[Swift-commit] r5583 - SwiftApps/SciColSim
jonmon at ci.uchicago.edu
Fri Feb 10 16:10:58 CST 2012
Author: jonmon
Date: 2012-02-10 16:10:57 -0600 (Fri, 10 Feb 2012)
New Revision: 5583
Modified:
SwiftApps/SciColSim/swiftopt.sh
Log:
some error supressing and mac compatability fixes
Modified: SwiftApps/SciColSim/swiftopt.sh
--- SwiftApps/SciColSim/swiftopt.sh 2012-02-10 22:01:30 UTC (rev 5582)
+++ SwiftApps/SciColSim/swiftopt.sh 2012-02-10 22:10:57 UTC (rev 5583)
@@ -1,5 +1,7 @@
#! /bin/sh
+#TODO: Fix espcape code nonense, seems to be passing in -n -e to swift
# Usage: swiftopt.sh [-s sitename] [-p paramfile] [-n # for dryrun ]
usage="$0 [-s sitename] [-p paramfile] [-n] # -n for dryrun: just print params and time estimates"
@@ -11,7 +13,16 @@
ram=2000M
dryrun=
+# check to see if the following check is even necessary on a linux distro
+system=`uname | grep Darwin`
+if [ $system == "Darwin" ];
+then
+ escapecode=$(echo '\033')
+else
+ escapecode=$(echo -n -e '\033')
+fi
# Process command line arguments
while [ $# -gt 0 ]; do
@@ -31,10 +42,17 @@
else
cat nextrun | awk '{ printf("%03d\n", $1+1)}' >newrun
fi
-runid=$(cat newrun)
-mv newrun nextrun
+runid=$(cat newrun 2> /dev/null)
+mv newrun nextrun 2> /dev/null
rundir=run${runid}
-mkdir $rundir
+#Exit if rundir already exits. Something is funky
+if [ -d $rundir ];
+then
+ echo "$rundir already exists! exiting." >&2
+ exit 2
+else
+ mkdir $rundir
+fi
# Get optimization parameters
@@ -42,8 +60,8 @@
sed -e '/^ */d' -e 's/#.*//' -e 's/ */=/' <params/$paramfile >$rundir/params.annealing
source $rundir/params.annealing
-e33="-e33=$(echo -n -e '\033')"
-swift=../swift/bin/swift # relative to runNNN/ dirs
+#swift=../swift/bin/swift # relative to runNNN/ dirs
+swift=swift
echo Optimization run $runid: site=$execsite paramfile=$paramfile
@@ -73,7 +91,8 @@
cd $rundir
-SWIFT_HEAP_MAX=$ram SWIFT_LIB=.. $swift >> swift.out 2>&1 -tc.file tc -sites.file $execsite.xml -config cf ../annealing.swift $e33 \
+SWIFT_HEAP_MAX=$ram SWIFT_LIB=.. $swift >> swift.out 2>&1 -tc.file tc -sites.file $execsite.xml -config cf ../annealing.swift -e33="$escapecode" \
+#SWIFT_HEAP_MAX=$ram SWIFT_LIB=.. $swift 2>&1 -tc.file tc -sites.file $execsite.xml -config cf ../annealing.swift -e33="$escapecode" \
-minrange=$min_target_innovation \
-maxrange=$max_target_innovation \
@@ -92,9 +111,9 @@
-nworkers=$nworkers \
-rerunsperapp=$reruns_per_opt_invocation
-exit
+exit $?
- at arg("nworkers","4")
+ at Arg("nworkers","4")
@arg("rerunsperapp", "100")
@arg("seed", "0" ) FIXME
@arg("minrange", "58")
More information about the Swift-commit
