[Swift-commit] r5848 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu
Tue Jul 17 13:48:00 CDT 2012
Author: hategan
Date: 2012-07-17 13:48:00 -0500 (Tue, 17 Jul 2012)
New Revision: 5848
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
Log:
fix merge
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2012-07-17 18:42:51 UTC (rev 5847)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2012-07-17 18:48:00 UTC (rev 5848)
@@ -38,7 +38,6 @@
import org.griphyn.vdl.mapping.InvalidPathException;
import org.griphyn.vdl.mapping.Mapper;
import org.griphyn.vdl.mapping.Path;
-import org.griphyn.vdl.type.Field;
import org.griphyn.vdl.type.Type;
public class SetFieldValue extends VDLFunction {
@@ -101,7 +100,6 @@
- @SuppressWarnings("unchecked")
private void log(DSHandle leaf, DSHandle value) {
if (logger.isDebugEnabled()) {
logger.debug("Setting " + leaf + " to " + value);
@@ -140,10 +138,10 @@
StringBuilder sb = new StringBuilder();
sb.append("{");
synchronized(handle) {
- Iterator<Map.Entry<String,DSHandle>> it =
+ Iterator<Map.Entry<Comparable<?>, DSHandle>> it =
handles.entrySet().iterator();
while (it.hasNext()) {
- Map.Entry<String,DSHandle> entry = it.next();
+ Map.Entry<Comparable<?>, DSHandle> entry = it.next();
sb.append(entry.getKey());
sb.append('=');
sb.append(entry.getValue().getValue());
@@ -157,7 +155,6 @@
/** make dest look like source - if its a simple value, copy that
and if its an array then recursively copy */
public static void deepCopy(DSHandle dest, DSHandle source, VariableStack stack, int level) throws ExecutionException {
((AbstractDataNode) source).waitFor();
if (source.getType().isPrimitive()) {
@@ -214,7 +211,7 @@
logger.debug("Remapping " + dest + " to " + source);
- dmapper.remap(dpath, source.getMapper().map(source.getPathFromRoot()));
+ dmapper.remap(dpath, source.getMapper(), source.getPathFromRoot());
dest.closeShallow();
else {
More information about the Swift-commit
