[Swift-commit] r5835 - in trunk: resources src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Jul 14 19:06:37 CDT 2012
Author: hategan
Date: 2012-07-14 19:06:37 -0500 (Sat, 14 Jul 2012)
New Revision: 5835
Modified:
   trunk/resources/Karajan.stg
   trunk/resources/swiftscript.stg
   trunk/resources/swiftscript.xsd
   trunk/src/org/griphyn/vdl/engine/Karajan.java
   trunk/src/org/griphyn/vdl/engine/VariableScope.java
   trunk/src/org/griphyn/vdl/karajan/HangChecker.java
   trunk/src/org/griphyn/vdl/karajan/Monitor.java
   trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java
Log:
detect more complex dependency loops (such as those cause by partial writes); don't close outputs of procs if they are not partial (since the proc does it itself)
Modified: trunk/resources/Karajan.stg
--- trunk/resources/Karajan.stg	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/resources/Karajan.stg	2012-07-15 00:06:37 UTC (rev 5835)
@@ -210,9 +210,9 @@
 </swiftscript:$name$>
-iterate(declarations,statements,cond,var,cleanups) ::= <<
+iterate(declarations,statements,cond,var,cleanups,trace,line) ::= <<
-<vdl:infinitecountingwhile var="$var$">
+<vdl:infinitecountingwhile var="$var$" $if(trace)$ _traceline="$line$"$endif$>
   $sub_comp(declarations=declarations, statements=statements, cleanups=cleanups)$
   <sys:if>
     <vdl:getfieldvalue>$cond$</vdl:getfieldvalue>
@@ -222,8 +222,8 @@
 </vdl:infinitecountingwhile>
-foreach(var,in,indexVar,indexVarType,declarations,statements,line,selfClose,cleanups) ::= <<
-<vdl:tparallelFor name="\$"$if(selfClose)$ selfClose="$selfClose$"$endif$>
+foreach(var,in,indexVar,indexVarType,declarations,statements,line,selfClose,cleanups,trace) ::= <<
+<vdl:tparallelFor name="\$"$if(selfClose)$ selfClose="$selfClose$"$endif$ $if(trace)$ _traceline="$line$"$endif$>
   <getarrayiterator>$in$</getarrayiterator>
   <set names="\$\$, $var$">
     <each items="{\$}"/>
@@ -364,8 +364,8 @@
 <vdl:parameter name="$name$">$expr$</vdl:parameter>
-assign(var,value) ::= <<
-   <vdl:setfieldvalue>
+assign(var,value,line) ::= <<
+   <vdl:setfieldvalue $if(line)$_traceline="$line$"$else$_traceline="-1"$endif$>
        $var$
        $value$
    </vdl:setfieldvalue>
@@ -442,8 +442,8 @@
  	</if>
-if(condition,vthen,velse) ::= <<
-<if>
+if(condition,vthen,velse,line,trace) ::= <<
+<if $if(trace)$ _traceline="$line$"$endif$>
   <vdl:getfieldvalue>$condition$</vdl:getfieldvalue>
   <then>
   	<unitStart type="CONDITION_BLOCK"/>
@@ -507,7 +507,13 @@
   <partialCloseDataset var="{$var$}" closeID="$closeID$" />
+unitStart(type, outputs) ::= <<
+  <unitStart type="$type$" outputs="$outputs$"/>
+unitEnd(type) ::= <<
+  <unitEnd type="$type$"/>
 operator ::= [
   "+":"vdlop:sum",
Modified: trunk/resources/swiftscript.stg
--- trunk/resources/swiftscript.stg	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/resources/swiftscript.stg	2012-07-15 00:06:37 UTC (rev 5835)
@@ -204,7 +204,7 @@
 if(cond,body,els,sourcelocation) ::= <<
-<if>
+<if src="$sourcelocation$">
   $cond$
   <then>
   $body$
@@ -247,7 +247,7 @@
 iterate(cond,body,var,sourcelocation) ::= <<
-<iterate var="$var$">
+<iterate var="$var$" src="$sourcelocation$">
   <body>
     $body$
   </body>
Modified: trunk/resources/swiftscript.xsd
--- trunk/resources/swiftscript.xsd	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/resources/swiftscript.xsd	2012-07-15 00:06:37 UTC (rev 5835)
@@ -484,6 +484,8 @@
        item</xs:documentation>
      </xs:annotation>
    </xs:attribute>
+   <xs:attribute name="src" type="xs:string" />
   </xs:complexType>
@@ -506,6 +508,8 @@
         </xs:complexType>
       </xs:element>
     </xs:sequence>
   </xs:complexType>
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-07-15 00:06:37 UTC (rev 5835)
@@ -574,6 +574,7 @@
 						" to a variable of type " + datatype(varST));
 			assignST.setAttribute("var", varST);
 			assignST.setAttribute("value", valueST);
+			assignST.setAttribute("line", getLine(assign.getSrc()));
 			String rootvar = abstractExpressionToRootVariable(assign.getAbstractExpressionArray(0));
 			scope.addWriter(rootvar, new Integer(callID++), rootVariableIsPartial(assign.getAbstractExpressionArray(0)));
 			scope.appendStatement(assignST);
@@ -817,8 +818,7 @@
 					ActualParameter output = call.getOutputArray(i);
 					StringTemplate argST = actualParameter(output, scope);
 					callST.setAttribute("outputs", argST);
-					String rootvar = abstractExpressionToRootVariable(call.getOutputArray(i).getAbstractExpression());
-					scope.addWriter(rootvar, new Integer(callID++), rootVariableIsPartial(call.getOutputArray(i).getAbstractExpression()));
+					addWriterToScope(scope, call.getOutputArray(i).getAbstractExpression());
 			if (keywordArgsOutput) {
@@ -837,8 +837,7 @@
 						throw new CompilationException("Wrong type for output parameter number " + i +
 								", expected " + formalType + ", got " + actualType);
 			} else { /* Positional arguments */
 				for (int i = 0; i < call.sizeOfOutputArray(); i++) {
@@ -855,8 +854,7 @@
 						throw new CompilationException("Wrong type for parameter number " + i +
@@ -869,6 +867,16 @@
+    private void addWriterToScope(VariableScope scope, XmlObject var) throws CompilationException {
+        String rootvar = abstractExpressionToRootVariable(var);
+        boolean partial = rootVariableIsPartial(var);
+        if (!partial) {
+            // don't close variables that are already closed by the function itself
+            scope.inhibitClosing(rootvar);
+        scope.addWriter(rootvar, new Integer(callID++), partial);
     public void iterateStat(Iterate iterate, VariableScope scope) throws CompilationException {
 		VariableScope loopScope = new VariableScope(this, scope, VariableScope.ENCLOSURE_LOOP);
 		VariableScope innerScope = new VariableScope(this, loopScope, VariableScope.ENCLOSURE_LOOP);
@@ -876,6 +884,7 @@
 		loopScope.addVariable(iterate.getVar(), "int");
 		StringTemplate iterateST = template("iterate");
+		iterateST.setAttribute("line", getLine(iterate.getSrc()));
 		iterateST.setAttribute("var", iterate.getVar());
 		innerScope.bodyTemplate = iterateST;
@@ -945,13 +954,14 @@
 		StringTemplate ifST = template("if");
 		StringTemplate conditionST = expressionToKarajan(ifstat.getAbstractExpression(), scope);
 		ifST.setAttribute("condition", conditionST.toString());
+		ifST.setAttribute("line", getLine(ifstat.getSrc()));
 		if (!datatype(conditionST).equals("boolean"))
 			throw new CompilationException ("Condition in if statement has to be of boolean type.");
 		Then thenstat = ifstat.getThen();
 		Else elsestat = ifstat.getElse();
-		VariableScope innerThenScope = new VariableScope(this, scope);
+		VariableScope innerThenScope = new VariableScope(this, scope, VariableScope.ENCLOSURE_CONDITION);
 		innerThenScope.bodyTemplate = template("sub_comp");
 		ifST.setAttribute("vthen", innerThenScope.bodyTemplate);
Modified: trunk/src/org/griphyn/vdl/engine/VariableScope.java
--- trunk/src/org/griphyn/vdl/engine/VariableScope.java	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/src/org/griphyn/vdl/engine/VariableScope.java	2012-07-15 00:06:37 UTC (rev 5835)
@@ -47,7 +47,12 @@
 	/** permit no access to the containing scope except for finding
 	    global variables */
 	public static final int ENCLOSURE_PROCEDURE = 301926;
+	/** Override ENCLOSURE_LOOP to allow assignment inside a loop
+	 * based on some condition
+	public static final int ENCLOSURE_CONDITION = 301927;
 	public static final Logger logger = Logger.getLogger(VariableScope.class);
 	/** need this for the program as a whole. probably should factor
@@ -66,6 +71,9 @@
 	/** The string template in which we will store statements
 	    outputted into this scope. */
 	public StringTemplate bodyTemplate;
+	private List<String> outputs = new ArrayList<String>();
+	private Set<String> inhibitClosing = new HashSet<String>();
 	public VariableScope(Karajan c, VariableScope parent) {
 		this(c,parent,ENCLOSURE_ALL);
@@ -114,6 +122,10 @@
 	public void addVariable(String name, String type) throws CompilationException {
 		addVariable(name,type,false);
+	public void inhibitClosing(String name) {
+		inhibitClosing.add(name);
 	public void addVariable(String name, String type, boolean global) throws CompilationException {
 		logger.debug("Adding variable "+name+" of type "+type+" to scope "+hashCode());
@@ -194,6 +206,10 @@
 // in the same scope here
 	public boolean isVariableWriteable(String name, boolean partialWriter) {
 		if(isVariableLocallyDefined(name)) return true;
+		if(parentScope != null && parentScope.isVariableWriteable(name, true) && enclosureType == ENCLOSURE_CONDITION) {
+		    logger.warn("Variable " + name + " might have multiple writers");
+		    return true;
 		if(parentScope != null && parentScope.isVariableWriteable(name, partialWriter) && enclosureType == ENCLOSURE_ALL) return true;
 		if(parentScope != null && parentScope.isVariableWriteable(name, partialWriter) && enclosureType == ENCLOSURE_LOOP && partialWriter) return true;
 		return false;
@@ -206,9 +222,9 @@
 	/** List of templates to be executed in sequence after the present
 	    in-preparation statement is outputted. */
-	List<StringTemplate> presentStatementPostStatements =  Collections.synchronizedList(new ArrayList<StringTemplate>());
+	List<StringTemplate> presentStatementPostStatements =  new ArrayList<StringTemplate>();
-	Map<String, Variable> variableUsage = Collections.synchronizedMap(new HashMap<String, Variable>());
+	Map<String, Variable> variableUsage = new HashMap<String, Variable>();
 	/** indicates that the present in-preparation statement writes to the
 	    named variable. If the variable is declared in the local scope,
@@ -231,10 +247,14 @@
 			} else {
 				logger.debug("Variable "+variableName+" is local but has no template.");
-			StringTemplate postST = compiler.template("partialclose");
-			postST.setAttribute("var", variableName);
-			postST.setAttribute("closeID", closeID);
-			presentStatementPostStatements.add(postST);
+			outputs.add(variableName);
+			if (!inhibitClosing.contains(variableName)) {
+    			StringTemplate postST = compiler.template("partialclose");
+    			postST.setAttribute("var", variableName);
+    			postST.setAttribute("closeID", closeID);
+    			presentStatementPostStatements.add(postST);
 		} else {
 // TODO now we have to walk up the scopes until either we find the
@@ -258,6 +278,7 @@
 				logger.debug("added "+closeID+" to variable "+variableName+" in scope "+hashCode());
 			} else {
+			    isVariableWriteable(variableName, partialWriter);
 				throw new CompilationException("variable "+variableName+" is not writeable in this scope");
@@ -310,18 +331,46 @@
 	void appendStatement(StringTemplate statementST) {
 		StringTemplate wrapperST = compiler.template("sequential");
 		bodyTemplate.setAttribute("statements", wrapperST);
+		if (!outputs.isEmpty()) {
+            StringTemplate unitStart = compiler.template("unitStart");
+            unitStart.setAttribute("type", "SCOPE");
+            unitStart.setAttribute("outputs", join(outputs));
+            wrapperST.setAttribute("statements", unitStart);
+            StringTemplate unitEnd = compiler.template("unitEnd");
+            unitEnd.setAttribute("type", "SCOPE");
+            presentStatementPostStatements.add(unitEnd);
+            if ("foreach".equals(statementST.getName()) ||
+                    "if".equals(statementST.getName()) ||
+                    "iterate".equals(statementST.getName())) {
+                statementST.setAttribute("trace", Boolean.TRUE);
 		wrapperST.setAttribute("statements",statementST);
 		Iterator<StringTemplate> it = presentStatementPostStatements.iterator();
 		while(it.hasNext()) {
 			wrapperST.setAttribute("statements", it.next());
-		presentStatementPostStatements =  Collections.synchronizedList(new ArrayList<StringTemplate>());
+		presentStatementPostStatements.clear();
+		outputs.clear();
+		inhibitClosing.clear();
-	/** Stores information about a variable that is referred to in this
+	private String join(List<String> l) {
+        StringBuilder sb = new StringBuilder();
+        Iterator<String> i = l.iterator();
+        while (i.hasNext()) {
+            sb.append(i.next());
+            if (i.hasNext()) {
+                sb.append(",");
+        return sb.toString();
+    /** Stores information about a variable that is referred to in this
 	    scope. Should probably get used for dataset marking eventually. */
 	class Variable {
-		List<Object> writingStatements =  Collections.synchronizedList(new ArrayList<Object>());
+		List<Object> writingStatements =  new ArrayList<Object>();
 	Iterator<String> getVariableIterator() {
Modified: trunk/src/org/griphyn/vdl/karajan/HangChecker.java
--- trunk/src/org/griphyn/vdl/karajan/HangChecker.java	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/src/org/griphyn/vdl/karajan/HangChecker.java	2012-07-15 00:06:37 UTC (rev 5835)
@@ -32,10 +32,11 @@
 import org.apache.log4j.Logger;
 import org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler;
+import org.globus.cog.karajan.stack.VariableNotFoundException;
 import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.util.ThreadingContext;
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.events.EventBus;
-import org.globus.cog.karajan.workflow.futures.FutureEvaluationException;
 import org.globus.cog.karajan.workflow.nodes.grid.SchedulerNode;
 import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DSHandle;
@@ -44,6 +45,7 @@
     public static final Logger logger = Logger.getLogger(HangChecker.class);
     public static final int CHECK_INTERVAL = 10000;
+    public static final int MAX_CYCLES = 10;
     private Timer timer;
     private long lastEventCount;
     private VariableStack stack;
@@ -94,6 +96,8 @@
             l.add(e.getKey());
+        System.out.print("Finding dependency loops...");
         Set<VariableStack> seen = new HashSet<VariableStack>();
         LinkedList<Object> cycle = new LinkedList<Object>();
@@ -103,9 +107,8 @@
             cycle.clear();
             findLoop(t, rwt, ot, seen, cycle, cycles);
+        System.out.println();
-        cycles = removeDuplicates(cycles);
         if (cycles.size() == 1) {
             ps.println("Dependency loop found:");
@@ -121,38 +124,39 @@
             Object prev = c.getLast();
             for (Object o : c) {
                 if (o instanceof VariableStack) {
-                    ps.println("\t" + Monitor.varWithLine((DSHandle) prev) + " is needed by: ");
+                    if (prev != null) {
+                        ps.println("\t" + Monitor.varWithLine((DSHandle) prev) + " is needed by: ");
+                    else {
+                        ps.println("\tthe above must complete before the block below can complete:");
                     for (String t : Monitor.getSwiftTrace((VariableStack) o)) {
-                    	ps.println("\t\t" + t);
+                        ps.println("\t\t" + t);
-                else {
+                else {
                     prev = o;
-                    ps.println("\twhich produces " + Monitor.varWithLine((DSHandle) o));
+                    if (o != null) {
+                        ps.println("\twhich produces " + Monitor.varWithLine((DSHandle) o));
                     ps.println();
+        // TODO: fail the loops
         if (cycles.size() > 0) {
         	ps.println("----");
-    private static List<LinkedList<Object>> removeDuplicates(List<LinkedList<Object>> cycles) {
-    	List<LinkedList<Object>> nc = new LinkedList<LinkedList<Object>>();
-    	while (!cycles.isEmpty()) {
-    		Iterator<LinkedList<Object>> i = cycles.iterator();
-    		LinkedList<Object> first = i.next();
-    		i.remove();
-    		while (i.hasNext()) {
-    			if (isSameCycle(first, i.next())) {
-    				i.remove();
-    		nc.add(first);
-    	return nc;
+    private static boolean isDuplicate(List<LinkedList<Object>> cycles, LinkedList<Object> cycle) {
+        for (LinkedList<Object> c : cycles) {
+            if (isSameCycle(c, cycle)) {
+                return true;
+        return false;
     private static boolean isSameCycle(LinkedList<Object> a, LinkedList<Object> b) {
@@ -163,12 +167,12 @@
         Object o = i.next();
         Iterator<Object> j = b.iterator();
         while (j.hasNext()) {
-        	if (o == j.next()) {
+        	if (sameTraces(o, j.next())) {
         		    if (!j.hasNext()) {
         		        j = b.iterator();
-        		    if (i.next() != j.next()) {
+        		    if (!sameTraces(i.next(), j.next())) {
         		    	return false;
@@ -178,18 +182,85 @@
         return false;
+    private static boolean sameTraces(Object a, Object b) {
+        if (a instanceof DSHandle) {
+            return a == b;
+        if (b instanceof DSHandle) {
+            return false;
+        if (a == null || b == null) {
+            return a == b;
+        VariableStack sa = (VariableStack) a;
+        VariableStack sb = (VariableStack) b;
+        List<Object> ta = Monitor.getSwiftTraceElements(sa);
+        List<Object> tb = Monitor.getSwiftTraceElements(sb);
+        if (ta.size() != tb.size()) {
+            return false;
+        for (int i = 0; i < ta.size(); i++) {
+            if (ta.get(i) != tb.get(i)) {
+                return false;
+        return true;
     private static void findLoop(VariableStack t, Map<DSHandle, List<VariableStack>> rwt,
             Map<VariableStack, List<DSHandle>> ot, Set<VariableStack> seen, LinkedList<Object> cycle, List<LinkedList<Object>> cycles) {
+        if (cycles.size() > MAX_CYCLES) {
+            return;
         if (t == null) {
             return;
         if (seen.contains(t)) {
-            cycles.add(new LinkedList<Object>(cycle));
+            // remove things up to t in the cycle since they are just lead-ins
+            LinkedList<Object> lc = new LinkedList<Object>(cycle);
+            while (lc.getFirst() != t) {
+                lc.removeFirst();
+            if (!isDuplicate(cycles, lc)) {
+                cycles.add(new LinkedList<Object>(lc));
+                System.out.print(".");
             return;
         cycle.add(t);
         seen.add(t);
         // follow all the outputs of t
+        followOutputs(t, rwt, ot, seen, cycle, cycles);
+        // now follow all the outputs of parent threads to t
+        try {
+            ThreadingContext tc = ThreadingContext.get(t);
+            for (VariableStack stk : ot.keySet()) {
+                if (tc.isStrictlySubContext(ThreadingContext.get(stk))) {
+                    seen.add(stk);
+                    cycle.add(null);
+                    cycle.add(stk);
+                    followOutputs(stk, rwt, ot, seen, cycle, cycles);
+                    cycle.removeLast();
+                    seen.remove(stk);
+        catch (VariableNotFoundException e) {
+            e.printStackTrace();
+        seen.remove(t);
+    private static void followOutputs(VariableStack t,
+            Map<DSHandle, List<VariableStack>> rwt,
+            Map<VariableStack, List<DSHandle>> ot, Set<VariableStack> seen,
+            LinkedList<Object> cycle, List<LinkedList<Object>> cycles) {
         List<DSHandle> l = ot.get(t);
         if (l != null) {
             for (DSHandle h : l) {
@@ -203,8 +274,5 @@
                 cycle.removeLast();
-        cycle.removeLast();
-        seen.remove(t);
Modified: trunk/src/org/griphyn/vdl/karajan/Monitor.java
--- trunk/src/org/griphyn/vdl/karajan/Monitor.java	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/src/org/griphyn/vdl/karajan/Monitor.java	2012-07-15 00:06:37 UTC (rev 5835)
@@ -314,6 +314,21 @@
         return ret;
+    public static List<Object> getSwiftTraceElements(VariableStack stack) {
+        List<Object> ret = new ArrayList<Object>();
+        List<Object> trace = Trace.getAsList(stack);
+        for (Object o : trace) {
+            if (o instanceof FlowNode) {
+                FlowNode n = (FlowNode) o;
+                String traceLine = (String) n.getProperty("_traceline");
+                if (traceLine != null) {
+                    ret.add(o);
+        return ret;
     private static String fileName(FlowNode n) {
         return new File((String) FlowNode.getTreeProperty(FlowElement.FILENAME, n)).getName().replace(".kml", ".swift");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java
--- trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java	2012-07-15 00:01:19 UTC (rev 5834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/UnitStart.java	2012-07-15 00:06:37 UTC (rev 5835)
@@ -14,6 +14,7 @@
 import org.globus.cog.karajan.arguments.Arg;
@@ -52,15 +53,25 @@
         String outputs = (String) OUTPUTS.getStatic(this);
         if (outputs != null) {
-            trackOutputs(stack, outputs);
+            trackOutputs(stack, outputs, "SCOPE".equals(type));
-    private void trackOutputs(VariableStack stack, String outputs) {
+    private void trackOutputs(VariableStack stack, String outputs, boolean deep) {
         String[] names = outputs.split(",");
         List<DSHandle> l = new LinkedList<DSHandle>();
         for (String name : names) {
-            l.add((DSHandle) stack.parentFrame().getVar(name));
+        	if (deep) {
+        	    try {
+                    l.add((DSHandle) stack.getVar(name));
+        	else {
+        		l.add((DSHandle) stack.parentFrame().getVar(name));
         WaitingThreadsMonitor.addOutput(stack, l);
