[Swift-commit] cog r3507
swift at ci.uchicago.edu
Fri Nov 9 23:15:04 CST 2012
r3507 | hategan | 2012-11-09 23:12:47 -0600 (Fri, 09 Nov 2012) | 1 line
fixed NPE and added some generics
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Misc.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Misc.java (revision 3506)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Misc.java (working copy)
@@ -66,8 +66,10 @@
String expanded = TypeUtil.toString(PA_VALUE.getValue(stack));
do {
line = br.readLine();
- if (line.indexOf(expanded) != -1) {
- return true;
+ if (line != null) {
+ if (line.indexOf(expanded) != -1) {
+ return true;
} while (line != null);
@@ -375,10 +377,10 @@
setArguments("str_split", new Arg[] { PA_STRING, PA_SEPARATOR });
- public List str_split(VariableStack stack) throws ExecutionException {
+ public List<String> str_split(VariableStack stack) throws ExecutionException {
String str = TypeUtil.toString(PA_STRING.getValue(stack));
String sep = TypeUtil.toString(PA_SEPARATOR.getValue(stack));
- List list = new ArrayList();
+ List<String> list = new ArrayList<String>();
int index = -1;
int last = 0;
do {
@@ -436,7 +438,7 @@
Pattern pattern = Pattern.compile(TypeUtil.toString(PA_REGEXP.getValue(stack)));
boolean invert = TypeUtil.toBoolean(OA_INVERT.getValue(stack));
Object[] args = Arg.VARGS.asArray(stack);
- ArrayList ret = new ArrayList();
+ ArrayList<String> ret = new ArrayList<String>();
if (args.length > 1) {
for (int i = 0; i < args.length; i++) {
String value = TypeUtil.toString(args[i]);
@@ -447,7 +449,7 @@
return ret.toArray();
else if (args.length == 1) {
- Iterator i = TypeUtil.toIterator(args[0]);
+ Iterator<?> i = TypeUtil.toIterator(args[0]);
while (i.hasNext()) {
String value = TypeUtil.toString(i.next());
if (pattern.matcher(value).matches() ^ invert) {
More information about the Swift-commit
