[Swift-commit] r5670 - SwiftApps/SciColSim/conf
jonmon at ci.uchicago.edu
Wed Feb 22 17:14:06 CST 2012
Author: jonmon
Date: 2012-02-22 17:14:06 -0600 (Wed, 22 Feb 2012)
New Revision: 5670
Added:
SwiftApps/SciColSim/conf/beagle03.cf
SwiftApps/SciColSim/conf/beagle03.xml
Modified:
SwiftApps/SciColSim/conf/beagle.xml
SwiftApps/SciColSim/conf/beagle01.xml
SwiftApps/SciColSim/conf/beagle02.xml
SwiftApps/SciColSim/conf/local.xml
SwiftApps/SciColSim/conf/pads-ssh.xml
SwiftApps/SciColSim/conf/pads.xml
SwiftApps/SciColSim/conf/pads01.xml
SwiftApps/SciColSim/conf/pads02.xml
Log:
o removed the project entry in the sites files. Now Swift should use the default project when submitting jobs
o added beagle03 config files, these config files should use the scalability queue
Modified: SwiftApps/SciColSim/conf/beagle.xml
--- SwiftApps/SciColSim/conf/beagle.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/beagle.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -1,13 +1,10 @@
<config>
<pool handle="beagle">
<execution provider="coaster" jobmanager="local:pbs"/>
- <profile namespace="globus" key="project">CI-MCB000119</profile>
<profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
<profile namespace="globus" key="jobsPerNode">1</profile>
- <profile namespace="env" key="OMP_NUM_THREADS">24</profile>
- <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
<profile namespace="globus" key="lowOverAllocation">100</profile>
<profile namespace="globus" key="highOverAllocation">100</profile>
<profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
@@ -20,8 +17,7 @@
<profile namespace="karajan" key="jobThrottle">9.59</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<filesystem provider="local"/>
- <!--<workdirectory>/lustre/beagle/ketan/labs/SciColSim-Bgl/swift.workdir</workdirectory>-->
- <workdirectory>_WORK_</workdirectory>
+ <workdirectory>_WORK_/beagle</workdirectory>
</pool>
</config>
Modified: SwiftApps/SciColSim/conf/beagle01.xml
--- SwiftApps/SciColSim/conf/beagle01.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/beagle01.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -11,12 +11,10 @@
<pool handle="beagle01">
- <!-- <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile> -->
@@ -25,7 +23,6 @@
<profile namespace="globus" key="slots">50</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
<profile namespace="globus" key="maxNodes">1</profile>
- <!-- <profile namespace="globus" key="queue">route</profile> -->
<profile namespace="karajan" key="jobThrottle">12.00</profile>
Modified: SwiftApps/SciColSim/conf/beagle02.xml
--- SwiftApps/SciColSim/conf/beagle02.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/beagle02.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -11,12 +11,10 @@
<pool handle="beagle02">
Added: SwiftApps/SciColSim/conf/beagle03.cf
--- SwiftApps/SciColSim/conf/beagle03.cf (rev 0)
+++ SwiftApps/SciColSim/conf/beagle03.cf 2012-02-22 23:14:06 UTC (rev 5670)
@@ -0,0 +1,10 @@
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=3
+lazy.errors=true
+status.mode=provider
+use.provider.staging=false
+provider.staging.pin.swiftfiles=false
+#app local sumloss=$PWD/../sumloss.sh
+#app beagle03 evolve=$PWD/../evolve.sh
Added: SwiftApps/SciColSim/conf/beagle03.xml
--- SwiftApps/SciColSim/conf/beagle03.xml (rev 0)
+++ SwiftApps/SciColSim/conf/beagle03.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -0,0 +1,38 @@
+<config>
+ <pool handle="local" >
+ <execution provider="local" url="none" />
+ <profile namespace="karajan" key="jobThrottle">0.09</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local"/>
+ <workdirectory>_WORK_/local</workdirectory>
+ </pool>
+ <pool handle="beagle03">
+ <execution provider="coaster" jobmanager="local:pbs"/>
+ <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
+ <profile namespace="globus" key="jobsPerNode">1</profile>
+ <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
+ <profile namespace="globus" key="workerLoggingDirectory">_WORK_/workers</profile>
+ <profile namespace="globus" key="lowOverAllocation">100</profile>
+ <profile namespace="globus" key="highOverAllocation">100</profile>
+ <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+ <profile namespace="globus" key="maxTime">1800</profile>
+ <profile namespace="globus" key="slots">2</profile>
+ <profile namespace="globus" key="nodeGranularity">1</profile>
+ <profile namespace="globus" key="maxNodes">5</profile>
+ <profile namespace="globus" key="queue">scalability</profile>
+ <profile namespace="karajan" key="jobThrottle">12.00</profile>
+ </pool>
+</config>
Modified: SwiftApps/SciColSim/conf/local.xml
--- SwiftApps/SciColSim/conf/local.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/local.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -4,6 +4,6 @@
<profile namespace="karajan" key="jobThrottle">_JOB_THROTTLE_</profile>
</pool>
</config>
Modified: SwiftApps/SciColSim/conf/pads-ssh.xml
--- SwiftApps/SciColSim/conf/pads-ssh.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/pads-ssh.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -5,14 +5,14 @@
</pool>
<pool handle="pads-ssh">
<execution provider="pads-ssh" jobmanager="ssh:pbs" url="login.pads.ci.uchicago.edu" />
- <profile namespace="globus" key="project">CI-CCR000013</profile>
+ <workdirectory>_WORK_/pads</workdirectory>
<profile namespace="globus" key="ppn">8</profile>
Modified: SwiftApps/SciColSim/conf/pads.xml
--- SwiftApps/SciColSim/conf/pads.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/pads.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -4,14 +4,13 @@
</pool>
<pool handle="pads">
<execution provider="coaster" jobmanager="local:pbs" />
Modified: SwiftApps/SciColSim/conf/pads01.xml
--- SwiftApps/SciColSim/conf/pads01.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/pads01.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -13,7 +13,6 @@
@@ -23,7 +22,6 @@
<profile namespace="globus" key="slots">384</profile>
- <!-- <profile namespace="globus" key="queue">fast</profile> -->
Modified: SwiftApps/SciColSim/conf/pads02.xml
--- SwiftApps/SciColSim/conf/pads02.xml 2012-02-22 22:58:48 UTC (rev 5669)
+++ SwiftApps/SciColSim/conf/pads02.xml 2012-02-22 23:14:06 UTC (rev 5670)
@@ -13,7 +13,6 @@
@@ -23,7 +22,6 @@
<profile namespace="karajan" key="jobThrottle">400</profile>
More information about the Swift-commit
