[Swift-commit] r5822 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu
Sat Jul 7 19:33:44 CDT 2012
Author: hategan
Date: 2012-07-07 19:33:44 -0500 (Sat, 07 Jul 2012)
New Revision: 5822
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
Log:
also log progress lines
Modified: trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java 2012-07-08 00:05:39 UTC (rev 5821)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java 2012-07-08 00:33:44 UTC (rev 5822)
@@ -22,6 +22,7 @@
import java.util.HashMap;
import java.util.Map;
+import org.apache.log4j.Logger;
import org.globus.cog.karajan.arguments.Arg;
import org.globus.cog.karajan.stack.VariableNotFoundException;
import org.globus.cog.karajan.stack.VariableStack;
@@ -43,7 +44,7 @@
public static SimpleDateFormat formatter =
new SimpleDateFormat("E, dd MMM yyyy HH:mm:ss Z");
public static final int MIN_PERIOD_MS=1000;
- public static final int MAX_PERIOD_MS=30000;
+ public static final int MAX_PERIOD_MS=3000;
public static final String[] preferredOutputOrder = {
"uninitialized",
@@ -142,6 +143,8 @@
static public class ProgressTicker extends Thread {
+ public static final Logger logger = Logger.getLogger(ProgressTicker.class);
private Map<String, Integer> counts;
@@ -227,35 +230,47 @@
printStates("Final status:");
- public synchronized Map getSummary() {
+ public synchronized Map<String, Integer> getSummary() {
return new HashMap<String, Integer>(counts);
void printStates(String prefix) {
Map<String, Integer> summary = getSummary();
- // SimpleDateFormat formatter = new SimpleDateFormat("E, dd MMM yyyy HH:mm:ss Z");
+ StringBuilder sb = new StringBuilder();
// output the results of summarization, in a relatively
// pretty form - first the preferred order listed elements,
// and then anything remaining
- System.err.print(prefix + " ");
- //System.err.print(" time:" + (System.currentTimeMillis() - start));
+ System.err.print(prefix);
+ System.err.print(" ");
System.err.print(formatter.format(System.currentTimeMillis()));
for (int pos = 0; pos < preferredOutputOrder.length; pos++) {
String key = preferredOutputOrder[pos];
Integer value = summary.get(key);
if(value != null) {
- System.err.print(" " + key + ":" + value);
+ sb.append(" ");
+ sb.append(key);
+ sb.append(":");
+ sb.append(value);
summary.remove(key);
for (Map.Entry<String, Integer> s : summary.entrySet()) {
- System.err.print(" " + s.getKey() + ":" + s.getValue());
+ sb.append(" ");
+ sb.append(s.getKey());
+ sb.append(":");
+ sb.append(s.getValue());
+ String msg = sb.toString();
- System.err.println();
+ System.err.println(msg);
+ if (logger.isInfoEnabled()) {
+ logger.info(msg);
More information about the Swift-commit
