[Swift-commit] r5784 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu
Fri May 4 14:51:43 CDT 2012
Author: wozniak
Date: 2012-05-04 14:51:42 -0500 (Fri, 04 May 2012)
New Revision: 5784
Modified:
usertools/plotter/src/plotter/Lines.java
usertools/plotter/src/plotter/Util.java
Log:
Support annotations
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java 2012-05-01 03:53:59 UTC (rev 5783)
+++ usertools/plotter/src/plotter/Lines.java 2012-05-04 19:51:42 UTC (rev 5784)
@@ -13,6 +13,7 @@
import org.apache.xmlgraphics.java2d.ps.EPSDocumentGraphics2D;
import org.jfree.chart.ChartFactory;
import org.jfree.chart.JFreeChart;
+import org.jfree.chart.annotations.XYTextAnnotation;
import org.jfree.chart.axis.LogarithmicAxis;
import org.jfree.chart.axis.NumberAxis;
import org.jfree.chart.plot.PlotOrientation;
@@ -51,6 +52,9 @@
static boolean withLegend = true;
+ static List<XYTextAnnotation> notes =
+ new ArrayList<XYTextAnnotation>();
Args: Lines <properties> <output file> <data file>*
Reads settings from properties: see scanProperties()
@@ -165,6 +169,7 @@
PlotOrientation.VERTICAL, withLegend, false, false);
setupPlot(chart, collection);
chart.draw(g2d, rectangle);
try
@@ -235,6 +240,9 @@
setAxes(plot);
plot.setRenderer(renderer);
plot.setBackgroundPaint(Color.WHITE);
+ for (XYTextAnnotation note : notes)
+ plot.addAnnotation(note);
static void setAxes(XYPlot plot)
@@ -345,8 +353,28 @@
tmp = properties.getProperty("axis.y");
if (tmp != null)
axis_y_type = tmp;
+ tmp = properties.getProperty("notes");
+ if (tmp != null)
+ loadNotes();
+ static void loadNotes()
+ String s = properties.getProperty("notes");
+ int count = Integer.parseInt(s);
+ for (int i = 0; i < count; i++)
+ String p = "note."+i;
+ String d = properties.getProperty(p);
+ String[] tokens = d.split("\\s");
+ double x = Double.parseDouble(tokens[0]);
+ double y = Double.parseDouble(tokens[1]);
+ String text = Util.concat(tokens, 2);
+ XYTextAnnotation note = new XYTextAnnotation(text, x, y);
+ notes.add(note);
static void load(String propFile)
try
Modified: usertools/plotter/src/plotter/Util.java
--- usertools/plotter/src/plotter/Util.java 2012-05-01 03:53:59 UTC (rev 5783)
+++ usertools/plotter/src/plotter/Util.java 2012-05-04 19:51:42 UTC (rev 5784)
@@ -1,5 +1,7 @@
package plotter;
+import java.util.List;
* Plot data helpers.
@@ -24,6 +26,52 @@
return sb.toString();
+ public static String concat(List<String> tokens)
+ String[] array = new String[tokens.size()];
+ tokens.toArray(array);
+ return concat(array, 0, " ");
+ public static String concat(String... strings)
+ return concat(' ', strings);
+ public static String concat(String[] tokens, int start)
+ return concat(tokens, start, " ");
+ public static String concat(String[] tokens, int start,
+ String separator)
+ if (tokens == null)
+ return "null";
+ StringBuilder sb = new StringBuilder();
+ for (int i = start; i < tokens.length; i++)
+ sb.append(tokens[i]);
+ if (i < tokens.length - 1)
+ sb.append(separator);
+ return sb.toString();
+ public static String concat(char c, String... strings)
+ if (strings == null)
+ return "null";
+ for (int i = 0; i < strings.length; i++)
+ sb.append(strings[i]);
+ if (i < strings.length - 1)
+ sb.append(c);
public static void fatal(String s)
System.err.println(s);
More information about the Swift-commit
