[Swift-commit] r6069 - trunk/src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu
Tue Nov 20 16:11:26 CST 2012
Author: hategan
Date: 2012-11-20 16:11:26 -0600 (Tue, 20 Nov 2012)
New Revision: 6069
Modified:
trunk/src/org/griphyn/vdl/engine/CompilerUtils.java
trunk/src/org/griphyn/vdl/engine/Karajan.java
trunk/src/org/griphyn/vdl/engine/VariableScope.java
Log:
fixed NPE with shadowing warnings and improved warning messages to distinguish between "variable", "parameter" etc.
Modified: trunk/src/org/griphyn/vdl/engine/CompilerUtils.java
--- trunk/src/org/griphyn/vdl/engine/CompilerUtils.java 2012-11-20 21:29:29 UTC (rev 6068)
+++ trunk/src/org/griphyn/vdl/engine/CompilerUtils.java 2012-11-20 22:11:26 UTC (rev 6069)
@@ -22,7 +22,13 @@
return getLine(n.getParentNode());
else {
- return src.getNodeValue();
+ String loc = src.getNodeValue();
+ if (loc == null || loc.length() == 0) {
+ return "unknown";
+ else {
+ return loc.substring(loc.indexOf(' ') + 1);
@@ -30,12 +36,6 @@
if (src == null) {
return null;
- String loc = src.getDomNode().getAttributes().getNamedItem("src").getNodeValue();
- if (loc == null) {
- return null;
- else {
- return loc.substring(loc.indexOf(' ') + 1);
+ return getLine(src.getDomNode());
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2012-11-20 21:29:29 UTC (rev 6068)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2012-11-20 22:11:26 UTC (rev 6069)
@@ -355,7 +355,7 @@
procST.setAttribute("arguments", paramST);
String type = normalize(param.getType().getLocalPart());
checkIsTypeDefined(type);
- innerScope.addVariable(param.getName(), type, param);
+ innerScope.addVariable(param.getName(), type, "Return parameter", param);
for (int i = 0; i < proc.sizeOfInputArray(); i++) {
FormalParameter param = proc.getInputArray(i);
@@ -367,7 +367,7 @@
- outerScope.addVariable(param.getName(), type, param);
+ outerScope.addVariable(param.getName(), type, "Parameter", param);
Binding bind;
@@ -441,9 +441,8 @@
public void variableForSymbol(Variable var, VariableScope scope) throws CompilationException {
checkIsTypeDefined(var.getType().getLocalPart());
- scope.addVariable(var.getName(), var.getType().getLocalPart(), var.getIsGlobal(), var);
+ scope.addVariable(var.getName(), var.getType().getLocalPart(), "Variable", var.getIsGlobal(), var);
public void variable(Variable var, VariableScope scope) throws CompilationException {
@@ -498,7 +497,7 @@
scope.bodyTemplate.setAttribute("declarations",variableDeclarationST);
StringTemplate paramValueST=expressionToKarajan(param.getAbstractExpression(),scope);
String paramValueType = datatype(paramValueST);
- scope.addVariable(parameterVariableName, paramValueType, param);
+ scope.addVariable(parameterVariableName, paramValueType, "Variable", param);
variableDeclarationST.setAttribute("type", paramValueType);
StringTemplate variableReferenceST = template("id");
variableReferenceST.setAttribute("var",parameterVariableName);
@@ -898,7 +897,7 @@
VariableScope loopScope = new VariableScope(this, scope, VariableScope.ENCLOSURE_LOOP);
VariableScope innerScope = new VariableScope(this, loopScope, VariableScope.ENCLOSURE_LOOP);
- loopScope.addVariable(iterate.getVar(), "int", iterate);
+ loopScope.addVariable(iterate.getVar(), "int", "Iteration variable", iterate);
StringTemplate iterateST = template("iterate");
iterateST.setAttribute("line", getLine(iterate));
@@ -938,11 +937,11 @@
if (itemType == null) {
throw new CompilationException("You can iterate through an array structure only");
- innerScope.addVariable(foreach.getVar(), itemType, foreach);
+ innerScope.addVariable(foreach.getVar(), itemType, "Iteration variable", foreach);
foreachST.setAttribute("indexVar", foreach.getIndexVar());
foreachST.setAttribute("indexVarType", keyType);
if(foreach.getIndexVar() != null) {
- innerScope.addVariable(foreach.getIndexVar(), keyType, foreach);
+ innerScope.addVariable(foreach.getIndexVar(), keyType, "Iteration variable", foreach);
innerScope.bodyTemplate = foreachST;
Modified: trunk/src/org/griphyn/vdl/engine/VariableScope.java
--- trunk/src/org/griphyn/vdl/engine/VariableScope.java 2012-11-20 21:29:29 UTC (rev 6068)
+++ trunk/src/org/griphyn/vdl/engine/VariableScope.java 2012-11-20 22:11:26 UTC (rev 6069)
@@ -120,15 +120,15 @@
declaration already exists. Perhaps error in same scope and
warning if it shadows an outer scope? */
- public void addVariable(String name, String type, XmlObject src) throws CompilationException {
- addVariable(name, type, false, src);
+ public void addVariable(String name, String type, String context, XmlObject src) throws CompilationException {
+ addVariable(name, type, context, false, src);
public void inhibitClosing(String name) {
inhibitClosing.add(name);
- public void addVariable(String name, String type, boolean global, XmlObject src) throws CompilationException {
+ public void addVariable(String name, String type, String context, boolean global, XmlObject src) throws CompilationException {
if (logger.isDebugEnabled()) {
logger.debug("Adding variable " + name + " of type " + type + " to scope " + hashCode());
@@ -142,7 +142,7 @@
// by the above if? in which case isVariableDefined should
// be replaced by is locally defined test.
if(parentScope != null && parentScope.isVariableDefined(name)) {
- Warnings.warn("Variable " + name + ", defined on line " + CompilerUtils.getLine(src)
+ Warnings.warn(context + " " + name + ", on line " + CompilerUtils.getLine(src)
+ ", shadows variable of same name on line " + parentScope.getDefinitionLine(name));
More information about the Swift-commit
