[Swift-commit] r5696 - trunk/bin
jonmon at ci.uchicago.edu
Wed Feb 29 11:29:27 CST 2012
Author: jonmon
Date: 2012-02-29 11:29:26 -0600 (Wed, 29 Feb 2012)
New Revision: 5696
Modified:
trunk/bin/start-coaster-service
Log:
o allow the user to specify the coaster-service.conf file on the commandline of start-coaster-service.
command line flag is "-conf <conf.file>"
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2012-02-28 02:12:27 UTC (rev 5695)
+++ trunk/bin/start-coaster-service 2012-02-29 17:29:26 UTC (rev 5696)
@@ -76,7 +76,7 @@
ssh $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" &
echo $! >> $PID_FILE
fi
done
@@ -143,7 +143,7 @@
crash "SWIFTVMBOOT_DIR incorrectly defined in coaster-service.conf"
fi
- export EC2_HOME="$SWIFTVMBOOT_DIR/ec2"
+ export EC2_HOME="$SWIFTVMBOOT_DIR/ec2"
export EC2_PRIVATE_KEY="$EC2_KEYFILE"
export EC2_CERT="$EC2_CERTFILE"
@@ -284,6 +284,13 @@
return 0
+while [ $# -gt 0 ]; do
+ case $1 in
+ -conf) CMDLN_CONF=$2; shift 2;;
+ *) echo "Do not recognize command line option: $1" 1>&2; exit 1;;
+ esac
+done
if [ ! -d "$HOME/.swift" ]; then
mkdir -p "$HOME/.swift" || crash "Unable to create $HOME/.swift"
fi
@@ -292,7 +299,9 @@
RUN_DIR=`pwd`
# Import settings
-if [ -f "$RUN_DIR/coaster-service.conf" ]; then
+if [ -f "$CMDLN_CONF" ]; then
+ CONFIG_FILE=$CMDLN_CONF
+elif [ -f "$RUN_DIR/coaster-service.conf" ]; then
CONFIG_FILE="$RUN_DIR/coaster-service.conf"
elif [ -f "$HOME/.swift/coaster-service.conf" ]; then
CONFIG_FILE="$HOME/.swift/coaster-service.conf"
More information about the Swift-commit
