[Swift-commit] r5843 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu
Mon Jul 16 23:49:09 CDT 2012
Author: hategan
Date: 2012-07-16 23:49:09 -0500 (Mon, 16 Jul 2012)
New Revision: 5843
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
Log:
track output of assignments; implement structure deep copy
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2012-07-17 04:48:30 UTC (rev 5842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2012-07-17 04:49:09 UTC (rev 5843)
@@ -20,6 +20,7 @@
package org.griphyn.vdl.karajan.lib;
+import java.util.Collections;
import java.util.Iterator;
import java.util.Map;
@@ -31,10 +32,12 @@
import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
import org.griphyn.vdl.karajan.Pair;
import org.griphyn.vdl.karajan.PairIterator;
+import org.griphyn.vdl.karajan.WaitingThreadsMonitor;
import org.griphyn.vdl.mapping.AbstractDataNode;
import org.griphyn.vdl.mapping.DSHandle;
import org.griphyn.vdl.mapping.InvalidPathException;
import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.type.Type;
public class SetFieldValue extends VDLFunction {
public static final Logger logger = Logger.getLogger(SetFieldValue.class);
@@ -72,6 +75,7 @@
return null;
catch (FutureFault f) {
+ WaitingThreadsMonitor.addOutput(stack, Collections.singletonList(var));
throw f;
catch (Exception e) { // TODO tighten this
@@ -85,7 +89,13 @@
return name;
else {
- return name + var.getPathFromRoot();
+ Path p = var.getPathFromRoot();
+ if (p.isArrayIndex(0)) {
+ return name + var.getPathFromRoot();
+ else {
+ return name + "." + var.getPathFromRoot();
@@ -98,9 +108,16 @@
if (leaf instanceof AbstractDataNode) {
AbstractDataNode data = (AbstractDataNode) leaf;
Path path = data.getPathFromRoot();
- String p = path.toString();
- if (p.equals("$"))
+ String p;
+ if (path.isEmpty()) {
p = "";
+ else if (path.isArrayIndex(0)) {
+ p = path.toString();
+ else {
+ p = "." + path.toString();
String name = data.getDisplayableName() + p;
if (value.getType().isArray()) {
if (logger.isInfoEnabled()) {
@@ -136,9 +153,10 @@
/** make dest look like source - if its a simple value, copy that
and if its an array then recursively copy */
- void deepCopy(DSHandle dest, DSHandle source, VariableStack stack, int level) throws ExecutionException {
- ((AbstractDataNode) source).waitFor();
+ @SuppressWarnings("unchecked")
+ void deepCopy(DSHandle dest, DSHandle source, VariableStack stack, int level) throws ExecutionException {
if (source.getType().isPrimitive()) {
+ ((AbstractDataNode) source).waitFor();
dest.setValue(source.getValue());
else if (source.getType().isArray()) {
@@ -206,8 +224,27 @@
else {
- // TODO implement this
- //throw new RuntimeException("Deep non-array structure copying not implemented, when trying to copy "+source);
+ Type t = source.getType();
+ Iterator<String> it;
+ if (stack.isDefined("it" + level)) {
+ it = (Iterator<String>) stack.getVar("it" + level);
+ else {
+ it = t.getFieldNames().iterator();
+ stack.setVar("it" + level, it);
+ while (it.hasNext()) {
+ Path memberPath = Path.EMPTY_PATH.addLast(it.next(), false);
+ try {
+ deepCopy(dest.getField(memberPath), source.getField(memberPath), stack, level + 1);
+ catch (InvalidPathException ipe) {
+ throw new ExecutionException("Could not get destination field", ipe);
+ stack.currentFrame().deleteVar("it" + level);
+ dest.closeShallow();
More information about the Swift-commit
