[Swift-commit] r5572 - in SwiftApps/SciColSim: . conf params
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Thu Feb 9 16:30:17 CST 2012
Author: wilde
Date: 2012-02-09 16:30:17 -0600 (Thu, 09 Feb 2012)
New Revision: 5572
Added:
   SwiftApps/SciColSim/conf/
   SwiftApps/SciColSim/conf/basiclocal.xml
   SwiftApps/SciColSim/conf/beagle.xml
   SwiftApps/SciColSim/conf/cf
   SwiftApps/SciColSim/conf/local.xml
   SwiftApps/SciColSim/conf/pads.similar.beagle.xml
   SwiftApps/SciColSim/conf/sites.beagle.quick.xml
   SwiftApps/SciColSim/conf/sites.beagle.xml
   SwiftApps/SciColSim/conf/tc
   SwiftApps/SciColSim/getswift.sh
   SwiftApps/SciColSim/params/
   SwiftApps/SciColSim/params/ARtest01
   SwiftApps/SciColSim/params/Fast01
   SwiftApps/SciColSim/params/MWtest01
   SwiftApps/SciColSim/swiftopt.sh
Log:
Add new end-user commands.
Added: SwiftApps/SciColSim/conf/basiclocal.xml
--- SwiftApps/SciColSim/conf/basiclocal.xml	                        (rev 0)
+++ SwiftApps/SciColSim/conf/basiclocal.xml	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,10 @@
+<config>
+   <pool handle="localhost">
+     <execution provider="local" url="none" />
+     <filesystem provider="local"/>
+     <workdirectory>/home/wilde/swift/lab/swiftwork</workdirectory>
+     <profile namespace="karajan" key="jobThrottle">0</profile>
+   </pool>
+</config>
Added: SwiftApps/SciColSim/conf/beagle.xml
--- SwiftApps/SciColSim/conf/beagle.xml	                        (rev 0)
+++ SwiftApps/SciColSim/conf/beagle.xml	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,60 @@
+<config>
+<!-- From Glen: used w/ "Swift svn swift-r4813 (swift modified locally) cog-r3175" -->
+  <pool handle="beagle">
+    <execution provider="coaster" jobmanager="local:pbs" url="none"/>
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+    <profile key="jobsPerNode" namespace="globus">1</profile>
+    <profile namespace="env" key="OMP_NUM_THREADS">24</profile>
+    <profile namespace="globus" key="maxwalltime">02:00:00</profile>
+    <profile namespace="globus" key="maxTime">14400</profile>
+    <profile namespace="globus" key="slots">20</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="globus" key="maxNodes">1</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="karajan" key="jobThrottle">.15</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <profile namespace="globus" key="project">CI-MCB000119</profile>
+    <profile namespace="globus" key="queue">route</profile>
+    <workdirectory >/lustre/beagle/wilde/swiftwork</workdirectory>
+  </pool>
+<!-- From Justin's swift-devel page:
+<import file="sys.xml"/>
+<set name="wdir" value="/lustre/beagle/{user.name}/work"/>
+<echo message="setting workDirectory to: {wdir}"/>
+<pool handle="beagle-pbs">
+  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
+  <profile namespace="globus" key="maxWallTime">1</profile>
+  <profile namespace="globus" key="maxTime">7200</profile>
+    pbs.aprun;pbs.mpp;depth=24
+  </profile>
+  <profile key="jobsPerNode" namespace="globus">24</profile>
+  <profile key="slots" namespace="globus">1</profile>
+  <profile key="nodeGranularity" namespace="globus">1</profile>
+  <profile key="maxNodes" namespace="globus">1</profile>
+  <profile key="queue" namespace="globus">batch</profile>
+  <profile key="jobThrottle" namespace="karajan">5.99</profile>
+  <profile key="initialScore" namespace="karajan">10000</profile>
+  <profile namespace="globus" key="project">_PROJECT_</profile>
+  <profile namespace="globus" key="project">_QUEUE_</profile>
+  <filesystem provider="local" url="none" />
+  <workdirectory>{wdir}</workdirectory>
+</pool>
+</config>
Added: SwiftApps/SciColSim/conf/cf
--- SwiftApps/SciColSim/conf/cf	                        (rev 0)
+++ SwiftApps/SciColSim/conf/cf	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,7 @@
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=3
+lazy.errors=true
+status.mode=provider
+use.provider.staging=false
+provider.staging.pin.swiftfiles=false
Added: SwiftApps/SciColSim/conf/local.xml
--- SwiftApps/SciColSim/conf/local.xml	                        (rev 0)
+++ SwiftApps/SciColSim/conf/local.xml	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,9 @@
+<config>
+  <pool handle="localhost" >
+    <profile namespace="karajan" key="jobThrottle">0.05</profile>
+    <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
+  </pool>
+</config>
Added: SwiftApps/SciColSim/conf/pads.similar.beagle.xml
--- SwiftApps/SciColSim/conf/pads.similar.beagle.xml	                        (rev 0)
+++ SwiftApps/SciColSim/conf/pads.similar.beagle.xml	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,23 @@
+<config>
+  <pool handle="pads">
+    <execution provider="coaster" jobmanager="ssh:pbs" url="login.pads.ci.uchicago.edu" />
+     <profile namespace="globus" key="project">CI-CCR000013</profile>
+    <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
+    <profile namespace="globus" key="ppn">8</profile>
+    <profile namespace="globus" key="jobsPerNode">1</profile>
+    <profile namespace="globus" key="maxTime">3600</profile>
+    <profile namespace="globus" key="maxWallTime">00:02:00</profile>
+    <profile namespace="globus" key="slots">10</profile>
+    <profile namespace="globus" key="queue">fast</profile>
+    <profile namespace="karajan" key="jobThrottle">9.59</profile>
+  </pool>
+</config>
Added: SwiftApps/SciColSim/conf/sites.beagle.quick.xml
--- SwiftApps/SciColSim/conf/sites.beagle.quick.xml	                        (rev 0)
+++ SwiftApps/SciColSim/conf/sites.beagle.quick.xml	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,24 @@
+<config>
+    <execution provider="coaster" jobmanager="local:pbs"/>
+    <profile namespace="globus" key="maxTime">10000</profile>
+    <profile namespace="globus" key="maxWallTime">01:30:00</profile>
+    <profile namespace="globus" key="slots">50</profile>
+    <profile namespace="globus" key="nodeGranularity">2</profile>
+    <profile namespace="globus" key="maxNodes">2</profile>
+    <workdirectory >/lustre/beagle/ketan/labs/SciColSim-Bgl/swift.workdir</workdirectory>
+  </pool>
+</config>
Added: SwiftApps/SciColSim/conf/sites.beagle.xml
--- SwiftApps/SciColSim/conf/sites.beagle.xml	                        (rev 0)
+++ SwiftApps/SciColSim/conf/sites.beagle.xml	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,23 @@
+<config>
+    <!--<profile namespace="globus" key="jobsPerNode">24</profile>-->
+    <profile namespace="globus" key="maxTime">37000</profile>
+    <profile namespace="globus" key="maxWallTime">10:00:00</profile>
+  </pool>
+</config>
Added: SwiftApps/SciColSim/conf/tc
--- SwiftApps/SciColSim/conf/tc	                        (rev 0)
+++ SwiftApps/SciColSim/conf/tc	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,15 @@
+localhost sh /bin/sh null null null
+localhost cat /bin/cat null null null
+pbs cat /bin/cat null null null
+mcs cat /bin/cat null null null
+localhost catnap /home/wilde/swift/lab/catnap.sh null null GLOBUS::maxwalltime="00:01:00"
+beagle optimizer /home/wilde/AndreysOptimizer/src/Optimizer null null null
+beagle optimizersh /home/wilde/AndreysOptimizer/src/optimizer.sh null null null
+beagle evolve /home/wilde/AndreysOptimizer/src/evolve.sh null null null
+localhost evolve /home/wilde/AndreysOptimizer/src/evolve.sh null null GLOBUS::maxwalltime="02:00:00"
+beagle sumloss /home/wilde/AndreysOptimizer/src/sumloss.sh null null null
+localhost sumloss /home/wilde/AndreysOptimizer/src/sumloss.sh null null GLOBUS::maxwalltime="02:00:00"
Added: SwiftApps/SciColSim/getswift.sh
--- SwiftApps/SciColSim/getswift.sh	                        (rev 0)
+++ SwiftApps/SciColSim/getswift.sh	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,30 @@
+#! /bin/sh
+swiftrel=http://www.ci.uchicago.edu/swift/packages/swift-0.93.tar.gz
+tarfile=$(basename $swiftrel)
+release=$(basename $swiftrel .tar.gz)
+echo
+echo Downloading $release from $swiftrel
+rm -f $tarfile
+if [ $(uname) = Linux ]; then
+  wget -nv $swiftrel
+else
+  curl $swiftrel > $(basename $swiftrel)
+fi
+tar zxf $tarfile
+echo
+echo Swift installed at $(pwd)/$release
+echo
+rm -f swift # We expect this to be a symlink or non-existant
+ln -s $release swift
+./swift/bin/swift -version
+rm -f swift.log
Property changes on: SwiftApps/SciColSim/getswift.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/SciColSim/params/ARtest01
--- SwiftApps/SciColSim/params/ARtest01	                        (rev 0)
+++ SwiftApps/SciColSim/params/ARtest01	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,18 @@
+min_target_innovation       = 58     # starting target innovation value to try
+max_target_innovation       = 209    # stops before this target innovation value
+target_innovation_increment = 50     # increment target innovation by this amount
+annealing_repeats           = 15     # times to repeate the entire optimization process for each target_innovation
+annealing_cycles            = 100    # times to perform the simulated annealing loop for all non-fixed parameters
+evolve_reruns               = 1000   # times to perform evolve_to_target_and_save() (objective function - is batched)
+nworkers                    = 2      # number of parallel threads (cores) to use per invocation of C++ optimizer
+reruns_per_opt_invocation   = 100    # reruns_per_opt_invocation mod nworkers must == 0 !!! <=== NOTE WELL !!!
+alpha_i                     = 0.0    # 5 evolve() parameters: must be decimal values !!!
+alpha_m                     = 0.0    # alpha_i and alpha_m are fixed for now
+beta                        = 4.0    # rest are varied by the optimization process
+gamma                       = 50.0
+delta                       = -1.0
Added: SwiftApps/SciColSim/params/Fast01
--- SwiftApps/SciColSim/params/Fast01	                        (rev 0)
+++ SwiftApps/SciColSim/params/Fast01	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,19 @@
+min_target_innovation         58     # starting target innovation value to try
+max_target_innovation         209    # stops before this target innovation value
+target_innovation_increment   50     # increment target innovation by this amount
+annealing_repeats             1      # times to repeate the entire optimization process for each target_innovation
+annealing_cycles              10     # times to perform the simulated annealing loop for all non-fixed parameters
+evolve_reruns                 10     # times to perform evolve_to_target_and_save() (objective function - is batched)
+nworkers                      2      # number of parallel threads (cores) to use per invocation of C++ optimizer
+reruns_per_opt_invocation     100    # reruns_per_opt_invocation mod nworkers must == 0 !!! <=== NOTE WELL !!!
+alpha_i                       0.0    # 5 evolve() parameters: must be decimal values !!!
+alpha_m                       0.0    # alpha_i and alpha_m are fixed for now
+beta                          4.0    # rest are varied by the optimization process
+gamma                         50.0
+delta                         -1.0
\ No newline at end of file
Added: SwiftApps/SciColSim/params/MWtest01
--- SwiftApps/SciColSim/params/MWtest01	                        (rev 0)
+++ SwiftApps/SciColSim/params/MWtest01	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,17 @@
+max_target_innovation       = 1009
+alpha_i                     = 0.0  # 5 parameters: must be decimal values !!!
+alpha_m                     = 0.0
+beta                        = 4.0
+gamma                       = 50.0
+delta                       = -1.0
+nworkers                    = 2
Added: SwiftApps/SciColSim/swiftopt.sh
--- SwiftApps/SciColSim/swiftopt.sh	                        (rev 0)
+++ SwiftApps/SciColSim/swiftopt.sh	2012-02-09 22:30:17 UTC (rev 5572)
@@ -0,0 +1,90 @@
+#! /bin/sh
+# Usage: swiftopt.sh [-s sitename] [-p paramfile] [-n # for dryrun ]
+usage="$0 [-s sitename] [-p paramfile] [-n] # -n for dryrun: just print params and time estimates"
+# Default settings:
+execsite=local
+paramfile=Fast01
+ram=2000M
+dryrun=
+# Process command line arguments
+while [ $# -gt 0 ]; do
+  case $1 in
+    -s) execsite=$2; shift 2;;
+    -p) paramfile=$2; shift 2;;
+    -n) dryrun=true; shift 1;;
+    *) echo $usage 1>&2
+       exit 1;;
+  esac
+done
+# Create next unique run id and run directory
+if [ ! -f nextrun ]; then
+  echo 000 >nextrun
+else
+  cat nextrun | awk '{ printf("%03d\n", $1+1)}' >newrun
+fi
+runid=$(cat newrun)
+mv newrun nextrun
+rundir=run${runid}
+mkdir $rundir
+# Get optimization parameters
+cp params/$paramfile $rundir/paramfile
+sed -e '/^  */d' -e 's/#.*//' -e 's/  */=/' <params/$paramfile >$rundir/params.annealing
+source $rundir/params.annealing
+e33="-e33=$(echo -n -e '\033')"
+swift=../swift/bin/swift # relative to runNNN/ dirs
+echo Optimization run $runid: site=$execsite paramfile=$paramfile
+cp conf/{tc,cf,$execsite.xml} $rundir
+cp movie_graph.txt $rundir
+# Echo parameters
+echo Annealing parameters:
+echo
+cat $rundir/params.annealing
+echo
+# Echo runtime estimates
+echo Total jobs = $((20*$annealing_repeats*$annealing_cycles*3*$evolve_reruns)) # FIXME: Example: replace with real formulas
+if [ _$dryrun != _ ]; then
+  exit 0
+fi
+# Do the run
+cd $rundir
+SWIFT_HEAP_MAX=$ram $swift >& swift.out -tc.file tc -sites.file $execsite.xml -config cf ../annealing.swift $e33 \
+-minrange=$min_target_innovation         \
+-maxrange=$max_target_innovation         \
+-rangeinc=$target_innovation_increment   \
+-nreps=$annealing_repeats                \
+-annealingcycles=$annealing_cycles       \
+-evoreruns=$evolve_reruns                \
+-alphai=$alpha_i                         \
+-alpham=$alpha_m                         \
+-beta=$beta                              \
+-gamma=$gamma                            \
+-delta=$delta                            \
+-nworkers=$nworkers                      \
+-rerunsperapp=$reruns_per_opt_invocation
Property changes on: SwiftApps/SciColSim/swiftopt.sh
