[Swift-commit] r6057 - trunk/src/org/griphyn/vdl/mapping/file
hategan at ci.uchicago.edu
Sun Nov 18 02:44:53 CST 2012
Author: hategan
Date: 2012-11-18 02:44:46 -0600 (Sun, 18 Nov 2012)
New Revision: 6057
Modified:
trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
Log:
fixed fixed_array_mapper
Modified: trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java 2012-11-18 07:41:37 UTC (rev 6056)
+++ trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java 2012-11-18 08:44:46 UTC (rev 6057)
@@ -18,23 +18,31 @@
package org.griphyn.vdl.mapping.file;
import java.util.ArrayList;
+import java.util.Arrays;
import java.util.Collection;
+import java.util.Iterator;
import java.util.List;
+import java.util.Map;
+import java.util.Set;
import java.util.StringTokenizer;
+import java.util.TreeSet;
import org.griphyn.vdl.mapping.AbsFile;
import org.griphyn.vdl.mapping.AbstractMapper;
+import org.griphyn.vdl.mapping.DSHandle;
import org.griphyn.vdl.mapping.InvalidMappingParameterException;
import org.griphyn.vdl.mapping.MappingParam;
import org.griphyn.vdl.mapping.MappingParamSet;
import org.griphyn.vdl.mapping.Path;
import org.griphyn.vdl.mapping.PhysicalFormat;
+import org.griphyn.vdl.type.Types;
/** Maps a string (separated by space, comma or semicolon) of filenames to
an array. */
public class FixedArrayFileMapper extends AbstractMapper {
public static final MappingParam PARAM_FILES = new MappingParam("files");
+ private List<String> files;
public FixedArrayFileMapper() {
super();
@@ -42,26 +50,42 @@
public void setParams(MappingParamSet params) {
super.setParams(params);
- String cfiles = PARAM_FILES.getStringValue(this);
- if (cfiles == null) {
- throw new InvalidMappingParameterException("Missing required mapper parameter: "
- + PARAM_FILES);
+ DSHandle dn = (DSHandle) PARAM_FILES.getRawValue(this);
+ if (dn == null) {
+ throw new InvalidMappingParameterException("Missing required mapper parameter: "
+ + PARAM_FILES);
- StringTokenizer st = new StringTokenizer(cfiles, " ,;");
- String[] files = new String[st.countTokens()];
- for (int i = 0; st.hasMoreTokens(); i++) {
- files[i] = st.nextToken();
+ if (Types.STRING.equals(dn.getType())) {
+ String cfiles = (String) dn.getValue();
+ StringTokenizer st = new StringTokenizer(cfiles, " ,;");
+ String[] files = new String[st.countTokens()];
+ for (int i = 0; st.hasMoreTokens(); i++) {
+ files[i] = st.nextToken();
+ this.files = Arrays.asList(files);
- PARAM_FILES.setValue(this, files);
+ else if (dn.getType().isArray() && Types.STRING.equals(dn.getType().itemType())) {
+ files = new ArrayList<String>();
+ Map<?, DSHandle> m = dn.getArrayValue();
+ // must keep order
+ @SuppressWarnings("unchecked")
+ Set<Comparable<?>> s = new TreeSet<Comparable<?>>((Set<Comparable<?>>) m.keySet());
+ Iterator<?> i = s.iterator();
+ while(i.hasNext()) {
+ Comparable<?> nextKey = (Comparable<?>) i.next();
+ files.add((String) m.get(nextKey).getValue());
+ else {
+ throw new InvalidMappingParameterException("Unrecognized value for "
+ + PARAM_FILES + " parameter: " + dn.getType() + ". Valid values are a string or an array of strings.");
- protected String[] getFiles() {
- return (String[]) PARAM_FILES.getValue(this);
public Collection<Path> existing() {
List<Path> l = new ArrayList<Path>();
- for (int i = 0; i < getFiles().length; i++) {
+ for (int i = 0; i < files.size(); i++) {
l.add(Path.EMPTY_PATH.addLast(i, true));
return l;
@@ -75,7 +99,7 @@
Object o = path.getFirst();
if (o instanceof Integer) {
int index = ((Integer) o).intValue();
- return new AbsFile(getFiles()[index]);
+ return new AbsFile(files.get(index));
else {
throw new IllegalArgumentException("The fixed array mapper can only be used with an int key array");
More information about the Swift-commit
