplate paramST, boolean returnArg, VariableScope scope) throws CompilationException {
+        if (!param.isNil()) {
+            procST.setAttribute("optargs", paramST);
+        else {
+            procST.setAttribute("arguments", paramST);
+        String type = normalize(param.getType().getLocalPart());
+        checkIsTypeDefined(type);
+        scope.addVariable(param.getName(), type, returnArg ? "Return value" : "Parameter", false, param);
+        if (returnArg) {
+            StringTemplate initWaitCountST = template("setWaitCount");
+            initWaitCountST.setAttribute("name", param.getName());
+            procST.setAttribute("initWaitCounts", initWaitCountST);
      * Convert to a case-insensitive representation by
      * pre-pending a '_' to upper case letters. If the
@@ -435,8 +426,9 @@
 		typeST.setAttribute("name", normalize(param.getType().getLocalPart()));
 		typeST.setAttribute("namespace", param.getType().getNamespaceURI());
 		paramST.setAttribute("type", typeST);
-		if(!param.isNil())
+		if(!param.isNil()) {
 			paramST.setAttribute("default",expressionToKarajan(param.getAbstractExpression(), scope));
 		return paramST;
@@ -452,9 +444,16 @@
 		variableST.setAttribute("isGlobal", Boolean.valueOf(var.getIsGlobal()));
 		variableST.setAttribute("line", getLine(var));
 		variables.add(variableST);
+		 *  possibly an input; mark it as such here, and if
+		 *  writers are detected, remove the input attribute (that is
+		 *  done in VariableScope).
+		variableST.setAttribute("input", "true");
-		if(!var.isNil()) {
+		if (!var.isNil()) {
 			if (var.getFile() != null) {
 				StringTemplate fileST = new StringTemplate("file");
 				fileST.setAttribute("name", escapeQuotes(var.getFile().getName()));
@@ -462,8 +461,6 @@
 				variableST.setAttribute("file", fileST);
 			Mapping mapping = var.getMapping();
 			if (mapping != null) {
@@ -471,56 +468,14 @@
 				mappingST.setAttribute("descriptor", mapping.getDescriptor());
 				for (int i = 0; i < mapping.sizeOfParamArray(); i++) {
 					Param param = mapping.getParamArray(i);
-					StringTemplate paramST = template("vdl_parameter");
-					paramST.setAttribute("name", param.getName());
-					Node expressionDOM = param.getAbstractExpression().getDomNode();
-					String namespaceURI = expressionDOM.getNamespaceURI();
-					String localName = expressionDOM.getLocalName();
-					QName expressionQName = new QName(namespaceURI, localName);
-					if(expressionQName.equals(VARIABLE_REFERENCE_EXPR))     {
-						paramST.setAttribute("expr",expressionToKarajan(param.getAbstractExpression(),scope));
-					} else {
-						String parameterVariableName="swift#mapper#"+(internedIDCounter++);
-						// make template for variable declaration (need to compute type of this variable too?)
-						StringTemplate variableDeclarationST = template("variable");
-						variableDeclarationST.setAttribute("waitfor","");
-						// TODO factorise this and other code in variable()?
-						StringTemplate pmappingST = new StringTemplate("mapping");
-						pmappingST.setAttribute("descriptor", "concurrent_mapper");
-						StringTemplate pparamST = template("vdl_parameter");
-						pparamST.setAttribute("name", "prefix");
-						pparamST.setAttribute("expr", parameterVariableName + "-" + UUIDGenerator.getInstance().generateRandomBasedUUID().toString());
-						pmappingST.setAttribute("params", pparamST);
-						//variableDeclarationST.setAttribute("mapping", pmappingST);
-						variableDeclarationST.setAttribute("nil", Boolean.TRUE);
-						variableDeclarationST.setAttribute("name", parameterVariableName);
-						scope.bodyTemplate.setAttribute("declarations",variableDeclarationST);
-						StringTemplate paramValueST=expressionToKarajan(param.getAbstractExpression(),scope);
-						String paramValueType = datatype(paramValueST);
-						scope.addVariable(parameterVariableName, paramValueType, "Variable", param);
-						variableDeclarationST.setAttribute("type", paramValueType);
-						StringTemplate variableReferenceST = template("id");
-						variableReferenceST.setAttribute("var",parameterVariableName);
-						StringTemplate variableAssignmentST = template("assign");
-						variableAssignmentST.setAttribute("var",variableReferenceST);
-						variableAssignmentST.setAttribute("value",paramValueST);
-						scope.appendStatement(variableAssignmentST);
-						if (param.getAbstractExpression().getDomNode().getNodeName().equals("stringConstant")) {
-							StringTemplate valueST = template("sConst");
-							valueST.setAttribute("innervalue", param.getAbstractExpression().getDomNode().getFirstChild().getNodeValue());
-                            paramST.setAttribute("expr",valueST);
-                        else {
-                        	paramST.setAttribute("expr",variableReferenceST);
-					mappingST.setAttribute("params", paramST);
+					mappingST.setAttribute("params", mappingParameter(param, scope));
 				variableST.setAttribute("mapping", mappingST);
-		} else {
-			// add temporary mapping info
-			if (!org.griphyn.vdl.type.Types.isPrimitive(var.getType().getLocalPart())) {
+		else {
+			// add temporary mapping info in not primitive or array of primitive
+			if (!isPrimitiveOrArrayOfPrimitive(var.getType().getLocalPart())) {
     			StringTemplate mappingST = new StringTemplate("mapping");
@@ -531,21 +486,79 @@
     			variableST.setAttribute("nil", Boolean.TRUE);
 		scope.bodyTemplate.setAttribute("declarations", variableST);
+    private StringTemplate mappingParameter(Param param, VariableScope scope) throws CompilationException {
+        StringTemplate paramST = template("vdl_parameter");
+        paramST.setAttribute("name", param.getName());
+        Node expressionDOM = param.getAbstractExpression().getDomNode();
+        String namespaceURI = expressionDOM.getNamespaceURI();
+        String localName = expressionDOM.getLocalName();
+        QName expressionQName = new QName(namespaceURI, localName);
+        if (expressionQName.equals(VARIABLE_REFERENCE_EXPR))     {
+            paramST.setAttribute("expr", expressionToKarajan(param.getAbstractExpression(), scope));
+        else {
+            String parameterVariableName="swift#mapper#"+(internedIDCounter++);
+            // make template for variable declaration (need to compute type of this variable too?)
+            StringTemplate variableDeclarationST = template("variable");
+            // TODO factorise this and other code in variable()?
+            StringTemplate pmappingST = new StringTemplate("mapping");
+            pmappingST.setAttribute("descriptor", "concurrent_mapper");
+            StringTemplate pparamST = template("vdl_parameter");
+            pparamST.setAttribute("name", "prefix");
+            pparamST.setAttribute("expr", parameterVariableName + "-" +
+            pmappingST.setAttribute("params", pparamST);
+            variableDeclarationST.setAttribute("nil", Boolean.TRUE);
+            variableDeclarationST.setAttribute("name", parameterVariableName);
+            scope.bodyTemplate.setAttribute("declarations", variableDeclarationST);
+            StringTemplate paramValueST=expressionToKarajan(param.getAbstractExpression(),scope);
+            String paramValueType = datatype(paramValueST);
+            scope.addVariable(parameterVariableName, paramValueType, "Variable", param);
+            variableDeclarationST.setAttribute("type", paramValueType);
+            StringTemplate variableReferenceST = template("id");
+            variableReferenceST.setAttribute("var",parameterVariableName);
+            StringTemplate variableAssignmentST = template("assign");
+            variableAssignmentST.setAttribute("var",variableReferenceST);
+            variableAssignmentST.setAttribute("value",paramValueST);
+            scope.appendStatement(variableAssignmentST);
+            if (param.getAbstractExpression().getDomNode().getNodeName().equals("stringConstant")) {
+                StringTemplate valueST = template("sConst");
+                valueST.setAttribute("innervalue", param.getAbstractExpression().getDomNode().getFirstChild().getNodeValue());
+                paramST.setAttribute("expr",valueST);
+            else {
+                paramST.setAttribute("expr",variableReferenceST);
+        return paramST;
     void checkIsTypeDefined(String type) throws CompilationException {
 	    if (!org.griphyn.vdl.type.Types.isValidType(type, typesMap.keySet())) {
 	        throw new CompilationException("Type " + type + " is not defined.");
+    private boolean isPrimitiveOrArrayOfPrimitive(String type) {
+        org.griphyn.vdl.type.Type t;
+        try {
+            t = org.griphyn.vdl.type.Types.getType(type);
+            return t.isPrimitive() || (t.isArray() && t.itemType().isPrimitive());
+        catch (NoSuchTypeException e) {
+            return false;
 	public void assign(Assign assign, VariableScope scope) throws CompilationException {
 		try {
 			StringTemplate assignST = template("assign");
-			StringTemplate varST = expressionToKarajan(assign.getAbstractExpressionArray(0),scope);
+			StringTemplate varST = expressionToKarajan(assign.getAbstractExpressionArray(0), scope, true);
 			StringTemplate valueST = expressionToKarajan(assign.getAbstractExpressionArray(1),scope);
 			if (! (datatype(varST).equals(datatype(valueST)) ||
 			       datatype(valueST).equals("java")))
@@ -555,7 +568,7 @@
 			assignST.setAttribute("value", valueST);
 			assignST.setAttribute("line", getLine(assign));
 			String rootvar = abstractExpressionToRootVariable(assign.getAbstractExpressionArray(0));
-			scope.addWriter(rootvar, new Integer(callID++), rootVariableIsPartial(assign.getAbstractExpressionArray(0)));
+			scope.addWriter(rootvar, getRootVariableWriteType(assign.getAbstractExpressionArray(0)), assign, assignST);
 			scope.appendStatement(assignST);
 		} catch(CompilationException re) {
 			throw new CompilationException("Compile error in assignment at "+assign.getSrc()+": "+re.getMessage(),re);
@@ -580,7 +593,7 @@
             appendST.setAttribute("value", value);
             String rootvar = abstractExpressionToRootVariable(append.getAbstractExpressionArray(0));
             // an append is always a partial write
-            scope.addWriter(rootvar, new Integer(callID++), true);
+            scope.addWriter(rootvar, WriteType.PARTIAL, append, appendST);
             scope.appendStatement(appendST);
             throw new CompilationException("Compile error in assignment at "+append.getSrc()+": "+re.getMessage(),re);
@@ -797,7 +810,7 @@
 					ActualParameter output = call.getOutputArray(i);
 					StringTemplate argST = actualParameter(output, scope);
 					callST.setAttribute("outputs", argST);
-					addWriterToScope(scope, call.getOutputArray(i).getAbstractExpression());
+					addWriterToScope(scope, call.getOutputArray(i).getAbstractExpression(), call, callST);
 			if (keywordArgsOutput) {
@@ -816,12 +829,12 @@
 						throw new CompilationException("Wrong type for output parameter number " + i +
 								", expected " + formalType + ", got " + actualType);
 			} else { /* Positional arguments */
 				for (int i = 0; i < call.sizeOfOutputArray(); i++) {
-					StringTemplate argST = actualParameter(output, scope);
+					StringTemplate argST = actualParameter(output, scope, true);
 					FormalArgumentSignature formalArg =proceduresMap.get(procName).getOutputArray(i);
@@ -833,7 +846,7 @@
 						throw new CompilationException("Wrong type for parameter number " + i +
@@ -844,8 +857,9 @@
 			    callST.setAttribute("serialize", Boolean.TRUE);
 			return callST;
-		} catch(CompilationException ce) {
-			throw new CompilationException("Compile error in procedure invocation at "+call.getSrc()+": "+ce.getMessage(),ce);
+		catch (CompilationException ce) {
+			throw new CompilationException("Compile error in procedure invocation at " + call.getSrc(), ce);
@@ -883,19 +897,19 @@
         return true;
-    private void addWriterToScope(VariableScope scope, XmlObject var) throws CompilationException {
+    private void addWriterToScope(VariableScope scope, XmlObject var, XmlObject src, StringTemplate out) throws CompilationException {
         String rootvar = abstractExpressionToRootVariable(var);
-        boolean partial = rootVariableIsPartial(var);
-        if (!partial) {
+        WriteType writeType = getRootVariableWriteType(var);
+        if (writeType == WriteType.FULL) {
             // don't close variables that are already closed by the function itself
             scope.inhibitClosing(rootvar);
-        scope.addWriter(rootvar, new Integer(callID++), partial);
+        scope.addWriter(rootvar, writeType, src, out);
     public void iterateStat(Iterate iterate, VariableScope scope) throws CompilationException {
-		VariableScope loopScope = new VariableScope(this, scope, VariableScope.ENCLOSURE_LOOP);
-		VariableScope innerScope = new VariableScope(this, loopScope, VariableScope.ENCLOSURE_LOOP);
+		VariableScope loopScope = new VariableScope(this, scope, EnclosureType.LOOP, iterate);
+		VariableScope innerScope = new VariableScope(this, loopScope, EnclosureType.LOOP, iterate);
 		loopScope.addVariable(iterate.getVar(), "int", "Iteration variable", iterate);
@@ -904,6 +918,8 @@
 		iterateST.setAttribute("var", iterate.getVar());
 		innerScope.bodyTemplate = iterateST;
+		loopScope.addWriter(iterate.getVar(), WriteType.FULL, iterate, iterateST);
 		statementsForSymbols(iterate.getBody(), innerScope);
 		statements(iterate.getBody(), innerScope);
@@ -912,16 +928,13 @@
 		StringTemplate condST = expressionToKarajan(cond, innerScope);
 		iterateST.setAttribute("cond", condST);
-		Object statementID = new Integer(callID++);
-		for (String v : innerScope.getVariables())
-			scope.addWriter(v, statementID, true);
 		scope.appendStatement(iterateST);
 		iterateST.setAttribute("cleanups", innerScope.getCleanups());
 	public void foreachStat(Foreach foreach, VariableScope scope) throws CompilationException {
 		try {
-			VariableScope innerScope = new VariableScope(this, scope, VariableScope.ENCLOSURE_LOOP);
+			VariableScope innerScope = new VariableScope(this, scope, EnclosureType.LOOP, foreach);
 			StringTemplate foreachST = template("foreach");
 			foreachST.setAttribute("var", foreach.getVar());
@@ -930,6 +943,10 @@
 			XmlObject in = foreach.getIn().getAbstractExpression();
 			StringTemplate inST = expressionToKarajan(in, scope);
 			foreachST.setAttribute("in", inST);
+			if ("id".equals(inST.getName())) {
+                innerScope.setForeachSourceVar((String) inST.getAttribute("var"), foreach);
 			String inType = datatype(inST);
 			String itemType = org.griphyn.vdl.type.Types.getArrayInnerItemTypeName(inType);
@@ -938,30 +955,26 @@
 			    throw new CompilationException("You can iterate through an array structure only");
 			innerScope.addVariable(foreach.getVar(), itemType, "Iteration variable", foreach);
+			innerScope.addWriter(foreach.getVar(), WriteType.FULL, foreach, foreachST);
 			foreachST.setAttribute("indexVar", foreach.getIndexVar());
 			foreachST.setAttribute("indexVarType", keyType);
-			if(foreach.getIndexVar() != null) {
+			if (foreach.getIndexVar() != null) {
 				innerScope.addVariable(foreach.getIndexVar(), keyType, "Iteration variable", foreach);
+				innerScope.addWriter(foreach.getIndexVar(), WriteType.FULL, foreach, foreachST);
 			innerScope.bodyTemplate = foreachST;
 			statementsForSymbols(foreach.getBody(), innerScope);
 			statements(foreach.getBody(), innerScope);
-			String inVar = (String) inST.getAttribute("var");
-			for (String v : innerScope.getVariables()) {
-			    if (v.equals(inVar) && !innerScope.isVariableLocallyDefined(v))
-			        foreachST.setAttribute("selfClose", "true");
 			scope.appendStatement(foreachST);
 			Collection<String> cleanups = innerScope.getCleanups();
 			cleanups.remove(foreach.getVar());
 			foreachST.setAttribute("cleanups", cleanups);
-		} catch(CompilationException re) {
-			throw new CompilationException("Compile error in foreach statement at "+foreach.getSrc()+": "+re.getMessage(),re);
+		catch (CompilationException re) {
+			throw new CompilationException("Compile error in foreach statement at " + foreach.getSrc(), re);
@@ -977,7 +990,8 @@
 		Then thenstat = ifstat.getThen();
 		Else elsestat = ifstat.getElse();
-		VariableScope innerThenScope = new VariableScope(this, scope, VariableScope.ENCLOSURE_CONDITION);
+		VariableScope innerThenScope = new VariableScope(this, scope,
+		    EnclosureType.CONDITION, thenstat);
 		innerThenScope.bodyTemplate = template("sub_comp");
 		ifST.setAttribute("vthen", innerThenScope.bodyTemplate);
@@ -985,31 +999,32 @@
 		statements(thenstat, innerThenScope);
 		innerThenScope.bodyTemplate.setAttribute("cleanups", innerThenScope.getCleanups());
-		for (String v : innerThenScope.getVariables())
 		if (elsestat != null) {
-			VariableScope innerElseScope = new VariableScope(this, scope);
+			VariableScope innerElseScope = new VariableScope(this, scope,
+			    EnclosureType.CONDITION, elsestat);
 			innerElseScope.bodyTemplate = template("sub_comp");
+			innerElseScope.setThen(innerThenScope);
 			ifST.setAttribute("velse", innerElseScope.bodyTemplate);
 			statementsForSymbols(elsestat, innerElseScope);
 			statements(elsestat, innerElseScope);
-			for (String v : innerElseScope.getVariables())
 			innerElseScope.bodyTemplate.setAttribute("cleanups", innerElseScope.getCleanups());
+		else if (innerThenScope.hasPartialClosing()) {
+		    // must do matching partial closing somewhere, so need
+		    // else branch even though not specified in the swift source
+            innerElseScope.bodyTemplate = template("sub_comp");
+            ifST.setAttribute("velse", innerElseScope.bodyTemplate);
 		scope.appendStatement(ifST);
 	public void switchStat(Switch switchstat, VariableScope scope) throws CompilationException {
 		StringTemplate switchST = template("switch");
 		scope.bodyTemplate.setAttribute("statements", switchST);
 		StringTemplate conditionST = expressionToKarajan(switchstat.getAbstractExpression(), scope);
 		switchST.setAttribute("condition", conditionST.toString());
@@ -1020,24 +1035,19 @@
 		for (int i=0; i< switchstat.sizeOfCaseArray(); i++) {
 			Case casestat = switchstat.getCaseArray(i);
-			VariableScope caseScope = new VariableScope(this, scope);
+			VariableScope caseScope = new VariableScope(this, scope, casestat);
 			caseScope.bodyTemplate = new StringTemplate("case");
 			switchST.setAttribute("cases", caseScope.bodyTemplate);
 			caseStat(casestat, caseScope);
-			for (String v : caseScope.getVariables())
 		Default defaultstat = switchstat.getDefault();
 		if (defaultstat != null) {
-			VariableScope defaultScope = new VariableScope(this, scope);
+			VariableScope defaultScope = new VariableScope(this, scope, defaultstat);
 			defaultScope.bodyTemplate = template("sub_comp");
 			switchST.setAttribute("sdefault", defaultScope.bodyTemplate);
 			statementsForSymbols(defaultstat, defaultScope);
 			statements(defaultstat, defaultScope);
-			for (String v : defaultScope.getVariables())
@@ -1047,10 +1057,14 @@
 		statementsForSymbols(casestat.getStatements(), scope);
 		statements(casestat.getStatements(), scope);
+	public StringTemplate actualParameter(ActualParameter arg, VariableScope scope) throws CompilationException {
+	    return actualParameter(arg, scope, false);
-	public StringTemplate actualParameter(ActualParameter arg, VariableScope scope) throws CompilationException {
+	public StringTemplate actualParameter(ActualParameter arg, VariableScope scope, boolean lvalue) throws CompilationException {
 		StringTemplate argST = template("call_arg");
-		StringTemplate expST = expressionToKarajan(arg.getAbstractExpression(), scope);
+		StringTemplate expST = expressionToKarajan(arg.getAbstractExpression(), scope, lvalue);
 		argST.setAttribute("bind", arg.getBind());
 		argST.setAttribute("expr", expST);
 		argST.setAttribute("datatype", datatype(expST));
@@ -1188,11 +1202,15 @@
 	static final QName RANGE_EXPR = new QName(SWIFTSCRIPT_NS, "range");
 	static final QName FUNCTION_EXPR = new QName(SWIFTSCRIPT_NS, "function");
 	static final QName CALL_EXPR = new QName(SWIFTSCRIPT_NS, "call");
+	public StringTemplate expressionToKarajan(XmlObject expression, VariableScope scope) throws CompilationException {
+	    return expressionToKarajan(expression, scope, false);
 	/** converts an XML intermediate form expression into a
 	 *  Karajan expression.
-	public StringTemplate expressionToKarajan(XmlObject expression, VariableScope scope) throws CompilationException
+	public StringTemplate expressionToKarajan(XmlObject expression, VariableScope scope, boolean lvalue) throws CompilationException
 		Node expressionDOM = expression.getDomNode();
@@ -1322,10 +1340,12 @@
 			XmlString xmlString = (XmlString) expression;
 			String s = xmlString.getStringValue();
 			if(!scope.isVariableDefined(s)) {
-				throw new CompilationException("Variable " + s + " is undefined.");
+				throw new CompilationException("Variable " + s + " was not declared in this scope.");
-			setVariableUsed(s);
+			if (!lvalue) {
+			    scope.addReader(s, false, expression);
 			StringTemplate st = template("id");
 			st.setAttribute("var", s);
 			String actualType;
@@ -1336,7 +1356,7 @@
 		} else if (expressionQName.equals(ARRAY_SUBSCRIPT_EXPR)) {
 			BinaryOperator op = (BinaryOperator) expression;
 			StringTemplate arrayST = expressionToKarajan(op.getAbstractExpressionArray(1), scope);
-			StringTemplate parentST = expressionToKarajan(op.getAbstractExpressionArray(0), scope);
+			StringTemplate parentST = expressionToKarajan(op.getAbstractExpressionArray(0), scope, true);
 			String indexType = datatype(arrayST);
 			String declaredIndexType = org.griphyn.vdl.type.Types.getArrayOuterIndexTypeName(datatype(parentST));
@@ -1359,6 +1379,8 @@
 			        + indexType + ") does not match the declared index type (" + declaredIndexType + ")");
+			scope.addReader((String) parentST.getAttribute("var"), true, expression);
 			StringTemplate newst = template("extractarrayelement");
 			newst.setAttribute("arraychild", arrayST);
 			newst.setAttribute("parent", parentST);
@@ -1367,7 +1389,7 @@
 			return newst;
 		} else if (expressionQName.equals(STRUCTURE_MEMBER_EXPR)) {
 			StructureMember sm = (StructureMember) expression;
-			StringTemplate parentST = expressionToKarajan(sm.getAbstractExpression(), scope);
+			StringTemplate parentST = expressionToKarajan(sm.getAbstractExpression(), scope, true);
 			String parentType = datatype(parentST);
@@ -1414,6 +1436,8 @@
 			else {
 				newst = template("extractstructelement");
 			newst.setAttribute("memberchild", sm.getMemberName());
             newst.setAttribute("datatype", actualType);
@@ -1492,7 +1516,7 @@
 		} else if (expressionQName.equals(CALL_EXPR)) {
 		    Call c = (Call) expression;
 		    c.addNewOutput();
-		    VariableScope subscope = new VariableScope(this, scope);
+		    VariableScope subscope = new VariableScope(this, scope, c);
 		    VariableReferenceDocument ref = VariableReferenceDocument.Factory.newInstance();
 		    ref.setVariableReference("swift#callintermediate");
 		    c.getOutputArray(0).set(ref);
@@ -1517,7 +1541,6 @@
 		    call.setAttribute("datatype", type);
 		    call.setAttribute("call", call(c, subscope, true));
-		    call.setAttribute("callID", new Integer(callID++));
 		    call.setAttribute("prefix", UUIDGenerator.getInstance().generateRandomBasedUUID().toString());
 		    return call;
 		} else {
@@ -1585,17 +1608,17 @@
-	public boolean rootVariableIsPartial(XmlObject expression) {
+	public WriteType getRootVariableWriteType(XmlObject expression) {
-			return false;
+			return WriteType.FULL;
-			return true;
+			return WriteType.PARTIAL;
-			return true;
 		} else {
 			throw new RuntimeException("Could not find root for abstract expression.");
Modified: trunk/src/org/griphyn/vdl/engine/VariableScope.java
--- trunk/src/org/griphyn/vdl/engine/VariableScope.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/engine/VariableScope.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -18,12 +18,16 @@
 import java.util.ArrayList;
+import java.util.Collection;
+import java.util.Collections;
 import java.util.HashMap;
 import java.util.HashSet;
 import java.util.Iterator;
+import java.util.LinkedList;
 import java.util.List;
 import java.util.Map;
 import java.util.Set;
+import java.util.Stack;
 import org.antlr.stringtemplate.StringTemplate;
 import org.apache.log4j.Logger;
@@ -32,25 +36,26 @@
 public class VariableScope {
-	/** permit array up-assignment, but not entire variables */
-	public final static int ENCLOSURE_LOOP = 301923;
-	/** permit all upwards assignments */
-	public static final int ENCLOSURE_ALL = 301924;
-	/** permit no upwards assignments */
-	public static final int ENCLOSURE_NONE = 301925;
-	/** permit no access to the containing scope except for finding
-	    global variables */
-	public static final int ENCLOSURE_PROCEDURE = 301926;
+    public enum EnclosureType {
+        /** permit array up-assignment, but not entire variables */
+        LOOP,
+        /** permit all upwards assignments */
+        ALL,
+        /** permit no upwards assignments */
+        NONE,
+        /** permit no access to the containing scope except for finding
+        global variables */
+        PROCEDURE,
+        /** Override ENCLOSURE_LOOP to allow assignment inside a loop
+         * based on some condition
+        CONDITION;
+    public enum WriteType {
+        FULL, PARTIAL
-	/** Override ENCLOSURE_LOOP to allow assignment inside a loop
-	 * based on some condition
-	public static final int ENCLOSURE_CONDITION = 301927;
 	public static final Logger logger = Logger.getLogger(VariableScope.class);
 	/** need this for the program as a whole. probably should factor
@@ -64,17 +69,114 @@
 	    this will be the same as parentScope or this. */
 	VariableScope rootScope;
-	int enclosureType;
+	private EnclosureType enclosureType;
 	/** The string template in which we will store statements
 	    outputted into this scope. */
 	public StringTemplate bodyTemplate;
 	private List<String> outputs = new ArrayList<String>();
-	private Set<String> inhibitClosing = new HashSet<String>();
+	private Set<String> inhibitClosing;
+	private List<VariableScope> children = new LinkedList<VariableScope>();
+	private XmlObject src;
+	/** List of templates to be executed in sequence after the present
+        in-preparation statement is outputted. */
+    List<StringTemplate> presentStatementPostStatements =  new ArrayList<StringTemplate>();
+    /** Set of variables (String token names) that are declared in
+        this scope - not variables in parent scopes, though. */
+    Map<String, Variable> variables;
+     * Usage (such as writing or reading) in this scope
+    Map<String, VariableUsage> variableUsage;
+     * If this is the scope of an 'else', then store a reference
+     * to the corresponding 'then'
+    private VariableScope thenScope;
+    private static class Variable {
+        public final String name, type;
+        public final XmlObject src;
+        public final boolean isGlobal;
+        private XmlObject foreachSrc;
+        public Variable(String name, String type, boolean isGlobal, XmlObject src) {
+            this.name = name;
+            this.type = type;
+            this.src = src;
+            this.isGlobal = isGlobal;
+    /** Stores information about a variable that is referred to in this
+        scope. Should probably get used for dataset marking eventually. */
+    private static class VariableUsage {
+        private final String name;
+        private XmlObject fullWritingLoc, foreachSourceVar;
+        private List<XmlObject> partialWritingLoc;
+        private List<XmlObject> fullReadingLoc;
+        private int referenceCount;
+        public VariableUsage(String name) {
+            this.name = name;
+        public boolean addWritingStatement(XmlObject loc, WriteType writeType) throws CompilationException {
+            if (writeType == WriteType.PARTIAL) {
+                if (partialWritingLoc == null) {
+                    partialWritingLoc = new LinkedList<XmlObject>();
+                if (!partialWritingLoc.contains(loc)) {
+                    partialWritingLoc.add(loc);
+                    return true;
+                else {
+                    return false;
+            else {
+                if (fullWritingLoc != null) {
+                    throw new CompilationException("Variable " + name + " is written to in two different locations:\n\t1. "
+                        + CompilerUtils.info(fullWritingLoc) + "\n\t2. " + CompilerUtils.info(loc));
+                else {
+                    fullWritingLoc = loc;
+                    return true;
-	public VariableScope(Karajan c, VariableScope parent) {
-		this(c, parent, ENCLOSURE_ALL);
+        public boolean hasWriters() {
+            return fullWritingLoc != null || (partialWritingLoc != null && partialWritingLoc.size() > 0);
+        public void addFullReadingStatement(XmlObject where) {
+            if (fullReadingLoc == null) {
+                fullReadingLoc = new LinkedList<XmlObject>();
+            fullReadingLoc.add(where);
+        public boolean hasReaders() {
+            return fullReadingLoc != null && fullReadingLoc.size() > 0;
+        public XmlObject getForeachSourceVar() {
+            return foreachSourceVar;
+        public void setForeachSourceVar(XmlObject foreachSourceVar) {
+            this.foreachSourceVar = foreachSourceVar;
+	public VariableScope(Karajan c, VariableScope parent, XmlObject src) {
+		this(c, parent, EnclosureType.ALL, src);
 	/** Creates a new variable scope.
@@ -84,7 +186,7 @@
 		@param a specifies how assignments to variables made in enclosing
 			scopes will be handled.
-	public VariableScope(Karajan c, VariableScope parent, int a) {
+	public VariableScope(Karajan c, VariableScope parent, EnclosureType a, XmlObject src) {
 	    if (logger.isDebugEnabled()) {
     		if (parentScope != null) {
     			logger.debug("New scope " + hashCode() + " with parent scope " + parentScope.hashCode());
@@ -96,24 +198,30 @@
 		compiler = c;
 		parentScope = parent;
 		enclosureType = a;
-		if(parentScope == null) {
+		if (parentScope == null) {
 			rootScope = this;
-		} else {
+		else {
 			rootScope = parentScope.getRootScope();
+			parentScope.addChild(this);
+		this.src = src;
-	/** Set of variables (String token names) that are declared in
-	    this scope - not variables in parent scopes, though. */
-	Map<String, XmlObject> variables = new HashMap<String, XmlObject>();
-	Map<String, String> varTypes = new HashMap<String, String>();
+	public void addChild(VariableScope scope) {
+	    children.add(scope);
+	public List<VariableScope> getChildren() {
+	    return children;
+	public void setThen(VariableScope thenScope) {
+	    this.thenScope = thenScope;
+	    updateBranchReferenceCounts();
-	/** Set of variables (String token names) which are global and
-	    declared in this scope (which must be a root scope). Variables
-	    in this set must also appear in the variables set. */
-	Map<String, XmlObject> globals = new HashMap<String, XmlObject>();
 	/** Asserts that a named variable is declared in this scope.
 	    Might also eventually contain more information about the
 	    variable. Need to define behaviour here when the
@@ -124,7 +232,81 @@
 		addVariable(name, type, context, false, src);
+	private Collection<VariableUsage> getVariableUsageValues() {
+	    if (variableUsage == null) {
+	        return Collections.emptyList();
+	    else {
+	        return variableUsage.values();
+	private Map<String, VariableUsage> getVariableUsage() {
+	        variableUsage = new HashMap<String, VariableUsage>();
+	    return variableUsage;
+	 * Get variable usage if it exists, otherwise return null
+	protected VariableUsage getExistingUsage(String name) {
+	        return null;
+	    else {
+	        return variableUsage.get(name);
+	private Collection<String> getUsedVariableNames() {
+	    else {
+	        return variableUsage.keySet();
+	private Collection<String> getLocallyDeclaredVariableNames() {
+        if (variables == null) {
+        else {
+            return variables.keySet();
+	 * Returns variable usage in this scope for the given name.
+	 * If no previous usage exists, create it. This method
+	 * guarantees a non-null return
+	protected VariableUsage getUsageForUpdate(String name) {
+	    Map<String, VariableUsage> usage = getVariableUsage();
+	    VariableUsage u = usage.get(name);
+	    if (u == null) {
+	        u = new VariableUsage(name);
+	        usage.put(name, u);
+	    return u;
+	public void setForeachSourceVar(String name, XmlObject src) {
+	    getUsageForUpdate(name).setForeachSourceVar(src);
+	public boolean isForeachSourceVar(String name) {
+	    VariableUsage u = getExistingUsage(name);
+	    return u != null && u.getForeachSourceVar() != null;
 	public void inhibitClosing(String name) {
+	    if (inhibitClosing == null) {
+	        inhibitClosing = new HashSet<String>();
 		inhibitClosing.add(name);
@@ -135,7 +317,7 @@
 		if(isVariableDefined(name)) {
 			throw new CompilationException("Variable " + name + ", on line "
-			    + CompilerUtils.getLine(src) + ", was already defined on line " + getDefinitionLine(name));
+			    + CompilerUtils.getLine(src) + ", was already defined on line " + getDeclarationLine(name));
 		// TODO does this if() ever fire? or is it always taken
@@ -143,22 +325,24 @@
 		// be replaced by is locally defined test.
 		if(parentScope != null && parentScope.isVariableDefined(name)) {
 		    Warnings.warn(context + " " + name + ", on line " + CompilerUtils.getLine(src)
-			+ ", shadows variable of same name on line " + parentScope.getDefinitionLine(name));
+			+ ", shadows variable of same name on line " + parentScope.getDeclarationLine(name));
-		if(global && this != rootScope) {
+		if (global && this != rootScope) {
 			throw new CompilationException("Global " + name + " can only be declared in the root scope of a program.");
-		variables.put(name, src);
-		varTypes.put(name, type);
-		if (global) {
-			globals.put(name, src);
+		getVariablesMap().put(name, new Variable(name, type, global, src));
+	private Map<String, Variable> getVariablesMap() {
+	        variables = new HashMap<String, Variable>();
+	    return variables;
 	 * Does pretty much the same as addVariable() except it doesn't throw
 	 * an exception if the variable is defined in a parent scope
@@ -169,16 +353,18 @@
 		if(isVariableLocallyDefined(name)) {
+		getVariablesMap().put(name, new Variable(name, type, false, src));
-	public String getDefinitionLine(String name) {
-	    XmlObject src = rootScope.getGlobalSrc(name);
-	    if (src == null) {
+	public String getDeclarationLine(String name) {
+	    XmlObject src;
+	    if (rootScope.isGlobalDefined(name)) {
+	        src = rootScope.getGlobalSrc(name);
+	    else {
 	        src = getSrcRecursive(name);
 	    if (src != null) {
@@ -191,155 +377,609 @@
 	public boolean isVariableDefined(String name) {
 		if(rootScope.isGlobalDefined(name)) return true;
-		return isVariableDefinedRecursive(name);
+		return isVariableVisible(name);
-	private XmlObject getSrcRecursive(String name) {
-	    XmlObject src = variables.get(name);
-	        if (enclosureType != ENCLOSURE_PROCEDURE && parentScope != null) {
-	            src = parentScope.getSrcRecursive(name);
+	 * Recursively find information about a variable visible in this scope.
+	 * Also, look for globals.
+	public Variable lookup(String name) {
+	    if (variables != null) {
+	        Variable var = variables.get(name);
+	        if (var != null) {
+	            return var;
-	    return src;
+	    if (enclosureType != EnclosureType.PROCEDURE && parentScope != null) {
+	        return parentScope.lookup(name);
+	    else {
+	        // if the search fails, see if there is a global with this name
+	        if (rootScope.variables != null) {
+	            Variable v = rootScope.variables.get(name);
+	            if (v != null && v.isGlobal) {
+	                return v;
+	            else {
+	                return null;
+	        else {
+	            return null;
+	private XmlObject getSrcRecursive(String name) {
+	    Variable var = lookup(name);
+	    if (var == null) {
+	        throw new IllegalArgumentException("Variable " + name + " is not visible in this scope");
+	    return var.src;
-	private boolean isVariableDefinedRecursive(String name) {
-		if(isVariableLocallyDefined(name)) return true;
-		if(enclosureType != ENCLOSURE_PROCEDURE && parentScope != null && parentScope.isVariableDefined(name)) return true;
-		return false;
+	private boolean isVariableVisible(String name) {
+		if (isVariableLocallyDefined(name)) {
+		    return true;
+		    return parentScope.isVariableVisible(name);
+		else {
+		    return false;
+	private StringTemplate getExistingDeclaration(String name) {
+            return getLocalDeclaration(name);
+        else if (parentScope != null) {
+            return parentScope.getExistingDeclaration(name);
+        else {
+            return null;
 	public boolean isGlobalDefined(String name) {
-		return globals.containsKey(name);
+	    Variable var = rootScope.lookup(name);
+	    return var != null && var.isGlobal;
 	public XmlObject getGlobalSrc(String name) {
-	    return globals.get(name);
+        if (var != null && var.isGlobal) {
+            return var.src;
+        else {
+            throw new IllegalArgumentException("'" + name + "' is not a global variable");
-	/** note that this will return variable types for variables in
-	    containing scopes even if they are not accessible. non-null
-	    return value from this method should not be treated as an
-	    indication that the variable is in any way accessible from
-	    this scope. The isVariableDefined and isGlobalDefined methods
-	    should be used to check that. */
 	public String getVariableType(String name) {
-			return varTypes.get(name).toString();
-		if(parentScope != null && parentScope.isVariableDefined(name))
-			return parentScope.getVariableType(name);
-		return null;
+	        return var.type;
+	    else {
-// TODO could also mark variable as written and catch duplicate assignments
-// in the same scope here
-	public boolean isVariableWriteable(String name, boolean partialWriter) {
-		if(parentScope != null && parentScope.isVariableWriteable(name, true) && enclosureType == ENCLOSURE_CONDITION) {
-		    Warnings.warn("Variable " + name + ", defined on line " + getDefinitionLine(name) + ", might have multiple writers");
+	public boolean isVariableWriteable(String name, WriteType writeType) {
 		    return true;
-		if(parentScope != null && parentScope.isVariableWriteable(name, partialWriter) && enclosureType == ENCLOSURE_ALL) return true;
-		if(parentScope != null && parentScope.isVariableWriteable(name, partialWriter) && enclosureType == ENCLOSURE_LOOP && partialWriter) return true;
-		return false;
+		    // if we are the root scope and the variable is not declared here,
+		    // then there is no other place to look
+		    return false;
+		switch (enclosureType) {
+		    case CONDITION:
+		        if (parentScope.isVariableWriteable(name, WriteType.FULL)) {
+		            if (getTopmostLoopToDeclaration(name) != null) {
+		                Warnings.warn("Variable " + name + ", defined on line " +
+		                    getDeclarationLine(name) + ", might have multiple conflicting writers");
+		            return true;
+		        else {
+		            return false;
+		    case ALL:
+		        return parentScope.isVariableWriteable(name, writeType);
+		    case LOOP:
+		        return parentScope.isVariableWriteable(name, writeType) && writeType == WriteType.PARTIAL;
+		    default:
+		        return false;
-	public boolean isVariableLocallyDefined(String name) {
-		return variables.containsKey(name);
+	 * Assumes that the variable is defined in some parent scope.
+	 * Returns the top-most loop between this scope and the declaration
+	 * or null if no such loop is found
+	private VariableScope getTopmostLoopToDeclaration(String name) {
+            return null;
+        else if (enclosureType == EnclosureType.LOOP) {
+            VariableScope parentLoop = parentScope.getTopmostLoopToDeclaration(name);
+            if (parentLoop != null) {
+                return parentLoop;
+            else {
+                return this;
+        else {
+            return parentScope.getTopmostLoopToDeclaration(name);
+	 * This deals with cases like this:
+	 * a[]; a[0] = 1;
+	 * foreach v, k in a {
+	 *   if (c) {
+	 *     a[k + 1] = 1;
+	 *   if (c) {
+     *     a[k + 100] = 1;
+	 * a[] can be considered closed when all of the following are true:
+	 *   1. the write reference count is equal to the number of loops
+	 *      that both iterate on and write to a
+	 *   2. none of those loops have any iterations running
+	 *   3. there are no elements in a[] left to iterate on
+	 * These three conditions guarantee that no more writing
+	 * can happen to a[].
+	 *  Unfortunately, it seems horribly complicated to deal with multiple
+	 *  loops that do this. Simple reference counting doesn't work, since
+	 *  any of the conditions above can become false at any point and it is
+	 *  hard to have an absolute time for all of the loops.
+	 *  So engineering compromise: this is allowed for a single loop (per
+	 *  array), and that's been shown to work (the self close scheme).
+	 *  If used in more than one array, throw an error.
+	 * @throws CompilationException
+	private void markInVariableUsedInsideLoop(String name) throws CompilationException {
+	        return;
+	        case PROCEDURE:
+	        case NONE:
+	            return;
+	        case LOOP:
+	            if (isForeachSourceVar(name)) {
+	                // mark as selfClosing
+	                if (var.foreachSrc != null) {
+	                    throw new CompilationException("Updating of an array (" +
+	                        name + ", line " + getDeclarationLine(name) + ") inside a " +
+	                        "foreach loop that iterates over it is limited to a single " +
+	                        "loop, but it is used in both " + CompilerUtils.info(var.foreachSrc) +
+	                        " and " + CompilerUtils.info(src));
+	                else {
+	                    setSelfClose();
+	            // also add partial close
+	        default:
+	            if (parentScope != null) {
+	                parentScope.markInVariableUsedInsideLoop(name);
-	/** List of templates to be executed in sequence after the present
-	    in-preparation statement is outputted. */
-	List<StringTemplate> presentStatementPostStatements =  new ArrayList<StringTemplate>();
+    private void setSelfClose() {
+        bodyTemplate.setAttribute("selfClose", "true");
-	Map<String, Variable> variableUsage = new HashMap<String, Variable>();
+    public boolean isVariableLocallyDefined(String name) {
+		return variables != null && variables.containsKey(name);
 	/** indicates that the present in-preparation statement writes to the
 	    named variable. If the variable is declared in the local scope,
 	    register a closing statement; otherwise, record that this scope
 	    writes to the variable so that the scope-embedding code (such as
 	    the foreach compiler) can handle appropriately. */
-	public void addWriter(String variableName, Object closeID, boolean partialWriter) throws CompilationException
-		if(!isVariableDefined(variableName)) {
+	public void addWriter(String variableName, WriteType writeType,
+	        XmlObject where, StringTemplate out) throws CompilationException {
+		if (!isVariableDefined(variableName)) {
 			throw new CompilationException("Variable " + variableName + " is not defined");
+		if (logger.isDebugEnabled()) {
+		    logger.debug("Writer " + variableName + " " + CompilerUtils.info(where));
-		if(isVariableLocallyDefined(variableName)) {
-			StringTemplate ld = getLocalDeclaration(variableName);
-			if (ld != null) {
-				if(!partialWriter && ld.getAttribute("waitfor") != null) {
-					throw new CompilationException("variable " + variableName + ", defined on line "
-					    + getDefinitionLine(variableName) + ", has multiple writers.");
-				ld.setAttribute("waitfor", closeID);
-			else {
-			    if (logger.isDebugEnabled()) {
-			        logger.debug("Variable " + variableName + " is local but has no template.");
-			outputs.add(variableName);
-			if (!inhibitClosing.contains(variableName)) {
-    			StringTemplate postST = compiler.template("partialclose");
-    			postST.setAttribute("var", variableName);
-    			postST.setAttribute("closeID", closeID);
-    			presentStatementPostStatements.add(postST);
-		} else {
+		if (isVariableWriteable(variableName, writeType)) {
+	        setVariableWrittenToInThisScope(variableName, writeType, where, out);
+		else {
+		    isVariableWriteable(variableName, writeType);
+			throw new CompilationException("variable " + variableName + " is not writeable in this scope");
+	public void partialClose(String name, XmlObject src, StringTemplate out) {
+	    if (inhibitClosing == null || !inhibitClosing.contains(name)) {
+	        StringTemplate decl = getExistingDeclaration(name);
+	        if (decl != null) {
+	            // a function return value will result
+	            // in a missing declaration
+	            // TODO fix that
+	            incWaitCount(name);
+	            StringTemplate postST = compiler.template("partialclose");
+	            postST.setAttribute("var", name);
+	            out.setAttribute("partialClose", postST);
+	public boolean hasPartialClosing() {
+	    if (enclosureType != EnclosureType.CONDITION || thenScope != null) {
+	        throw new IllegalStateException("hasPartialClosing should only be called in a 'then' condition scope");
+	    for (String name : getUsedVariableNames()) {
+	        VariableUsage v = getExistingUsage(name);
+	        if (v != null && v.referenceCount > 0) {
+	            return true;
+	    return false;
+	private void setPreClose(String name, int count) {
+	    setCount("preClose", name, count,
+	        new RefCountSetter<StringTemplate>() {
+	            @Override
+                public StringTemplate create(String name, int count) {
+	                StringTemplate t = compiler.template("partialclose");
+	                t.setAttribute("var", name);
+	                if (count != 1) {
+	                    t.setAttribute("count", count);
+	                return t;
+                @Override
+                public void set(StringTemplate t, int count) {
+                    t.removeAttribute("count");
+                    if (count != 1) {
+                        // 1 is the default count, so no need to have it explicitly
-// TODO now we have to walk up the scopes until either we find the
-// variable or we find an upwards assignment prohibition or we run
-// out of scopes
+                @Override
+                public boolean matches(StringTemplate t, String name) {
+                    return t.getAttribute("var").equals(name);
+	private void setLoopReferenceCount(String name, int count) {
+        setCount("refs", name, count, new RefCountSetter<SimpleRefCountRep>() {
+            @Override
+            public SimpleRefCountRep create(String name, int count) {
+                return new SimpleRefCountRep(name, count);
-// TODO so far this should find undeclared variables at compile time
-// so perhaps worth making this into a separate patch if it actually
-// works
+            @Override
+            public boolean matches(SimpleRefCountRep t, String name) {
+                return t.name.equals(name);
-			if(isVariableWriteable(variableName, partialWriter)) {
-				Variable variable = variableUsage.get(variableName);
-				if(variable == null) {
-					variable = new Variable();
-					variableUsage.put(variableName, variable);
+            @Override
+            public void set(SimpleRefCountRep t, int count) {
+                t.count = count;
+	private static class SimpleRefCountRep {
+	    public final String name;
+	    public int count;
+	    public SimpleRefCountRep(String name, int count) {
+	        this.name = name;
+	        this.count = count;
+	    public String toString() {
+	        return name + " " + count;
+	private static interface RefCountSetter<T> {
+	    T create(String name, int count);
+	    void set(T o, int count);
+	    boolean matches(T t, String name);
+	@SuppressWarnings("unchecked")
+    private <T> void setCount(String attrName, String name, int count, RefCountSetter<T> r) {
+   	    Object o = bodyTemplate.getAttribute(attrName);
+   	    List<T> pcs;
+   	    T matching = null;
+   	    if (o instanceof List) {
+   	        pcs = (List<T>) o;
+   	        Iterator<T> i = pcs.iterator();
+   	        while (i.hasNext()) {
+   	            T st = i.next();
+   	            if (r.matches(st, name)) {
+   	                if (count == 0) {
+   	                    i.remove();
+   	                else {
+   	                    matching = st;
+   	                    break;
+   	    else if (o != null) {
+   	        T st = (T) o;
+   	            if (count == 0) {
+   	                bodyTemplate.removeAttribute("preClose");
+   	            else {
+   	                matching = st;
+   	    if (count != 0 ) {
+   	        // add
+   	        if (matching == null) {
+   	            bodyTemplate.setAttribute(attrName, r.create(name, count));
+   	        else {
+	            r.set(matching, count);
+	private void incWaitCountLocal(String name) {
+	    StringTemplate decl = getLocalDeclaration(name);
+	    Integer i = (Integer) decl.getAttribute("waitCount");
+	    if (i == null) {
+	        i = 1;
+	    else {
+	        i = i + 1;
+	        decl.removeAttribute("waitCount");
+	    decl.setAttribute("waitCount", i);
-				List<Object> statementList = variable.writingStatements;
-				if(!statementList.contains(closeID)) {
-					statementList.add(closeID);
-				    logger.debug("added  " + closeID + " to variable "
-				        + variableName + " in scope " + hashCode());
-			} else {
-			    isVariableWriteable(variableName, partialWriter);
-				throw new CompilationException("variable " + variableName + " is not writeable in this scope");
+    private void incWaitCount(String name) {
+	    if (this.isVariableLocallyDefined(name)) {
+	        incWaitCountLocal(name);
+	    else {
+	        boolean propagateToParent = true;
+	        if (enclosureType == EnclosureType.CONDITION) {
+	            // due to the parsing order, the
+	            // then scopes are done before the else scopes,
+	            // so no need to update counts in subling else scopes
+	            // if this is a then scope
+	            if (thenScope == null) {
+	                // we are then 'then' scope
+	                incVariableReferenceCount(name);
+	            else {
+	                // else scope
+	                int myCount = incVariableReferenceCount(name);
+	                int thenCount = thenScope.getVariableReferenceCount(name);
+	                if (myCount > thenCount) {
+	                    thenScope.setPreClose(name, myCount - thenCount);
+	                    this.setPreClose(name, 0);
+	                else {
+	                    this.setPreClose(name, thenCount - myCount);
+	                    thenScope.setPreClose(name, 0);
+	                    // this has already been accounted for in the then branch
+	                    // so skip propagating it up
+	                    propagateToParent = false;
+	            // issue statements to dynamically increment wait
+	            // count on each iteration
+	            addLoopReferenceCount(name);
+	        // keep going until we hit the declaration
+	        if (propagateToParent && parentScope != null) {
+	            parentScope.incWaitCount(name);
+     * This is only called by setThen(scope), so guaranteed to
+     * be an 'else' scope
+    private void updateBranchReferenceCounts() {
+        for (VariableUsage v : thenScope.getVariableUsageValues()) {
+            if (v.referenceCount != 0) {
+                setPreClose(v.name, v.referenceCount);
+    public void addReader(String name, boolean partial, XmlObject where) throws CompilationException {
+	    setVariableReadInThisScope(name, partial, where);
+	    if (!partial) {
+	            logger.debug(name + " fully read in " + CompilerUtils.info(where));
+	private void setVariableWrittenToInThisScope(String name, WriteType writeType, XmlObject where, StringTemplate out)
+	throws CompilationException {
+	    VariableUsage variable = getUsageForUpdate(name);
+	    boolean added = variable.addWritingStatement(where, writeType);
+	    if (added) {
+	        partialClose(name, where, out);
+	        setNonInput(name);
+	    markInVariableUsedInsideLoop(name);
+	private void setNonInput(String name) {
+	        decl.removeAttribute("input");
-	/** looks up the template that declared the named variable in the
+    private void setVariableReadInThisScope(String name, boolean partial, XmlObject where)
+	    // only care about full reads, since they can only happen in
+	    // a scope higher than the closing
+	    if (partial) {
+	        return;
+        getUsageForUpdate(name).addFullReadingStatement(where);
+	private boolean isVariableWrittenToInThisScope(String name) {
+	    return v != null && v.hasWriters();
+	private int incVariableReferenceCount(String name) {
+	    return ++getUsageForUpdate(name).referenceCount;
+	private void addLoopReferenceCount(String name) {
+        int count = incVariableReferenceCount(name);
+        setLoopReferenceCount(name, count);
+	private int getVariableReferenceCount(String name) {
+        if (v == null) {
+            return 0;
+        else {
+            return v.referenceCount;
+	private boolean isVariableFullyReadInThisScope(String name) {
+        return v != null && v.hasReaders();
+	private XmlObject getFirstFullRead(String name) {
+        if (v == null) {
+            return null;
+        if (v.fullReadingLoc == null) {
+            return null;
+        if (v.fullReadingLoc.isEmpty()) {
+            return null;
+        return v.fullReadingLoc.get(0);
+	private XmlObject getFirstWrite(String name) {
+        if (v == null) {
+            return null;
+        if (v.fullWritingLoc != null) {
+            return v.fullWritingLoc;
+        if (v.partialWritingLoc == null) {
+            return null;
+        if (v.partialWritingLoc.isEmpty()) {
+            return null;
+        return v.partialWritingLoc.get(0);
+	private List<XmlObject> getAllWriters(String name) {
+	    if (v == null) {
+	        throw new IllegalArgumentException("Variable " + name + " is not written to in this scope");
+	    return v.partialWritingLoc;
+	StringTemplate getLocalDeclaration(String name) {
+	    StringTemplate st = getLocalDeclaration(name, "declarations");
+	     * procedure scopes go like this:
+         * outerScope - contains all arguments - PROCEDURE
+         * innerScope - contains all returns - NONE
+         * compoundScope - this is where the proc template lives - ALL
+         * this prevents writing to arguments, since writing upwards of NONE is prohibited,
+         * but allows writing to return values
+	    if (st == null && parentScope != null && parentScope.enclosureType == EnclosureType.PROCEDURE) {
+	        if (children.size() != 1) {
+	            throw new IllegalStateException("Procedure scope with more than one child found");
+	        return children.get(0).getLocalDeclaration(name, "initWaitCounts");
+	    else {
+	        return st;
+    /** looks up the template that declared the named variable in the
 	    present scope. If such a template does not exist, returns null.
 	    TODO this should probably merge into general variable structure
 	    rather then walking the template.
-	StringTemplate getLocalDeclaration(String name) {
+	StringTemplate getLocalDeclaration(String name, String type) {
 	    if (bodyTemplate == null) {
 	        return null;
-		Object decls = bodyTemplate.getAttribute("declarations");
-		if(decls == null) return null;
+		Object decls = bodyTemplate.getAttribute(type);
+		if (decls == null) {
+		    return null;
-		if(decls instanceof StringTemplate) {
+		if (decls instanceof StringTemplate) {
 			StringTemplate declST = (StringTemplate) decls;
-			if(declST.getAttribute("name").equals(name)) {
-				logger.debug("thats the declaration for "+name);
+			if (declST.getAttribute("name").equals(name)) {
+			        logger.debug("Found declaration for " + name);
 				return declST;
-		} else { // assume its a List of StringTemplate
+		else { // assume its a List of StringTemplate
 		     List<StringTemplate> list = (List<StringTemplate>) decls;
 		     for (StringTemplate declST : list) {
@@ -347,9 +987,9 @@
 		             logger.debug("looking at declaration " + declST);
 		         try {
-		                     logger.debug("thats the declaration for " + name);
 		                 return declST;
@@ -361,7 +1001,9 @@
-		logger.info("UH OH - couldn't find local definition for "+name);
+		if (logger.isInfoEnabled()) {
+		    logger.info("Couldn't find local definition for " + name);
 		return null;
@@ -393,7 +1035,7 @@
 		presentStatementPostStatements.clear();
 		outputs.clear();
-		inhibitClosing.clear();
+		inhibitClosing = null;
 	private String join(List<String> l) {
@@ -407,20 +1049,6 @@
         return sb.toString();
-    /** Stores information about a variable that is referred to in this
-	    scope. Should probably get used for dataset marking eventually. */
-	class Variable {
-		List<Object> writingStatements =  new ArrayList<Object>();
-	Iterator<String> getVariableIterator() {
-		return variableUsage.keySet().iterator();
-	Set<String> getVariables() {
-	    return variableUsage.keySet();
 	public VariableScope getRootScope() {
 		return rootScope;
@@ -428,7 +1056,7 @@
     public List<String> getCleanups() {
         List<String> cleanups = new ArrayList<String>();
-        for (String var : variables.keySet()) {
+        for (String var : getLocallyDeclaredVariableNames()) {
             String type = getVariableType(var);
             if (!org.griphyn.vdl.type.Types.isPrimitive(type)) {
                 cleanups.add(var);
@@ -438,7 +1066,78 @@
-        return variables.toString();
+        return CompilerUtils.info(src);
+    public void analyzeWriters() throws CompilationException {
+        // find variables that are read but not written to
+        // keep a stack to account for shadowing
+        Map<String, Stack<Usage>> access = new HashMap<String, Stack<Usage>>();
+        analyzeWriters(access);
+    private static class Usage {
+        public VariableScope lastWriter, lastReader;
+    private void analyzeWriters(Map<String, Stack<Usage>> access) throws CompilationException {
+        for (String name : getLocallyDeclaredVariableNames()) {
+            declare(access, name);
+        // parent first, which ensures that the topmost writer
+        // is always first
+        for (Map.Entry<String, Stack<Usage>> e : access.entrySet()) {
+            String name = e.getKey();
+            Stack<Usage> stack = e.getValue();
+            boolean fullyRead = isVariableFullyReadInThisScope(name);
+            if (isVariableWrittenToInThisScope(name)) {
+                stack.peek().lastWriter = this;
+            if (fullyRead && org.griphyn.vdl.type.Types.isPrimitive(getVariableType(name))) {
+                stack.peek().lastReader = this;
+        for (VariableScope child : children) {
+            child.analyzeWriters(access);
+            undeclare(access, name);
+    private void declare(Map<String, Stack<Usage>> access, String name) {
+        Stack<Usage> s = access.get(name);
+        if (s == null) {
+            s = new Stack<Usage>();
+            access.put(name, s);
+        Usage u = new Usage();
+        s.push(u);
+    private void undeclare(Map<String, Stack<Usage>> access, String name) throws CompilationException {
+        if (s == null || s.isEmpty()) {
+            throw new RuntimeException("Mistmatched undeclare for " + name + " in scope " + this);
+        Usage u = s.pop();
+        if (s.isEmpty()) {
+            access.remove(name);
+        if (u.lastReader != null && u.lastWriter == null) {
+            throw new CompilationException("Uninitalized variable: " + name);
Modified: trunk/src/org/griphyn/vdl/karajan/Loader.java
--- trunk/src/org/griphyn/vdl/karajan/Loader.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/karajan/Loader.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -248,9 +248,17 @@
     private static String getMessages(Throwable e) {
         StringBuilder sb = new StringBuilder();
+        String lastMessage = null;
         while (e != null) {
-            sb.append(":\n\t");
-            sb.append(e.getMessage());
+            String msg = e.getMessage();
+            if (msg == null) {
+                msg = e.toString();
+            sb.append("\n\t");
+            if (lastMessage == null || !lastMessage.contains(msg)) {
+                sb.append(msg);
+                lastMessage = msg;
             e = e.getCause();
@@ -336,7 +344,6 @@
         if (recompile) {
             VDLt2VDLx.compile(new FileInputStream(swiftscript),
                 new PrintStream(new FileOutputStream(xml)));
             try {
                 FileOutputStream f = new FileOutputStream(kml);
                 Karajan.compile(xml.getAbsolutePath(), new PrintStream(f), provenanceEnabled);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -51,11 +51,12 @@
 	public static final Arg OA_MAPPING = new Arg.Optional("mapping", null);
 	public static final Arg OA_VALUE = new Arg.Optional("value", null);
 	public static final Arg OA_DBGNAME = new Arg.Optional("dbgname", null);
-	public static final Arg OA_WAITFOR = new Arg.Optional("waitfor", null);
+	public static final Arg OA_WAITCOUNT = new Arg.Optional("waitcount", null);
+	public static final Arg OA_INPUT = new Arg.Optional("input", Boolean.FALSE);
 	static {
 		setArguments(New.class,
-				new Arg[] { OA_TYPE, OA_MAPPING, OA_VALUE, OA_DBGNAME, OA_WAITFOR});
+				new Arg[] { OA_TYPE, OA_MAPPING, OA_VALUE, OA_DBGNAME, OA_WAITCOUNT, OA_INPUT});
 	private Tracer tracer;
@@ -73,7 +74,8 @@
         Map<String,Object> mapping =
 		    (Map<String,Object>) OA_MAPPING.getValue(stack);
 		String dbgname = TypeUtil.toString(OA_DBGNAME.getValue(stack));
-		String waitfor = (String) OA_WAITFOR.getValue(stack);
+		String waitCount = (String) OA_WAITCOUNT.getValue(stack);
+		boolean input = TypeUtil.toBoolean(OA_INPUT.getValue(stack));
 		String line = (String) getProperty("_defline");
 		MappingParamSet mps = new MappingParamSet();
@@ -83,6 +85,10 @@
 			mps.set(MappingParam.SWIFT_DBGNAME, dbgname);
+		if (input) {
+		    mps.set(MappingParam.SWIFT_INPUT, true);
 		if (line != null) {
 		    mps.set(MappingParam.SWIFT_LINE, line);
@@ -91,9 +97,15 @@
 		mps.set(MappingParam.SWIFT_RESTARTID, threadPrefix + ":" + dbgname);
-		if (waitfor != null) {
-			mps.set(MappingParam.SWIFT_WAITFOR, waitfor);
+		// input means never written to, but read at least once
+		int initialWriteRefCount;
+		boolean noWriters = input;
+		if (waitCount != null) {
+			initialWriteRefCount = Integer.parseInt(waitCount);
+		else {
+		    initialWriteRefCount = 0;
 		if (typename == null && value == null) {
 			throw new ExecutionException("You must specify either a type or a value");
@@ -157,7 +169,7 @@
 					handle.closeShallow();
-				else {
+				else {
 				    if (tracer.isEnabled()) {
 				        tracer.trace(threadPrefix, dbgname);
@@ -191,6 +203,7 @@
 			if (AbstractDataNode.provenance && logger.isDebugEnabled()) {
 			    logger.debug("NEW id=" + handle.getIdentifier());
+			handle.setWriteRefCount(initialWriteRefCount);
 			return handle;
 		catch (Exception e) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java
--- trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/karajan/lib/PartialCloseDataset.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -20,92 +20,32 @@
 import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.util.TypeUtil;
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.griphyn.vdl.mapping.DSHandle;
-import org.griphyn.vdl.mapping.MappingParam;
-import java.util.StringTokenizer;
-import java.util.List;
-import java.util.Map;
-import java.util.HashMap;
-import java.util.ArrayList;
 public class PartialCloseDataset extends VDLFunction {
 	public static final Logger logger = Logger.getLogger(CloseDataset.class);
-	public static final Arg OA_CLOSE_ID = new Arg.Optional("closeID", null);
+	public static final Arg OA_COUNT = new Arg.Optional("count", 1);
 	static {
-		setArguments(PartialCloseDataset.class, new Arg[] { PA_VAR, OA_CLOSE_ID });
+		setArguments(PartialCloseDataset.class, new Arg[] { PA_VAR, OA_COUNT });
-	/** Map from DSHandles (as keys) to lists of what we have seen
-	    already. TODO this may end up growing too much when a program
-	    has lots of objects. Consider alternative ways of doing this. */
-	static Map<DSHandle,List<String>> pendingDatasets =
-	    new HashMap<DSHandle,List<String>>();
 	public Object function(VariableStack stack) throws ExecutionException {
-		boolean hasUnseenToken = false;
 		DSHandle var = (DSHandle) PA_VAR.getValue(stack);
-		String closeID = (String) OA_CLOSE_ID.getValue(stack);
-			logger.debug("Partially closing " + var +
-                                     " hash: " + var.hashCode() +
-                                     " for statement " + closeID);
+			logger.debug("Partially closing " + var);
-		if(var.isClosed()) {
+		if (var.isClosed()) {
 			logger.debug("variable already closed - skipping partial close processing");
 			return null;
-		synchronized(pendingDatasets) {
-			List<String> c = pendingDatasets.get(var);
-			if (c == null) {
-				c = new ArrayList<String>();
-				pendingDatasets.put(var, c);
-			c.add(closeID);
-			    logger.debug("Adding token "+closeID+" with hash "+closeID.hashCode());
-			String needToWaitFor = var.getParam(MappingParam.SWIFT_WAITFOR);
-			logger.debug("need to wait for " + needToWaitFor);
-			StringTokenizer stok = new StringTokenizer(needToWaitFor, " ");
-			while(stok.hasMoreTokens()) {
-				String s = stok.nextToken();
-				// do we have this token in our list of already seen
-				// statement IDs?
-				if(! c.contains(s)) {
-					// then we have a required element that we have not
-					// seen yet, so...
-					hasUnseenToken = true;
-					    logger.debug("Container does not contain token " + s);
-				} else {
-				        logger.debug("Container does contain token " + s);
-		    logger.debug("hasUnseenToken = "+hasUnseenToken);
-		if(!hasUnseenToken) {
-			if(logger.isInfoEnabled()) {
-				logger.info("All partial closes for " + var +
-				             " have happened. Closing fully.");
-			var.closeDeep();
-			pendingDatasets.remove(var);
+		int count = TypeUtil.toInt(OA_COUNT.getValue(stack));
+		var.updateWriteRefCount(-count);
 		return null;
Added: trunk/src/org/griphyn/vdl/karajan/lib/SetWaitCount.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetWaitCount.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetWaitCount.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -0,0 +1,47 @@
+ * Copyright 2012 University of Chicago
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+package org.griphyn.vdl.karajan.lib;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.griphyn.vdl.mapping.DSHandle;
+public class SetWaitCount extends VDLFunction {
+	public static final Logger logger = Logger.getLogger(CloseDataset.class);
+	static {
+		setArguments(SetWaitCount.class, new Arg[] { PA_VAR, OA_COUNT });
+	public Object function(VariableStack stack) throws ExecutionException {
+		DSHandle var = (DSHandle) PA_VAR.getValue(stack);
+			throw new ExecutionException("Attempted to set a wait count for a closed variable " + var);
+		var.setWriteRefCount(count);
+		return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -21,6 +21,7 @@
+import java.util.StringTokenizer;
@@ -43,17 +44,17 @@
 import org.griphyn.vdl.util.VDL2Config;
 public class ThrottledParallelFor extends AbstractParallelIterator {
-	public static final Logger logger = Logger
-			.getLogger(ThrottledParallelFor.class);
+	public static final Logger logger = Logger.getLogger(ThrottledParallelFor.class);
 	public static final int DEFAULT_MAX_THREADS = 1024;
 	public static final Arg A_NAME = new Arg.Positional("name");
 	public static final Arg A_IN = new Arg.Positional("in");
-	public static final Arg A_SELF_CLOSE = new Arg.Optional("selfclose", Boolean.FALSE);
+	public static final Arg O_SELFCLOSE = new Arg.Optional("selfclose", Boolean.FALSE);
+	public static final Arg O_REFS = new Arg.Optional("refs", null);
 	static {
-		setArguments(ThrottledParallelFor.class, new Arg[] { A_NAME, A_IN, A_SELF_CLOSE });
+		setArguments(ThrottledParallelFor.class, new Arg[] { A_NAME, A_IN, O_SELFCLOSE, O_REFS });
 	public static final String THREAD_COUNT = "#threadcount";
@@ -61,7 +62,36 @@
 	private int maxThreadCount = -1;
 	private Tracer forTracer, iterationTracer;
 	private String kvar, vvar;
+	private List<StaticRefCount> srefs;
+	private static class StaticRefCount {
+        public final int count;
+        public StaticRefCount(String name, int count) {
+            this.name = name;
+	private static class RefCount {
+	    public final DSHandle var;
+	    public RefCount(DSHandle var, int count) {
+	        this.var = var;
+	    public void inc() {
+	    public void dec() {
     @Override
     protected void initializeStatic() {
         super.initializeStatic();
@@ -69,11 +99,44 @@
         iterationTracer = Tracer.getTracer(this, "ITERATION");
         kvar = (String) getProperty("_kvar");
         vvar = (String) getProperty("_vvar");
+        srefs = buildStaticRefs();
+    private List<StaticRefCount> buildStaticRefs() {
+        String refs = (String) O_REFS.getStatic(this);
+        if (refs == null) {
+            return null;
+        List<StaticRefCount> l = new ArrayList<StaticRefCount>();
+        String name = null;
+        boolean flip = true;
+        StringTokenizer st = new StringTokenizer(refs);
+        while (st.hasMoreTokens()) {
+            if (flip) {
+                name = st.nextToken();
+            else {
+                int count = Integer.parseInt(st.nextToken());
+                l.add(new StaticRefCount(name, count));
+            flip = !flip;
+        return l;
+    private List<RefCount> buildRefs(VariableStack stack) throws VariableNotFoundException {
+        if (srefs == null) {
+            return null;
+        List<RefCount> l = new ArrayList<RefCount>(srefs.size());
+        for (StaticRefCount s : srefs) {
+            l.add(new RefCount((DSHandle) stack.getVar(s.name), s.count));
+        return l;
     protected void partialArgumentsEvaluated(VariableStack stack)
-        stack.setVar("selfclose", A_SELF_CLOSE.getValue(stack));
         if (forTracer.isEnabled()) {
             forTracer.trace(ThreadingContext.get(stack).toString());
@@ -89,8 +152,7 @@
 			stack.setVar(VAR, var);
 			setChildFailed(stack, false);
 			stack.setCaller(this);
-			initThreadCount(stack, TypeUtil.toBoolean(stack.currentFrame().getVar("selfclose")), i);
-			stack.currentFrame().deleteVar("selfclose");
+			initThreadCount(stack, TypeUtil.toBoolean(O_SELFCLOSE.getStatic(this)), i);
 			citerate(stack, var, i);
 		else {
@@ -110,35 +172,18 @@
 		    int j = 0;
 		    try {
     		    for (; j < available && i.hasNext(); j++) {
-    		        VariableStack copy = stack.copy();
-                    copy.enter();
-                    ThreadingContext ntc = ThreadingContext.get(copy).split(i.current());
-                    ThreadingContext.set(copy, ntc);
-                    setIndex(copy, getArgCount());
-                    setArgsDone(copy);
-                    Object value = i.next();
-                    if (iterationTracer.isEnabled()) {
-                        iterationTracer.trace(ntc.toString(), unwrap(value));
-                    copy.setVar(var.getName(), value);
-                    startElement(getArgCount(), copy);
+    		        startIteration(tc, var, i.current(), i.next(), stack);
 		    finally {
 		        tc.add(j);
-				Object value = tc.tryIncrement();
-				copy.enter();
-				ThreadingContext.set(copy, ThreadingContext.get(copy).split(
-						i.current()));
+			    startIteration(tc, var, i.current(), tc.tryIncrement(), stack);
+			decRefs(tc.rc);
 			int left;
 			synchronized(tc) {
 			    // can only have closed and running = 0 in one place
@@ -157,7 +202,38 @@
-	private Object unwrap(Object value) {
+	private void startIteration(ThreadCount tc, Identifier var, int id, Object value,
+            VariableStack stack) throws ExecutionException {
+	    incRefs(tc.rc);
+        VariableStack copy = stack.copy();
+        copy.enter();
+        ThreadingContext ntc = ThreadingContext.get(copy).split(id);
+        ThreadingContext.set(copy, ntc);
+        setIndex(copy, 2);
+        if (iterationTracer.isEnabled()) {
+            iterationTracer.trace(ntc.toString(), unwrap(value));
+        copy.setVar(var.getName(), value);
+        startElement(1, copy);
+    private void decRefs(List<RefCount> rcs) throws ExecutionException {
+	    if (rcs != null) {
+	        for (RefCount rc : rcs) {
+	            rc.var.updateWriteRefCount(-rc.count);
+	private void incRefs(List<RefCount> rcs) throws ExecutionException {
+                rc.var.updateWriteRefCount(rc.count);
+    private Object unwrap(Object value) {
         if (value instanceof Pair) {
             Pair p = (Pair) value;
             if (kvar != null) {
@@ -171,6 +247,28 @@
             return "!";
+    @Override
+    public void completed(VariableStack stack) throws ExecutionException {
+        int index = preIncIndex(stack) - 1;
+        if (index == 1) {
+            // iterator
+            stack.currentFrame().deleteVar(QUOTED);
+            processArguments(stack);
+            try {
+                partialArgumentsEvaluated(stack);
+            catch (FutureFault e) {
+                e.getFuture().addModificationAction(new PartialResume(), stack);
+        else if (index == elementCount()) {
+            iterationCompleted(stack);
+        else {
+            startElement(index, stack);
     public void failed(VariableStack stack, ExecutionException e) throws ExecutionException {
         if (!testAndSetChildFailed(stack)) {
@@ -191,16 +289,21 @@
 		synchronized(tc) {
 		    closed = tc.isClosed();
 		    running = tc.decrement();
-		    iteratorHasValues = !tc.selfClose || tc.iteratorHasValues();
+		    iteratorHasValues = tc.iteratorHasValues();
+		boolean done = false;
 		if (running == 0) {
-		    if (closed || !iteratorHasValues) {
+		    if (closed) {
 		        complete(stack);
+		    if (tc.selfClose && !iteratorHasValues) {
+		        decRefs(tc.rc);
+		        complete(stack);
-	private void initThreadCount(VariableStack stack, boolean selfClose, KarajanIterator i) {
+	private void initThreadCount(VariableStack stack, boolean selfClose, KarajanIterator i) throws VariableNotFoundException {
 		if (maxThreadCount < 0) {
 			try {
 				maxThreadCount = TypeUtil.toInt(VDL2Config.getConfig()
@@ -210,7 +313,7 @@
 				maxThreadCount = DEFAULT_MAX_THREADS;
-		stack.setVar(THREAD_COUNT, new ThreadCount(maxThreadCount, selfClose, i));
+		stack.setVar(THREAD_COUNT, new ThreadCount(maxThreadCount, selfClose, i, buildRefs(stack)));
 	private ThreadCount getThreadCount(VariableStack stack)
@@ -224,20 +327,27 @@
     private static class ThreadCount implements FutureIterator {
-		private int maxThreadCount;
+		public boolean selfClose;
+        private int maxThreadCount;
 		private int crt;
-		private boolean selfClose, closed;
+		private boolean closed;
 		private List<ListenerStackPair> listeners;
 		private KarajanIterator i;
+		private final List<RefCount> rc;
-		public ThreadCount(int maxThreadCount, boolean selfClose, KarajanIterator i) {
+		public ThreadCount(int maxThreadCount, boolean selfClose, KarajanIterator i, List<RefCount> rc) {
 			this.maxThreadCount = maxThreadCount;
-			this.selfClose = selfClose;
 			this.i = i;
 			crt = 0;
+			this.selfClose = selfClose;
+			this.rc = rc;
-		public boolean iteratorHasValues() {
+		public boolean raiseWaiting() {
+            return false;
+        public boolean iteratorHasValues() {
             try {
                 return i.hasNext();
@@ -245,10 +355,6 @@
                 return false;
-        public boolean isSelfClose() {
-		    return selfClose;
         public synchronized int available() {
             return maxThreadCount - crt;
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -29,6 +29,7 @@
 import org.globus.cog.karajan.workflow.futures.Future;
 import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
 import org.griphyn.vdl.karajan.DSHandleFutureWrapper;
@@ -84,6 +85,7 @@
     private Path pathFromRoot;
     protected FutureWrapper wrapper;
+    private int writeRefCount;
     protected AbstractDataNode(Field field) {
         this.field = field;
@@ -681,4 +683,30 @@
         value = null;
         pathFromRoot = null;
+    @Override
+    public synchronized void setWriteRefCount(int count) {
+        this.writeRefCount = count;
+    @Override
+    public synchronized int updateWriteRefCount(int delta) {
+        this.writeRefCount += delta;
+        if (this.writeRefCount < 0) {
+            throw new IllegalArgumentException("Reference count mismatch for " + this + ". Count is " + this.writeRefCount);
+            logger.debug(this + " writeRefCount " + this.writeRefCount);
+        if (this.writeRefCount == 0) {
+            if(logger.isInfoEnabled()) {
+                logger.info("All partial closes for " + this +
+                             " have happened. Closing fully.");
+            closeDeep();
+        return this.writeRefCount;
Modified: trunk/src/org/griphyn/vdl/mapping/DSHandle.java
--- trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -103,4 +103,8 @@
     public String getIdentifyingString();
     public boolean isRestartable();
+    public void setWriteRefCount(int count);
+    public int updateWriteRefCount(int delta);
Modified: trunk/src/org/griphyn/vdl/mapping/MappingParam.java
--- trunk/src/org/griphyn/vdl/mapping/MappingParam.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/mapping/MappingParam.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -29,7 +29,6 @@
     public static final MappingParam SWIFT_LINE = new MappingParam("swift#line");
     public static final MappingParam SWIFT_DBGNAME = new MappingParam("swift#dbgname");
     public static final MappingParam SWIFT_RESTARTID = new MappingParam("swift#restartid");
-    public static final MappingParam SWIFT_WAITFOR = new MappingParam("swift#waitfor");
     public static final MappingParam SWIFT_BASEDIR = new MappingParam("swift#basedir");
     public static final MappingParam SWIFT_DESCRIPTOR = new MappingParam("swift#descriptor");
     public static final MappingParam SWIFT_INPUT = new MappingParam("swift#input");
Modified: trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -77,7 +77,12 @@
 		String desc = (String) params.get(MappingParam.SWIFT_DESCRIPTOR);
 		if (desc == null) {
-			initialized();
+			initialized();
+			Boolean input = (Boolean) params.get(MappingParam.SWIFT_INPUT);
+			if (input != null && input.booleanValue()) {
+			    // Empty array. Clearly only in test cases.
+			    closeDeep();
 			return;
 		try {
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-23 08:44:21 UTC (rev 6076)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-23 08:56:28 UTC (rev 6077)
@@ -120,8 +120,8 @@
 	static protected void checkInputs(MappingParamSet params, Mapper mapper, AbstractDataNode root,
 	        DuplicateMappingChecker dmc) {
-		String input = (String) params.get(MappingParam.SWIFT_INPUT);
-		if (input != null && Boolean.valueOf(input.trim()).booleanValue()) {
 			addExisting(mapper, root);
 			checkConsistency(root, true, mapper, dmc);
More information about the Swift-commit
