[Swift-commit] r5683 - trunk/examples/tutorial
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Sun Feb 26 12:08:24 CST 2012
Author: wilde
Date: 2012-02-26 12:08:23 -0600 (Sun, 26 Feb 2012)
New Revision: 5683
Added:
   trunk/examples/tutorial/gensweep.sh
   trunk/examples/tutorial/simulate.sh
   trunk/examples/tutorial/sweep.sh
   trunk/examples/tutorial/sweep.swift
Log:
Initial version.
Added: trunk/examples/tutorial/gensweep.sh
--- trunk/examples/tutorial/gensweep.sh	                        (rev 0)
+++ trunk/examples/tutorial/gensweep.sh	2012-02-26 18:08:23 UTC (rev 5683)
@@ -0,0 +1,36 @@
+#! /bin/sh
+# gensweep.sh - Generate per-member and common parameter files
+#               for a parameter sweep (an ensemble of simulations).
+#               Generates 2-column files of the form: "paramter value"
+# echo gensweep.sh: $0 $* >/dev/tty # For debugging on localhost
+# Determine the filename patterns from the supplied zero'th file names
+nMembers=$1
+mBase=$(basename $2 .0)
+mDir=$(dirname  $2)
+mName=$mDir/$mBase
+nCommon=$3
+cBase=$(basename $4 .0)
+cDir=$(dirname  $4)
+cName=$cDir/$cBase
+# Generate an input file for each simulation in the ensemble
+for (( m=0; m<nMembers; m++ )); do
+  echo n    $m       >$mName.$m
+  echo rate $RANDOM >>$mName.$m
+  echo dx   $RANDOM >>$mName.$m
+done
+# Generate the input files common to all simulations in the ensemble
+for (( c=0; c<nCommon; c++ )); do
+  echo c     $c       >$cName.$c
+  echo alpha $RANDOM >>$cName.$c
+  echo beta  $RANDOM >>$cName.$c
+done
Property changes on: trunk/examples/tutorial/gensweep.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/examples/tutorial/simulate.sh
--- trunk/examples/tutorial/simulate.sh	                        (rev 0)
+++ trunk/examples/tutorial/simulate.sh	2012-02-26 18:08:23 UTC (rev 5683)
@@ -0,0 +1,18 @@
+#! /bin/sh
+# simulate.sh - a tiny script to model a "simulation application"
+#               Reads N files of 2-column lines of the form "parameter value"
+#               Computes a random function of (some of) the inputs
+awk ' # Prints a single text line result with a random function of (some of) the input parameters
+{ param[$1] = $2 } # read in the parameter values (for this member plus common files)
+END {
+  srand(param["n"] * param["rate"]) / param["beta"]; # the "simulation" :)
+  printf ("Simulation number: %d alpha: %f beta: %f: result: %f\n", param["n"],
+           param["alpha"], param["beta"], rand());
+' $*  # member-file common-files...
Property changes on: trunk/examples/tutorial/simulate.sh
Added: trunk/examples/tutorial/sweep.sh
--- trunk/examples/tutorial/sweep.sh	                        (rev 0)
+++ trunk/examples/tutorial/sweep.sh	2012-02-26 18:08:23 UTC (rev 5683)
@@ -0,0 +1,42 @@
+#! /bin/sh
+# Create new runNNN directory
+rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
+mkdir $rundir
+cat >$rundir/cf <<END
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=0
+lazy.errors=false
+END
+cat >$rundir/local.xml <<END
+<config>
+  <pool handle="local">
+    <execution provider="local" />
+    <profile namespace="karajan" key="jobThrottle">.23</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <filesystem provider="local"/>
+    <workdirectory>$PWD/swiftwork</workdirectory>
+  </pool>
+</config>
+END
+cat >$rundir/tc <<END
+local gensweep $PWD/gensweep.sh
+local simulate $PWD/simulate.sh
+END
+cp sweep.swift $rundir
+cd $rundir
+echo Running in directory $rundir
+swift -config cf -tc.file tc -sites.file local.xml sweep.swift $* 2>&1 | tee swift.out
Property changes on: trunk/examples/tutorial/sweep.sh
Added: trunk/examples/tutorial/sweep.swift
--- trunk/examples/tutorial/sweep.swift	                        (rev 0)
+++ trunk/examples/tutorial/sweep.swift	2012-02-26 18:08:23 UTC (rev 5683)
@@ -0,0 +1,62 @@
+type file;
+# Application to generate the parameter and data files
+app (file m[], file c[]) genSweep (int nm, int nc)
+  gensweep nm @filename(m[0]) nc @filename(c[0]);
+# Application to perform a "simulation"
+app (file o) simulation (file f, file common[])
+  simulate stdout=@filename(o) @filename(f) @filenames(common);
+# Set the size of the parameter sweep
+int nMembers = @toInt(@arg("nMembers","5"));   // number of members in the simulation
+int nCommon  = @toInt(@arg("nCommon","3"));    // number of common files to each sim
+tracef("Running parameter sweep ensemble of %i members with %i common files\n", nMembers, nCommon);
+# Generate the file names to use
+string mName[];
+string oName[];
+string cName[];
+foreach i in [0:nMembers-1] {
+  mName[i] = @sprintf("member.%i",i);
+  oName[i] = @sprintf("result.%i",i);
+foreach i in [0:nCommon-1] {
+  cName[i] = @sprintf("common.%i",i);
+# Set the file names to use
+file mFile[] <array_mapper; files=mName>;
+file cFile[] <array_mapper; files=cName>;
+file oFile[] <array_mapper; files=oName>;
+# Generate the files for the ensemble run
+(mFile, cFile) = genSweep(nMembers, nCommon);
+# Perform the ensemble of parallel simulations
+foreach f, i in mFile {
+  oFile[i] = simulation(f, cFile);
+/* For debugging:
+trace("mFiles", at filenames(mFile));
+trace("oFiles", at filenames(oFile));
+trace("cFiles", at filenames(cFile));
\ No newline at end of file
