[Swift-commit] r6074 - in trunk: . bin
wilde at ci.uchicago.edu
Wed Nov 21 17:38:43 CST 2012
Author: wilde
Date: 2012-11-21 17:38:43 -0600 (Wed, 21 Nov 2012)
New Revision: 6074
Modified:
trunk/bin/slurm-qsub
trunk/bin/slurm-qsub-emulator
trunk/build.xml
Log:
Corrections to SLURM support: add local copy of qsub emulator to bin/ in build.xml; correct error in pbslog file naming; merge -l options on qsub line into one arg, as qsub emulator only handles one correctly; and remove #PBS lines from submit script, as these seem to be getting picked up by sbatch, causing contradictory settings.
Modified: trunk/bin/slurm-qsub
--- trunk/bin/slurm-qsub 2012-11-21 21:01:21 UTC (rev 6073)
+++ trunk/bin/slurm-qsub 2012-11-21 23:38:43 UTC (rev 6074)
@@ -7,7 +7,7 @@
script=$1.slurm
echo '#! /bin/sh' >$script
# echo 'export PBS_NODELIST=SLURM_NODELIST'' >>$script # FIXME: convert SLURM_NODELIST to PBS_NODEFILE here...
-cat $1 >>$script
+cat $1 | grep -v '^#PBS' >>$script
chmod +x $script
srunargs=$(awk <$1 '
@@ -29,7 +29,7 @@
# printf("-S %s -N %s -m %s -l nodes=%s:ppn=%s -l walltime=%s -q %s -o %s -e %s",
# shell, jobname, m, nodes, ppn, walltime, queue, sofile, sefile);
- printf("-N %s -m %s -l nodes=%s:ppn=%s -l walltime=%s -q %s -o %s -e %s",
+ printf("-N %s -m %s -l nodes=%s:ppn=%s,walltime=%s -q %s -o %s -e %s",
Modified: trunk/bin/slurm-qsub-emulator
--- trunk/bin/slurm-qsub-emulator 2012-11-21 21:01:21 UTC (rev 6073)
+++ trunk/bin/slurm-qsub-emulator 2012-11-21 23:38:43 UTC (rev 6074)
@@ -81,7 +81,6 @@
my $sbatch = "sbatch";
my $salloc = "salloc";
-my $srun = "$srun";
GetOptions('a=s' => \$start_time,
'A=s' => \$account,
@@ -215,7 +214,7 @@
$command .= " $script";
-system("(echo; echo $command; echo) >> $HOME/pbslog");
+system("(echo; echo $command; echo) >> \$HOME/pbslog");
system($command);
Modified: trunk/build.xml
--- trunk/build.xml 2012-11-21 21:01:21 UTC (rev 6073)
+++ trunk/build.xml 2012-11-21 23:38:43 UTC (rev 6074)
@@ -113,6 +113,7 @@
<include name="worker.sh"/>
<include name="workers.ranger.sh"/>
<include name="slurm-qsub"/>
+ <include name="slurm-qsub-emulator"/>
<include name="slurm-qdel"/>
<include name="slurm-qstat"/>
</fileset>
More information about the Swift-commit
