[Swift-commit] r5653 - SwiftApps/Cybershake/etc
    ketan at ci.uchicago.edu
    Mon Feb 20 13:26:50 CST 2012
Author: ketan
Date: 2012-02-20 13:26:50 -0600 (Mon, 20 Feb 2012)
New Revision: 5653
Added:
   SwiftApps/Cybershake/etc/cdm_lib.sh
Log:
adding cdm patch and updating README
Added: SwiftApps/Cybershake/etc/cdm_lib.sh
--- SwiftApps/Cybershake/etc/cdm_lib.sh	                        (rev 0)
+++ SwiftApps/Cybershake/etc/cdm_lib.sh	2012-02-20 19:26:50 UTC (rev 5653)
@@ -0,0 +1,232 @@
+# Source this for CDM shell functions
+log "Reading cdm_lib.sh ..."
+# Do a CDM lookup
+cdm_lookup() {
+	CDM_PL=$1
+	CDM_FILE=$2
+	FILE=$3
+	RESULT="DEFAULT"
+	if [ ! -z $CDM_FILE ] && [ -f $CDM_PL ] && [ -f $CDM_FILE ]; then
+		RESULT=$( perl $CDM_PL lookup $FILE < $CDM_FILE 2> $INFO )
+		checkError 254 "cdm_lookup(): failed! (malformed CDM file?)"
+	fi
+	echo $RESULT
+cdm_action() {
+	log "CDM_ACTION: $@"
+	local JOBDIR=$1  # Given jobdir
+	local MODE=$2    # INPUT or OUTPUT
+	local FILE=$3    # User file
+	local POLICY=$4  # DIRECT, BROADCAST, ...
+	shift 4
+	local ARGS=$@
+	log "POLICY=$POLICY"
+	case $POLICY in
+		DIRECT)
+			DIRECT_DIR=${ARGS[0]}
+			log "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE via $JOBDIR/$FILE"
+			if [ $MODE == "INPUT" ]; then
+				[ -f "$DIRECT_DIR/$FILE" ]
+				checkError 254 "CDM[DIRECT]: $DIRECT_DIR/$FILE does not exist!"
+                mkdir -p $( dirname $JOBDIR/$FILE )
+				checkError 254 "CDM[DIRECT]: mkdir -p $JOBDIR failed!"
+				ln -s $DIRECT_DIR/$FILE $JOBDIR/$FILE
+				checkError 254 "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE for linkname $JOBDIR/$FILE failed!"
+			elif [ $MODE == "OUTPUT" ]; then
+				mkdir -p $DIRECT_DIR
+				checkError 254 "CDM[DIRECT]: mkdir -p $DIRECT_DIR failed!"
+				mkdir -p $( dirname $DIRECT_DIR/$FILE )
+				checkError 254 "CDM[DIRECT]: mkdir -p $( dirname $FILE ) failed!"
+				touch $DIRECT_DIR/$FILE
+				checkError 254 "CDM[DIRECT]: Touching $DIRECT_DIR/$FILE failed!"
+				checkError 254 "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE failed!"
+			else
+				fail 254 "Unknown MODE: $MODE"
+			fi
+ 		LOCAL)
+			# TODO: Can/should we use this as a cache?
+			TOOL=$1
+			REMOTE_DIR=$2
+			FLAGS=$3
+			log "CDM[LOCAL]: TOOL=$TOOL FLAGS=$FLAGS REMOTE_DIR=$REMOTE_DIR ARGS=$ARGS"
+ 			log "CDM[LOCAL]: Copying $REMOTE_DIR/$FILE to $JOBDIR/$FILE"
+ 				[ -f "$REMOTE_DIR/$FILE" ]
+ 				checkError 254 "CDM[LOCAL]: $REMOTE_DIR/$FILE does not exist!"
+				if [ $TOOL == "cp" ]; then
+ 					$TOOL $FLAGS $REMOTE_DIR/$FILE $JOBDIR/$FILE
+					checkError 254 "CDM[LOCAL]: cp failed!"
+				elif [ $TOOL == "dd" ]; then
+					$TOOL $FLAGS if=$REMOTE_DIR/$FILE of=$JOBDIR/$FILE
+					checkError 254 "CDM[LOCAL]: dd failed!"
+				else
+					fail 254 "CDM[LOCAL]: Unknown TOOL: $TOOL"
+				fi
+ 				log "CDM[LOCAL]..." # This should probably be an error
+ 			else
+ 			fi
+		BROADCAST)
+			BROADCAST_DIR=${ARGS[0]}
+				log "CDM[BROADCAST]: Linking $JOBDIR/$FILE to $BROADCAST_DIR/$FILE"
+				[ -f "$BROADCAST_DIR/$FILE" ]
+				checkError 254 "CDM[BROADCAST]: $BROADCAST_DIR/$FILE does not exist!"
+				ln -s $BROADCAST_DIR/$FILE $JOBDIR/$FILE
+				checkError 254 "CDM[BROADCAST]: Linking to $BROADCAST_DIR/$FILE failed!"
+			else
+				echo "CDM[BROADCAST]: Skipping output file: ${FILE}"
+			fi
+		GATHER)
+				fail 254 "Cannot GATHER an input file!"
+			fi
+    esac
+# Setup GATHER_DIR and some variables
+cdm_gather_setup() {
+	GATHER_DIR=$1
+	logstate "GATHER_DIR $GATHER_DIR"
+	mkdir -p $GATHER_DIR
+	checkError 254 "Could not create: $GATHER_DIR"
+	GATHER_LOCKFILE=$GATHER_DIR/.cdm.lock
+	GATHER_MY_FILE=$GATHER_DIR/.cdm-$ID.lock
+	GATHER_MY_OUTBOX=$GATHER_DIR/.cdm-outgoing-$ID
+# Acquire the GATHER_LOCKFILE
+cdm_gather_lock_acquire() {
+	TRYING=1
+	COUNT=0
+	touch $GATHER_MY_FILE
+	checkError 254 "Could not touch my file: $GATHER_MY_FILE"
+	logstate "LOCK_ACQUIRE $GATHER_MY_FILE"
+	while (( TRYING )); do
+		ln $GATHER_MY_FILE $GATHER_LOCKFILE
+		CODE=$?
+		TRYING=$CODE
+		if (( TRYING )); then
+			logstate "LOCK_DELAY $GATHER_MY_FILE : $CODE"
+			if (( COUNT++ > 10 )); then
+				fail 254 "Could not acquire lock!"
+				exit 1
+			fi
+			sleep $(( RANDOM % 10 ))
+		fi
+	done
+# Move files from JOBDIR to GATHER_DIR
+cdm_gather_import() {
+	pushd jobs/$JOBDIR/$ID
+	logstate "GATHER_IMPORT $GATHER_OUTPUT"
+	mv $GATHER_OUTPUT $GATHER_DIR
+	checkError 254 "Could not move output to $GATHER_DIR"
+	popd
+# Move files from GATHER_DIR to OUTBOX
+# Note that this function modifies $IFS
+cdm_gather_export() {
+	RESULT=1
+	pushd ${GATHER_DIR}
+	IFS="
+	FILES=( $( ls -A -I ".cdm*.lock" -I ".cdm-outgoing-*" ) )
+	log "FILES: ${#FILES[@]}"
+	mkdir -p $GATHER_MY_OUTBOX
+	checkError 254 "Could not mkdir ${GATHER_MY_OUTBOX}"
+	if (( ${#FILES} > 0 )); then
+		mv ${FILES[@]} $GATHER_MY_OUTBOX
+		checkError 254 "Could not move ${FILES[@]} to $GATHER_MY_OUTBOX"
+		RESULT=0
+	fi
+	popd
+	return $RESULT
+# Release the GATHER_LOCKFILE
+cdm_gather_lock_release() {
+	logstate "LOCK_RELEASE $GATHER_LOCKFILE"
+	unlink $GATHER_LOCKFILE
+# Move files from (LFS) OUTBOX to (GFS) GATHER_TARGET
+cdm_gather_flush() {
+	pushd ${GATHER_MY_OUTBOX}
+	logstate "GATHER_TARGET $GATHER_TARGET"
+	mkdir -p ${GATHER_TARGET}
+	logstate "GATHER_FLUSH_START ${GATHER_TARGET}/cdm-gather-$ID.tar"
+	TARBALL=${GATHER_TARGET}/cdm-gather-$ID.tar
+	tar cf ${TARBALL} *
+	checkError 254 "CDM[GATHER]: error writing: ${TARBALL}"
+	logstate "GATHER_FLUSH_DONE"
+	popd
+# Called by _swiftwrap at the end of each job
+cdm_gather_action() {
+	GATHER_OUTPUT=${*}
+	GATHER_DIR=$(    perl shared/cdm.pl property GATHER_DIR    < $CDM_FILE )
+	GATHER_MAX=$(    perl shared/cdm.pl property GATHER_LIMIT  < $CDM_FILE )
+	GATHER_TARGET=$( perl shared/cdm.pl property GATHER_TARGET < $CDM_FILE )
+	cdm_gather_setup $GATHER_DIR
+	cdm_gather_lock_acquire
+	cdm_gather_import
+	USAGE=$( du -s --exclude=".cdm*" -B 1 $GATHER_DIR )
+	USAGE=${USAGE%	*} # Chop off filename in output
+	logstate "USAGE_CHECK $USAGE / $GATHER_MAX"
+	FLUSH="no"
+	if (( USAGE > GATHER_MAX )); then
+		FLUSH="yes"
+		cdm_gather_export
+	fi
+	cdm_gather_lock_release
+	if [ $FLUSH == "yes" ]; then
+		cdm_gather_flush
+	fi
+# Called by cdm_cleanup.sh at the end of the workflow
+cdm_gather_cleanup() {
+	declare -p PWD DIR GATHER_DIR GATHER_TARGET ID
+	cdm_gather_export
+	EXPORT_RESULT=$?
+	if (( EXPORT_RESULT == 0)); then
+		cdm_gather_flush
+	fi
+# Local Variables:
+# mode: sh
+# sh-basic-offset: 4
+# tab-width: 4
+# indent-tabs-mode: 1
+# End:
More information about the Swift-commit
