[Swift-commit] Cog update
swift at ci.uchicago.edu swift at ci.uchicago.edu
Thu Feb 9 14:10:08 CST 2012
r3360 | jmwozniak | 2012-02-09 14:09:35 -0600 (Thu, 09 Feb 2012) | 1 line
New worker_init_cmd()
Index: modules/provider-coaster/.classpath
--- modules/provider-coaster/.classpath	(revision 3359)
+++ modules/provider-coaster/.classpath	(working copy)
@@ -14,5 +14,6 @@
 	<classpathentry kind="src" path="/abstraction-provider-local"/>
 	<classpathentry kind="src" path="/util"/>
 	<classpathentry kind="con" path="org.eclipse.jdt.USER_LIBRARY/log4j"/>
+	<classpathentry kind="lib" path="/home/wozniak/proj/cog/lib/log4j-1.2.16.jar"/>
 	<classpathentry kind="output" path=".build"/>
 </classpath>
Index: modules/provider-coaster/resources/worker.pl
--- modules/provider-coaster/resources/worker.pl	(revision 3359)
+++ modules/provider-coaster/resources/worker.pl	(working copy)
@@ -189,7 +189,7 @@
 #									flags: the protocol flags to send (e.g. err, fin)
 #									data: the actual data
 #									yieldFlag: if CONTINUE then it instructs the sending procedure
-#												to loop sending data until YIELD is returned
+#												to loop sending data until YIELD is returned
 #		dataSent: proc(state, tag) - invoked when all data was sent
 #		PUT file specific state:
@@ -219,9 +219,9 @@
 #		state when sending array data:
 #			index: the current index in the data array
 #			data: an array containing the data chunks
 #	time:  last communication time (used to determine timeouts)
@@ -403,6 +403,13 @@
 		push(@PROFILE_EVENTS, "START", "N/A", time());
 	logsetup();
+	if (defined $ENV{"WORKER_COPIES"}) {
+		workerCopies($ENV{"WORKER_COPIES"});
+	if(defined $ENV{"WORKER_INIT_CMD"}) {
+		worker_init_cmd($ENV{"WORKER_INIT_CMD"});
 	reconnect();
@@ -431,6 +438,13 @@
+sub worker_init_cmd {
+  my ($cmd) = @_;
+  wlog DEBUG, "worker_init_cmd: $cmd\n";
+  my $rc = system($cmd);
+  print "rc: $rc\n";
 sub trim {
 	my ($arg) = @_;
 	$arg =~ s/^\s+|\s+$//g ;
@@ -458,7 +472,7 @@
 	my $flg2;
 	my $msg;
 	my $yield;
 	do {
 		($flg2, $msg, $yield) = $$data{"nextData"}($data);
 		if (defined($msg)) {
@@ -469,11 +483,11 @@
 	if (($flg2 & FINAL_FLAG) == 0) {
 		# final flag not set; put it back in the queue
 		wlog TRACE, "$tag yielding\n";
 		# update last time
 		my $record = $REPLIES{$tag};
 		$$record[1] = time();
 		queueCmdCustomDataHandling($REPLIES{$tag}, $data);
 	else {
@@ -512,11 +526,11 @@
 	my ($state) = @_;
 	my $s = $$state{"state"};
 	my $tag = $$state{"tag"};
 	wlog TRACE, "$tag nextFileData state=$s\n";
 	if ($s == PUT_START) {
 		$$state{"state"} = $s + 1;
 		return (0, $$state{"cmd"}, CONTINUE);
@@ -540,7 +554,7 @@
 			wlog TRACE, "$tag Transfer suspendend; yielding\n";
 			return (0, undef, YIELD);
 		my $handle = $$state{"handle"};
 		my $buffer;
 		my $sz = read($handle, $buffer, IOBUFSZ);
@@ -642,14 +656,14 @@
 	my $len = unpack("V", substr($data, 8, 4));
 	my $hcsum = unpack("V", substr($data, 12, 4));
 	my $csum = unpack("V", substr($data, 16, 4));
 	my $chcsum = ($tag ^ $flg ^ $len);
 	if ($chcsum != $hcsum) {
 		wlog WARN, "Header checksum failed. Computed checksum: $chcsum, checksum: $hcsum\n";
 		return;
 	my $msg;
 	my $frag;
 	my $alen = 0;
@@ -658,7 +672,7 @@
 		$alen = $alen + length($frag);
 		$msg = $msg.$frag;
 	my $actuallen = length($msg);
 	wlog(TRACE, " IN: len=$len, actuallen=$actuallen, tag=$tag, flags=$flg, $msg\n");
 	if ($len != $actuallen) {
@@ -707,7 +721,7 @@
 		if (exists($REPLIES{$tag})) {
 			($cont, $lastTime) = ($$record[0], $$record[1]);
-			# update last time
+			# update last time
 		else {
@@ -1068,7 +1082,7 @@
 	my $jobid = $$state{"jobid"};
 	my $len = length($reply);
 	wlog DEBUG, "$jobid getFileCBDataIn jobid: $jobid, state: $s, tag: $tag, flags: $flags, len: $len\n";
 	if ($flags & SIGNAL_FLAG) {
 		if ($reply eq "QUEUED") {
 			$REPLIES{$tag}[1] = NEVER;
@@ -1323,8 +1337,8 @@
 					$JOBDATA{$jobid}{"stageoutCount"} = 0;
 				$JOBDATA{$jobid}{"stageoutCount"} += 1;
-				wlog DEBUG, "$jobid Stagecount is $JOBDATA{$jobid}{stageoutCount}\n";
+				wlog DEBUG, "$jobid Stagecount is $JOBDATA{$jobid}{stageoutCount}\n";
 				queueCmdCustomDataHandling(putFileCB($jobid), fileData("PUT", $lfile, $rfile));
 			elsif ($protocol eq "sfs") {
@@ -1361,9 +1375,9 @@
 sub sendStatus {
 	my ($jobid) = @_;
 	my $ec = $JOBDATA{$jobid}{"exitcode"};
 	if ($ec == 0) {
 		queueCmd((nullCB(), "JOBSTATUS", $jobid, COMPLETED, "0", ""));
@@ -1385,7 +1399,7 @@
 		else {
 			# there were stageouts. Wait until all are acknowledged
 			# as done by the client. And we keep track of the
-			# count of stageouts that weren't acknowledged in
+			# count of stageouts that weren't acknowledged in
 			# $JOBDATA{$jobid}{"stageoutCount"}
@@ -1436,7 +1450,7 @@
 	if (ASYNC) {
 		wlog DEBUG, "$tag putFileCBDataSent\n";
-		if ($jobid != -1) {
+		if ($jobid != -1) {
 			wlog DEBUG, "$tag Data sent, async is on. Staging out next file\n";
 			stageout($jobid);
@@ -1459,7 +1473,7 @@
 		return;
 	elsif ($reply eq "STOP") {
-		$SUSPENDED_TRANSFERS{"$tag"} = 1;
+		$SUSPENDED_TRANSFERS{"$tag"} = 1;
 		wlog DEBUG, "$tag Got stop request. Suspending transfer.\n";
 	elsif ($reply eq "CONTINUE") {
@@ -1634,7 +1648,7 @@
 	my ($PARENT_R, $CHILD_W);
 	pipe($PARENT_R, $CHILD_W);
 	$pid = fork();
 	if (defined($pid)) {
@@ -1788,10 +1802,6 @@
 init();
-if (defined $ENV{"WORKER_COPIES"}) {
-	workerCopies($ENV{"WORKER_COPIES"});
 mainloop();
 # Code may not reach this point - see shutdownw()
