[Swift-commit] r5694 - SwiftApps/SciColSim
jonmon at ci.uchicago.edu
Mon Feb 27 11:08:01 CST 2012
Author: jonmon
Date: 2012-02-27 11:08:01 -0600 (Mon, 27 Feb 2012)
New Revision: 5694
Modified:
SwiftApps/SciColSim/TODO
Log:
o more updates to the TODO file in SciColSim
Modified: SwiftApps/SciColSim/TODO
--- SwiftApps/SciColSim/TODO 2012-02-27 17:02:54 UTC (rev 5693)
+++ SwiftApps/SciColSim/TODO 2012-02-27 17:08:01 UTC (rev 5694)
@@ -120,3 +120,19 @@
[ ] create a lib directory of swift scripts to import in the swift release
[-] Document each command line parameter for annealing.swift
+[x] automate the setup of SciColSim
+[x] Create run script for SciColSim
+[-] copy run files to a different location
+ -- currently uses GlobusOnline to copy the entire run dir
+ Would be nice to copy the output files(*.txt and *.fmt)
+ to Andrey's Dropbox
+[ ] Try different compiler optimization options
+[ ] Verify that we are running openmp on Beagle
+[ ] Dynamically adjust rerunsperapp variable based on t.i. value
+ -- Seems to also rely on the parameters
More information about the Swift-commit
