[Swift-commit] cog r3512
swift at ci.uchicago.edu swift at ci.uchicago.edu
Sun Nov 18 16:55:55 CST 2012
r3512 | hategan | 2012-11-18 16:54:36 -0600 (Sun, 18 Nov 2012) | 1 line
small test to make sure paking is the same as perl's
Index: modules/karajan/src/org/globus/cog/karajan/workflow/service/RequestReply.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/service/RequestReply.java	(revision 3511)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/service/RequestReply.java	(working copy)
@@ -36,7 +36,7 @@
 	public static final int DEFAULT_TIMEOUT = 120 * 1000;
 	private int timeout = DEFAULT_TIMEOUT;
 	public static final int NOID = -1;
 	private int id;
 	private String outCmd;
@@ -177,7 +177,7 @@
 		return inData;
-	public byte[] getInData() {
+	public synchronized byte[] getInData() {
 		if (inData == null) {
 			return null;
@@ -246,11 +246,49 @@
 	public static void main(String[] args) {
-	    System.out.println(unpackLong(pack(1L)));
-	    System.out.println(unpackLong(pack(10L)));
-	    System.out.println(unpackLong(pack(1000000000L)));
-	    System.out.println(unpackLong(pack(10000000000000L)));
+		test(1L);
+		test(10L);
+		test(1000000000L);
+		test(10000000000000L);
+		testPerl(1L);
+        testPerl(10L);
+        testPerl(1000000000L);
+        testPerl(10000000000000L);
+	private static void test(long l) {
+		System.out.print("Test " + l);
+		if (unpackLong(pack(l)) != l) {
+			throw new RuntimeException("Failed: " + l);
+		System.out.println(" OK");
+	private static void testPerl(long l) {
+		System.out.print("Test perl " + l);
+        if (unpackLong(packPerl(l)) != l) {
+            throw new RuntimeException("Failed perl: " + l);
+	private static byte[] packPerl(long l) {
+		try {
+			Process p = Runtime.getRuntime().exec(new String[]
+			     {"perl", "-e", "my $ts = " + l + "; print pack(\"VV\", ($ts & 0xffffffff), ($ts >> 32));"});
+			int ec = p.waitFor();
+			if (ec != 0) {
+				return new byte[8];
+			byte b[] = new byte[8];
+			p.getInputStream().read(b);
+			return b;
+		catch (Exception e) {
+			e.printStackTrace();
 	public boolean getInDataAsBoolean(int index) {
 		return getInDataAsInt(index) != 0;
