[Swift-commit] r5681 - branches/release-0.93/tests/sites/mcs
ketan at ci.uchicago.edu
Sat Feb 25 21:48:39 CST 2012
Author: ketan
Date: 2012-02-25 21:48:39 -0600 (Sat, 25 Feb 2012)
New Revision: 5681
Modified:
branches/release-0.93/tests/sites/mcs/coaster-service.conf
Log:
updates in coaster-service.conf
Modified: branches/release-0.93/tests/sites/mcs/coaster-service.conf
--- branches/release-0.93/tests/sites/mcs/coaster-service.conf 2012-02-26 03:47:30 UTC (rev 5680)
+++ branches/release-0.93/tests/sites/mcs/coaster-service.conf 2012-02-26 03:48:39 UTC (rev 5681)
@@ -5,7 +5,7 @@
export SWIFT=
# Where to place/launch worker.pl on the remote machine for sites.xml
-export WORKER_LOCATION=/home/${USER}/work
+export WORKER_LOCATION=/sandbox/${USER}
# How to launch workers: local, ssh, or cobalt
export WORKER_MODE=ssh
@@ -13,18 +13,36 @@
# Worker logging setting passed to worker.pl for sites.xml
export WORKER_LOGGING=INFO
+# User name to use for all systems
+export WORKER_USERNAME=$USER
# Worker host names for ssh
-export WORKER_HOSTS="crush.mcs.anl.gov thwomp.mcs.anl.gov stomp.mcs.anl.gov crank.mcs.anl.gov
-steamroller.mcs.anl.gov grind.mcs.anl.gov churn.mcs.anl.gov trounce.mcs.anl.gov
+export WORKER_HOSTS="crush.mcs.anl.gov thwomp.mcs.anl.gov stomp.mcs.anl.gov crank.mcs.anl.gov
+steamroller.mcs.anl.gov grind.mcs.anl.gov churn.mcs.anl.gov trounce.mcs.anl.gov
thrash.mcs.anl.gov vanquish.mcs.anl.gov"
# Directory to keep log files, relative to working directory when launching start-coaster-service
export LOG_DIR=logs
+export WORKER_LOG_DIR=/home/ketan/worker.log
# Manually define ports. If not specified, ports will be automatically generated
export LOCAL_PORT=
export SERVICE_PORT=
+# Set shared filesystem to no since work will be done in local /sandbox directory
+export SHARED_FILESYSTEM=no
# start-coaster-service tries to automatically detect IP address.
# Specify here if auto detection is not working correctly
export IPADDR=
+# Below are various settings to give information about how to create sites.xml
+ export WORK=/sandbox/${USER}
+ export JOBS_PER_NODE=8
+ export JOB_THROTTLE=$( echo "scale=5; ($JOBS_PER_NODE * $( echo $WORKER_HOSTS | wc -w ))/100 - 0.00001"|bc )
+# Swift applications
+#app cat=/bin/cat
+#app bash=/bin/bash
+#app echo=/bin/echo
More information about the Swift-commit
