[Swift-commit] r5790 - in trunk: bin tests/sites tests/sites/osg
davidk at ci.uchicago.edu
Tue May 22 07:27:09 CDT 2012
Author: davidk
Date: 2012-05-22 07:27:09 -0500 (Tue, 22 May 2012)
New Revision: 5790
Added:
trunk/tests/sites/osg/
trunk/tests/sites/osg/coaster-service.conf
Modified:
trunk/bin/start-coaster-service
trunk/bin/stop-coaster-service
Log:
Integrate gwms scripts with coaster-service scripts
Added a test configuration for osg which uses the worker.pl init command to symlink work directory
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2012-05-11 17:47:42 UTC (rev 5789)
+++ trunk/bin/start-coaster-service 2012-05-22 12:27:09 UTC (rev 5790)
@@ -265,7 +265,7 @@
if [ -z "$PORT" ]; then
crash "start-workers-local: Port number not specified, giving up"
fi
- echo Starting worker on local machine
+ echo Starting workers
if [ -z "$CONDOR_WORKERS" ]; then
crash "CONDOR_WORKERS undefined - please check coaster-service.conf"
@@ -286,6 +286,25 @@
return 0
+# Start GWMS workers
+start-workers-gwms()
+ PORT=$1
+ EXECUTION_URL=http://$IPADDR:$PORT
+ if [ -z "$PORT" ]; then
+ crash "start-workers-local: Port number not specified, giving up"
+ fi
+ if [ -z "$CONDOR_WORKERS" ]; then
+ crash "CONDOR_WORKERS undefined - please check coaster-service.conf"
+ fi
+ mkdir -p condor
+ run-gwms-workers $EXECUTION_URL $CONDOR_WORKERS > gwms-workers.log 2>&1 &
# Start cobalt workers
start-workers-cobalt()
@@ -477,6 +496,9 @@
condor)
start-workers-condor $LOCAL_PORT
+ gwms)
+ start-workers-gwms $LOCAL_PORT
crash "Unknown WORKER_MODE. Please modify coaster-service.conf"
Modified: trunk/bin/stop-coaster-service
--- trunk/bin/stop-coaster-service 2012-05-11 17:47:42 UTC (rev 5789)
+++ trunk/bin/stop-coaster-service 2012-05-22 12:27:09 UTC (rev 5790)
@@ -60,7 +60,7 @@
fi
fi
-if [ "$WORKER_MODE" == "condor" ]; then
+if [ "$WORKER_MODE" == "condor" ] || [ "$WORKER_MODE" == "gwms" ]; then
condor_rm $USER
fi
Added: trunk/tests/sites/osg/coaster-service.conf
--- trunk/tests/sites/osg/coaster-service.conf (rev 0)
+++ trunk/tests/sites/osg/coaster-service.conf 2012-05-22 12:27:09 UTC (rev 5790)
@@ -0,0 +1,40 @@
+# Location of SWIFT. If empty, PATH is searched
+export SWIFT=
+# Where to copy worker.pl on the remote machine for sites.xml
+export IPADDR=engage-submit3.renci.org
+# Make sure we always use $OSG_WN_TMP as our work directory
+export WORKER_INIT_CMD="ln -s \$OSG_WN_TMP /tmp/osg_wn_tmp"
+# How to launch workers: local, ssh, cobalt, or futuregrid
+export WORKER_MODE=gwms
+export CONDOR_WORKERS=1
+# Do all the worker nodes you're using have a shared filesystem? (yes/no)
+export SHARED_FILESYSTEM=no
+# Enable SSH tunneling? (yes/no)
+export SSH_TUNNELING=no
+# Directory to keep log files, relative to working directory when launching start-coaster-service
+export LOG_DIR=logs
+# Manually define ports. If not specified, an available port will be used
+export LOCAL_PORT=
+export SERVICE_PORT=
+# Swift information for creating sites.xml
+export WORK=/tmp/osg_wn_tmp
+# Jobs per node is usually equal to the number of CPUs per node
+export JOBS_PER_NODE=1
+# To calculate job throttle:
+# jobs per node * nodes - 0.1 / 100
+export JOB_THROTTLE=$( echo "scale=5; ($JOBS_PER_NODE * $CONDOR_WORKERS)/100 - 0.00001"|bc )
+# Swift applications
+#app bash=/bin/bash
+#app cat=/bin/cat
+#app echo=/bin/echo
More information about the Swift-commit
