[Swift-commit] r5685 - in trunk/examples/tutorial: . ParameterSweep
wilde at ci.uchicago.edu
Sun Feb 26 12:20:37 CST 2012
Author: wilde
Date: 2012-02-26 12:20:37 -0600 (Sun, 26 Feb 2012)
New Revision: 5685
Added:
trunk/examples/tutorial/ParameterSweep/README
trunk/examples/tutorial/ParameterSweep/gensweep.sh
trunk/examples/tutorial/ParameterSweep/simulate.sh
trunk/examples/tutorial/ParameterSweep/sweep.sh
trunk/examples/tutorial/ParameterSweep/sweep.swift
Removed:
trunk/examples/tutorial/gensweep.sh
trunk/examples/tutorial/simulate.sh
trunk/examples/tutorial/sweep.sh
trunk/examples/tutorial/sweep.swift
Log:
Move initial files for ParameterSweep tutorial example to right place; add README.
Added: trunk/examples/tutorial/ParameterSweep/README
--- trunk/examples/tutorial/ParameterSweep/README (rev 0)
+++ trunk/examples/tutorial/ParameterSweep/README 2012-02-26 18:20:37 UTC (rev 5685)
@@ -0,0 +1,18 @@
+This directory contains an example of running a "parameter sweep" or
+"ensemble" of N simulations or "members".
+To run:
+ # make sure Swift 0.93 or trunk is in your $PATH
+ svn co https://svn.ci.uchicago.edu/svn/vdl2/trunk/tutorial/ParameterSweep
+ cd ParameterSweep
+ ./sweep.sh # Runs default sweep of 5 members with 3 common data/parameter files
+ ./sweep.sh -nMembers=20 -nCommon=2 # 20 members with 2 common data/parameter files
+ # Each run is executed in a new unique runNNN directory: run001, run002, ...
+ # tc, sites file (local.xml), and Swift properties files (cf) are generated by sweep.sh
Copied: trunk/examples/tutorial/ParameterSweep/gensweep.sh (from rev 5684, trunk/examples/tutorial/gensweep.sh)
--- trunk/examples/tutorial/ParameterSweep/gensweep.sh (rev 0)
+++ trunk/examples/tutorial/ParameterSweep/gensweep.sh 2012-02-26 18:20:37 UTC (rev 5685)
@@ -0,0 +1,36 @@
+#! /bin/sh
+# gensweep.sh - Generate per-member and common parameter files
+# for a parameter sweep (an ensemble of simulations).
+# Generates 2-column files of the form: "paramter value"
+# echo gensweep.sh: $0 $* >/dev/tty # For debugging on localhost
+# Determine the filename patterns from the supplied zero'th file names
+nMembers=$1
+mBase=$(basename $2 .0)
+mDir=$(dirname $2)
+mName=$mDir/$mBase
+nCommon=$3
+cBase=$(basename $4 .0)
+cDir=$(dirname $4)
+cName=$cDir/$cBase
+# Generate an input file for each simulation in the ensemble
+for (( m=0; m<nMembers; m++ )); do
+ echo n $m >$mName.$m
+ echo rate $RANDOM >>$mName.$m
+ echo dx $RANDOM >>$mName.$m
+done
+# Generate the input files common to all simulations in the ensemble
+for (( c=0; c<nCommon; c++ )); do
+ echo c $c >$cName.$c
+ echo alpha $RANDOM >>$cName.$c
+ echo beta $RANDOM >>$cName.$c
+done
Copied: trunk/examples/tutorial/ParameterSweep/simulate.sh (from rev 5684, trunk/examples/tutorial/simulate.sh)
--- trunk/examples/tutorial/ParameterSweep/simulate.sh (rev 0)
+++ trunk/examples/tutorial/ParameterSweep/simulate.sh 2012-02-26 18:20:37 UTC (rev 5685)
@@ -0,0 +1,18 @@
+#! /bin/sh
+# simulate.sh - a tiny script to model a "simulation application"
+# Reads N files of 2-column lines of the form "parameter value"
+# Computes a random function of (some of) the inputs
+awk ' # Prints a single text line result with a random function of (some of) the input parameters
+{ param[$1] = $2 } # read in the parameter values (for this member plus common files)
+END {
+ srand(param["n"] * param["rate"]) / param["beta"]; # the "simulation" :)
+ printf ("Simulation number: %d alpha: %f beta: %f: result: %f\n", param["n"],
+ param["alpha"], param["beta"], rand());
+' $* # member-file common-files...
Copied: trunk/examples/tutorial/ParameterSweep/sweep.sh (from rev 5684, trunk/examples/tutorial/sweep.sh)
--- trunk/examples/tutorial/ParameterSweep/sweep.sh (rev 0)
+++ trunk/examples/tutorial/ParameterSweep/sweep.sh 2012-02-26 18:20:37 UTC (rev 5685)
@@ -0,0 +1,42 @@
+#! /bin/sh
+# Create new runNNN directory
+rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
+mkdir $rundir
+cat >$rundir/cf <<END
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=0
+lazy.errors=false
+END
+cat >$rundir/local.xml <<END
+<config>
+ <pool handle="local">
+ <execution provider="local" />
+ <profile namespace="karajan" key="jobThrottle">.23</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local"/>
+ <workdirectory>$PWD/swiftwork</workdirectory>
+ </pool>
+</config>
+END
+cat >$rundir/tc <<END
+local gensweep $PWD/gensweep.sh
+local simulate $PWD/simulate.sh
+END
+cp sweep.swift $rundir
+cd $rundir
+echo Running in directory $rundir
+swift -config cf -tc.file tc -sites.file local.xml sweep.swift $* 2>&1 | tee swift.out
Copied: trunk/examples/tutorial/ParameterSweep/sweep.swift (from rev 5684, trunk/examples/tutorial/sweep.swift)
--- trunk/examples/tutorial/ParameterSweep/sweep.swift (rev 0)
+++ trunk/examples/tutorial/ParameterSweep/sweep.swift 2012-02-26 18:20:37 UTC (rev 5685)
@@ -0,0 +1,62 @@
+type file;
+# Application to generate the parameter and data files
+app (file m[], file c[]) genSweep (int nm, int nc)
+ gensweep nm @filename(m[0]) nc @filename(c[0]);
+# Application to perform a "simulation"
+app (file o) simulation (file f, file common[])
+ simulate stdout=@filename(o) @filename(f) @filenames(common);
+# Set the size of the parameter sweep
+int nMembers = @toInt(@arg("nMembers","5")); // number of members in the simulation
+int nCommon = @toInt(@arg("nCommon","3")); // number of common files to each sim
+tracef("Running parameter sweep ensemble of %i members with %i common files\n", nMembers, nCommon);
+# Generate the file names to use
+string mName[];
+string oName[];
+string cName[];
+foreach i in [0:nMembers-1] {
+ mName[i] = @sprintf("member.%i",i);
+ oName[i] = @sprintf("result.%i",i);
+foreach i in [0:nCommon-1] {
+ cName[i] = @sprintf("common.%i",i);
+# Set the file names to use
+file mFile[] <array_mapper; files=mName>;
+file cFile[] <array_mapper; files=cName>;
+file oFile[] <array_mapper; files=oName>;
+# Generate the files for the ensemble run
+(mFile, cFile) = genSweep(nMembers, nCommon);
+# Perform the ensemble of parallel simulations
+foreach f, i in mFile {
+ oFile[i] = simulation(f, cFile);
+/* For debugging:
+trace("mFiles", at filenames(mFile));
+trace("oFiles", at filenames(oFile));
+trace("cFiles", at filenames(cFile));
\ No newline at end of file
Deleted: trunk/examples/tutorial/gensweep.sh
--- trunk/examples/tutorial/gensweep.sh 2012-02-26 18:10:34 UTC (rev 5684)
+++ trunk/examples/tutorial/gensweep.sh 2012-02-26 18:20:37 UTC (rev 5685)
@@ -1,36 +0,0 @@
-#! /bin/sh
-# gensweep.sh - Generate per-member and common parameter files
-# for a parameter sweep (an ensemble of simulations).
-# Generates 2-column files of the form: "paramter value"
-# echo gensweep.sh: $0 $* >/dev/tty # For debugging on localhost
-# Determine the filename patterns from the supplied zero'th file names
-nMembers=$1
-mBase=$(basename $2 .0)
-mDir=$(dirname $2)
-mName=$mDir/$mBase
-nCommon=$3
-cBase=$(basename $4 .0)
-cDir=$(dirname $4)
-cName=$cDir/$cBase
-# Generate an input file for each simulation in the ensemble
-for (( m=0; m<nMembers; m++ )); do
- echo n $m >$mName.$m
- echo rate $RANDOM >>$mName.$m
- echo dx $RANDOM >>$mName.$m
-done
-# Generate the input files common to all simulations in the ensemble
-for (( c=0; c<nCommon; c++ )); do
- echo c $c >$cName.$c
- echo alpha $RANDOM >>$cName.$c
- echo beta $RANDOM >>$cName.$c
-done
Deleted: trunk/examples/tutorial/simulate.sh
--- trunk/examples/tutorial/simulate.sh 2012-02-26 18:10:34 UTC (rev 5684)
+++ trunk/examples/tutorial/simulate.sh 2012-02-26 18:20:37 UTC (rev 5685)
@@ -1,18 +0,0 @@
-#! /bin/sh
-# simulate.sh - a tiny script to model a "simulation application"
-# Reads N files of 2-column lines of the form "parameter value"
-# Computes a random function of (some of) the inputs
-awk ' # Prints a single text line result with a random function of (some of) the input parameters
-{ param[$1] = $2 } # read in the parameter values (for this member plus common files)
-END {
- srand(param["n"] * param["rate"]) / param["beta"]; # the "simulation" :)
- printf ("Simulation number: %d alpha: %f beta: %f: result: %f\n", param["n"],
- param["alpha"], param["beta"], rand());
-' $* # member-file common-files...
Deleted: trunk/examples/tutorial/sweep.sh
--- trunk/examples/tutorial/sweep.sh 2012-02-26 18:10:34 UTC (rev 5684)
+++ trunk/examples/tutorial/sweep.sh 2012-02-26 18:20:37 UTC (rev 5685)
@@ -1,42 +0,0 @@
-#! /bin/sh
-# Create new runNNN directory
-rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
-mkdir $rundir
-cat >$rundir/cf <<END
-wrapperlog.always.transfer=true
-sitedir.keep=true
-execution.retries=0
-lazy.errors=false
-END
-cat >$rundir/local.xml <<END
-<config>
- <pool handle="local">
- <execution provider="local" />
- <profile namespace="karajan" key="jobThrottle">.23</profile>
- <profile namespace="karajan" key="initialScore">10000</profile>
- <filesystem provider="local"/>
- <workdirectory>$PWD/swiftwork</workdirectory>
- </pool>
-</config>
-END
-cat >$rundir/tc <<END
-local gensweep $PWD/gensweep.sh
-local simulate $PWD/simulate.sh
-END
-cp sweep.swift $rundir
-cd $rundir
-echo Running in directory $rundir
-swift -config cf -tc.file tc -sites.file local.xml sweep.swift $* 2>&1 | tee swift.out
Deleted: trunk/examples/tutorial/sweep.swift
--- trunk/examples/tutorial/sweep.swift 2012-02-26 18:10:34 UTC (rev 5684)
+++ trunk/examples/tutorial/sweep.swift 2012-02-26 18:20:37 UTC (rev 5685)
@@ -1,62 +0,0 @@
-type file;
-# Application to generate the parameter and data files
-app (file m[], file c[]) genSweep (int nm, int nc)
- gensweep nm @filename(m[0]) nc @filename(c[0]);
-# Application to perform a "simulation"
-app (file o) simulation (file f, file common[])
- simulate stdout=@filename(o) @filename(f) @filenames(common);
-# Set the size of the parameter sweep
-int nMembers = @toInt(@arg("nMembers","5")); // number of members in the simulation
-int nCommon = @toInt(@arg("nCommon","3")); // number of common files to each sim
-tracef("Running parameter sweep ensemble of %i members with %i common files\n", nMembers, nCommon);
-# Generate the file names to use
-string mName[];
-string oName[];
-string cName[];
-foreach i in [0:nMembers-1] {
- mName[i] = @sprintf("member.%i",i);
- oName[i] = @sprintf("result.%i",i);
-foreach i in [0:nCommon-1] {
- cName[i] = @sprintf("common.%i",i);
-# Set the file names to use
-file mFile[] <array_mapper; files=mName>;
-file cFile[] <array_mapper; files=cName>;
-file oFile[] <array_mapper; files=oName>;
-# Generate the files for the ensemble run
-(mFile, cFile) = genSweep(nMembers, nCommon);
-# Perform the ensemble of parallel simulations
-foreach f, i in mFile {
- oFile[i] = simulation(f, cFile);
-/* For debugging:
-trace("mFiles", at filenames(mFile));
-trace("oFiles", at filenames(oFile));
-trace("cFiles", at filenames(cFile));
More information about the Swift-commit
