[Swift-commit] r5579 - SwiftApps/SciColSim
wilde at ci.uchicago.edu
Fri Feb 10 09:45:29 CST 2012
Author: wilde
Date: 2012-02-10 09:45:29 -0600 (Fri, 10 Feb 2012)
New Revision: 5579
Added:
SwiftApps/SciColSim/getboost.sh
SwiftApps/SciColSim/setup.sh
Modified:
SwiftApps/SciColSim/Makefile
SwiftApps/SciColSim/README
SwiftApps/SciColSim/getswift.sh
SwiftApps/SciColSim/swiftopt.sh
Log:
Enhanced readme and installation process. some changes to swiftop.sh
Modified: SwiftApps/SciColSim/Makefile
--- SwiftApps/SciColSim/Makefile 2012-02-10 01:37:02 UTC (rev 5578)
+++ SwiftApps/SciColSim/Makefile 2012-02-10 15:45:29 UTC (rev 5579)
@@ -8,7 +8,7 @@
g++ -DP_OPENMP -fopenmp -I boost_1_47_0 -o openmp-optimizer optimizer.cpp
clean:
- rm -rf mac-openmp-optimizer mac-dispatch-optimizer mac-orig-optimizer
+ rm -rf openmp-optimizer
endif
Modified: SwiftApps/SciColSim/README
--- SwiftApps/SciColSim/README 2012-02-10 01:37:02 UTC (rev 5578)
+++ SwiftApps/SciColSim/README 2012-02-10 15:45:29 UTC (rev 5579)
@@ -1,25 +1,27 @@
-*** FIXME: New quiskstart to integrate
+*** Getting started
-cd $HOME
-svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/SciColSim
-cd SciColSim
-./getswift.sh # just do this one
+To run shorter tests on single local hosts (Mac, Linux, Beagle
+Sandbox, Swift lab machines):
-./swiftopt.sh -s local -p Fast01 & # Tells you what run dir its in. Note the "&" !!!
+ cd $HOME
+ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/SciColSim
+ cd SciColSim
-cd runNNN # cd to that run dir eg run007
-tail -f swift.out # to view progress
-tail -f best_some_opt_swift.txt # to view optimization results
+ ./setup.sh # just do this once. Will install Boost and Swift, and compile the optimizer
-./swiftopt.sh -s pads -p ARtest01 # Etc.
+ ./swiftopt.sh -s local -p Fast01 & # Tells you what run dir its in. Note the "&" !!!
+ cd runNNN # cd to that run dir eg run007
+ tail -f swift.out # to view progress
+ tail -f best_some_opt_swift.txt # to view optimization results
-Args:
+ ./swiftopt.sh -s pads -p params/ARtest01 # Etc.
+swiftopt.sh command line arguments:
-s site to run on: can be local, pads, beagle
-p param set to use, from param/ dir
@@ -31,13 +33,34 @@
FIXME: create a few more tet variations
-You can add new param sets in the param dir: just copy an existing one and change the params.
+Contents of parameter file:
-You can add new sites in the conf/ dir. FIXME: for now, add gen.SITENAME files. Limited flexibility w/ tc
+#-------- params/Fast01
+min_target_innovation 58 # starting target innovation value to try
+max_target_innovation 109 # stops before this target innovation value
+target_innovation_increment 50 # increment target innovation by this amount
+annealing_repeats 1 # times to repeate the entire optimization process for each target_innovation
+annealing_cycles 10 # times to perform the simulated annealing loop for all non-fixed parameters
+evolve_reruns 8 # times to perform evolve_to_target_and_save() (objective function - is batched)
+nworkers 1 # number of parallel threads (cores) to use per invocation of C++ optimizer
+reruns_per_opt_invocation 2 # reruns_per_opt_invocation mod nworkers must == 0 !!! <=== NOTE WELL !!!
+alpha_i 0.0 # 5 evolve() parameters: must be decimal values !!!
+alpha_m 0.0 # alpha_i and alpha_m are fixed for now
+beta 4.0 # rest are varied by the optimization process
+gamma 50.0
+delta -1.0
+You can add new param sets in the param dir (or anywhere): just copy an existing one and change the params.
+You can add new sites in the conf/ dir. FIXME: for now, add gen.SITENAME files. Limited flexibility w/ tc
*** QuickStart
mkdir $HOME/SciColSim # scientific collaboration simulation application
Added: SwiftApps/SciColSim/getboost.sh
--- SwiftApps/SciColSim/getboost.sh (rev 0)
+++ SwiftApps/SciColSim/getboost.sh 2012-02-10 15:45:29 UTC (rev 5579)
@@ -0,0 +1,30 @@
+#! /bin/sh
+tarfile=boost_1_47_0.tar.gz
+release=$(basename $tarfile .tar.gz)
+boostrel=http://sourceforge.net/projects/boost/files/boost/1.47.0/boost_1_47_0.tar.gz/download
+echo
+echo Downloading $release from $boostrel
+echo
+rm -rf $tarfile $release
+if [ $(uname) = Linux ]; then
+ wget $boostrel
+else
+ curl $boostrel > $(basename $boostrel)
+fi
+echo
+echo Extracting $release from $tarfile
+echo
+tar zxf $tarfile
+echo
+echo Boost installed at $(pwd)/$release
+echo
Property changes on: SwiftApps/SciColSim/getboost.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftApps/SciColSim/getswift.sh
--- SwiftApps/SciColSim/getswift.sh 2012-02-10 01:37:02 UTC (rev 5578)
+++ SwiftApps/SciColSim/getswift.sh 2012-02-10 15:45:29 UTC (rev 5579)
@@ -6,15 +6,20 @@
echo
echo Downloading $release from $swiftrel
+echo
-rm -f $tarfile
- wget -nv $swiftrel
+ wget $swiftrel
else
curl $swiftrel > $(basename $swiftrel)
fi
+echo
+echo Extracting $release from $swiftrel
+echo
tar zxf $tarfile
echo
@@ -27,4 +32,10 @@
./swift/bin/swift -version
rm -f swift.log
+echo
+echo Swift installation complete.
+echo
Added: SwiftApps/SciColSim/setup.sh
--- SwiftApps/SciColSim/setup.sh (rev 0)
+++ SwiftApps/SciColSim/setup.sh 2012-02-10 15:45:29 UTC (rev 5579)
@@ -0,0 +1,10 @@
+#! /bin/sh
+./getswift.sh
+./getboost.sh
+make clean
+make
+echo Setup complete.
\ No newline at end of file
Property changes on: SwiftApps/SciColSim/setup.sh
Modified: SwiftApps/SciColSim/swiftopt.sh
--- SwiftApps/SciColSim/swiftopt.sh 2012-02-10 01:37:02 UTC (rev 5578)
+++ SwiftApps/SciColSim/swiftopt.sh 2012-02-10 15:45:29 UTC (rev 5579)
@@ -73,7 +73,7 @@
cd $rundir
-SWIFT_HEAP_MAX=$ram SWIFT_LIB=.. $swift >& swift.out -tc.file tc -sites.file $execsite.xml -config cf ../annealing.swift $e33 \
+SWIFT_HEAP_MAX=$ram SWIFT_LIB=.. $swift >> swift.out 2>&1 -tc.file tc -sites.file $execsite.xml -config cf ../annealing.swift $e33 \
-minrange=$min_target_innovation \
-maxrange=$max_target_innovation \
More information about the Swift-commit
