[Swift-commit] r5793 - in trunk: bin src/org/griphyn/vdl/mapping/file
davidk at ci.uchicago.edu
Wed May 23 08:37:56 CDT 2012
Author: davidk
Date: 2012-05-23 08:37:55 -0500 (Wed, 23 May 2012)
New Revision: 5793
Modified:
trunk/bin/gensites
trunk/bin/start-coaster-service
trunk/bin/stop-coaster-service
trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
Log:
AbstractFileMapper currently prints a message that says "(input): N number of files". This can get very spammy on some workflows, to the point where it's nearly impossible to read the ticker bar. Disabled this message for now
start-coaster-service: Ability to remotely start workers for gwms and condor sites
gensites: When generating tc, currently assumes that the application is on the local filesystem. Add a test for this to avoid errors
Modified: trunk/bin/gensites
--- trunk/bin/gensites 2012-05-22 15:30:18 UTC (rev 5792)
+++ trunk/bin/gensites 2012-05-23 13:37:55 UTC (rev 5793)
@@ -199,8 +199,13 @@
NAME=`echo $line |cut -d'=' -f1|awk '{print $2}'`
COMMAND=`echo $line |cut -d'=' -f2`
COMMAND=`eval echo $COMMAND`
- COMMAND_PATH=$(cd $(dirname $COMMAND); pwd)/$(basename $COMMAND)
- echo $HOST $NAME $COMMAND_PATH null null null >> tc.data
+ COMMAND_DIRNAME=$(dirname $COMMAND)
+ if [ -d "$COMMAND_DIRNAME" ]; then
+ COMMAND_PATH=$(cd $COMMAND_DIRNAME; pwd)/$(basename $COMMAND)
+ echo $HOST $NAME $COMMAND_PATH null null null >> tc.data
+ else
+ echo $HOST $NAME $COMMAND null null null >> tc.data
+ fi
done
fi
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2012-05-22 15:30:18 UTC (rev 5792)
+++ trunk/bin/start-coaster-service 2012-05-23 13:37:55 UTC (rev 5793)
@@ -274,7 +274,7 @@
cat <<EOF > start_workers.submit
output = workers.stdout
error = workers.stderr
-initialdir = $PWD
+#initialdir = \$PWD
executable = $SWIFT_BIN/$WORKER
arguments = $EXECUTION_URL node .
notification = Never
@@ -282,8 +282,12 @@
queue $CONDOR_WORKERS
EOF
- condor_submit start_workers.submit
- return 0
+ if [ -n "$WORKER_RELAY_HOST" ]; then
+ scp start_workers.submit $WORKER_USERNAME@$WORKER_RELAY_HOST:
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "condor_submit start_workers.submit"
+ else
+ condor_submit start_workers.submit
+ fi
# Start GWMS workers
@@ -301,8 +305,13 @@
fi
echo Starting workers
- mkdir -p condor
- run-gwms-workers $EXECUTION_URL $CONDOR_WORKERS
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "mkdir -p condor"
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "run-gwms-workers $EXECUTION_URL $CONDOR_WORKERS"
+ else
+ mkdir -p condor
+ run-gwms-workers $EXECUTION_URL $CONDOR_WORKERS
+ fi
# Start cobalt workers
Modified: trunk/bin/stop-coaster-service
--- trunk/bin/stop-coaster-service 2012-05-22 15:30:18 UTC (rev 5792)
+++ trunk/bin/stop-coaster-service 2012-05-23 13:37:55 UTC (rev 5793)
@@ -61,7 +61,11 @@
fi
if [ "$WORKER_MODE" == "condor" ] || [ "$WORKER_MODE" == "gwms" ]; then
- condor_rm $USER
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "condor_rm $USER"
+ else
+ condor_rm $USER
+ fi
fi
if [ -f "$HOME/.swift/machines" ]; then
Modified: trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java 2012-05-22 15:30:18 UTC (rev 5792)
+++ trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java 2012-05-23 13:37:55 UTC (rev 5793)
@@ -257,7 +257,7 @@
if(logger.isDebugEnabled()) {
logger.debug("Finish list existing paths for mapper "+this.hashCode()+" list="+result);
- System.out.println(getVarName() + " (input): found " + result.size() + " files");
+ // System.out.println(getVarName() + " (input): found " + result.size() + " files");
return result;
More information about the Swift-commit
