[Swift-commit] r5841 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu
Mon Jul 16 23:47:33 CDT 2012
Author: hategan
Date: 2012-07-16 23:47:33 -0500 (Mon, 16 Jul 2012)
New Revision: 5841
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java
Log:
don't record outputs for things that don't have an output
Modified: trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java
--- trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java 2012-07-17 04:46:25 UTC (rev 5840)
+++ trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java 2012-07-17 04:47:33 UTC (rev 5841)
@@ -9,6 +9,7 @@
package org.griphyn.vdl.karajan.lib;
+import java.util.Collections;
import java.util.LinkedList;
import java.util.List;
@@ -57,24 +58,28 @@
trackOutputs(stack, outputs, "SCOPE".equals(type));
+ private static final List<DSHandle> EMPTY_OUTPUTS = Collections.emptyList();
private void trackOutputs(VariableStack stack, String outputs, boolean deep) {
- String[] names = outputs.split(",");
- List<DSHandle> l = new LinkedList<DSHandle>();
- for (String name : names) {
- if (deep) {
- try {
- l.add((DSHandle) stack.getVar(name.toLowerCase()));
- catch (VariableNotFoundException e) {
- logger.info("Could not find variable " + name, e);
- else {
- l.add((DSHandle) stack.parentFrame().getVar(name));
- WaitingThreadsMonitor.addOutput(stack, l);
+ if (outputs.length() != 0) {
+ String[] names = outputs.split(",");
+ List<DSHandle> l = new LinkedList<DSHandle>();
+ for (String name : names) {
+ if (deep) {
+ try {
+ l.add((DSHandle) stack.getVar(name.toLowerCase()));
+ catch (VariableNotFoundException e) {
+ logger.info("Could not find variable " + name, e);
+ else {
+ l.add((DSHandle) stack.parentFrame().getVar(name));
+ WaitingThreadsMonitor.addOutput(stack, l);
protected static void log(boolean start, String type, ThreadingContext thread, String name, String line) {
More information about the Swift-commit
